    4. 0.6.5 installation
    0.6.5 installation
      susouke last edited by
      Also auf der Konsole bekomme ich den gleichen Fehler wie über die Admin-UI.
      ! root@raspberrypi:/opt/iobroker# cd /opt/iobroker
      ! root@raspberrypi:/opt/iobroker# ./iobroker add vis
      ! npm install iobroker.vis –production --prefix "/opt/iobroker" (System call)
      ! npm http GET https://registry.npmjs.org/iobroker.vis
      ! npm http 304 https://registry.npmjs.org/iobroker.vis
      ! 2015-07-26 17:43:14.488 - error: vis.0
      ! 2015-07-26 17:43:14.490 - error: vis.0 /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
      ! 2015-07-26 17:43:14.494 - error: vis.0 console.warn('Adapter "' + obj._id + ' is disabled ^
      ! 2015-07-26 17:43:14.584 - error: vis.0 TypeError: Cannot read property '_id' of null at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
      ! at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
      ! at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
      ! at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      ! at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      ! at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
      ! at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      ! at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      ! at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
      ! at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
      ! install adapter vis
      ! npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
      ! npm WARN cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
      ! got /opt/iobroker/node_modules/iobroker.vis/admin
      ! upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
      ! upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
      ! /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
      ! console.warn('Adapter "' + obj._id + ' is disabled
      ! TypeError: Cannot read property '_id' of null
      ! at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
      ! root@raspberrypi:/opt/iobroker#</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
      • Bluefox
        Bluefox last edited by
        @susouke:
        ! root@raspberrypi:/opt/iobroker#</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous> `
        Kannst du aktuellste (nicht offizielle) js-controller Version installieren:
        cd /opt/iobroker
        iobroker stop
        npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
        iobroker start
          Das werde ich gleich mal testen.
          Also folgendes habe ich mal probiert:
          In Zeile 2332 der /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js habe ich das hier auskommentiert:
          console.warn('Adapter "' + obj._id + ' is disabled and cannot be restarted.');
          Neustart von iobroker und danach konnte ich vis ohne Fehler installieren. Leider habe ich keine Zeit tiefer reinzugehen,
          ich denke den Code verstehst du wesentlich besser als ich 😄
            Wenn ich das richtig sehe hast du die Ölkontroll-Leuchte herausgeschraubt, statt Öl nachzufüllen 😉
            Was mich nur wundert, dass es jetzt läuft.
            Rainer
              Pman last edited by
              Die Änderung von Bluefox setzt ja genau an der Zeile an 😉 .
              Ich teste mal ob bei mir der Github code geht. Bleibt die Frage wodurch die Warnung überhaupt ausgelöst wird?!
                @Homoran:
                Wenn ich das richtig sehe hast du die Ölkontroll-Leuchte herausgeschraubt, statt Öl nachzufüllen 😉 `
                Da hast du Recht, aber so startet der "Motor" wenigstens 😄 War ja nur ein Test.
                @Bluefox:
                @susouke:
                Kannst du aktuellste (nicht offizielle) js-controller Version installieren?
                Perfekt! Das scheint zu laufen. Danke Bluefox für den wirklich schnellen Hotfix!
                  Pman last edited by
                  Bei mir auch, die error Meldung kommt natürlich trotzdem während der Installation, läuft danach aber sauber durch.
