    4. Shelly Adapter
    SOLVED Shelly Adapter
      apollon77 last edited by
      DIe Bitte war:
      • Stoppe den Adaspter
      • Öffne eine Shell/SSH und wechsle ins ioBroker Verzeichnis
      • führe den genannten Befehl manuell dort aus
      • schicke das in der Shell ausgegebene Log mit - vor allem den Schluss wenn er wieder abstürzt
        äääähm ... alos Stündlicher restart muss das erste * eine 0 sein ... ansonsten: warum denn überhaupt? Und auch der Default ist nur * * * * * sondern "leer" weil an sich kein Restart beim Shelly Adapter nötig ist
        Stuebi H 2 Replies Last reply Reply Quote 0
          Home79 @apollon77 last edited by Negalein
          @apollon77
          pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.shelly/shelly.js --force --logs
          starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.0
          Schedule restart: * 1,3,5-23 * * *
          Stating Shelly adapter in CoAP modus.
          Listening for Shelly packets in the network
          CoAP status package received: {"3332":"SHRGBW2#662476#1","3412":38400,"3420":7936,"Uri-Path":"cit/s"} / {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}
          Status update received for SHRGBW2#662476#1: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}
          CoAP device description request for SHRGBW2#662476#1 to 192.168.178.62(0)
          CoAP response: {"3332":"SHRGBW2#662476#1"}
          Device description received: {"3332":"SHRGBW2#662476#1"} / {"blk":[{"I":1,"D":"RGBW2"}],"sen":[{"I":111,"T":"Red","R":"0/255","L":0},{"I":121,"T":"Green","R":"0/255","L":0},{"I":131,"T":"Blue","R":"0/255","L":0},{"I":141,"T":"White","R":"0/255","L":0},{"I":151,"T":"Gain","R":"0/100","L":0},{"I":161,"T":"VSwitch","R":"0/1","L":0}],"act":[{"I":211,"D":"RGBW2","L":0,"P":[{"I":2011,"T":"Red","R":"0/255"},{"I":2021,"T":"Green","R":"0/255"},{"I":2031,"T":"Blue","R":"0/255"},{"I":2041,"T":"White","R":"0/255"},{"I":2051,"T":"Gain","R":"0/100"},{"I":2061,"T":"VSwitch","R":"0/1"}]}]}
          Shelly device 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1) with CoAP connected!
          CoAP Message for SHRGBW2#662476#1 : {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}
          Create State : SHRGBW2#662476#1.color.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          State change : SHRGBW2#662476#1.color.Switch, Value: false for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Create State : SHRGBW2#662476#1.color.red, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          State change : SHRGBW2#662476#1.color.red, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Create State : SHRGBW2#662476#1.color.green, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          State change : SHRGBW2#662476#1.color.green, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Create State : SHRGBW2#662476#1.color.blue, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          State change : SHRGBW2#662476#1.color.blue, Value: 255 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Create State : SHRGBW2#662476#1.color.white, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          State change : SHRGBW2#662476#1.color.white, Value: 97 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Create State : SHRGBW2#662476#1.color.gain, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          State change : SHRGBW2#662476#1.color.gain, Value: 4 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Create State : SHRGBW2#662476#1.white0.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          Create State : SHRGBW2#662476#1.white0.brightness, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          Create State : SHRGBW2#662476#1.white1.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          Create State : SHRGBW2#662476#1.white1.brightness, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          Create State : SHRGBW2#662476#1.white2.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          Create State : SHRGBW2#662476#1.white2.brightness, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          Set state SHRGBW2#662476#1.color.AutoTimerOff, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Set state SHRGBW2#662476#1.color.AutoTimerOn, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Set state SHRGBW2#662476#1.mode, Value: "color" for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Set state SHRGBW2#662476#1.version, Value: "20190531-080138/v1.5.0-hotfix2@022ec015" for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Create State : SHRGBW2#662476#1.white3.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          Create State : SHRGBW2#662476#1.white3.brightness, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
          Set state SHRGBW2#662476#1.color.effect, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
          Scheduled restart.
