Tinkerboard / CPH Temperatur
top - 13:57:17 up 7 min, 1 user, load average: 0,59, 0,62, 0,34 Tasks: 139 total, 2 running, 80 sleeping, 0 stopped, 0 zombie %Cpu(s): 4,4 us, 4,2 sy, 0,0 ni, 91,3 id, 0,0 wa, 0,0 hi, 0,0 si, 0,0 st KiB Mem : 2050740 total, 946464 free, 679012 used, 425264 buff/cache KiB Swap: 1025360 total, 1025360 free, 0 used. 1303588 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1530 iobroker 20 0 192616 100616 21884 S 2,6 4,9 0:21.80 io.javascript.0 921 iobroker 20 0 177996 92900 20880 S 4,0 4,5 0:49.29 iobroker.js-con 2266 iobroker 20 0 140144 60792 21396 S 1,7 3,0 0:09.49 io.sql.0 1425 iobroker 20 0 154952 59112 20608 S 0,0 2,9 0:08.06 io.admin.0 1984 iobroker 20 0 144668 50444 20172 S 5,0 2,5 0:13.53 io.shelly.0 2281 iobroker 20 0 126668 46228 20636 S 2,6 2,3 0:07.83 io.info.0 2089 iobroker 20 0 119180 41824 20368 S 0,0 2,0 0:01.61 io.enigma2.1 3141 iobroker 20 0 138144 41804 20808 S 0,0 2,0 0:02.71 io.worx.0 1719 iobroker 20 0 134384 39956 20916 S 0,0 1,9 0:03.51 io.sonos.0 2947 iobroker 20 0 126140 39760 21476 S 0,3 1,9 0:04.38 io.radar2.0 1614 iobroker 20 0 120184 39612 20372 S 0,0 1,9 0:01.33 io.mqtt.0 1667 iobroker 20 0 127976 39596 20384 S 0,0 1,9 0:01.77 io.scenes.0 1904 iobroker 20 0 119704 39560 20336 S 0,0 1,9 0:01.20 io.backitup.0 2917 iobroker 20 0 130072 37168 20952 S 0,0 1,8 0:01.35 io.smartmeter.1 2035 iobroker 20 0 127884 36764 20368 S 0,3 1,8 0:03.71 io.enigma2.0 2719 iobroker 20 0 129480 36604 20952 S 0,0 1,8 0:01.32 io.smartmeter.0 1870 iobroker 20 0 126052 36420 20308 S 0,0 1,8 0:01.90 io.web.0 780 pi 20 0 128140 36268 22532 R 4,6 1,8 0:14.94 deCONZ 1770 iobroker 20 0 116264 35476 20152 S 0,0 1,7 0:01.11 io.text2command 1546 iobroker 20 0 116136 35192 20240 S 0,0 1,7 0:01.07 io.lgtv11.0 1464 iobroker 20 0 116152 35056 20192 S 0,0 1,7 0:01.14 io.geofency.0 2156 iobroker 20 0 119320 34816 21116 S 0,0 1,7 0:01.36 io.ble.0 1600 iobroker 20 0 117376 32552 20244 S 0,0 1,6 0:01.08 io.mihome.0 1515 iobroker 20 0 118256 30816 20108 S 0,0 1,5 0:01.63 io.history.0 782 root 20 0 98664 13712 11548 S 0,0 0,7 0:01.19 NetworkManager 1237 root 20 0 37556 5880 5220 S 0,0 0,3 0:00.05 polkitd 1 root 20 0 26508 5044 3836 S 0,0 0,2 0:04.19 systemd 1238 root 20 0 7876 4848 4356 S 0,0 0,2 0:00.13 wpa_supplicant 9108 root 20 0 9652 4760 4052 S 0,0 0,2 0:00.10 sshd 254 root 20 0 18916 4184 3760 S 0,0 0,2 0:01.15 systemd-journal 359 root 20 0 7204 4116 1060 S 0,0 0,2 0:01.44 haveged 998 root 20 0 8496 3992 3480 S 0,0 0,2 0:00.07 sshd 9271 root 20 0 7580 3896 3404 S 0,0 0,2 0:00.03 systemd 9358 root 20 0 7084 3668 2432 S 0,0 0,2 0:00.05 bash 708 root 20 0 6128 3492 3076 S 0,0 0,2 0:00.11 systemd-logind 1317 root 20 0 5864 3076 2788 S 0,0 0,1 0:00.02 bluetoothd 9580 root 20 0 8796 2956 2496 R 0,7 0,1 0:00.53 top 1246 root 20 0 5256 2908 2208 S 0,0 0,1 0:00.01 dhclient -
@LJSven
Das sieht schon anders aus, aber die CPU-Belastung ist gering. Die CPU-Temperatur sollte also niedriger sein. -
@paul53 sagte in Tinkerboard / CPH Temperatur:
@LJSven
Das sieht schon anders aus, aber die CPU-Belastung ist gering. Die CPU-Temperatur sollte also niedriger sein.Ich habe den ioBroker mal gestoppt - mal schauen, wie sich das dann verhält. Hast du sonst noch eine Idee? Config?
@paul53 Soll ich mal die transparente Oberteil mal annehmen und schauen, ob sich die Temperatur verändert? Habe das hier gelesen, soll ich das mal umstellen?
https://forum.iobroker.net/topic/8882/tinkerboard-all-in-one-mit-pivccu-cpu-taktung-zu-hoch/10
@LJSven sagte:
Ja, das würde ich auch als erstes machen.