                  4266_55pus727212.txt
                  • derAuge
                    derAuge last edited by
                    Beim versuch VIS zu installieren
                    iobroker	2015-07-27 08:02:51	info	exit 8
                    iobroker	2015-07-27 08:02:51	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
                    iobroker	2015-07-27 08:02:51	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                    iobroker	2015-07-27 08:02:51	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                    iobroker	2015-07-27 08:02:51	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                    iobroker	2015-07-27 08:02:51	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
                    iobroker	2015-07-27 08:02:51	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                    iobroker	2015-07-27 08:02:51	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                    iobroker	2015-07-27 08:02:51	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
                    iobroker	2015-07-27 08:02:51	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                    iobroker	2015-07-27 08:02:51	error	TypeError: Cannot read property '_id' of null at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                    iobroker	2015-07-27 08:02:51	error	console.warn('Adapter "' + obj._id + ' is disabled ^
                    iobroker	2015-07-27 08:02:51	error	/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                    iobroker	2015-07-27 08:02:50	info	upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                    iobroker	2015-07-27 08:02:50	info	upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                    iobroker	2015-07-27 08:02:50	info	got /opt/iobroker/node_modules/iobroker.vis/admin
                    iobroker	2015-07-27 08:02:50	info	cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
                    iobroker	2015-07-27 08:02:50	info	WARN
                    iobroker	2015-07-27 08:02:50	info	npm
                    iobroker	2015-07-27 08:02:47	info	npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
                    iobroker	2015-07-27 08:02:47	info	install adapter vis
                    vis-0	2015-07-27 08:02:21	info	Uploaded.
                    vis-0	2015-07-27 08:02:21	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
                    vis-0	2015-07-27 08:02:21	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                    vis-0	2015-07-27 08:02:21	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                    vis-0	2015-07-27 08:02:21	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                    vis-0	2015-07-27 08:02:21	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
                    vis-0	2015-07-27 08:02:21	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                    vis-0	2015-07-27 08:02:21	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                    vis-0	2015-07-27 08:02:21	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
                    vis-0	2015-07-27 08:02:21	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                    vis-0	2015-07-27 08:02:21	error	TypeError: Cannot read property '_id' of null at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                    vis-0	2015-07-27 08:02:21	error	^
                    vis-0	2015-07-27 08:02:21	error	console.warn('Adapter "' + obj._id + ' is disabled
                    iobroker	2015-07-27 08:02:21	info	2015-07-27 08:02:21.409 - error: vis.0 ^
                    iobroker	2015-07-27 08:02:21	info	2015-07-27 08:02:21.404 - error: vis.0 /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:22752015-07-27 08:02:21.407 - error: vis.0 console.warn('Adapter "'
                    iobroker	2015-07-27 08:02:21	info	2015-07-27 08:02:21.401 - error: vis.0
                    vis-0	2015-07-27 08:02:21	error	/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                    vis-0	2015-07-27 08:02:19	info	Upload vis anew, while changes detected...
                    vis-0	2015-07-27 08:02:19	info	Changes in index.html detected => update cache.manifest
                    vis-0	2015-07-27 08:02:19	info	starting. Version 0.6.5 in /opt/iobroker/node_modules/iobroker.vis
                    iobroker	2015-07-27 08:01:51	info	npm install iobroker.vis --production --prefix "/opt/iobroker" (System call)
                    iobroker	2015-07-27 08:01:49	info	add vis
                    was läuft falsch?
                    Jürgen
                      Hast du den post von Bluefox gelesen?
                      http://www.forum.iobroker.org/viewtopic … 8675#p8648
                      Rainer
                      • derAuge
                        @Homoran:
                        Rainer `
                        habe ich auch getestet und danach noch mal versucht
                        • root@Pi2-3:/opt/iobroker# npm install iobroker.vis –production
                        > iobroker.vis@0.6.5 install /opt/iobroker/node_modules/iobroker.vis
                        2015-07-27 08:14:15.697 - info: vis.0 starting. Version 0.6.5 in /opt/iobroker/node_modules/iobroker.vis
                        2015-07-27 08:14:15.940 - info: vis.0 Changes in index.html detected => update cache.manifest
                        2015-07-27 08:14:15.961 - info: vis.0 Upload vis anew, while changes detected...
                        2015-07-27 08:14:17.743 - error: vis.0 Adapter " is disabled and cannot be restarted.
                        2015-07-27 08:14:25.394 - info: vis.0 100 files uploaded...
                        2015-07-27 08:14:39.959 - info: vis.0 200 files uploaded...
                        2015-07-27 08:14:52.987 - info: vis.0 300 files uploaded...
                        2015-07-27 08:14:54.749 - info: vis.0 Uploaded.
