    4. Test Adapter lovelace v0.2.x
      mandragora last edited by
      Hallo Leute,
      Hab mir den Adapter auch gerade installiert aber bekomme die Instanz nicht gestartet.
      Bekomme im Log folgendes:
      host.ioBroker	2019-06-09 21:04:57.232	error	instance system.adapter.lovelace.0 terminated with code 1 ()
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/index.js:3:19)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at require (internal/module.js:20:19)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Module.require (module.js:504:17)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Module.load (module.js:494:32)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Module._compile (module.js:549:28)
      host.ioBroker	2019-06-09 21:04:57.232	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: at createScript (vm.js:56:10)
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: SyntaxError: Unexpected token ...
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: ^^^
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: ...options
      host.ioBroker	2019-06-09 21:04:57.231	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/websocket.js:347
      host.ioBroker	2019-06-09 21:04:56.731	info	instance system.adapter.lovelace.0 started with pid 1035
      Kann mir vielleicht jemand ein wenig auf die Sprünge helfen was eventuell falsch läuft ?
      Vielen Dank
      lg
      mandragora
      apollon77 Bluefox 2 Replies Last reply Reply Quote 0
        holgerwolf @dontobi last edited by
        @dontobi
        Ne E-Mail an die User mit dem Link tut es auch.
        Die Authentifizierung sollte jetzt mit dem letzten Update auch Geschichte sein.
        • dontobi
          Ihr könnt ja gerne weiterhin einen Browser verwenden. In meinem Fall werde ich aber nach einer App Lösung suchen. Das ist ja das schöne... Jeder kann die Software so nutzen, wie er oder sie es will...
            Raducanu last edited by
            Endlich mal ein UI mit wirklich viel Potential. Irgendeine Möglichkeit Rolladensteuerung (level.blind) zu integrieren?
              apollon77 @mandragora last edited by
              @mandragora ja. Du hast denke ich nodejs 6 installiert. Du brauchst mindestens nodejs 8 für den Adapter. Nodejs 6 ist weiterhin eh end of life.update angeraten!
                apollon77 @dontobi last edited by
                @dontobi iogo schon gesehn? Adapter mir android app
                dontobi 1 Reply Last reply Reply Quote 0
                • dontobi
                  dontobi @apollon77 last edited by
                  @apollon77 Ja, habe ich. Nutze ich auch derzeit noch. Jedoch sind bei iogo die Möglichkeiten begrenzter. Bin daher auf der Suche nach einer Alternative und Lovelace ist super. Es gibt für Homeassistent auch ein paar Apps, jedoch klappt bisher nur WallPanel.
                  Auf unserem Zentralen Tablet rennt WallPanel ohne Probleme und dort brauche ich keine andere App. Auf den Handy meiner Frau und meines Sohnes könnte die App auch zum Einsatz kommen, aber dazu muss ich erst alle Features in Lovelace einbauen. Bin aber bisher sehr zufrieden.
                    Ich habe gerade die ersten Sachen ausprobiert. Was ich nicht verstehe oder den Fehler nicht finde:
                    • Ich habe mehrere Sonoff Relais die über den Sonoff Adapter eingebunden sind.
                      Steuere ich das Relais über Lovelace, wird zwar das Objekt auf True/False gestellt, das Sonoff Relais schaltet aber nicht. Stelle ich das Objekt im Objekt Browser manuell auf True/False schaltet das Relais normal....
                    • Bluefox
                      Bluefox @mandragora last edited by
                      @mandragora node.js zu alt?
                      • dontobi
                        dontobi @Raducanu last edited by
                        @Raducanu Wird der STATE der Geräte im ioBroker unter Objekte mit ON und OFF angezeigt? Das war bei mir der Fall. Hab mir daher ein kleines Script gebastelt. Kann es gerne hier anhängen, wenn das mit dem STATE so ist.
                          Raducanu @dontobi last edited by Raducanu
                          @dontobi
                          Der State ist "TRUE" / "FALSE"
                          Hier als Beispiel:
                          Sonoff07 -> POWER1 ist der "Terrasse" Schalter im Lovelace. Oben Rechts die Tasmota WebGUI mit dem "ECHTEN" State.
                          Aktuell ist alles aus:
                          Schalte ich das Licht über Lovelace ein, wird der Wert im Objekt auf "TRUE" gesetzt, das Relais schaltet aber nicht:
                          Setze ich den Wert allerdings direkt im Objekt Browser auf TRUIE, schaltet das Relais (Und Lovelace zeigt auch den Status an)
                          Beim Ausschalten das Selbe: IOBroker und Lovelace zeigen "FALSE" als State an, das Relais hat aber nicht geschaltet
                          Ich werde nochmal schauen was im MQTT Protokoll steht, aber irgendwas ist dort faul
                            Raducanu @Raducanu last edited by
                            @Raducanu said in [Aufruf] Test lovelace Adapter:
                            @dontobi
                            Hier als Beispiel:
                            Sorry, gerade gesehen dass dieses in 0.1.1 gefixed ist
                              Hallo, kann man die Fehlermeldungen unterdrücken?
