    4. Zigbee Update 0.11.1 keine Verbindung zu Geräten
    SOLVED Zigbee Update 0.11.1 keine Verbindung zu Geräten
      tilly last edited by tilly
      ich habe das Update Zigbee auf 0.11.1 gemacht, seitdem verbindet sich kein Gerät mehr mit dem Stick.
      Hier ein Ausschnitt aus dem Log.
      "6.1.0.18912" (You read the device Firmware version)
      zigbee.0	2019-06-21 12:04:30.502	info	16 (0x00158d00029ac603): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      zigbee.0	2019-06-21 12:04:30.501	info	15 (0x00158d0002ed88c1): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      zigbee.0	2019-06-21 12:04:30.500	info	14 (0x00158d0002411dcc): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
      zigbee.0	2019-06-21 12:04:30.499	info	13 (0x00158d00030acbe3): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0	2019-06-21 12:04:30.498	info	12 (0x00158d0002ad441a): JTYJ-GD-01LM/BW - Xiaomi MiJia Honeywell smoke detector (EndDevice)
      zigbee.0	2019-06-21 12:04:30.496	info	11 (0x00158d000309c28f): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2019-06-21 12:04:30.495	info	10 (0x8418260000001d88): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.494	info	9 (0x841826000000100b): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.492	info	8 (0x8418260000001ac6): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.491	info	7 (0x8418260000da5f57): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.489	info	6 (0x8418260000c9a2c0): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.487	info	5 (0x8418260000da5fd2): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.486	info	4 (0x8418260000da5475): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.485	info	3 (0x8418260000da46e4): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.482	info	2 (0x8418260000001c0c): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.475	info	1 (0x8418260000da5d60): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2019-06-21 12:04:30.321	info	Shepherd ready. {"state":"Coordinator","channel":"11","panId":6754,"extPanId":[221,221,221,221,221,221,221,221],"ieeeAddr":"0x00124b0018e1a2ea","nwkAddr":0}
      zigbee.0	2019-06-21 12:04:30.315	info	Zigbee-shepherd ready. Firmware version: 2.6.3 rev 20190109
      zigbee.0	2019-06-21 12:04:30.060	info	zigbee-shepherd started!
      zigbee.0	2019-06-21 12:04:17.343	info	Reset coordinator
      zigbee.0	2019-06-21 12:04:17.205	info	Queue is: true
      zigbee.0	2019-06-21 12:04:17.204	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1A2EA-if00 channel 11
      zigbee.0	2019-06-21 12:04:17.107	info	starting. Version 0.11.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.16.0
      Jemand eine Idee?
        tilly @ramses last edited by
        @ramses
        Hab gerade noch mal den Raspberry ein Update verpasst und jetzt haben sich die Geräte verbunden.
        Welche Version muss ich denn installieren?
          ramses last edited by ramses
          1. Das log sagt mal so garnichts aus. Hier wäre ein Debug log die richtige Wahl.
          2. Update mal die Firmware vom Stick. Das machts für die Zukunft einfacher weil du Updates des Sticks fahren kannst ohne neu anlernen zu müssen.
          Ich empfehle hierbei unbedingt die max_stable Firmware zu nehmen.
          Neu anlernen ist leider unvermeidbar.
          T arteck 2 Replies Last reply Reply Quote 0
            @ramses
              arteck Developer Most Active @tilly last edited by arteck
              @tilly lass es sein wenns läuft...alles gut. die Version 20190109 ist ok
                arteck Developer Most Active @ramses last edited by
                @ramses wenn du mit dem LOG nicht klar kommst dann lass die schlauen Ratschläge sein..
                  Leider haben sich nur die Sensoren verbunden, die Osram Lampen jedoch nicht.
