    4. Objekt Motion / Nomotion zu 1 oder 0
      ChrisXY last edited by
      okay wie geht das ? Bisher noch nicht gemacht
      LausiD 1 Reply Last reply Reply Quote 0
      • LausiD
        LausiD @ChrisXY last edited by
        @ChrisXY
        Ok....in der Befehlszeile von FHEM: jsonlist2 "Name Bewegungsmelder" eingeben.
          ChrisXY @LausiD last edited by
          @LausiD okay hier
            "Arg":"motion_stall",
            "Results": [
              "Name":"motion_stall",
              "PossibleSets":"assignHmKey:noArg clear:readings,trigger,register,oldRegs,rssi,msgEvents,msgErrors,attack,all deviceRename fwUpdate getConfig:noArg getDevInfo:noArg getRegRaw peerBulk peerChan raw regBulk regSet reset:noArg sign:on,off unpair:noArg  peerSmart:Rauchmelder_Team,TeamVirtuell_Stall,VCCU_Btn4,VCCU_disarm,VCCU_lampe_stall_unterstand,VCCU_lampe_stall_unterstand_reitplatz,heizung_badoben_WindowRec,heizung_badoben_remote,heizung_badunten_WindowRec,heizung_badunten_remote,heizung_buro_WindowRec,heizung_buro_remote,heizung_esszimmer_WindowRec,heizung_esszimmer_remote,heizung_milena_WindowRec,heizung_milena_remote,heizung_schlafzimmer_WindowRec,heizung_schlafzimmer_remote,heizung_wohnzimmervitrine_WindowRec,heizung_wohnzimmervitrine_remote,pumpe_regenwasser_Sw,strom_aquarium_Sw,strom_server_Sw,strom_zaun ",
              "PossibleAttrs":"alias comment:textField-long eventMap:textField-long group room suppressReading userReadings:textField-long verbose:0,1,2,3,4,5 do_not_notify:1,0 showtime:1,0 rawToReadable unit expert:0_defReg,1_allReg,2_defReg+raw,3_allReg+raw,4_off,8_templ+default,12_templOnly,251_anything param readOnly:0,1 actAutoTry:0_off,1_on aesCommReq:1,0 model ignore:1,0 dummy:1,0 IODev IOList IOgrp rssiLog:1,0 actCycle hmKey hmKey2 hmKey3 readingOnDead:multiple,noChange,state,periodValues,periodString,channels subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,display,keyMatic,motionAndBtn,motionDetector,no,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,rgb,senBright,sensRain,sensor,singleButton,siren,smokeDetector,swi,switch,thermostat,threeStateSensor,timer,tipTronic,virtual,winMatic .mId serialNr firmware .stc .devInfo actStatus autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto msgRepeat hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger aesKey:5,4,3,2,1,0  modelForce:ACTIONDETECTOR,ACTIONDETECTOR,ASH550,ASH550I,CCU-FHEM,CMM,DORMA_ATENT,DORMA_BRC-H,DORMA_RC-H,HM-CC-RT-DN,HM-CC-RT-DN-BOM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-DIS-EP-WM55,HM-DIS-TD-T,HM-DIS-WM55,HM-DW-WM,HM-ES-PMSW1-DR,HM-ES-PMSW1-PL,HM-ES-PMSW1-PL-DN-R1,HM-ES-PMSW1-PL-DN-R2,HM-ES-PMSW1-PL-DN-R3,HM-ES-PMSW1-PL-DN-R4,HM-ES-PMSW1-PL-DN-R5,HM-ES-PMSW1-SM,HM-ES-TX-WM,HM-HM-LC-DW-WM,HM-LC-AO-SM,HM-LC-BL1-FM,HM-LC-BL1-FM-2,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-BL1-SM-2,HM-LC-BL1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-CV-2,HM-LC-DIM1L-CV-644,HM-LC-DIM1L-PL,HM-LC-DIM1L-PL-2,HM-LC-DIM1L-PL-3,HM-LC-DIM1L-PL-644,HM-LC-DIM1PWM-CV,HM-LC-DIM1PWM-CV-2,HM-LC-DIM1T-CV,HM-LC-DIM1T-CV-2,HM-LC-DIM1T-CV-644,HM-LC-DIM1T-DR,HM-LC-DIM1T-FM,HM-LC-DIM1T-FM-2,HM-LC-DIM1T-FM-644,HM-LC-DIM1T-FM-LF,HM-LC-DIM1T-PL,HM-LC-DIM1T-PL-2,HM-LC-DIM1T-PL-3,HM-LC-DIM1T-PL-644,HM-LC-DIM1TPBU-FM,HM-LC-DIM1TPBU-FM-2,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2L-SM-2,HM-LC-DIM2L-SM-644,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM-2,HM-LC-JA1PBU-FM,HM-LC-RGBW-WM,HM-LC-