          Closing Adapter
          terminating
          Closing Adapter
            Home79 @Home79 last edited by
            @Home79
            passt das so ? sorry bin nicht ganz so drin im Thema sorry
              @Home79 sagte in Shelly Adapter:
              Scheduled restart.
              ääähm ?!
              Bedeutet: Neustart des Adapter jede Minute in der 1., 3. und zwischen 5-23. Stunde ... und du wunderst dich? :-))
              Was willst Du denn damit bezwecken?
                @apollon77 nein das hatte ich eingestellt soll jede stunde neu starten damit er wieder anlauft
                  Home79 @apollon77 last edited by Stabilostick
                  @apollon77oAP connected!
                  CoAP Message for SHSW-1#058C2B#1 : {"G":[[0,112,0]]}
                  Create State : SHSW-1#058C2B#1.Relay0.Switch, Payload: {"G":[[0,112,0]]}for SHSW-1#058C2B#1
                  State change : SHSW-1#058C2B#1.Relay0.Switch, Value: false for 192.168.178.30 (shelly1 / shelly1-058C2B / SHSW-1#058C2B#1)
                  Set state SHSW-1#058C2B#1.Relay0.AutoTimerOff, Value: 0 for 192.168.178.30 (shelly1 / shelly1-058C2B / SHSW-1#058C2B#1)
                  Set state SHSW-1#058C2B#1.Relay0.AutoTimerOn, Value: 0 for 192.168.178.30 (shelly1 / shelly1-058C2B / SHSW-1#058C2B#1)
                  Set state SHSW-1#058C2B#1.version, Value: "20190531-075800/v1.5.0-hotfix2@022ec015" for 192.168.178.30 (shelly1 / shelly1-058C2B / SHSW-1#058C2B#1)
                  Set state SHSW-1#058C2B#1.firmware, Value: false for 192.168.178.30 (shelly1 / shelly1-058C2B / SHSW-1#058C2B#1)
                  Set state SHSW-1#058C2B#1.hostname, Value: "192.168.178.30" for 192.168.178.30 (shelly1 / shelly1-058C2B / SHSW-1#058C2B#1)
                  Set state SHSW-1#058C2B#1.rssi, Value: -29 for 192.168.178.30 (shelly1 / shelly1-058C2B / SHSW-1#058C2B#1)
                  Set state SHSW-21#32C173#1.rssi, Value: -78 for 192.168.178.36 (shellyswitch / shellyswitch-32C173 / SHSW-21#32C173#1)
                  CoAP status package received: {"3332":"SHSW-1#32CA57#1","3412":38400,"3420":1280,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
                  Status update received for SHSW-1#32CA57#1: {"G":[[0,112,0]]}
                  CoAP device description request for SHSW-1#32CA57#1 to 192.168.178.32(0)
                  Connection update received for SHSW-1#32CA57#1: true
                  CoAP response: {"3332":"SHSW-1#32CA57#1"}
                  Device description received: {"3332":"SHSW-1#32CA57#1"} / {"blk":[{"I":0,"D":"Relay0"}],"sen":[{"I":112,"T":"Switch","R":"0/1","L":0}],"act":[{"I":211,"D":"Switch","L":0,"P":[{"I":2011,"D":"ToState","R":"0/1"}]}]}
                  Shelly device 192.168.178.32 (shelly1 / shelly1-32CA57 / SHSW-1#32CA57#1) with CoAP connected!