                  Verstehe nicht ganz warum die sich nicht verbinden??
                  zigbee.0	2019-06-26 12:36:21.858	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:36:21.857	debug	Device 0x8418260000001d88 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:36:21.857	debug	Device 0x8418260000001d88 is not reachable
                  zigbee.0	2019-06-26 12:36:21.857	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:36:21.857	debug	Device 0x841826000000100b incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:36:21.856	debug	Device 0x841826000000100b is not reachable
                  zigbee.0	2019-06-26 12:36:21.856	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:36:21.856	debug	Device 0x8418260000001ac6 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:36:21.856	debug	Device 0x8418260000001ac6 is not reachable
                  zigbee.0	2019-06-26 12:36:21.855	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:36:21.855	debug	Device 0x8418260000da5f57 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:36:21.855	debug	Device 0x8418260000da5f57 is not reachable
                  zigbee.0	2019-06-26 12:36:21.855	debug	Device 0x8418260000c9a2c0 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:36:21.854	debug	Device 0x8418260000c9a2c0 is not reachable
                  zigbee.0	2019-06-26 12:36:21.854	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:36:21.854	debug	Device 0x8418260000da5fd2 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:36:21.854	debug	Device 0x8418260000da5fd2 is not reachable
                  zigbee.0	2019-06-26 12:36:21.853	debug	Device 0x8418260000da5475 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:36:21.853	debug	Device 0x8418260000da5475 is not reachable
                  zigbee.0	2019-06-26 12:36:21.853	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:36:21.853	debug	Device 0x8418260000da46e4 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:36:21.852	debug	Device 0x8418260000da46e4 is not reachable
                  zigbee.0	2019-06-26 12:36:21.852	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:36:21.852	debug	Device 0x8418260000001c0c incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:36:21.851	debug	Device 0x8418260000001c0c is not reachable
                  zigbee.0	2019-06-26 12:36:11.825	debug	Check online 0x8418260000001d88. 0x8418260000001d88
                  zigbee.0	2019-06-26 12:36:11.825	debug	Check online 0x841826000000100b. 0x841826000000100b
                  zigbee.0	2019-06-26 12:36:11.824	debug	Check online 0x8418260000001ac6. 0x8418260000001ac6
                  zigbee.0	2019-06-26 12:36:11.824	debug	Check online 0x8418260000da5f57. 0x8418260000da5f57
                  zigbee.0	2019-06-26 12:36:11.824	debug	Check online 0x8418260000c9a2c0. 0x8418260000c9a2c0
                  zigbee.0	2019-06-26 12:36:11.824	debug	Check online 0x8418260000da5fd2. 0x8418260000da5fd2
                  zigbee.0	2019-06-26 12:36:11.823	debug	Check online 0x8418260000da5475. 0x8418260000da5475
                  zigbee.0	2019-06-26 12:36:11.823	debug	Check online 0x8418260000da46e4. 0x8418260000da46e4
                  zigbee.0	2019-06-26 12:36:11.822	debug	Check online 0x8418260000001c0c. 0x8418260000001c0c
                  zigbee.0	2019-06-26 12:35:21.829	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:35:21.829	debug	Device 0x8418260000001d88 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:35:21.829	debug	Device 0x8418260000001d88 is not reachable
                  zigbee.0	2019-06-26 12:35:21.828	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:35:21.828	debug	Device 0x841826000000100b incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:35:21.828	debug	Device 0x841826000000100b is not reachable
                  zigbee.0	2019-06-26 12:35:21.827	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:35:21.827	debug	Device 0x8418260000001ac6 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:35:21.827	debug	Device 0x8418260000001ac6 is not reachable
                  zigbee.0	2019-06-26 12:35:21.826	debug	Device 0x8418260000da5f57 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:35:21.826	debug	Device 0x8418260000da5f57 is not reachable
                  zigbee.0	2019-06-26 12:35:21.826	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:35:21.826	debug	Device 0x8418260000c9a2c0 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:35:21.825	debug	Device 0x8418260000c9a2c0 is not reachable