SW1-BA-PCB,HM-LC-SW1-DR,HM-LC-SW1-FM,HM-LC-SW1-FM-2,HM-LC-SW1-PB-FM,HM-LC-SW1-PCB,HM-LC-SW1-PL,HM-LC-SW1-PL-3,HM-LC-SW1-PL-CT-R1,HM-LC-SW1-PL-CT-R2,HM-LC-SW1-PL-CT-R3,HM-LC-SW1-PL-CT-R4,HM-LC-SW1-PL-CT-R5,HM-LC-SW1-PL-DN-R1,HM-LC-SW1-PL-DN-R2,HM-LC-SW1-PL-DN-R3,HM-LC-SW1-PL-DN-R4,HM-LC-SW1-PL-DN-R5,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-2,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW1PBU-FM,HM-LC-SW2-DR,HM-LC-SW2-DR-2,HM-LC-SW2-FM,HM-LC-SW2-FM-2,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW2PBU-FM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-DR-2,HM-LC-SW4-PCB,HM-LC-SW4-PCB-2,HM-LC-SW4-SM,HM-LC-SW4-SM-2,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-SW4-WM-2,HM-MOD-EM-8,HM-MOD-EM-8BIT,HM-MOD-RE-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CFM-TW,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-2-PBU-FM,HM-RC-4,HM-RC-4-2,HM-RC-4-3,HM-RC-4-3-D,HM-RC-4-B,HM-RC-8,HM-RC-DIS-H-X-EU,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-KEY4-2,HM-RC-KEY4-3,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-SEC4-2,HM-RC-SEC4-3,HM-SCI-3-FM,HM-SEC-CEN,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-MDIR-3,HM-SEC-RHS,HM-SEC-RHS-2,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCO,HM-SEC-SD,HM-SEC-SD-2,HM-SEC-SFA-SM,HM-SEC-SIR-WM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-DB-PCB,HM-SEN-EP,HM-SEN-LI-O,HM-SEN-MDIR-O,HM-SEN-MDIR-O-2,HM-SEN-MDIR-O-3,HM-SEN-MDIR-SM,HM-SEN-MDIR-WM55,HM-SEN-RD-O,HM-SEN-WA-OD,HM-SWI-3-FM,HM-SYS-SRP-PL,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS100-C6-O-2,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-OT2-SM-2,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550TECH,IS-WDS-TH-OD-S-R3,KFM-DISPLAY,KFM-SENSOR,KS550,KS550LC,KS550TECH,KS888,OLIGO-SMART-IQ-HM,PS-SWITCH,PS-TH-SENS,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FFK,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FSS-UP3,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,S550IA,SCHUECO_263-130,SCHUECO_263-131,SCHUECO_263-132,SCHUECO_263-133,SCHUECO_263-134,SCHUECO_263-135,SCHUECO_263-144,SCHUECO_263-145,SCHUECO_263-146,SCHUECO_263-147,SCHUECO_263-155,SCHUECO_263-157,SCHUECO_263-158,SCHUECO_263-160,SCHUECO_263-162,SCHUECO_263-167,SCHUECO_263-XXX,SENSOTIMER-ST-6,VIRTUAL,WDF-SOLAR,WS888 repPeers peerIDs tempListTmpl:none,defaultWeekplan, levelRange levelMap cyclicMsgOffset event-aggregator event-min-interval event-on-change-reading event-on-update-reading oldreadings stateFormat:textField-long timestamp-on-change-reading DbLogExclude DbLogInclude alarmDevice:Actor,Sensor alarmSettings cmdIcon devStateIcon:textField-long devStateStyle icon msgContactAudio msgContactLight msgContactMail msgContactPush msgContactScreen msgParams msgPriority msgRecipient msgRecipientAudio msgRecipientLight msgRecipientMail msgRecipientPush msgRecipientScreen msgRecipientText msgTitle msgTitleShrt msgType:text,push,mail,screen,light,audio,queue sortby webCmd webCmdLabel:textField-long widgetOverride userattr",
              "Internals": {
                ".triggerUsed": "0",
                "DEF": "461309",
                "FUUID": "5cce995c-f33f-09a2-4026-a0e84556b11b8ebe",
                "HMLANGW_MSGCNT": "168",
                "HMLANGW_RAWMSG": "050000830084104613090000000601C400",
                "HMLANGW_RSSI": "-131",
                "HMLANGW_TIME": "2019-06-05 16:33:51",
                "HMLAN_MSGCNT": "43",