                              lovelace.0	2019-06-11 11:54:15.363	error	Invalid attribute name for {"friendly_name":"Multimedia Badzimmer","entity_picture":"./adapter/alexa2/icons/echo_dot.png","icon":"mdi:play-network","media_content_type":"unknown","supported_features"
                              lovelace.0	2019-06-11 11:54:15.360	error	Invalid attribute name for {"friendly_name":"Multimedia Küche","entity_picture":"./adapter/alexa2/icons/echo_dot.png","icon":"mdi:play-network","media_content_type":"unknown","supported_features":174
                              lovelace.0	2019-06-11 11:54:15.357	error	Invalid attribute name for {"friendly_name":"Multimedia roomLivingRoom","entity_picture":"./adapter/alexa2/icons/echo_dot.png","icon":"mdi:play-network","media_content_type":"unknown","supported_feat
                              Bluefox 1 Reply Last reply Reply Quote 0
                              • Bluefox
                                Bluefox @sigi234 last edited by
                                @sigi234 Das muss ich noch fixen/implementieren. Die müssen als Errinerung für mich da bleiben 🙂
                                • dontobi
                                  Ich versuche gerade eine Custom Card zu verwenden. Genauer gesagt diese hier...
                                  https://github.com/kalkih/mini-graph-card
                                  Hier ist mein Code:
                                  type: 'custom:mini-graph-card'
                                  icon: mdi:server
                                  entities:
                                    - entity: sensor.System_CPU_Load1
                                    - entity: sensor.System_CPU_Load5
                                    - entity: sensor.System_CPU_Load15
                                  Als Fehlermeldung bekomme ich dann das hier:
                                  Custom element doesn't exist: mini-graph-card.
                                    "type": "custom:mini-graph-card",
                                    "name": "CPU Load",
                                    "icon": "mdi:server",
                                    "entities": [
                                        "entity": "sensor.System_CPU_Load1",
                                        "name": "Load 1"
                                        "entity": "sensor.System_CPU_Load5",
                                        "name": "Load 5"
                                        "entity": "sensor.System_CPU_Load15",
                                        "name": "Load 15"
                                  Die JS Datei habe ich im Admin per Drag & Drop eingespielt und der Adapter wurde neugestartet.
                                  Vielleicht mache ich etwas falsch oder die Custom Card klappt nicht.
                                  sigi234 Bluefox 2 Replies Last reply Reply Quote 0
                                    sigi234 Forum Testing Most Active @dontobi last edited by
                                    @dontobi sagte in [Aufruf] Test lovelace Adapter:
                                    Wohin genau?
                                    • dontobi
                                      dontobi @sigi234 last edited by
                                      @sigi234 geh Mal in die Instanz Einstellungen. Ist dort selbsterklärend.
                                      Und ich hab noch etwas festgestellt. Die Weather Card geht auch mit Weatherunderground, jedoch werden da (genauso wie bei yr.no) keine Icons angezeigt. Hat einer die Wetter Karte mit Icons am laufen?
                                      • Bluefox
                                        Bluefox @dontobi last edited by Bluefox
                                        Участник @dontobi написал в [Aufruf] Test lovelace Adapter:
                                        icon: mdi:server
                                        entities:
                                        • entity: sensor.System_CPU_Load1
                                        • entity: sensor.System_CPU_Load5
                                        • entity: sensor.System_CPU_Load15
                                        Welche Datei hast du uploaded?
                                        Diese hier: https://github.com/kalkih/mini-graph-card/releases/download/v0.4.3/mini-graph-card-bundle.js
                                        9da95f1c-cf27-44e5-9683-54b0fcad1d84-image.png35c86934-2cdf-4af4-a15d-5a4251a10b86-image.png
                                          Hallo Leute,
                                          Vielen Dank für die Info.
                                          Hab noch wie ihr schon vermutet eine alte Version drauf
                                          Ich hab iobroker auf einer Synology unter Docker laufen.
                                          node hab ich bereits auf die 10.16.0 bringen können.
                                          Kann mir jemand eventuell noch sagen wie ich gefahrlos (Backup mit Backitup ist vorhanden) ein Update von nodejs und npm machen kann ?
                                          Hab schon einiges hier gefunden aber hab ein wenig die Scheu das was schiefgehen könnte.
                                          Müsste es so funktionieren ?
                                          iobroker stop
                                          apt-get --purge remove node nodejs
                                          apt-get autoremove
                                          reboot
                                          Nach dem Reboot geht es mit diesen Befehlen weiter:
                                          curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                                          apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                                          reboot
                                          Vielen Dank nochmals
                                          lg
                                          mandragora
                                          • Bluefox
                                            @mandragora https://www.iobroker.net/#de/documentation/install/updatenode.md
                                            call for action lovelace test visualisierung
                                            131
                                            1051
                                            376762
