    4. Fehler bei der Installation vom SQL Adapter
    SOLVED Fehler bei der Installation vom SQL Adapter
    • Amnesia1211
      Amnesia1211 last edited by Amnesia1211
      Hallo liebe Iobroker Gemeinde,
      leider habe ich einen Fehler bei der Installation des SQL Adapters und weiß leider auch keine Abhilfe.
      Vielleicht hat ja einer von euch eine Idee.
      iobroker läuft auf Synology (Docker) Version 2.0.0
      Fertig mit Fehler: host.iobroker Cannot install sql
      $ ./iobroker add sql  --host iobroker
      NPM version: 6.4.1
      npm install iobroker.sql --production --save --prefix "/opt/iobroker" (System call)
      gyp
       WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/8.14.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/mmmagic/.node-gyp"
      gyp
       WARN install got an error, rolling back install
      gyp WARN
      gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/mmmagic/.node-gyp'
      gyp ERR! System Linux 3.10.105gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd
       /opt/iobroker/node_modules/mmmagicgyp ERR! node -v v8.14.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      npm
       WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm
       ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! mmmagic@0.5.3 install: `node-gyp rebuild`npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the mmmagic@0.5.3 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-06-06T20_28_50_353Z-debug.log
      host.iobroker install adapter sql
      NPM version: 6.4.1
      gyp
      gyp
      gyp
       WARN install got an error, rolling back installgyp ERR! configure error
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/mmmagic
      gyp ERR! not ok
      npm
      npm ERR! code ELIFECYCLEnpm ERR! errno 1
      npm
      npm ERR!
      npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-06-06T20_29_37_206Z-debug.log
      NPM version: 6.4.1
      gyp
      gyp WARN install got an error, rolling back install
      gyp ERR!
       node -v v8.14.0gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      npm
      npm
      npm ERR!
      npm ERR!
      npm ERR!     /root/.npm/_logs/2019-06-06T20_30_24_236Z-debug.log
      ERROR: host.iobroker Cannot install sql
      ERROR: process exited with code 13
      • Amnesia1211
        Wirklich keiner eine Idee? Würde gerne die SQL Datenbank für das loggen nutzen.
          Homoran Global Moderator Administrators @Amnesia1211 last edited by
          @Amnesia1211
          Hast du Mal im Forum nach fehlender Berechtigung und Behebung davon gesucht?
          Die in diesem Rahmen übliche Frage:
          Wann und wie würde ioBroker installiert?
          Amnesia1211 1 Reply Last reply Reply Quote 0
          • Amnesia1211
            Amnesia1211 @Homoran last edited by
            @Homoran sagte in Fehler bei der Installation vom SQL Adapter:
            Berechtigung
            Ja habe schon mal gesucht aber nichts gefunden 😞
            Wann ich iobroker installiert habe weiß ich nicht mehr genau, denke vor 3 Wochen.
            Wie hatte ich oben schon erwähnt, es läuft auf einer Synology DS RS818+ über Docker,
            der link ist hier https://hub.docker.com/r/buanet/iobroker/ die Version ist 2.0.0
            Andere Adapter lassen sich normal installieren. Was der Unterschied zum SQL Adapter sind kann ich mir nicht erklären.
            Homoran Negalein 2 Replies Last reply Reply Quote 0
              @Amnesia1211
              Sorry, das mit dem Docker habe ich überlesen. Aber genau da eird das Problem luegen. Leider kenne ich mich damit überhaupt nicht aus.
              • Negalein
                Negalein Global Moderator @Amnesia1211 last edited by
                @Amnesia1211 sagte in Fehler bei der Installation vom SQL Adapter:
                Hast du hier schon mal gefragt?
                Ich glaube @andre hat mal was zwecks SQL geschrieben.
                • Amnesia1211
                  Amnesia1211 @Negalein last edited by
                  @Negalein
                  Nein habe ich nicht gemacht, werde ich aber jetzt im Anschluss tun danke gute Idee 🙂
                  • Amnesia1211
                    Also...
                    Mir wurde geraten die Docker Version auf 3.0 upzudaten, was ich dann nach einigen Problemen auch hin bekommen habe.
                    Der SQL Adapter läuft auf der Version 3.0, zudem wurde mir gesagt das ich ein Rechte Problem mit der Version 2.0 habe und deswegen die Installation
                    des SQL Adapters nicht klappt.
                    adapter sql fehler