                "HMLAN_RAWMSG": "E461309,0000,03E48BA9,FF,FFAC,0084104613090000000601C400",
                "HMLAN_RSSI": "-84",
                "HMLAN_TIME": "2019-06-05 16:33:51",
                "LASTInputDev": "HMLAN",
                "MSGCNT": "211",
                "NAME": "motion_stall",
                "NOTIFYDEV": "global",
                "NR": "839",
                "NTFY_ORDER": "50-motion_stall",
                "STATE": "noMotion",
                "TYPE": "CUL_HM",
                "chanNo": "01",
                "lastMsg": "No:00 - t:10 s:461309 d:000000 0601C400",
                "protCmdPend": "4 CMDs_pending",
                "protLastRcv": "2019-06-05 16:33:51",
                "protRcv": "178 last_at:2019-06-05 16:33:51",
                "protRcvB": "2 last_at:2019-06-04 05:09:12",
                "protState": "CMDs_pending",
                "rssi_at_HMLAN": "cnt:43 min:-103 max:-83 avg:-89.62 lst:-84 ",
                "rssi_at_HMLANGW": "cnt:166 min:-134 max:-37 avg:-129.78 lst:-131 ",
                "rssi_at_rpt_HMLANGW": "cnt:2 min:-133 max:-63 avg:-98 lst:-63 ",
                "rssi_broadcast": "cnt:1 min:-189 max:-189 avg:-189 lst:-189 "
              "Readings": {
                ".D-devInfo": { "Value":"110100", "Time":"2019-05-06 09:13:34" },
                ".D-stc": { "Value":"81", "Time":"2019-05-06 09:13:34" },
                ".protLastRcv": { "Value":"2019-06-05 16:33:51", "Time":"2019-06-05 16:33:51" },
                "Activity": { "Value":"alive", "Time":"2019-06-01 16:45:59" },
                "D-firmware": { "Value":"1.6", "Time":"2019-05-06 09:13:34" },
                "D-serialNr": { "Value":"NEQ0118339", "Time":"2019-05-06 09:13:34" },
                "battery": { "Value":"ok", "Time":"2019-06-05 16:33:51" },
                "brightness": { "Value":"196", "Time":"2019-06-05 16:33:51" },
                "cover": { "Value":"closed", "Time":"2019-06-05 16:33:51" },
                "motion": { "Value":"off", "Time":"2019-06-05 16:37:39" },
                "motionCount": { "Value":"1_next:240s", "Time":"2019-06-05 16:33:37" },
                "motionDuration": { "Value":"296", "Time":"2019-06-05 16:37:39" },
                "powerOn": { "Value":"2019-06-05 16:33:04", "Time":"2019-06-05 16:33:04" },
                "recentStateType": { "Value":"info", "Time":"2019-06-05 16:33:51" },
                "state": { "Value":"noMotion", "Time":"2019-06-05 16:37:39" },
                "trigDst_broadcast": { "Value":"noConfig", "Time":"2019-05-23 17:17:26" },
                "trigger_cnt": { "Value":"1", "Time":"2019-06-05 16:33:37" }
              "Attributes": {
                ".mId": "005D",
                "DbLogExclude": ".*",
                "DbLogInclude": "trigger_cnt,brightness,motionDuration",
                "IODev": "HMLAN",
                "actCycle": "024:00",
                "actStatus": "alive",
                "alias": "motion_stall",
                "autoReadReg": "4_reqStatus",
                "expert": "2_raw",
                "firmware": "1.6",
                "model": "HM-SEN-MDIR-O",
                "room": "CUL_HM,ioBroker",
                "serialNr": "NEQ0118339",
                "subType": "motionDetector"
            "totalResultsReturned":1
          • LausiD
            @ChrisXY
            Danke..kannst FHEM Adapter über github aktualisieren
            Nach Neustart sollte der Bewegungsmelder im ioBroker ein Objekt state_boolean mit true/false haben.