@LJSven sagte in Tinkerboard / CPH Temperatur:
Aber wie ich bereits schrieb auch die Belüftung von unten optimieren
@Homoran Soll ich es mal Hochkant stellen, oder wie soll ich das „optimieren?“
@LJSven
Ich kenne das Gehäuse nicht.
Wenn das Board da direkt auf dem Boden liegt und keinerlei Lüftung vorhanden ist, bzw. Das Gehäuse auf dem Tisch liegt, so dass da keine Luft zirkulieren kann, kann es zu heiß werden.Ich habe meine SBC mit kleinen Distanzhülsen etwa 10 -15 mm über dem Boden und (fast) immer ohne Gehäuse
Kann ich an der armbian-config was ändern?
was willst du ändern?
der Prozessor langweilt sich.Hast du mal die Werte geloggt (Load/Mem/...) Frequency müsste bei armbian auch klappen
@Homoran sagte in Tinkerboard / CPH Temperatur:
Was meinst du damit genau? Das Temperaturproblem habe ich auch, wenn ioBroker gestoppt ist.
@LJSven Evtl. kann man die max. CPU-Freqenz absenken, z.B. auf 1200 MHz ? Aus der Armbian-Doku:
How to alter CPU frequency?
Some boards allow to adjust CPU speed.
nano /etc/default/cpufrequtils
Alter min_speed or max_speed variable.
service cpufrequtils restart
Interessant wäre auch mit welchem Governor das System läuft.Bei meinen Beiden Tinkern (einmal Armbian, einmal Tinker-OS - aber wer ist wer??) gibt es zwei:
ondemand ändert die Frequenz auf Bedarf (deswegn fragte ich ob diese geloggt wurde und ob sie vielleicht dauernd auf max. ist)
Conservative ist noch weniger belastend.
Auf keinen Fall sollte der Governor auf Performance stehen
@Homoran Es steht auf "ondemand" ->
Hallo, gestern abend habe ich es mal auf "schedulit" gestellt - dann geht die Temp. runter.
Heute Morgen habe ich wieder umgestellt auf "ondemand" - dann sieht es wie folgt aus:
Gibt es hier ein Update, was es vllt. besser macht?
Welcome to ARMBIAN 5.73 stable Debian GNU/Linux 9 (stretch) 4.19.41-rockchip
Im Moment gibt es:
Armbian Stretch
mainline based kernel 4.19.yIst also der neueste Kernel
Bei mir läuft noch 4.4.120
_____ _ _ _ _ |_ _(_)_ __ | | _____ _ __| |__ ___ __ _ _ __ __| | | | | | '_ \| |/ / _ \ '__| '_ \ / _ \ / _` | '__/ _` | | | | | | | | < __/ | | |_) | (_) | (_| | | | (_| | |_| |_|_| |_|_|\_\___|_| |_.__/ \___/ \__,_|_| \__,_| Welcome to ARMBIAN 5.73 stable Ubuntu 16.04.6 LTS 4.4.120-rockchip System load: 0.45 0.46 0.46 Up time: 145 days Memory usage: 41 % of 2010MB IP: 192.168.138.74 CPU temp: 39°C Usage of /: 20% of 58G@LJSven sagte in Tinkerboard / CPH Temperatur:
Hast du mal
apt update && apt upgradegemacht?@LJSven sagte in Tinkerboard / CPH Temperatur:
Und warum bleibst du dann nicht bei scheduled?
Hast du mal apt update && apt upgrade gemacht?
Wenn ich das mache, wird der Armbian aber nicht aktualisiert.
Welcome to ARMBIAN 5.73 stable Debian GNU/Linux 9 (stretch) 4.19.41-rockchip System load: 0.29 0.60 0.64 Up time: 1:17 hour Memory usage: 34 % of 2002MB IP: 192.168.178.161 CPU temp: 53°C Usage of /: 8% of 30G [ General system configuration (beta): armbian-config ] Last login: Sat Jun 22 09:58:26 2019 from 192.168.178.201 root@tinkerboardmaster:~# apt update && apt upgrade OK:1 http://security.debian.org stretch/updates InRelease OK:5 http://phoscon.de/apt/deconz stretch InRelease Ign:2 http://cdn-fastly.deb.debian.org/debian stretch InRelease OK:3 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease OK:4 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease OK:7 http://cdn-fastly.deb.debian.org/debian stretch Release OK:8 https://deb.nodesource.com/node_8.x stretch InRelease OK:6 https://apt.armbian.com stretch InRelease Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Alle Pakete sind aktuell. Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Paketaktualisierung (Upgrade) wird berechnet... Fertig 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. root@tinkerboardmaster:~#Stelle mir halt die Frage, warum er im "ondemand"-Modus nicht herunter fährt. Ausserdem ist meine Temp noch über 53° Grad - im Vergleich zu deiner Temp sehr warm.
@LJSven sagte:
Weil irgendein Prozess (ich vermute: deCONZ) ihn dazu veranlasst (on demand) "hoch zu takten" und die Zeitspanne zwischen zwei Anforderungen zu kurz ist, um wieder "runter zu takten". Beobachte mal mit top die CPU-Last der einzelnen Prozesse im "scheduled"-Modus, um den "Übeltäter" zu erkennen.
Okay, teste ich mal. Der USB Stick ist im Moment noch nicht am Tinker angeschlossen. Habe es „nur“ installiert.
