    4. [How-to] Node.js für ioBroker richtig updaten
    • Stabilostick
      Stabilostick @crunchip last edited by
      @crunchip
      Mea culpa, mein Fehler. Das „r“ war falsch. Sollte ein „u“ für uninstall sein.
        crunchip Forum Testing Most Active @Stabilostick last edited by crunchip
        @Stabilostick wenn man blind vertraut 😁
        bist du sicher mit dem "u"😂
        das klappt nicht
        root@IoBroker:/opt/iobroker# npm u epoll@0.1.22
        Usage: npm <command>
        where <command> is one of:
            access, adduser, audit, bin, bugs, c, cache, ci, cit,
            clean-install, clean-install-test, completion, config,
            create, ddp, dedupe, deprecate, dist-tag, docs, doctor,
            edit, explore, get, help, help-search, hook, i, init,
            install, install-ci-test, install-test, it, link, list, ln,
            login, logout, ls, org, outdated, owner, pack, ping, prefix,
            profile, prune, publish, rb, rebuild, repo, restart, root,
            run, run-script, s, se, search, set, shrinkwrap, star,
            stars, start, stop, t, team, test, token, tst, un,
            uninstall, unpublish, unstar, up, update, v, version, view,
            whoami
        npm <command> -h  quick help on <command>
        npm -l            display full usage info
        npm help <term>   search for help on <term>
        npm help npm      involved overview
        Specify configs in the ini-formatted file:
            /root/.npmrc
        or on the command line via: npm <command> --key value
        Config info can be viewed via: npm help config
        npm@6.9.0 /usr/lib/node_modules/npm
        man darf halt nicht immer so faul sein und manche Wörter einfach ausschreiben
        die Ausgabe
        root@IoBroker:/opt/iobroker# npm uninstall epoll@0.1.22
        > epoll@0.1.22 install /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build“ wird betreten
          CXX(target) Release/obj.target/epoll/src/epoll.o
        In file included from ../../nan/nan.h:192:0,
                         from ../src/epoll.cc:15:
        ../../nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
        ../../nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
           return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
        In file included from ../src/epoll.cc:15:0:
        ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
        ../../nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                 v8::Isolate::GetCurrent(), target, func, argc, argv);
        In file included from ../src/epoll.cc:12:0:
        /root/.node-gyp/10.16.0/include/node/node.h:177:50: note: declared here
                         NODE_EXTERN v8::Local<v8::Value> MakeCallback(
        /root/.node-gyp/10.16.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
             __attribute__((deprecated(message))) declarator
        ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
        ../../nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                 v8::Isolate::GetCurrent(), target, symbol, argc, argv);
        /root/.node-gyp/10.16.0/include/node/node.h:170:50: note: declared here
        ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
        ../../nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                 v8::Isolate::GetCurrent(), target, method, argc, argv);
        /root/.node-gyp/10.16.0/include/node/node.h:163:50: note: declared here
        ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
        ../../nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
        ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Add(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/epoll.cc:210:44: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           int err = epoll->Add(info[0]->Int32Value(), info[1]->Int32Value());
        In file included from /root/.node-gyp/10.16.0/include/node/v8.h:26:0,
                         from ../src/epoll.cc:11:
        /root/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
           V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
        /root/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../src/epoll.cc:210:67: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Modify(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/epoll.cc:230:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());
        ../src/epoll.cc:230:70: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/epoll.cc:247:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           int err = epoll->Remove(info[0]->Int32Value());
        epoll.target.mk:103: die Regel für Ziel „Release/obj.target/epoll/src/epoll.o“ scheiterte
        make: *** [Release/obj.target/epoll/src/epoll.o] Fehler 1
        make: Verzeichnis „/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build“ wird verlassen
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.9.0-9-amd64
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
        gyp ERR! node -v v10.16.0
        gyp ERR! node-gyp -v v3.8.0
        gyp ERR! not ok
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 (node_modules/rpi-gpio/node_modules/epoll):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 install: `node-gyp rebuild`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        audited 51142 packages in 67.966s
        found 141 vulnerabilities (73 low, 5 moderate, 63 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        • Mic
          Mic Developer @Stabilostick last edited by Mic
          @Stabilostick sagte in [How-to] Node.js für ioBroker richtig updaten:
          npm i acme-dns-01-cli
          Danke.
          Das Verzeichnis "/opt/iobroker/node_modules/acme-dns-01-cli/" existiert gar nicht. Nach Updaten durch "npm i acme-dns-01-cli" folgende Ausgabe:
          npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
          npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
          npm WARN root No description
          npm WARN root No repository field.
          npm WARN root No README data
          npm WARN root No license field.
          + acme-dns-01-cli@3.0.7
          updated 1 package and audited 643 packages in 2.32s
          found 0 vulnerabilities
          Auch danach wird das Verzeichnis "/opt/iobroker/node_modules/acme-dns-01-cli/" nicht erstellt.