                  zigbee.0	2019-06-26 12:35:21.825	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:35:21.825	debug	Device 0x8418260000da5fd2 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:35:21.825	debug	Device 0x8418260000da5fd2 is not reachable
                  zigbee.0	2019-06-26 12:35:21.824	debug	Device 0x8418260000da5475 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:35:21.824	debug	Device 0x8418260000da5475 is not reachable
                  zigbee.0	2019-06-26 12:35:21.824	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:35:21.824	debug	Device 0x8418260000da46e4 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:35:21.823	debug	Device 0x8418260000da46e4 is not reachable
                  zigbee.0	2019-06-26 12:35:21.823	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:35:21.823	debug	Device 0x8418260000001c0c incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:35:21.822	debug	Device 0x8418260000001c0c is not reachable
                  zigbee.0	2019-06-26 12:35:11.993	debug	Check online 0x8418260000001d88. 0x8418260000001d88
                  zigbee.0	2019-06-26 12:35:11.993	debug	Check online 0x841826000000100b. 0x841826000000100b
                  zigbee.0	2019-06-26 12:35:11.993	debug	Check online 0x8418260000001ac6. 0x8418260000001ac6
                  zigbee.0	2019-06-26 12:35:11.993	debug	Check online 0x8418260000da5f57. 0x8418260000da5f57
                  zigbee.0	2019-06-26 12:35:11.992	debug	Check online 0x8418260000c9a2c0. 0x8418260000c9a2c0
                  zigbee.0	2019-06-26 12:35:11.992	debug	Check online 0x8418260000da5fd2. 0x8418260000da5fd2
                  zigbee.0	2019-06-26 12:35:11.992	debug	Check online 0x8418260000da5475. 0x8418260000da5475
                  zigbee.0	2019-06-26 12:35:11.991	debug	Check online 0x8418260000da46e4. 0x8418260000da46e4
                  zigbee.0	2019-06-26 12:35:11.987	debug	Check online 0x8418260000001c0c. 0x8418260000001c0c
                  zigbee.0	2019-06-26 12:34:21.731	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:34:21.731	debug	Device 0x8418260000001d88 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:34:21.730	debug	Device 0x8418260000001d88 is not reachable
                  zigbee.0	2019-06-26 12:34:21.730	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:34:21.730	debug	Device 0x841826000000100b incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:34:21.730	debug	Device 0x841826000000100b is not reachable
                  zigbee.0	2019-06-26 12:34:21.730	debug	Device 0x8418260000001ac6 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:34:21.729	debug	Device 0x8418260000001ac6 is not reachable
                  zigbee.0	2019-06-26 12:34:21.729	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:34:21.729	debug	Device 0x8418260000da5f57 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:34:21.729	debug	Device 0x8418260000da5f57 is not reachable
                  zigbee.0	2019-06-26 12:34:21.729	debug	Device 0x8418260000c9a2c0 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:34:21.728	debug	Device 0x8418260000c9a2c0 is not reachable
                  zigbee.0	2019-06-26 12:34:21.728	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:34:21.728	debug	Device 0x8418260000da5fd2 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:34:21.728	debug	Device 0x8418260000da5fd2 is not reachable
                  zigbee.0	2019-06-26 12:34:21.728	debug	Device 0x8418260000da5475 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:34:21.727	debug	Device 0x8418260000da5475 is not reachable
                  zigbee.0	2019-06-26 12:34:21.727	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:34:21.727	debug	Device 0x8418260000da46e4 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:34:21.727	debug	Device 0x8418260000da46e4 is not reachable
                  zigbee.0	2019-06-26 12:34:21.727	debug	Device 0x8418260000001c0c incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:34:21.726	debug	Device 0x8418260000001c0c is not reachable
                  zigbee.0	2019-06-26 12:34:11.693	debug	Check online 0x8418260000001d88. 0x8418260000001d88
                  zigbee.0	2019-06-26 12:34:11.692	debug	Check online 0x841826000000100b. 0x841826000000100b
                  zigbee.0	2019-06-26 12:34:11.692	debug	Check online 0x8418260000001ac6. 0x8418260000001ac6
                  zigbee.0	2019-06-26 12:34:11.692	debug	Check online 0x8418260000da5f57. 0x8418260000da5f57
                  zigbee.0	2019-06-26 12:34:11.692	debug	Check online 0x8418260000c9a2c0. 0x8418260000c9a2c0
                  zigbee.0	2019-06-26 12:34:11.692	debug	Check online 0x8418260000da5fd2. 0x8418260000da5fd2
