    2. English
    3. ioBroker general
    4. Problem iobroker as docker-installation (solved)
      Surfer2010 last edited by Surfer2010
      Hello,
      the problem i have with the docker container of the buanet/iobroker:latest docker image is:
      the container starts, but docker is not accessable.
      If i start the container with NO volume mounted, it works, but if I start it with an empty folder mounted, it does not work properly (see below)
      here is the only error i can see, but i have no clue if this really is the problem:
      /opt/scripts/iobroker_startup.sh: Zeile 49: /usr/bin/iobroker: Keine Berechtigung
      first the docker command with NO MOUNT - and following the docker log
      docker run -d --network dockernet --name=iobrokertest -p 8085:8081 -p 8086:8082 --restart=always -e PUID=1000 -e PGID=996 -e TZ=Europe/Berlin buanet/iobroker:latest
      a4951e00b49cba2a8d80c336a4af3f18d53241ab1261abcfa95771be58deffcc
      root@FriedbergServer:~# docker logs -f iobroker
      iobroker      iobrokertest
      root@FriedbergServer:~# docker logs -f iobrokertest
      -----     Image-Version: 3.0.0     -----
      -----      2019-06-25 18:28:50     -----
      Startupscript running...
      Installing additional packages...
      The following packages will be installed: nano
      Installing additional packages done...
      This is the first run of an new installation...
      Hostname given is a4951e00b49c...
      Renaming ioBroker...
      Instance host changed for "system.adapter.admin.0" from "a284247a5edd" to "a4951e00b49c".
      Instance host changed for "system.adapter.discovery.0" from "a284247a5edd" to "a4951e00b49c".
      Renaming ioBroker done...
      Changing permissions upon first run (This might take a while! Please be patient!)...
      Changing permissions done...
      Starting ioBroker...
      Starting ioBroker done...
      second the docker command with MOUNT - and following the docker log
      docker run -d --network dockernet --name=iobroker -p 1880:1880 -p 1883:1883 -p 1887:1887 -p 8081:8081 -p 8082:8082 --restart=always -e PUID=1000 -e PGID=996 -e TZ=Europe/Berlin -v /sharedfolders/DockerData/ioBroker:/opt/iobroker/ buanet/iobroker:latest
      d7f3866b96e5d72674af26f86dc3cb0e569728e5a9655b71e0468b330b86f80e
      root@FriedbergServer:/sharedfolders/DockerData# docker logs -f iobroker
      -----      2019-06-25 18:27:23     -----
      Directory /opt/iobroker is empty!
      Restoring data from image...
      Restoring done...
      Hostname given is d7f3866b96e5...
      here I show you the mounted directory with permissions
      /sharedfolders# ls -ll
      total 8
      drwx--s--x+ 14 dom users 4096 Jun 25 15:32 DockerData
      and
      /sharedfolders/DockerData# ls -ll
      total 96
      drwxrwsr-x+ 11 dom  docker 4096 Jun 10 14:36 LetsEncrypt
      drwxrwsr-x+  4 root root   4096 Jun 22 23:06 MariaDB
      drwxr-xr-x+  3 root root   4096 Jun 25 18:21 Quassel
      drwxrwxr-x+  7 dom  docker 4096 Jun 25 00:10 ioBroker
      here are the running procceses (top) in the container with NO-MOUNT
      PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
      274 iobroker  20   0 1239372  96924  23096 S   0,3  1,2   0:06.46 iobroker.js-con
      290 iobroker  20   0 1096988  92844  22888 S   0,3  1,2   0:07.64 io.admin.0
      304 iobroker  20   0  985476  39032  22784 S   0,3  0,5   0:01.81 io.discovery.0
        1 root      20   0   21176   3284   2988 S   0,0  0,0   0:00.07 iobroker_startu
      272 root      20   0   52716   3696   3276 S   0,0  0,0   0:00.00 sudo
      273 root      20   0    7404    784    724 S   0,0  0,0   0:00.00 tail
      332 root      20   0   21404   3668   3232 S   0,0  0,0   0:00.05 bash
      337 root      20   0   44220   3680   3196 R   0,0  0,0   0:00.01 top
      and with MOUNT
        1 root      20   0   21176   3468   3176 S   0,0  0,0   0:00.08 iobroker_startu
      308 root      20   0   52716   3696   3288 S   0,0  0,0   0:00.00 sudo
      309 root      20   0    7404    688    628 S   0,0  0,0   0:00.00 tail
      310 iobroker  20   0  924456  45660  22728 S   0,0  0,6   0:00.56 iobroker.js-con
      326 root      20   0   21404   3652   3220 S   0,0  0,0   0:00.05 bash
      331 root      20   0   44220   3668   3180 R   0,0  0,0   0:00.01 top
        Problem solved ...
        after hunting down the error even further (script wasn't executed ...) i found the error beeing at my mounted folder.
        but it wasn't really the permission on the folder but the drive this folder was on has been mounted as "noexec" (fstab).
          jrjong @Surfer2010 last edited by jrjong
          @Surfer2010 said in Problem iobroker as docker-installation (solved):
          Can you please elaborate on the change aol mail password solution, please. It would be great for us beginners.
          1.2k
          docker iobroker