          Stattdessen liegt das Verzeichnis hier: "/root/node_modules/acme-dns-01-cli", Inhalt:
          index.js
          LICENSE
          package.json
          README.md
          Stabilostick 2 Replies Last reply Reply Quote 0
          • Stabilostick
            Stabilostick @Mic last edited by Stabilostick
            @crunchip
            so, wieder am Rechner... Jetzt kann ich nachsehen. Also das aktuelle rpi-gpio Modul hat die folgenden Abhängigkeiten:
            "dependencies": {
               "async-retry": "^1.2.1",
               "debug": "^3.1.0",
               "epoll": "^2.0.3"
            Da ist ein Node 10-kompatibles epoll referenziert. Und so sieht es mit der Node 10-Kompatibilität von rpi-gpio allgemein aus (https://github.com/JamesBarwell/rpi-gpio.js) :
            rpi-gpio 1.x is no longer supported. Please use 2.x unless you need to run with an old version of node.
            node version 	rpi-gpio 1.x 	rpi-gpio 2.x +
            0.10 	 	Yes 	 	No
            0.12 	 	Yes 	 	No
            4 	 	Yes 	 	Yes
            6 	 	Yes 	 	Yes
            8 	 	Yes 	 	Yes
            10 	 	No 	 	Yes
            Falls der Auslöser für die Verwendung von rpi-gpio der rpi2-Adapter ist - der hat u.a. diese Abhängigkeit:
            "optionalDependencies": {
                "rpi-gpio": "^1.0.0"
            Das heißt, das Modul rpi-gpio kann auch in höheren Verionen als 1.0.0 für rpi2 eingesetzt werden.
            Mit
            npm ls rpi-gpio
            siehst Du, wo das Modul in welcher Version steckt. Was wird da angezeigt?
            PS: Der chicken-Way ist, sich die Einstellungen des rpi2-Adapter zu notieren, alles Instanzen und den Adapter zu löschen, und ihn anschließend neu zu installieren und zu konfigurieren. Da kommen dann die neuen Versionen der Module mit. 😋
            crunchip 1 Reply Last reply Reply Quote 1
            • Stabilostick
              @Mic sagte in [How-to] Node.js für ioBroker richtig updaten:
              Ah, Du bist einer welcher, der die Sicherheit seines Systems täglich aufs neue herausfordert, indem Du als root-User arbeitest. 😈
              Hattest Du das im ioBroker-Ordner (z.B. /opt/iobroker) ausgeführt?
              Wegen root-User: Versuche es ggf. einmal mit dem ioBroker-Fixer, der einige Berechtigungen und Einstellungen korrigiert:
              curl -sL https://iobroker.net/fix.sh | bash -
              Mic 1 Reply Last reply Reply Quote 1
                @Stabilostick
                root@IoBroker:/opt/iobroker# npm ls rpi-gpio
                iobroker.inst@2.0.3 /opt/iobroker
                └─┬ iobroker.rpi2@1.0.0
                 └── rpi-gpio@1.0.0
                dann wäre ja die einfachste Lösung, ich deinstalliere den Adapter, da er momentan nicht mehr in Gebrauch ist.
                Dieser war noch aus der Raspberry Zeit und Multihostbetrieb.
                Stabilostick smartboart S 3 Replies Last reply Reply Quote 0
                • Stabilostick
                  Stabilostick @crunchip last edited by Stabilostick
                  @crunchip
                  Ja.
                    @Stabilostick erledigt, dann bin ich mal gespannt, bei kommenden Updates/Installationen, ob diesbezüglich noch Fehlermeldungen/Warnungen auftauchen.
                    Besten Dank erstmal für die Ausführliche Info.
                    dann steht jetzt noch die Suche nach dem fast 3fachen Netzwerk Traffic aus.
                    kann aber ehrlich gesagt, nicht wirklich viel mit iftop anfangen.
                    werd ich mal ein wenig lesen und probieren
                      Interessanter Thread, den ich leider erst jetzt gesehen habe.
                      Hatte im Verlauf des letzten Jahres auch das Gefühl, den Überblick über die node.js und npm Versionen komplett verloren zu haben. Und ich hatte auch den Eindruck, daß einige Anfragen dazu unbeantwortet blieben, was auch aufgrund der Kombinatorik verständlich ist. Aber eine auf Dauer potentiell gefährliche Situation.
                      Den Ansatz mit getesteten und stimmigen Updatepakten bzw. Installern finde ich prima.
                      Der Windows-Installer hat mir schon sehr geholfen. Lief glatt durch und jetzt habe ich einen ioBroker auf einer leistungsfähigen, zeitgemäßen und ausbaufähigen Plattform.
                      Prima auch, wenn man damit künftig auf neuere funktionierende Pakete upgraden kann.
                      • O
                        Olivbus last edited by
                        Bei mir kommt am Ende nach dem Update auf Node 10.x und nmp rebuild diese Fehlermeldung. Der Iobroker läuft aber problemlos (alles grün). Besteht Handlungsbedarf? Ich würde mich über ein kurzes Statement freuen, weil ich noch ganz neu hier bin.
                        npm ERR! path /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/a        dapter-core/package.json
                        npm ERR! code ENOENT
                        npm ERR! errno -2
                        npm ERR! syscall open
                        npm ERR! enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modu        les/iobroker.admin/node_modules/@iobroker/adapter-core/package.json'
                        npm ERR! enoent This is related to npm not being able to find a file.