                  zigbee.0	2019-06-26 12:34:11.692	debug	Check online 0x8418260000da5475. 0x8418260000da5475
                  zigbee.0	2019-06-26 12:34:11.692	debug	Check online 0x8418260000da46e4. 0x8418260000da46e4
                  zigbee.0	2019-06-26 12:34:11.691	debug	Check online 0x8418260000001c0c. 0x8418260000001c0c
                  zigbee.0	2019-06-26 12:33:21.696	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:33:21.696	debug	Device 0x8418260000001d88 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:33:21.695	debug	Device 0x8418260000001d88 is not reachable
                  zigbee.0	2019-06-26 12:33:21.695	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:33:21.695	debug	Device 0x841826000000100b incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:33:21.695	debug	Device 0x841826000000100b is not reachable
                  zigbee.0	2019-06-26 12:33:21.695	debug	Device 0x8418260000001ac6 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:33:21.694	debug	Device 0x8418260000001ac6 is not reachable
                  zigbee.0	2019-06-26 12:33:21.694	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:33:21.694	debug	Device 0x8418260000da5f57 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:33:21.694	debug	Device 0x8418260000da5f57 is not reachable
                  zigbee.0	2019-06-26 12:33:21.694	debug	Device 0x8418260000c9a2c0 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:33:21.693	debug	Device 0x8418260000c9a2c0 is not reachable
                  zigbee.0	2019-06-26 12:33:21.693	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:33:21.693	debug	Device 0x8418260000da5fd2 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:33:21.693	debug	Device 0x8418260000da5fd2 is not reachable
                  zigbee.0	2019-06-26 12:33:21.693	debug	Device 0x8418260000da5475 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:33:21.692	debug	Device 0x8418260000da5475 is not reachable
                  zigbee.0	2019-06-26 12:33:21.692	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:33:21.692	debug	Device 0x8418260000da46e4 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:33:21.692	debug	Device 0x8418260000da46e4 is not reachable
                  zigbee.0	2019-06-26 12:33:21.692	debug	Device 0x8418260000001c0c incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:33:21.691	debug	Device 0x8418260000001c0c is not reachable
                  zigbee.0	2019-06-26 12:33:11.679	debug	Check online 0x8418260000001d88. 0x8418260000001d88
                  zigbee.0	2019-06-26 12:33:11.679	debug	Check online 0x841826000000100b. 0x841826000000100b
                  zigbee.0	2019-06-26 12:33:11.678	debug	Check online 0x8418260000001ac6. 0x8418260000001ac6
                  zigbee.0	2019-06-26 12:33:11.678	debug	Check online 0x8418260000da5f57. 0x8418260000da5f57
                  zigbee.0	2019-06-26 12:33:11.678	debug	Check online 0x8418260000c9a2c0. 0x8418260000c9a2c0
                  zigbee.0	2019-06-26 12:33:11.678	debug	Check online 0x8418260000da5fd2. 0x8418260000da5fd2
                  zigbee.0	2019-06-26 12:33:11.678	debug	Check online 0x8418260000da5475. 0x8418260000da5475
                  zigbee.0	2019-06-26 12:33:11.678	debug	Check online 0x8418260000da46e4. 0x8418260000da46e4
                  zigbee.0	2019-06-26 12:33:11.677	debug	Check online 0x8418260000001c0c. 0x8418260000001c0c
                  zigbee.0	2019-06-26 12:32:39.193	debug	Device 0x00158d000309c28f emit event devChange with data:{"cid":"genOnOff","data":{"onOff":0}}
                  zigbee.0	2019-06-26 12:32:39.192	debug	handleMessage. {"type":"devChange","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:32:39.192	debug	Publish {"contact":true,"linkquality":65}
                  zigbee.0	2019-06-26 12:32:39.192	debug	Device 0x00158d000309c28f emit event attReport with data:{"cid":"genOnOff","data":{"onOff":0}}
                  zigbee.0	2019-06-26 12:32:39.192	debug	handleMessage. {"type":"attReport","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:32:39.191	debug	Publish {"linkquality":65}
                  zigbee.0	2019-06-26 12:32:39.190	debug	Device 0x00158d000309c28f incoming event:{"groupid":0,"clusterid":6,"srcaddr":7924,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":65,"securityuse":0,"timestamp":3458586,"transseqnumber
                  zigbee.0	2019-06-26 12:32:35.522	debug	Device 0x00158d000309c28f emit event devChange with data:{"cid":"genOnOff","data":{"onOff":1}}
                  zigbee.0	2019-06-26 12:32:35.521	debug	handleMessage. {"type":"devChange","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:32:35.521	debug	Publish {"contact":false,"linkquality":63}
