    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
      dbathlon @andre last edited by
      @andre sorry,
      wollte ich schon früher machen, ich war aber unterwegs ohne Zugriff auf die Logs.
      -----   Image-Version: 3.0.2beta   -----,
      -----      2019-06-23 21:27:34     -----,
      Startupscript running...,
      Installing additional packages...,
      The following packages will be installed: nano,
      Installing additional packages done...,
      Changing permissions upon first run (This might take a while! Please be patient!)...,
      Changing permissions done...,
      Starting ioBroker...,
      -------     ioBroker Logging     -------,
      host.iobrokerv3Test check instance "system.adapter.admin.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.discovery.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.hm-rpc.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.hm-rpc.1" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.hm-rega.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.sony-bravia.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.fritzbox.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.web.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.scenes.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.ical.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.javascript.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.fakeroku.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.tankerkoenig.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.tvspielfilm.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.synology.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.zigbee.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis-bars.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis-history.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis-hqwidgets.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis-jqui-mfd.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis-justgage.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis-timeandweather.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis-players.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis-metro.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.dwd.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.weatherunderground.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.yr.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.feiertage.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.fullcalendar.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.daswetter.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.history.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.harmony.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.telegram.0" for host "iobrokerv3Test",
      host.iobrokerv3Test check instance "system.adapter.vis-colorpicker.0" for host "iobrokerv3Test",
      Sun, 23 Jun 2019 19:29:46 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.,
      In the future, you will have to enable it yourself.,
      See https://github.com/yagop/node-telegram-bot-api/issues/319. at module.js:653:30,
      Und danach kommt einfach nichts mehr.
      mania25 created this issue in yagop/node-telegram-bot-api
      closed Error: cannot enable cancellation after promises are in use #319
        Shwowak last edited by
        Habe es versucht mit dem einrichten des netzwerkes : MacVlan mit
        ... sudo docker network create -d macvlan --subnet=192.168.200.0/24 --gateway=192.168.200.55 --ip-range=192.168.200.80/28 --aux-address 'host=192.168.200.80' -o parent=eth0 mac0
        Fehler :
        Error response from daemon: invalid subinterface vlan name eth0, example formatting is eth0.10
        0
        sudo ifconfig
        br-8d1efcf7d034 Link encap:Ethernet Hardware Adresse 02:42:9c:b1:0a:8f
        inet Adresse:172.18.0.1 Bcast:172.18.255.255 Maske:255.255.0.0
        inet6-Adresse: fe80::42:9cff:feb1:a8f/64 Gültigkeitsbereich:Verbindung
        UP BROADCAST RUNNING MULTICAST MTU:1500 Metrik:1
        RX-Pakete:13032 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
        TX-Pakete:12203 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        Kollisionen:0 Sendewarteschlangenlänge:0
        RX-Bytes:14515209 (14.5 MB) TX-Bytes:1463926 (1.4 MB)
        br-e7bf6d8029c6 Link encap:Ethernet Hardware Adresse 02:42:6a:0c:73:4b
        inet Adresse:172.19.0.1 Bcast:172.19.255.255 Maske:255.255.0.0
