    4. Test Adapter lovelace v0.2.x
    • chmilli1
      chmilli1 last edited by Jey Cee
      Hallo !
      Ich bekomme Ihn nicht einmal installiert.....
      0 info it worked if it ends with ok
      1 verbose cli [ '/usr/bin/node',
      1 verbose cli   '/usr/bin/npm',
      1 verbose cli   'install',
      1 verbose cli   'https://www.home-assistant.io/lovelace/',
      1 verbose cli   '--production',
      1 verbose cli   '--save',
      1 verbose cli   '--prefix',
      1 verbose cli   '/opt/iobroker' ]
      2 info using npm@6.4.1
      3 info using node@v8.16.0
      4 verbose npm-session 675c4ef117ea92cb
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 http fetch GET 200 https://www.home-assistant.io/lovelace/ 55ms (from cache)
      8 silly fetchPackageMetaData error for https://www.home-assistant.io/lovelace/ Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
      9 timing stage:rollbackFailedOptional Completed in 1ms
      10 timing stage:runTopLevelLifecycles Completed in 6676ms
      11 verbose stack Error: Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
      11 verbose stack     at BB.join (/usr/lib/node_modules/npm/node_modules/pacote/lib/finalize-manifest.js:162:23)
      11 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
      11 verbose stack     at Holder$5._callFunction (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:14:44)
      11 verbose stack     at Holder$5.checkFulfillment (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:29:30)
      11 verbose stack     at Promise.eval (eval at thenCallback (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:14:16), <anonymous>:6:20)
      11 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:566:21)
      11 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
      11 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
      11 verbose stack     at Async._drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:133:16)
      11 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:143:10)
      11 verbose stack     at Immediate.Async.drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
      11 verbose stack     at runCallback (timers.js:810:20)
      11 verbose stack     at tryOnImmediate (timers.js:768:5)
      11 verbose stack     at processImmediate [as _immediateCallback] (timers.js:745:5)
      12 verbose cwd /
      13 verbose Linux 4.15.0-20-generic
      14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "https://www.home-assistant.io/lovelace/" "--production" "--save" "--prefix" "/opt/iobroker"
      15 verbose node v8.16.0
      16 verbose npm  v6.4.1
      17 error code ENOPACKAGEJSON
      18 error package.json Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
      19 error package.json npm can't find a package.json file in your current directory.
      20 verbose exit [ 1, true ]
      MOD Edit Jey Cee: Bitte Code und logs in code Tags packen
      thewhobox sigi234 2 Replies Last reply Reply Quote 0
      • thewhobox
        thewhobox @chmilli1 last edited by
        @chmilli1 Du benutzt den falschen Link.
        Das was du eingibst ist nicht der Github link sondern einfach nur die Infoseite von lovelance.
        https://github.com/ioBroker/ioBroker.lovelace
        Das ist der richtige.
          sigi234 Forum Testing Most Active @chmilli1 last edited by
          @chmilli1
          https://forum.iobroker.net/topic/23156/lovelace-in-iobroker-installieren/2
          • marcuskl
            marcuskl last edited by
            Bei mir werden einige Aufzählungen, z.B. Lampen die definiert sind in Aufzählungen nicht angezeigt?
            Nutze Material Ui, da sind sie alle vorhanden.
              sigi234 Forum Testing Most Active @marcuskl last edited by
              @marcuskl
              Raum und Funktion zugeordnet?
              • marcuskl
                Jap, habs sogar nochmal geprüft aber passt alles.
                Sonst würde es ja im Material Ui Adapter auch net gehen.
                  @marcuskl sagte in [Aufruf] Test lovelace Adapter:
                  der Adapter ist noch sehr neu, habe ich auch. Da musst du experimentieren. Vielleicht ist manches noch nicht implementiert.
                    Raducanu last edited by
                    So, hab mich die letzten Tage mit dem LoveLace Adapter beschäftigt und bin echt begeistert:
                    Die Übersicht welche Card was macht finde ich noch etwas schwirig, aber dort hilft die Home Assistant Seite gut weiter.
                    Eine Frage habe ich noch zum Screenshot im Einleitungspost:
                    https://forum.iobroker.net/assets/uploads/files/1559078898665-617ff2c4-59f2-4b49-8b2e-9cb7f030eafc-image.png
                    Welche Card ist das Rechts/Mitte "Heizung Schlafzimmer"?
                      mandragora last edited by
                      @ Bluefox.. vielen Dank 🙂 hat jetzt super funktioniert.