                  zigbee.0	2019-06-26 12:32:35.521	debug	Device 0x00158d000309c28f emit event attReport with data:{"cid":"genOnOff","data":{"onOff":1}}
                  zigbee.0	2019-06-26 12:32:35.521	debug	handleMessage. {"type":"attReport","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:32:35.520	debug	Publish {"linkquality":63}
                  zigbee.0	2019-06-26 12:32:35.519	debug	Device 0x00158d000309c28f incoming event:{"groupid":0,"clusterid":6,"srcaddr":7924,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":63,"securityuse":0,"timestamp":3447178,"transseqnumber
                  zigbee.0	2019-06-26 12:32:34.381	debug	Device 0x00158d000309c28f emit event devChange with data:{"cid":"genOnOff","data":{"onOff":0}}
                  zigbee.0	2019-06-26 12:32:34.381	debug	handleMessage. {"type":"devChange","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:32:34.381	debug	Publish {"contact":true,"linkquality":73}
                  zigbee.0	2019-06-26 12:32:34.381	debug	Device 0x00158d000309c28f emit event attReport with data:{"cid":"genOnOff","data":{"onOff":0}}
                  zigbee.0	2019-06-26 12:32:34.380	debug	handleMessage. {"type":"attReport","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:32:34.380	debug	Publish {"linkquality":73}
                  zigbee.0	2019-06-26 12:32:34.379	debug	Device 0x00158d000309c28f incoming event:{"groupid":0,"clusterid":6,"srcaddr":7924,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":73,"securityuse":0,"timestamp":3443527,"transseqnumber
                  zigbee.0	2019-06-26 12:32:28.240	debug	Device 0x00158d000309c28f emit event devChange with data:{"cid":"genOnOff","data":{"onOff":1}}
                  zigbee.0	2019-06-26 12:32:28.240	debug	handleMessage. {"type":"devChange","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:32:28.240	debug	Publish {"contact":false,"linkquality":63}
                  zigbee.0	2019-06-26 12:32:28.240	debug	Device 0x00158d000309c28f emit event attReport with data:{"cid":"genOnOff","data":{"onOff":1}}
                  zigbee.0	2019-06-26 12:32:28.239	debug	handleMessage. {"type":"attReport","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:32:28.239	debug	Publish {"linkquality":63}
                  zigbee.0	2019-06-26 12:32:28.238	debug	Device 0x00158d000309c28f incoming event:{"groupid":0,"clusterid":6,"srcaddr":7924,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":63,"securityuse":0,"timestamp":3424423,"transseqnumber
                  zigbee.0	2019-06-26 12:32:21.679	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:32:21.679	debug	Device 0x8418260000001d88 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:32:21.679	debug	Device 0x8418260000001d88 is not reachable
                  zigbee.0	2019-06-26 12:32:21.679	debug	Device 0x841826000000100b incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:32:21.679	debug	Device 0x841826000000100b is not reachable
                  zigbee.0	2019-06-26 12:32:21.678	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:32:21.678	debug	Device 0x8418260000001ac6 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:32:21.678	debug	Device 0x8418260000001ac6 is not reachable
                  zigbee.0	2019-06-26 12:32:21.677	debug	Device 0x8418260000da5f57 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:32:21.677	debug	Device 0x8418260000da5f57 is not reachable
                  zigbee.0	2019-06-26 12:32:21.677	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:32:21.677	debug	Device 0x8418260000c9a2c0 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:32:21.677	debug	Device 0x8418260000c9a2c0 is not reachable
                  zigbee.0	2019-06-26 12:32:21.676	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:32:21.676	debug	Device 0x8418260000da5fd2 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:32:21.676	debug	Device 0x8418260000da5fd2 is not reachable
                  zigbee.0	2019-06-26 12:32:21.676	debug	Device 0x8418260000da5475 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:32:21.676	debug	Device 0x8418260000da5475 is not reachable
                  zigbee.0	2019-06-26 12:32:21.675	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:32:21.675	debug	Device 0x8418260000da46e4 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:32:21.675	debug	Device 0x8418260000da46e4 is not reachable
                  zigbee.0	2019-06-26 12:32:21.674	debug	Device 0x8418260000001c0c incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:32:21.673	debug	Device 0x8418260000001c0c is not reachable