            LausiD
            C 2 Replies Last reply Reply Quote 0
              @LausiD Mega 🙂 Vielen DANK
                ChrisXY @LausiD last edited by ChrisXY
                @LausiD
                host.iobroker	2019-06-06 16:04:16.687	error	instance system.adapter.fhem.0 terminated with code 1 ()
                Caught	2019-06-06 16:04:16.687	error	by controller[0]: at bootstrap_node.js:625:3
                Caught	2019-06-06 16:04:16.687	error	by controller[0]: at startup (bootstrap_node.js:204:16)
                Caught	2019-06-06 16:04:16.687	error	by controller[0]: at Function.Module.runMain (module.js:694:10)
                Caught	2019-06-06 16:04:16.687	error	by controller[0]: at Function.Module._load (module.js:498:3)
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: at tryModuleLoad (module.js:506:12)
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: at Module.load (module.js:566:32)
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: at Module._compile (module.js:617:28)
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: at Object.runInThisContext (vm.js:139:10)
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: at createScript (vm.js:80:10)
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: SyntaxError: Invalid or unexpected token
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: ^^^^^^^^^^^
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: if (valOrg === 'motion' || valOrg === 'nomotion' || valOrg === 'noMotion' || valOrg === "Motion') {
                Caught	2019-06-06 16:04:16.686	error	by controller[0]: /opt/iobroker/node_modules/iobroker.fhem/main.js:1725
                EDIT: oder auch FHEM selbst neu tarten ? Hab nur den Adapter
                • LausiD
                  @ChrisXY
                  Nein, FHEM nicht neu starten
                  Sorry, habe mich auf Handy vertippt.
                  Nochmal von github aktualisieren:-(
                    ChrisXY last edited by ChrisXY
                    hmm habs nochmal von github geladen nu is immer noch 1.2.1 drauf guthub gibt es aber nur 1.2.0
                    Edit : leider taucht auch ein state_boolean auf.. komisch
                    Will das fhem auch nicht löschen hab angst da was zu verlieren hab da Logging für vieles Aktiv.
                    • LausiD
                      LausiD last edited by LausiD
                      @ChrisXY
                      Sorry, Änderung nebenher ging schief.
                      Aller guten Dinge sind drei 🙂
                      Kannst bitte nochmal von github aktualisieren....
                      Korrekt, die Version ist 1.2.1 und ändert sich auch nicht.
                      Beim Start FHEM Adapter werden folgende Zeilen ins Log geschrieben:
                      fhem.1 2019-06-06 20:16:08.526 info STEP 01 ===== buildDate 06.06.19b - check objects fhem.1
                      fhem.1 2019-06-06 20:16:08.460 info starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.fhem, node: v8.15.1
                      Und jetzt sollte nach Neustart auch endgültig ein Objekt state_Boolean mit dem Wert true/false erscheinen 🙂
                      LausiD
                      C 1 Reply Last reply Reply Quote 1
                        @LausiD hehe macht ja nichts bin für jede änderung Dankbar. Super Adapter 🙂 Was würde ich ohne den nur machen g
                        79.9k
                        blockly javascript
                        1071