                        holgerwolf @Raducanu last edited by
                        @Raducanu Das ist die Thermostat Karte (type: 'custom:simple-thermostat')
                        sigi234 X 2 Replies Last reply Reply Quote 0
                          sigi234 Forum Testing Most Active @holgerwolf last edited by
                          @holgerwolf sagte in [Aufruf] Test lovelace Adapter:
                          Kannst du mal den Editor von der Karte zeigen, was hast du da drinnen?
                            holgerwolf @sigi234 last edited by holgerwolf
                            @sigi234 Nicht viel:
                            entity: climate.Thermostat_Hobby_1
                            Hätte gerne auch noch andere Parameter auf der Karte, aber die Anleitung gibt auch nix her.
                            Edit: Gerade noch die Infos hier gefunden:
                            https://github.com/nervetattoo/simple-thermostat
                              apollon77 @Gerni last edited by
                              @Gerni auch wenn off topic: hast du bei Material auf GitHub alle Infos zu den fehlenden Geräten mal in issues gepackt? Material ist vom Ansatz her so das Geräte erkannt werden können um dann sinnvoll dargestellt zu werden. Alles was also nicht erkannt werden kann bleibt im Zweifel unsichtbar.
                              Also: issues are your friend!!
                              • LausiD
                                LausiD last edited by
                                Super Sache!
                                Gerade etwas gespielt...wird der angezeigte Name immer aus Funktion und Raum generiert?
                                Bei Material UI wurde immer Name des Objekts angezeigt...
                                Danke und Gruß
                                LausiD
                                  holgerwolf @LausiD last edited by
                                  @LausiD Den Namen kannst du an mehreren Stellen ändern:
                                  • im Objekt im dem jeweiligen Setting für den Lovelace Adapter
                                  • in den Cardsetting gibt es oft ein Setting für den Namen
                                  • spätestens im Card Editor unter dem Eintrag für die Entity mit Name:“xyzzy“
                                  Holger
                                  LausiD 1 Reply Last reply Reply Quote 0
                                  • LausiD
                                    LausiD @holgerwolf last edited by
                                    @holgerwolf
                                    Vielen Dank für die Info.
                                    Wäre es nicht vielleicht sinnvoll den Namen aus dem Objekt als "Vorgabewert" zu übernehmen?
                                    Möchte ungern alle Namen händisch ändern 🙂
                                    LausiD
                                      Hat jemand eine Idee, wie ich einen State aus dem IOBroker richtig anzeigen kann.
                                      In IOBroker Objekt steht "states": { "1": "Unknown 1", "2": "Sleep no Charge", "3": "Sleep", "5": "Cleaning", "6": "Returning home", "7": "Manuell mode", "8": "Charging", "10": "Paused", "11": "Spot cleaning", "12": "Error?!", "16": "Going to Spot", "17": "Zone cleaning" },
                                      Im Lovelace wird aber z.b. nur "8" oder "5" usw
                                      • dontobi
                                        dontobi last edited by
                                        Hallo zusammen
                                        Ich wollte an dieser Stelle Mal meine Konfiguration präsentieren. Nur das Wetter Widget macht noch Probleme, aber das scheint ein Bug zu sein. Vielleicht suche ich mir dafür auch eine Custom Card, die funktioniert.
                                        Die Screenshots sind auf meinem Handy entstanden, am PC bzw. Tablet sieht das ganze etwas anders aus.
                                        Euch noch einen schönen Sonntag.
                                        coyote D 2 Replies Last reply Reply Quote 4
                                        • coyote
                                          coyote Most Active @dontobi last edited by
                                          @dontobi sieht sehr gut aus. Gibt es bei Lovelace eigentlich auch eine export Funktion wie in vis? Hab mich mit dem Adapter noch nicht wirklich beschäftigt, da wäre für den Anfang so ein Export ideal, um mal die Grundfunktionen anzuschauen
                                            holgerwolf @coyote last edited by
                                            @coyote Man kann einfach den Code im Editor kopieren und dann nach Belieben einsetzten und editieren.
                                            Das komplette Setup gibt es auch in einem RAW Editor (oben rechts).
                                            1.3k
                                            call for action lovelace test visualisierung
                                            131
                                            1051
                                            376329
