    4. 0.6.5 installation
    0.6.5 installation
    • Bluefox
      Bluefox last edited by
      @susouke:
      Ja genau so habe ich es gemacht inkl. das mit root.
      Admin-Seite geht ohne Probleme darüber wollte ich dan vis installieren, das ist die Ausgabe:
      ! $ ./iobroker add vis
      ! install adapter vis
      ! npm install –production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
      ! npm
      ! WARN cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
      ! got /opt/iobroker/node_modules/iobroker.vis/admin
      ! upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
      ! upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
      ! ERROR:
      ! ERROR: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
      ! ERROR: console.warn('Adapter "' + obj._id + ' is disabled ^
      ! ERROR: TypeError: Cannot read property '_id' of null at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
      ! at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
      ! at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
      ! at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      ! at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      ! at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
      ! at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      ! at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      ! at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
      ! at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
      ! ERROR: process exited with code 8</anonymous></anonymous></anonymous>
      Das gleiche steht natürlich auch im normalen log.
      Ich kann schauen ob in der Konsole noch was kommt… `
      Es ist folgendes. Normalerweise ist vis "enabled". Bei dir es ist disabled. (Kann das sein?)
      Du kannst trotzdem einfach vis updaten mit:
      cd /opt/iobroker
      npm install iobroker.vis --production
        susouke last edited by
        VIS ist nicht enabled, es wird als installiert angezeigt in der Adapterliste (zumindest ist die Mülltonne zum entfernen da).
        Es taucht aber nicht in der Instanzliste auf. Hab schon mehrfach ein update gemacht und auch nochmal neu installiert.
        • Bluefox
          @susouke:
          Es taucht aber nicht in der Instanzliste auf. Hab schon mehrfach ein update gemacht und auch nochmal neu installiert. `
          Mülltonne zeigt, dass Adapter auf der Festplatte ist und mit der Mülltonne kann man den von der Festplatte löschen.
          Instanz braucht man trotzdem.
            Es taucht solange nicht in der Instanzenliste auf, bis du es zugefügt hast.
            Im Reiter Adapter auf das + ganz rechts klicken, oder in der Konsole mit
            cd /opt/iobroker
            ./iobroker add vis
            Rainer
              Pman last edited by
              Der selbe Fehler kommt ja, wenn ich vis garnicht installiert habe (Verzeichnis iobroker.vis existiert auch nicht), nicht beim Update. Das Log im ersten Post ist bei der Installation von vis, nicht beim update.
                Also auf der Konsole bekomme ich den gleichen Fehler wie über die Admin-UI.
                ! root@raspberrypi:/opt/iobroker# cd /opt/iobroker
                ! root@raspberrypi:/opt/iobroker# ./iobroker add vis
                ! npm install iobroker.vis –production --prefix "/opt/iobroker" (System call)
                ! npm http GET https://registry.npmjs.org/iobroker.vis
                ! npm http 304 https://registry.npmjs.org/iobroker.vis
                ! 2015-07-26 17:43:14.488 - error: vis.0
                ! 2015-07-26 17:43:14.490 - error: vis.0 /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                ! 2015-07-26 17:43:14.494 - error: vis.0 console.warn('Adapter "' + obj._id + ' is disabled ^
                ! 2015-07-26 17:43:14.584 - error: vis.0 TypeError: Cannot read property '_id' of null at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                ! npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
                ! npm WARN cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
                ! /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                ! console.warn('Adapter "' + obj._id + ' is disabled
                ! TypeError: Cannot read property '_id' of null
                ! at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                ! root@raspberrypi:/opt/iobroker#</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                • Bluefox
                  @susouke:
                  ! root@raspberrypi:/opt/iobroker#</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous> `
                  Kannst du aktuellste (nicht offizielle) js-controller Version installieren:
                  cd /opt/iobroker
                  iobroker stop
                  npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
                  iobroker start
                    Das werde ich gleich mal testen.
