<variables>
<variable type="" id="(3zQ(:otG,Xx5wM{8H;">Reinigung_ausstehend</variable>
<variable type="undefined" id="timeout">timeout</variable>
<variable type="undefined" id="timeout2">timeout2</variable>
</variables>
<block type="schedule" id=":@XSrK:A(xs4_+#/[[%k" x="-462" y="-537">
<field name="SCHEDULE">0 11 * * 1,3,5</field>
<block type="controls_if" id="p|OX526Dn{+[N6y2g~7z">
<block type="get_value" id=",K0)C[~cUU+M;(oAz^M">
<field name="OID">javascript.0.Anwesenheit</field>
<block type="variables_set" id="o/G:d!SfBY?%Z-L_OBv">
<field name="VAR" id="(3zQ(:otG,Xx5wM{8H;" variabletype="">Reinigung_ausstehend</field>
<block type="logic_boolean" id="Jd@)x1Y.}BGFQuT[|q8h">
<statement name="ELSE">
<block type="control" id="dTG?zbRRO,^Bsv5TG_,K">
<field name="OID">vr200.0.Staubie.commands.eco</field>
<block type="logic_boolean" id="|d]{=OEa=erb]NeGC]k}">
<block type="control" id="8)T6=-yaHVA.PDy_bp1-">
<mutation delay_input="true"></mutation>
<field name="OID">vr200.0.Staubie.commands.clean</field>
<field name="DELAY_MS">1</field>
<block type="logic_boolean" id="cFJIdo7t:bh:;yiLn]UU">
<block type="on" id="TR~VHnVS1QaN*L-ABC-"> <field name="OID">javascript.0.Anwesenheit</field> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="MKLMUkQ]Haz0~8ZGo0W%"> <value name="IF0"> <block type="logic_operation" id="KX?!f8@wF51noA,%j]+#" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_negate" id="=mt-4B:lb00[cx*6]YuY"> <value name="BOOL"> <block type="on_source" id="kap(jom7~m6i~?W,{TKz"> <field name="ATTR">state.val</field> </block> </value> </block> </value> <value name="B"> <block type="variables_get" id="rs9KhRBz-},Ggmx)fL|x"> <field name="VAR" id="*(3zQ(:otG,Xx5wM{8H;" variabletype="">Reinigung_ausstehend</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="^}*p/Wcca1[Q}[u%+iOL"> <mutation delay_input="false"></mutation> <field name="OID">vr200.0.Staubie.commands.eco</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="@%m^zkFQPwR%~Y26/C*a"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="84TurGVzBe31AfrpaE,t"> <mutation delay_input="true"></mutation> <field name="OID">vr200.0.Staubie.commands.clean</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">1</field> <field name="UNIT">sec</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="l83dH~^1;M=r746ipFW*"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="timeouts_cleartimeout" id="kr3-UX[uNVVt0#xR,f%*"> <field name="NAME">timeout2</field> <next> <block type="timeouts_settimeout" id="JJ/F?%r}B=~X5(Zy]5yc"> <field name="NAME">timeout2</field> <field name="DELAY">10</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="variables_set" id="iz~kMR,^HvZgyDjr.m+v"> <field name="VAR" id="*(3zQ(:otG,Xx5wM{8H;" variabletype="">Reinigung_ausstehend</field> <value name="VALUE"> <block type="logic_boolean" id="NDjKYM~mc4}6?LvgfFVL"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> <next> <block type="on" id=".PujgfHwbO1)xewiH{uF"> <field name="OID">vr200.0.Staubie.status.action</field> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="timeouts_cleartimeout" id="aL)
d9b[Xg%Oj)}w8xj">
<block type="timeouts_settimeout" id="`wib25F%wCMDzf=U)Ll">
<field name="DELAY">1000</field>
<field name="UNIT">ms</field>
<block type="controls_if" id="rVlNwz0oQS)mcdqt]Lg">
<block type="logic_compare" id="my+-JZH}NozBae(ctdLA">
<field name="OP">EQ</field>
<block type="on_source" id="wvsIY6_D|u5~cG_JI/G">
<block type="math_number" id="6?rvbP=eF~z}Lw(I#LTd">
<field name="NUM">6</field>
<block type="variables_set" id="yuQD?kZ0iy1BKDQtwB4P">
<block type="logic_boolean" id="eLlnlv}E=CsZyX.oM?pj">
<variables>
</variables>
d9b[Xg%Oj)}w8xj">