                  CoAP Message for SHSW-1#32CA57#1 : {"G":[[0,112,0]]}
                  Create State : SHSW-1#32CA57#1.Relay0.Switch, Payload: {"G":[[0,112,0]]}for SHSW-1#32CA57#1
                  State change : SHSW-1#32CA57#1.Relay0.Switch, Value: false for 192.168.178.32 (shelly1 / shelly1-32CA57 / SHSW-1#32CA57#1)
                  Set state SHSW-1#32CA57#1.Relay0.AutoTimerOff, Value: 0 for 192.168.178.32 (shelly1 / shelly1-32CA57 / SHSW-1#32CA57#1)
                  Set state SHSW-1#32CA57#1.Relay0.AutoTimerOn, Value: 0 for 192.168.178.32 (shelly1 / shelly1-32CA57 / SHSW-1#32CA57#1)
                  Set state SHSW-1#32CA57#1.version, Value: "20190531-075800/v1.5.0-hotfix2@022ec015" for 192.168.178.32 (shelly1 / shelly1-32CA57 / SHSW-1#32CA57#1)
                  Set state SHSW-1#32CA57#1.firmware, Value: false for 192.168.178.32 (shelly1 / shelly1-32CA57 / SHSW-1#32CA57#1)
                  Set state SHSW-1#32CA57#1.hostname, Value: "192.168.178.32" for 192.168.178.32 (shelly1 / shelly1-32CA57 / SHSW-1#32CA57#1)
                  Set state SHSW-1#32CA57#1.rssi, Value: -71 for 192.168.178.32 (shelly1 / shelly1-32CA57 / SHSW-1#32CA57#1)
                  Set state SHRGBW2#661DC9#1.rssi, Value: -69 for 192.168.178.69 (shellyrgbw2 / shellyrgbw2-661DC9 / SHRGBW2#661DC9#1)
                  Set state SHSW-1#59E506#1.rssi, Value: -78 for 192.168.178.56 (shelly1 / shelly1-59E506 / SHSW-1#59E506#1)
                  CoAP data ignored: {"3332":"SHSW-25#73FD07#1","3412":38400,"3420":3584,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,113,100],[0,111,0.000000],[0,121,0.000000]]}
                  CoAP data ignored: {"3332":"SHSW-21#5B265F#1","3412":38400,"3420":5120,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,113,-1],[0,111,0.000000]]}
                  CoAP data ignored: {"3332":"SHSW-1#59EABB#1","3412":38400,"3420":768,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
                  Set state SHSW-1#59EABB#1.rssi, Value: -80 for 192.168.178.55 (shelly1 / shelly1-59EABB / SHSW-1#59EABB#1)
                  CoAP data ignored: {"3332":"SHSW-1#056E37#1","3412":38400,"3420":256,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
                  Set state SHSW-21#32C173#1.rssi, Value: -77 for 192.168.178.36 (shellyswitch / shellyswitch-32C173 / SHSW-21#32C173#1)
                  CoAP data ignored: {"3332":"SHRGBW2#662476#1","3412":38400,"3420":7936,"Uri-Path":"cit/s"} / {"G":[[0,111, 0],[0,121, 0],[0,131, 255],[0,141, 97],[0,151, 4],[0,161, 0]]}
                  Set state SHSW-1#32CA57#1.rssi, Value: -72 for 192.168.178.32 (shelly1 / shelly1-32CA57 / SHSW-1#32CA57#1)
                  Set state SHRGBW2#661DC9#1.rssi, Value: -68 for 192.168.178.69 (shellyrgbw2 / shellyrgbw2-661DC9 / SHRGBW2#661DC9#1)
                  CoAP data ignored: {"3332":"SHSW-25#73CDCC#1","3412":38400,"3420":2304,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,113,100],[0,111,0.000000],[0,121,0.000000]]}
                  Set state SHSW-1#056CEE#1.rssi, Value: -68 for 192.168.178.26 (shelly1 / shelly1-056CEE / SHSW-1#056CEE#1)
                  CoAP data ignored: {"3332":"SHSW-21#32C173#1","3412":38400,"3420":6144,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,113,100],[0,111,0.000000]]}
                  CoAP data ignored: {"3332":"SHSW-25#5DAE1C#1","3412":38400,"3420":2304,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,113,100],[0,111,0.000000],[0,121,0.000000]]}
