    4. [Gelöst]ObjectId (von Wiffi-WZ-Adapter) triggert Script nicht
    SOLVED [Gelöst]ObjectId (von Wiffi-WZ-Adapter) triggert Script nicht
      paul53 @smartboart last edited by paul53
      @smartboart sagte:
      indem ich überall ein hochkomma setze..
      Und wenn die nächste Version Zahlen und boolsche Werte liefert, machst Du alles wieder rückgängig ? Die Umwandlung stört auch nicht, wenn es keine Strings sind.
      Der Vergleich
      Sturm > '3'
      wird nicht funktionieren, da z.B. '10' kleiner ist als '3'.
      smartboart 1 Reply Last reply Reply Quote 0
      • coyote
        coyote Most Active last edited by
        Ja so habe ich es momentan auch gelöst.
        Was mich etwas wundert ist, dass laut JSON das in iobroker ankommt, die Typen eigentlich auch richtig sind.
        Schaut:
        Full message: {"modultyp":"weatherman","vars":[{"name":"0","homematic_name":"w_ip","desc":"weatherman_ip","type":"string","unit":"","value":"192.168.66.134"},{"name":"1","homematic_name":"w_temperatur","desc":"aussentemperatur","type":"number","unit":"gradC","value":"25.8"},{"name":"21","homematic_name":"w_windchill","desc":"gefuehlte_temperatur","type":"number","unit":"gradC","value":"25.8"},{"name":"9","homematic_name":"w_taupunkt","desc":"taupunkt_temperatur","type":"number","unit":"gradC","value":"10.4"},{"name":"14","homematic_name":"w_himmeltemperatur","desc":"himmel_temperatur","type":"number","unit":"gradC","value":"0.0"},{"name":"2","homematic_name":"w_feuchte_rel","desc":"rel_feuchte","type":"number","unit":"%","value":"38.0"},{"name":"17","homematic_name":"w_feuchte_abs","desc":"abs_feuchte","type":"number","unit":"g/m3","value":"9.1"},{"name":"18","homematic_name":"w_regensensor_wert","desc":"regenmelderwert","type":"number","unit":"","value":"5"},{"name":"7","homematic_name":"w_regenmelder","desc":"regenstatus","type":"boolean","unit":"","value":"false"},{"name":"8","homematic_name":"w_regenstaerke","desc":"regenstaerke","type":"number","unit":"mm/h","value":"0.0"},{"name":"19","homematic_name":"w_regen_letzte_h","desc":"regen_pro_h","type":"number","unit":"mm","value":"0.0"},{"name":"20","homematic_name":"w_regen_mm_heute","desc":"regen_mm_heute","type":"number","unit":"mm","value":"519.0"},{"name":"32","homematic_name":"w_regenstunden_heute","desc":"regenstunden_heute","type":"number","unit":"h","value":"0.0"},{"name":"27","homematic_name":"","desc":"regen_mm_gestern","type":"number","unit":"mm","value":"1245.5"},{"name":"3","homematic_name":"w_barometer","desc":"nn_luftdruck","type":"number","unit":"mb","value":"1300.00"},{"name":"11","homematic_name":"w_barotrend","desc":"luftdrucktrend","type":"string","unit":"","value":"bitte_warten"},{"name":"4","homematic_name":"w_wind_mittel","desc":"avg_windgeschwindigkeit","type":"number","unit":"m/s","value":"0.6"},{"name":"5","homematic_name":"w_wind_spitze","desc":"peak_windgeschwindigkeit","type":"number","unit":"m/s","value":"0.8"},{"name":"24","homematic_name":"w_windstaerke","desc":"bft_windgeschwindigkeit","type":"number","unit":"bft","value":"1"},{"name":"23","homematic_name":"w_windrichtung","desc":"windrichtung","type":"string","unit":"","value":"W"},{"name":"6","homematic_name":"w_wind_dir","desc":"windwinkel","type":"number","unit":"grad","value":"270"},{"name":"10","homematic_name":"w_lux","desc":"helligkeit","type":"number","unit":"lux","value":"11374.0"},{"name":"22","homematic_name":"w_sonne_diff_temp","desc":"sonnen_difftemperatur","type":"number","unit":"gradC","value":"13.6"},{"name":"15","homematic_name":"","desc":"sonnen_temperatur","type":"number","unit":"gradC","value":"39.4"},{"name":"16","homematic_name":"w_sonne_scheint","desc":"sonne_scheint","type":"boolean","unit":"","value":"true"},{"name":"26","homematic_name":"w_sonnenstunden_heute","desc":"Sonnenstunden_heute","type":"number","unit":"h","value":"0.8"},{"name":"12","homematic_name":"w_elevation","desc":"sonne_elevation","type":"number","unit":"grad","value":"47.2"},{"name":"13","homematic_name":"w_azimut","desc":"sonne_azimut","type":"number","unit":"grad","value":"112.8"},{"name":"30","homematic_name":"w_minuten_vor_sa","desc":"minuten_vor_sa","type":"number","unit":"min","value":"-307"},{"name":"31","homematic_name":"w_minuten_vor_su","desc":"minuten_vor_su","type":"number","unit":"min","value":"650"}]
        • smartboart
          smartboart @paul53 last edited by
          @paul53 said in [Gelöst]ObjectId (von Wiffi-WZ-Adapter) triggert Script nicht:
          Der Vergleich
          Sturm > '3'
          ok, dann habe ich deine Erklärung nicht ganz verstanden...Welche andere Möglichkeit / Workaround gibt es dazu?
            paul53 @coyote last edited by paul53
            @coyote sagte:
            Nein, das sind sie nicht. Die Werte werden alle in Anführungszeichen übergeben, z.B. "regen_mm_heute": "value":"519.0". Richtig wäre "value":519.0
              @smartboart sagte:
              Da ich nur einen kleinen Teil des Skripts kenne, am Beispiel Sonne:
                 var sonne = toBoolean(getState('wiffi-wz.0.root.192_168_66_134.w_sonne_scheint'/*16*/).val);
              Bei Zahlen entsprechend
                 var Sturm = parseFloat(getState('wiffi-wz.0.root.192_168_66_134.w_windstaerke).val);
              smartboart 2 Replies Last reply Reply Quote 0
              • smartboart
                smartboart @paul53 last edited by smartboart
                @paul53 ah gut....wierder was dazu gelernt....Danke..