                        iobroker.vis@0.6.5 node_modules/iobroker.vis
                        Jürgen
                          Hallo Jürgen,
                          ich sehe gerade, dass ich noch die 0.6.4 habe, also mein post von oben so auch nicht korrekt ist 😞
                          @derAuge:
                          root@Pi2-3:/opt/iobroker# npm install iobroker.vis –production `
                          damit überschreibst du aber wieder die noch nicht freigegebenen Korrekturen aus github!
                          Ich werde mir jetzt auch mein vis zerschießen 😉
                          Rainer
                            Ich trau mich gar nicht es zu sagen:
                            Mein Update nach 0.6.5 hat einwandfrei geklappt
                            Allerdings lässt sich der Editor immer noch nicht über das x schließen.
                            Rainer
                            PS habt ihr eigentlich alle Apple-OS, die das Problem haben?
                              Arminhh last edited by
                              Hallo Homoran,
                              ich habe OSX wo das speichern nicht funktioniert und der Schließen Button!
                                Hallo Armin,
                                Hier in dem Thread geht es um die Probleme bei der Installation.
                                Das Problem mit dem Speichern (welches vielleicht nur ein Problem der Falschmeldung ist) und des Close-Buttons haben mehrere (alle??)
                                Soll das Heißen, du hast mit OSX erfolgreich auf 0.6.5 updaten können?
                                Rainer
                                • coyote
                                  coyote Most Active last edited by
                                  Hatte auch keine Probleme auf 0.6.5 zu updaten
                                    Fitti last edited by
                                    Ich hatte ja auch meine Banane neu gemacht.
                                    Wollte gerade from the scratch .vis installieren. Es kommt auch diese Fehlermeldungen:
                                    ! ./iobroker add vis
                                    ! npm
                                    ! http GET https://registry.npmjs.org/iobroker.vis
                                    ! npm http 200
                                    ! https://registry.npmjs.org/iobroker.vis
                                    ! npm http GET https://registry.npmjs.org/iobroker.vis ... -0.6.5.tgz
                                    ! npm http 200 https://registry.npmjs.org/iobroker.vis ... -0.6.5.tgz
                                    ! 2015-07-29 01:50:02.239 - error: vis.0
                                    ! 2015-07-29 01:50:02.245 - error: vis.0 /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                                    ! 2015-07-29 01:50:02.254 - error: vis.0 console.warn('Adapter "' + obj._id + ' is disabled ^
                                    ! 2015-07-29 01:50:02.363 - error: vis.0 TypeError: Cannot read property '_id' of null at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                                    ! npm
                                    ! WARN cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
                                    ! ERROR:
                                    ! ERROR: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                                    ! ERROR: console.warn('Adapter "' + obj._id + ' is disabled ^
                                    ! ERROR: TypeError: Cannot read property '_id' of null at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                                    ! ERROR: process exited with code 8</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                                    Wieder diese Zeilen..
                                    werde mal jetzt den Post http://www.forum.iobroker.org/viewtopic … 8675#p8648 versuchen.
                                    => Update ging vorher (bevor ich alles neu gemacht hatte, konnte ich problemlos updaten. Die Neuinstallation ist anscheinend das Problem.
                                    Blöd ist, dass nach einem ioBroker Neustart iobroker als installiert angezeigt wird, aber nicht in den Instanzen vorhanden ist:
                                      Wird alles mit controller 0.7.5 nur noch schlimmer…
                                      Habe nach dem zuvor genannten Vorschlag das durchgeführt:
                                      cd /opt/iobroker
                                      iobroker stop
                                      iobroker start
                                      Jetzt kommen diese Fehler:
                                      ! $ ./iobroker add vis
                                      ! ERROR: events.js:72
                                      ! throw er; // Unhandled 'error' event
                                      ! ERROR: Error: listen EADDRINUSE at errnoException (net.js:901:11)
                                      ! at Server._listen2 (net.js:1039:14)
                                      ! at listen (net.js:1061:10)
                                      ! at Server.listen (net.js:1127:5)
                                      ! at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:2410:24)
                                      ! at /opt/iobroker/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:143:9
                                      ! at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:150:7)
                                      ! at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2192:27)
                                      ! at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
                                      Und nun?