                  CoAP data ignored: {"3332":"SHRGBW2#661DC9#1","3412":38400,"3420":3840,"Uri-Path":"cit/s"} / {"G":[[0,111, 0],[0,121, 0],[0,131, 255],[0,141, 87],[0,151, 10],[0,161, 0]]}
                  CoAP data ignored: {"3332":"SHSW-1#59E506#1","3412":38400,"3420":1280,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
                  CoAP data ignored: {"3332":"SHSW-25#00B6B7#1","3412":38400,"3420":6656,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,113,100],[0,111,0.000000],[0,121,0.000000]]}
                  CoAP data ignored: {"3332":"SHSW-25#73F757#1","3412":38400,"3420":5376,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,122,0],[0,113,99],[0,111,0.000000],[0,121,0.000000]]}
                  Set state SHSW-1#59E506#1.rssi, Value: -79 for 192.168.178.56 (shelly1 / shelly1-59E506 / SHSW-1#59E506#1)
                  Set state SHSW-25#73F757#1.rssi, Value: -65 for 192.168.178.67 (shellyswitch25 / shellyswitch25-73F757 / SHSW-25#73F757#1)
                  CoAP data ignored: {"3332":"SHSW-1#056CEE#1","3412":38400,"3420":1792,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
                  Set state SHSW-1#056CEE#1.rssi, Value: -67 for 192.168.178.26 (shelly1 / shelly1-056CEE / SHSW-1#056CEE#1)
                  CoAP data ignored: {"3332":"SHSW-1#058C2B#1","3412":38400,"3420":1792,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
                  CoAP data ignored: {"3332":"SHSW-1#32CA57#1","3412":38400,"3420":1280,"Uri-Path":"cit/s"} / {"G":[[0,112,0]]}
                  Set state SHSW-25#73F757#1.rssi, Value: -64 for 192.168.178.67 (shellyswitch25 / shellyswitch25-73F757 / SHSW-25#73F757#1)
                  Set state SHSW-25#73CDCC#1.rssi, Value: -62 for 192.168.178.64 (shellyswitch25 / shellyswitch25-73CDCC / SHSW-25#73CDCC#1)
                  Scheduled restart.
                  Closing Adapter
                  terminating
                  Closing Adapter
                  [Mod-Edit, Bitte Logs und Code in Code-Tags einfügen, stabilostick, 04.06.19)
                    @Home79 scheint für euch Profis auch schwierig zu sein :-)... vielleicht hat jemand noch eine Idee
                    Stuebi 1 Reply Last reply Reply Quote 0
                    • Stuebi
                      Stuebi @Home79 last edited by
                      @Home79 , hast Du wie @apollon77 vorgeschlagen hat, die Schedule Einstellungen rausgenommen? Bitte einmal auf Default (* * * * * bei jeder Minute) stellen um sicher zu gehen das es nicht damit zusammenhängt.
                        • Stuebi
                          Stuebi @apollon77 last edited by
                          @apollon77 , sorry meinte ich auch
                            @apollon77 also ich hab alles rausgenommen unverändert
                              Wenn er immer noch die ausgaben zum "scheduled restart" macht dann ists noch drin. Am besten adapter stoppen. dann den schedule restart rausnehmen, prüfen das es wirklich weg ist. adapter neu sarten. Im Zweifel mal in "Objekte" system.adapter.shelly.0 reinschauen (Stift symbol). Falls der schedule da noch drin ist auch dort leer machen.
                                @Home79 hey oh man DANKE ich habe die *** nicht gesehen skull_and_crossbones: ☹
                                Aber seit dem die weg sind ..... 👌
                                besten dank für die super Hilfe
                                Mensch kann das schön sein ☺
                                  @Home79 *** weg nun funst es DANKE EUCH
                                  6423