                • coyote
                  coyote Most Active @paul53 last edited by
                  @paul53 ok, danke Paul. Wieder was gelernt, ich dachte dass passt so. Dann sollten wir vllt doch mal bei Eugen nachhaken, ob er das ändern möchte. Dann wäre das JSON ja so nicht korrekt
                  • smartboart
                    smartboart @coyote last edited by
                    @coyote ja sieht so aus als hätte er in der firmware den Bock drinne...Schreibst du ihn an.. Er antwortet immer relativ schnell
                    • coyote
                      coyote Most Active last edited by coyote
                      Ja kann ich machen, meinst du direkt über seine Page oder Homematic Forum?
                      • smartboart
                        var sonne = toBoolean(getState('wiffi-wz.0.root.192_168_66_134.w_sonne_scheint'/16/).val);
                        Wie löse ich das hier?
                        on({id:"wiffi-wz.0.root.192_168_1_52.w_windstaerke", val: 6, change: 'ne' },function(obj){
                        bzw.
                        on({id:Sturm, val: 6, change: 'ne' },function(obj){
                        ok könnte man so machen
                        on(idSturm, function(dp) {
                        var Sturm = parseFloat(getState(idSturm).val);
                        if(Sturm>=6){
                        if (logging) log ('Trigger Sturm Rollo Couch aktiv');
                        Rolladen();
                        Dann wird aber immer immer beim pollen getriggert und nicht nur einmal bei Änderung auf 6..
                          @smartboart :
                          on("wiffi-wz.0.root.192_168_1_52.w_windstaerke",function(obj) {
                             if(parseFloat(obj.state.val) == 6) {
                          Du triggerst auf Windstärke == 6 ?
                            @smartboart sagte:
                            Du möchtest die Aktion nur ausführen, wenn der Grenzwert erstmalig überschritten wird und dann darüber bleibt ? Dann so
                               if(parseFloat(obj.state.val) >= 6 && parseFloat(obj.oldState.val) < 6) {
                            • smartboart
                              @paul53 Danke sehr...
                              Habe jetz alle Skripte durch...Im Scriptadapter in der Sufu wiffi-wz.0.root.192_168_1_52 eingegeben und alles durchgeackert...Das war kein Spaß...
                              Danke für die tolle Hilfe..
                              • coyote
                                Genau, vielen Dank @paul53 für deine Hilfe.
                                Eugen hab ich angeschrieben und der Entwickler des wiffi-wz Adapters weiß auch Bescheid über GitHub.
                                Dann hoffen wir mal das Eugen das JSON schnell fixt.
                                • coyote
                                  @smartboart
                                  Ich habe mit Eugen geschrieben hier die Mail von gestern:
                                  Ich habe mir die für mich gefühlte "unendliche" Geschichte/diskussion
                                  des richtigen JSON-Formats in den vielen Mails nochmal angesehen.
                                  Letzlich entstand aus den Diskussionen mit verschiedenen Usern der heute
                                  gewählte Ansatz, auch die "values" als Zahlen im Stringformat
                                  darzustellen. Wenn ich jetzt wieder auf die von Dir bevorzugte Lösung
                                  zurückschwenke, dann bekomme ich von vielen Seiten richtig Ärger, die
                                  auf Basis des aktuellen JSON-Formates ihre Auswertung
                                  ausgerichtet/programmiert haben.
                                  Also von meiner Seite die klare Entscheidung für das JSON-Format beim
                                  WEATHERMAN :
                                  Ich bleibe bei dem aktuellen Format mit den Values als String. Die
                                  anderen Produkte wie PULSECOUNTER werde ich sukzessive auf dieses Format
                                  umstellen.
                                  Daraus ergibt sich ggf. die Notwendigkeit, die entsprechenden
                                  IObroker-Adapter so anzupassen, daß aus den verschiedenen value-Strings
                                  die verschiedenen Zahlenformate erzeugt werden (was aber sicher kein
                                  großes technisches Problem sein wird).
                                  Ich bitte um Verständnis für diese für Dich möglicherweise nicht
                                  zufriedenstellende Antwort.
                                  Bleibt dann nur noch die Möglichkeit es direkt im Adapter abzuändern oder eben umzuwandeln wie paul53 es geschrieben hat.
                                  • smartboart
                                    smartboart @coyote last edited by smartboart
                                    @coyote Vielen Dank für die Rückmeldung...
                                    Ich hoffe x4tlaoguo passt den Adapter entsprechend an..
                                    • coyote
                                      coyote Most Active @smartboart last edited by
                                      @smartboart hab das jetzt mal im Github Issue weitergegeben und x4tlaoguo will den Adapter dann Anfang nächste Woche umbauen.
                                      datenpunkte problem script wiffi-wz
                                      2247