                  zigbee.0	2019-06-26 12:32:11.641	debug	Check online 0x8418260000001d88. 0x8418260000001d88
                  zigbee.0	2019-06-26 12:32:11.641	debug	Check online 0x841826000000100b. 0x841826000000100b
                  zigbee.0	2019-06-26 12:32:11.641	debug	Check online 0x8418260000001ac6. 0x8418260000001ac6
                  zigbee.0	2019-06-26 12:32:11.640	debug	Check online 0x8418260000da5f57. 0x8418260000da5f57
                  zigbee.0	2019-06-26 12:32:11.640	debug	Check online 0x8418260000c9a2c0. 0x8418260000c9a2c0
                  zigbee.0	2019-06-26 12:32:11.640	debug	Check online 0x8418260000da5fd2. 0x8418260000da5fd2
                  zigbee.0	2019-06-26 12:32:11.640	debug	Check online 0x8418260000da5475. 0x8418260000da5475
                  zigbee.0	2019-06-26 12:32:11.640	debug	Check online 0x8418260000da46e4. 0x8418260000da46e4
                  zigbee.0	2019-06-26 12:32:11.639	debug	Check online 0x8418260000001c0c. 0x8418260000001c0c
                  zigbee.0	2019-06-26 12:31:21.632	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:31:21.631	debug	Device 0x8418260000001d88 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:31:21.631	debug	Device 0x8418260000001d88 is not reachable
                  zigbee.0	2019-06-26 12:31:21.631	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:31:21.631	debug	Device 0x841826000000100b incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:31:21.631	debug	Device 0x841826000000100b is not reachable
                  zigbee.0	2019-06-26 12:31:21.630	debug	Device 0x8418260000001ac6 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:31:21.630	debug	Device 0x8418260000001ac6 is not reachable
                  zigbee.0	2019-06-26 12:31:21.630	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:31:21.630	debug	Device 0x8418260000da5f57 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:31:21.630	debug	Device 0x8418260000da5f57 is not reachable
                  zigbee.0	2019-06-26 12:31:21.629	debug	Device 0x8418260000c9a2c0 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:31:21.629	debug	Device 0x8418260000c9a2c0 is not reachable
                  zigbee.0	2019-06-26 12:31:21.629	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:31:21.629	debug	Device 0x8418260000da5fd2 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:31:21.629	debug	Device 0x8418260000da5fd2 is not reachable
                  zigbee.0	2019-06-26 12:31:21.628	debug	Device 0x8418260000da5475 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:31:21.628	debug	Device 0x8418260000da5475 is not reachable
                  zigbee.0	2019-06-26 12:31:21.628	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:31:21.628	debug	Device 0x8418260000da46e4 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:31:21.627	debug	Device 0x8418260000da46e4 is not reachable
                  zigbee.0	2019-06-26 12:31:21.627	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:31:21.627	debug	Device 0x8418260000001c0c incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:31:21.626	debug	Device 0x8418260000001c0c is not reachable
                  zigbee.0	2019-06-26 12:31:11.574	debug	Check online 0x8418260000001d88. 0x8418260000001d88
                  zigbee.0	2019-06-26 12:31:11.574	debug	Check online 0x841826000000100b. 0x841826000000100b
                  zigbee.0	2019-06-26 12:31:11.574	debug	Check online 0x8418260000001ac6. 0x8418260000001ac6
                  zigbee.0	2019-06-26 12:31:11.573	debug	Check online 0x8418260000da5f57. 0x8418260000da5f57
                  zigbee.0	2019-06-26 12:31:11.573	debug	Check online 0x8418260000c9a2c0. 0x8418260000c9a2c0
                  zigbee.0	2019-06-26 12:31:11.573	debug	Check online 0x8418260000da5fd2. 0x8418260000da5fd2
                  zigbee.0	2019-06-26 12:31:11.573	debug	Check online 0x8418260000da5475. 0x8418260000da5475
                  zigbee.0	2019-06-26 12:31:11.573	debug	Check online 0x8418260000da46e4. 0x8418260000da46e4
                  zigbee.0	2019-06-26 12:31:11.572	debug	Check online 0x8418260000001c0c. 0x8418260000001c0c
                  zigbee.0	2019-06-26 12:31:06.885	debug	Device 0x00158d000309c28f emit event devChange with data:{"cid":"genOnOff","data":{"onOff":0}}
                  zigbee.0	2019-06-26 12:31:06.885	debug	handleMessage. {"type":"devChange","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:31:06.885	debug	Publish {"contact":true,"linkquality":68}
                  zigbee.0	2019-06-26 12:31:06.885	debug	Device 0x00158d000309c28f emit event attReport with data:{"cid":"genOnOff","data":{"onOff":0}}