                    Also folgendes habe ich mal probiert:
                    In Zeile 2332 der /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js habe ich das hier auskommentiert:
                    console.warn('Adapter "' + obj._id + ' is disabled and cannot be restarted.');
                    Neustart von iobroker und danach konnte ich vis ohne Fehler installieren. Leider habe ich keine Zeit tiefer reinzugehen,
                    ich denke den Code verstehst du wesentlich besser als ich 😄
                      Wenn ich das richtig sehe hast du die Ölkontroll-Leuchte herausgeschraubt, statt Öl nachzufüllen 😉
                      Was mich nur wundert, dass es jetzt läuft.
                      Rainer
                        Pman last edited by
                        Die Änderung von Bluefox setzt ja genau an der Zeile an 😉 .
                        Ich teste mal ob bei mir der Github code geht. Bleibt die Frage wodurch die Warnung überhaupt ausgelöst wird?!
                          @Homoran:
                          Wenn ich das richtig sehe hast du die Ölkontroll-Leuchte herausgeschraubt, statt Öl nachzufüllen 😉 `
                          Da hast du Recht, aber so startet der "Motor" wenigstens 😄 War ja nur ein Test.
                          @Bluefox:
                          @susouke:
                          Kannst du aktuellste (nicht offizielle) js-controller Version installieren?
                          Perfekt! Das scheint zu laufen. Danke Bluefox für den wirklich schnellen Hotfix!
                            Pman last edited by
                            Bei mir auch, die error Meldung kommt natürlich trotzdem während der Installation, läuft danach aber sauber durch.
                            4266_55pus727212.txt
                            • derAuge
                              derAuge last edited by
                              Beim versuch VIS zu installieren
                              iobroker	2015-07-27 08:02:51	info	exit 8
                              iobroker	2015-07-27 08:02:51	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
                              iobroker	2015-07-27 08:02:51	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                              iobroker	2015-07-27 08:02:51	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                              iobroker	2015-07-27 08:02:51	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                              iobroker	2015-07-27 08:02:51	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
                              iobroker	2015-07-27 08:02:51	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                              iobroker	2015-07-27 08:02:51	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                              iobroker	2015-07-27 08:02:51	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
                              iobroker	2015-07-27 08:02:51	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                              iobroker	2015-07-27 08:02:51	error	TypeError: Cannot read property '_id' of null at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                              iobroker	2015-07-27 08:02:51	error	console.warn('Adapter "' + obj._id + ' is disabled ^
                              iobroker	2015-07-27 08:02:51	error	/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                              iobroker	2015-07-27 08:02:50	info	upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                              iobroker	2015-07-27 08:02:50	info	upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                              iobroker	2015-07-27 08:02:50	info	got /opt/iobroker/node_modules/iobroker.vis/admin
                              iobroker	2015-07-27 08:02:50	info	cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
                              iobroker	2015-07-27 08:02:50	info	WARN
                              iobroker	2015-07-27 08:02:50	info	npm
                              iobroker	2015-07-27 08:02:47	info	npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
                              iobroker	2015-07-27 08:02:47	info	install adapter vis
                              vis-0	2015-07-27 08:02:21	info	Uploaded.
                              vis-0	2015-07-27 08:02:21	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
                              vis-0	2015-07-27 08:02:21	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                              vis-0	2015-07-27 08:02:21	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                              vis-0	2015-07-27 08:02:21	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                              vis-0	2015-07-27 08:02:21	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
                              vis-0	2015-07-27 08:02:21	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                              vis-0	2015-07-27 08:02:21	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                              vis-0	2015-07-27 08:02:21	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
                              vis-0	2015-07-27 08:02:21	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                              vis-0	2015-07-27 08:02:21	error	TypeError: Cannot read property '_id' of null at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                              vis-0	2015-07-27 08:02:21	error	^
                              vis-0	2015-07-27 08:02:21	error	console.warn('Adapter "' + obj._id + ' is disabled
                              iobroker	2015-07-27 08:02:21	info	2015-07-27 08:02:21.409 - error: vis.0 ^
                              iobroker	2015-07-27 08:02:21	info	2015-07-27 08:02:21.404 - error: vis.0 /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:22752015-07-27 08:02:21.407 - error: vis.0 console.warn('Adapter "'
                              iobroker	2015-07-27 08:02:21	info	2015-07-27 08:02:21.401 - error: vis.0
                              vis-0	2015-07-27 08:02:21	error	/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                              vis-0	2015-07-27 08:02:19	info	Upload vis anew, while changes detected...