                                      4175_log_1012217.txt
                                      4175_objektstrukturjson.txt.txt
                                      4175_heizung_v2_1012217.txt
                                      • Bluefox
                                        @Fitti:
                                        cd /opt/iobroker
                                        iobroker stop
                                        iobroker start
                                        Und nun? `
                                        EADDRINUSE heißt, es läuft schon irgendwas auf dieser Adresse. Vermutlich alte Installation.
                                        Sei sicher, dass mit "ps -A | grep io" keine ioBroker module laufen.
                                        Sonst kannst du die mit "kill -KILL processNummer" anhalten.
                                        Falls nichts läuft, dann kannst du wieder dein "npm install iobroker.js-controller" aufrufen.
                                          nach einem iobroker stop lief tatsächlich immer noch io.hm-rega.0 -> den gekillt.
                                          Nun versucht: npm install iobroker.vis –production
                                          Fehler-Ausgabe:
                                          ! root@bananapi:/opt/iobroker# npm install iobroker.vis –production
                                          ! > iobroker.vis@0.6.5 install /opt/iobroker/node_modules/iobroker.vis
                                          ! > node main.js --install
                                          ! 2015-07-29 09:03:52.365 - warn: vis.0 no connection to objects DB
                                          ! iobroker.vis@0.6.5 node_modules/iobroker.vis
                                          Okay - irgendwo hier im Thread steht, das iobroker laufen soll.
                                          also
                                          root@bananapi:/opt/iobroker# ./iobroker start
                                          Starting ioBroker controller daemon...
                                          ioBroker controller daemon started. PID: 2762
                                          dann nochmal erfolglos npm install iobroker.vis –production .
                                          Ausgabe:
                                          ! 2015-07-29 09:06:55.005 - info: vis.0 starting. Version 0.6.5 in /opt/iobroker/node_modules/iobroker.vis
                                          ! 2015-07-29 09:06:56.100 - info: vis.0 Changes in index.html detected => update cache.manifest
                                          ! 2015-07-29 09:06:56.257 - info: vis.0 Upload vis anew, while changes detected...
                                          ! 2015-07-29 09:07:28.469 - info: vis.0 100 files uploaded...
                                          ! 2015-07-29 09:08:16.598 - info: vis.0 200 files uploaded...
                                          ! 2015-07-29 09:08:33.453 - info: vis.0 300 files uploaded...
                                          ! 2015-07-29 09:08:35.288 - info: vis.0 Uploaded.
                                          Die Instanz ist aber immer noch nicht da. Bei den Adaptern steht aber es sei 0.6.5 installiert.
                                          Installiert ist controller 0.7.5
                                          Nun nochmal mittels Plus aus der iobroker Adapter-Seite die installation aufgerufen.
                                          Jetzt scheint es zu gehen. Ich she zumindest .vis mal wieder. Was für eine Geburt… Das war mit 0.6.2 deutlich einfacher. Da dann ein Update auf 0.64 und dann ein Update auf 0.6.5 war (fast) stressfrei (bis auf die HQWidgets 😉 ).
                                          Wie gesagt - das ganze System ist komplett neu gemacht worden. Einschließlich debian mit igors wheezy 3.x Image
                                          Mal sehen, wie es so läuft oder ob ich noch in andere Probleme renne.
                                            @Homoran:
                                            Habe eben folgendes gesehen:
                                            die untere Zeile wird üblicherweise durch die Windows Taskleiste verdeckt.
                                            Aus irgendeinem Grund hatte sich das Bild verschoben, da konnte ich es sehen. War nur schwer zu reproduzieren. Beim Umschalten auf Vollbild blitzte es kurz auf. Den Augenblick musste man dann beim Screenshot erwischen 😉
                                            Rainer
                                            1.0k
                                            41
                                            6366