                        npm ERR! enoent
                        npm ERR!     /home/pi/.npm/_logs/2019-06-11T18_03_36_675Z-debug.log
                        • O
                          Olivbus @Olivbus last edited by Olivbus
                          @Olivbus Irgendwie wird nicht alles übernommen im Code, deshalb hier nochmal als Text
                          npm ERR! errno -2
                          npm ERR! enoent
                          O apollon77 2 Replies Last reply Reply Quote 0
                          • O
                            @Olivbus
                            Hier noch meine Systemdaten:
                            Betriebssystem:linux
                            Architektur:arm
                            CPUs:4
                            Geschwindigkeit:600 MHz
                            Modell:ARMv7 Processor rev 4 (v7l)
                            RAM:927.22 MB
                            Node.js: v10.16.0
                            NPM: 6.9.0
                            Anzahl der Adapter:243
                            Festplatte Größe:14.53 GB
                            Festplatte frei:12.09 GB
                            Aktive Instanzen:20
                            Hostname:ioBroker-RasPi
                            js controller: 1.5.11
                              apollon77 @crunchip last edited by
                              @crunchip komme auf dein Design an 😞
                                apollon77 @Olivbus last edited by
                                @Olivbus in dem Fall würde ich iobroker.admin mittels
                                npm install iobroker.admin --production
                                Im iobroker Verzeichnis einmal Neu installieren. Danach nochmal npm rebuild.
                                  crunchip Forum Testing Most Active @apollon77 last edited by
                                  @apollon77 ich weiss, nur ist leider keines dabei, das 100% zufriedenstellend ist und bei einem dunklem Design,
                                  ist halt nun mal das Problem, das irgendwas nicht lesbar ist.
                                  • MathiasJ
                                    MathiasJ last edited by
                                    Ich bin auch gerade dabei, node bzw nodejs upzudaten.
                                    da sich für mich alles recht kompliziert anhört, habe ich folgende Frage:
                                    Es ist doch möglich, erst mal den kompletten IObroker Ordner zu löschen, wie in der Erstinstallation nodejs und node zu deinstallieren.
                                    Danach würde ich wie bei der Doku https://www.iobroker.net/#de/documentation/install/linux.md IObroker neu aufsetzen inkl Backitup und das vorher gezogene Backup wieder einspielen. Sehe ich das richtig?
                                      apollon77 @MathiasJ last edited by
                                      @MathiasJ ließ doch mal die ersten beiden Posts. Da findest fundiere Idee als weg 3-5 oder so genau wieder. Steht alles da.
                                        Adnim last edited by
                                        Habe gerade von 8 zu 10 geupgraded. Hat alles geklappt dank der guten Anleitung hier. Danke!
                                        Nach dem Reboot gab es Fehlermeldungen im Iobroker Log : "MMMagic compiled against different Node version pls try npm rebuild.
                                        NPM rebuild hat aber nicht zum erfolg geführt. Geholfen hat dann:
                                        ->iobroker stop
                                        -> npm uninstall mmmagic
                                        ->iobroker del sql
                                        ->iobroker install sql
                                        ->reboot
                                        Danach läuft es anscheinend gerade wieder rund.
                                        LG
                                        • MathiasJ
                                          habe gerade IObroker platt gemacht und mit node 10.x neu installiert.
                                          Alle Adapter laufen außer tr-064.0 da bekomme ich immer Fehlermeldungen:
                                          host.rock64	2019-06-15 14:51:52.273	error	instance system.adapter.tr-064.0 terminated with code 1 ()
                                          host.rock64	2019-06-15 14:51:52.273	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
                                          host.rock64	2019-06-15 14:51:52.273	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
                                          host.rock64	2019-06-15 14:51:52.272	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:829:12)
                                          host.rock64	2019-06-15 14:51:52.272	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                          host.rock64	2019-06-15 14:51:52.272	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                          host.rock64	2019-06-15 14:51:52.272	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                          host.rock64	2019-06-15 14:51:52.272	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
                                          host.rock64	2019-06-15 14:51:52.272	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30)
                                          host.rock64	2019-06-15 14:51:52.271	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
                                          host.rock64	2019-06-15 14:51:52.271	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
                                          host.rock64	2019-06-15 14:51:52.271	error	Caught by controller[0]: TypeError: fns.adapter is not a function
                                          host.rock64	2019-06-15 14:51:52.271	error	Caught by controller[0]: ^
                                          host.rock64	2019-06-15 14:51:52.270	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
                                          host.rock64	2019-06-15 14:51:52.261	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
                                          was tun?
                                          Gruß,
                                          Mathias
                                          • dslraser
                                            dslraser Forum Testing Most Active @MathiasJ last edited by dslraser
                                            @MathiasJ
                                            https://forum.iobroker.net/topic/23116/tr-064-status-immer-rot/2
                                            MathiasJ 1 Reply Last reply Reply Quote 1
                                            1.0k
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            737584