                  zigbee.0	2019-06-26 12:31:06.884	debug	handleMessage. {"type":"attReport","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:31:06.884	debug	Publish {"linkquality":68}
                  zigbee.0	2019-06-26 12:31:06.883	debug	Device 0x00158d000309c28f incoming event:{"groupid":0,"clusterid":6,"srcaddr":7924,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":68,"securityuse":0,"timestamp":3170219,"transseqnumber
                  zigbee.0	2019-06-26 12:31:01.681	debug	Device 0x00158d000309c28f emit event devChange with data:{"cid":"genOnOff","data":{"onOff":1}}
                  zigbee.0	2019-06-26 12:31:01.681	debug	handleMessage. {"type":"devChange","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:31:01.681	debug	Publish {"contact":false,"linkquality":68}
                  zigbee.0	2019-06-26 12:31:01.681	debug	Device 0x00158d000309c28f emit event attReport with data:{"cid":"genOnOff","data":{"onOff":1}}
                  zigbee.0	2019-06-26 12:31:01.680	debug	handleMessage. {"type":"attReport","endpoints":[{"device":{"_id":12,"type":"EndDevice","ieeeAddr":"0x00158d000309c28f","nwkAddr":7924,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId
                  zigbee.0	2019-06-26 12:31:01.680	debug	Publish {"linkquality":68}
                  zigbee.0	2019-06-26 12:31:01.679	debug	Device 0x00158d000309c28f incoming event:{"groupid":0,"clusterid":6,"srcaddr":7924,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":68,"securityuse":0,"timestamp":3153883,"transseqnumber
                  zigbee.0	2019-06-26 12:30:21.591	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:30:21.591	debug	Device 0x8418260000001d88 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:30:21.591	debug	Device 0x8418260000001d88 is not reachable
                  zigbee.0	2019-06-26 12:30:21.590	debug	Device 0x841826000000100b incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:30:21.590	debug	Device 0x841826000000100b is not reachable
                  zigbee.0	2019-06-26 12:30:21.590	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:30:21.590	debug	Device 0x8418260000001ac6 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:30:21.590	debug	Device 0x8418260000001ac6 is not reachable
                  zigbee.0	2019-06-26 12:30:21.589	debug	Device 0x8418260000da5f57 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:30:21.589	debug	Device 0x8418260000da5f57 is not reachable
                  zigbee.0	2019-06-26 12:30:21.589	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:30:21.589	debug	Device 0x8418260000c9a2c0 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:30:21.589	debug	Device 0x8418260000c9a2c0 is not reachable
                  zigbee.0	2019-06-26 12:30:21.588	debug	Device 0x8418260000da5fd2 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:30:21.588	debug	Device 0x8418260000da5fd2 is not reachable
                  zigbee.0	2019-06-26 12:30:21.588	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:30:21.588	debug	Device 0x8418260000da5475 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:30:21.588	debug	Device 0x8418260000da5475 is not reachable
                  zigbee.0	2019-06-26 12:30:21.587	debug	Publish {"available":false}
                  zigbee.0	2019-06-26 12:30:21.587	debug	Device 0x8418260000da46e4 incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:30:21.587	debug	Device 0x8418260000da46e4 is not reachable
                  zigbee.0	2019-06-26 12:30:21.587	debug	Device 0x8418260000001c0c incoming event:{"available":false}
                  zigbee.0	2019-06-26 12:30:21.586	debug	Device 0x8418260000001c0c is not reachable
                    bei mir dauert es so 5 min bis alle Devices da sind
                      Nein auch über Tage verbinden sich die Lampen nicht.
                      Ein Neustart dauert ca. 30s und die Sensoren sind verbunden, die Lampen nicht.
                        @tilly dann wird das nix.. musst neu pairen.. dann ach aber das D ieder rein.. so das du direkt auf die richtige Schlüssellänge kommst
                          tilly @arteck last edited by
                          @arteck was meinst du?
                            Ich hab den Adapter einmal deinstalliert, Raspberry neu gestartet und Zigbee 0.11.1 erneut installiert.
                            Die Geräte sind alle wieder vorhanden, aber verbinden sich nicht.
                            Was kann man machen? Alle Geräte löschen und neu pairen?
                              @tilly ja währe am einfachsten
                              cc2531 zigbee
                              733