                              vis-0	2015-07-27 08:02:19	info	Changes in index.html detected => update cache.manifest
                              vis-0	2015-07-27 08:02:19	info	starting. Version 0.6.5 in /opt/iobroker/node_modules/iobroker.vis
                              iobroker	2015-07-27 08:01:51	info	npm install iobroker.vis --production --prefix "/opt/iobroker" (System call)
                              iobroker	2015-07-27 08:01:49	info	add vis
                              was läuft falsch?
                              Jürgen
                                Hast du den post von Bluefox gelesen?
                                http://www.forum.iobroker.org/viewtopic … 8675#p8648
                                Rainer
                                • derAuge
                                  @Homoran:
                                  Rainer `
                                  habe ich auch getestet und danach noch mal versucht
                                  • root@Pi2-3:/opt/iobroker# npm install iobroker.vis –production
                                  > iobroker.vis@0.6.5 install /opt/iobroker/node_modules/iobroker.vis
                                  2015-07-27 08:14:15.697 - info: vis.0 starting. Version 0.6.5 in /opt/iobroker/node_modules/iobroker.vis
                                  2015-07-27 08:14:15.940 - info: vis.0 Changes in index.html detected => update cache.manifest
                                  2015-07-27 08:14:15.961 - info: vis.0 Upload vis anew, while changes detected...
                                  2015-07-27 08:14:17.743 - error: vis.0 Adapter " is disabled and cannot be restarted.
                                  2015-07-27 08:14:25.394 - info: vis.0 100 files uploaded...
                                  2015-07-27 08:14:39.959 - info: vis.0 200 files uploaded...
                                  2015-07-27 08:14:52.987 - info: vis.0 300 files uploaded...
                                  2015-07-27 08:14:54.749 - info: vis.0 Uploaded.
                                  iobroker.vis@0.6.5 node_modules/iobroker.vis
                                  Jürgen
                                    Hallo Jürgen,
                                    ich sehe gerade, dass ich noch die 0.6.4 habe, also mein post von oben so auch nicht korrekt ist 😞
                                    @derAuge:
                                    root@Pi2-3:/opt/iobroker# npm install iobroker.vis –production `
                                    damit überschreibst du aber wieder die noch nicht freigegebenen Korrekturen aus github!
                                    Ich werde mir jetzt auch mein vis zerschießen 😉
                                    Rainer
                                      Ich trau mich gar nicht es zu sagen:
                                      Mein Update nach 0.6.5 hat einwandfrei geklappt
                                      Allerdings lässt sich der Editor immer noch nicht über das x schließen.
                                      Rainer
                                      PS habt ihr eigentlich alle Apple-OS, die das Problem haben?
                                        Arminhh last edited by
                                        Hallo Homoran,
                                        ich habe OSX wo das speichern nicht funktioniert und der Schließen Button!
                                          Hallo Armin,
                                          Hier in dem Thread geht es um die Probleme bei der Installation.
                                          Das Problem mit dem Speichern (welches vielleicht nur ein Problem der Falschmeldung ist) und des Close-Buttons haben mehrere (alle??)
                                          Soll das Heißen, du hast mit OSX erfolgreich auf 0.6.5 updaten können?
                                          Rainer
                                          • coyote
                                            coyote Most Active last edited by
                                            Hatte auch keine Probleme auf 0.6.5 zu updaten
                                            1.0k
                                            41
                                            6368