        inet6-Adresse: fe80::42:6aff:fe0c:734b/64 Gültigkeitsbereich:Verbindung
        RX-Pakete:3390 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
        TX-Pakete:4900 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:331979 (331.9 KB) TX-Bytes:10532561 (10.5 MB)
        docker0 Link encap:Ethernet Hardware Adresse 02:42:82:a3:c5:dc
        inet Adresse:172.17.0.1 Bcast:172.17.255.255 Maske:255.255.0.0
        UP BROADCAST MULTICAST MTU:1500 Metrik:1
        RX-Pakete:0 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
        TX-Pakete:0 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:0 (0.0 B) TX-Bytes:0 (0.0 B)
        enp0s3 Link encap:Ethernet Hardware Adresse 08:00:27:eb:1c:36
        inet Adresse:192.168.200.55 Bcast:192.168.200.255 Maske:255.255.255.0
        inet6-Adresse: fd00::a00:27ff:feeb:1c36/64 Gültigkeitsbereich:Global
        inet6-Adresse: fe80::a00:27ff:feeb:1c36/64 Gültigkeitsbereich:Verbindung
        RX-Pakete:2210199 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
        TX-Pakete:2384441 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        Kollisionen:0 Sendewarteschlangenlänge:1000
        RX-Bytes:1059216295 (1.0 GB) TX-Bytes:1777167531 (1.7 GB)
        lo Link encap:Lokale Schleife
        inet Adresse:127.0.0.1 Maske:255.0.0.0
        inet6-Adresse: ::1/128 Gültigkeitsbereich:Maschine
        UP LOOPBACK RUNNING MTU:65536 Metrik:1
        RX-Pakete:60549 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
        TX-Pakete:60549 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:23268811 (23.2 MB) TX-Bytes:23268811 (23.2 MB)
        veth2044459 Link encap:Ethernet Hardware Adresse f2:cf:11:67:82:ee
        inet6-Adresse: fe80::f0cf:11ff:fe67:82ee/64 Gültigkeitsbereich:Verbindung
        TX-Pakete:19 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:0 (0.0 B) TX-Bytes:2486 (2.4 KB)
        veth085da50 Link encap:Ethernet Hardware Adresse d6:76:da:32:b9:11
        inet6-Adresse: fe80::d476:daff:fe32:b911/64 Gültigkeitsbereich:Verbindung
        veth382b084 Link encap:Ethernet Hardware Adresse 32:8c:a9:45:db:ae
        inet6-Adresse: fe80::308c:a9ff:fe45:dbae/64 Gültigkeitsbereich:Verbindung
        veth56d3318 Link encap:Ethernet Hardware Adresse 62:f8:7f:20:1e:38
        inet6-Adresse: fe80::60f8:7fff:fe20:1e38/64 Gültigkeitsbereich:Verbindung
        TX-Pakete:30 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:0 (0.0 B) TX-Bytes:3284 (3.2 KB)
        veth797bc1b Link encap:Ethernet Hardware Adresse b6:75:93:8f:dc:4d
        inet6-Adresse: fe80::b475:93ff:fe8f:dc4d/64 Gültigkeitsbereich:Verbindung
        RX-Pakete:926 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
        TX-Pakete:925 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:145529 (145.5 KB) TX-Bytes:476649 (476.6 KB)
        veth8370a7b Link encap:Ethernet Hardware Adresse be:ad:b5:73:c2:2e
        inet6-Adresse: fe80::bcad:b5ff:fe73:c22e/64 Gültigkeitsbereich:Verbindung
        vetha921b80 Link encap:Ethernet Hardware Adresse 7a:d5:b7:e2:da:e2
        inet6-Adresse: fe80::78d5:b7ff:fee2:dae2/64 Gültigkeitsbereich:Verbindung
        TX-Pakete:18 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:0 (0.0 B) TX-Bytes:2444 (2.4 KB)
        vethac5005c Link encap:Ethernet Hardware Adresse 6a:4e:4f:62:0a:ac
        inet6-Adresse: fe80::684e:4fff:fe62:aac/64 Gültigkeitsbereich:Verbindung
        RX-Pakete:432 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
        TX-Pakete:581 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:401519 (401.5 KB) TX-Bytes:101380 (101.3 KB)
        vethe39d7b8 Link encap:Ethernet Hardware Adresse 8a:15:a7:a5:03:39
        inet6-Adresse: fe80::8815:a7ff:fea5:339/64 Gültigkeitsbereich:Verbindung
        RX-Pakete:2464 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
        TX-Pakete:3992 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:233910 (233.9 KB) TX-Bytes:10058290 (10.0 MB)
        virbr0 Link encap:Ethernet Hardware Adresse 52:54:00:21:25:ce
        inet Adresse:192.168.122.1 Bcast:192.168.122.255 Maske:255.255.255.0
        TX-Pakete:1 Fehler:0 Verloren:0 Überläufe:0 Träger:0
        RX-Bytes:0 (0.0 B) TX-Bytes:228 (228.0 B)
        Stuebi 1 Reply Last reply Reply Quote 0
        • Stuebi
          Stuebi @Shwowak last edited by
          @Shwowak , Versuche es einmal mit enp0s3 statt eth0.
            Shwowak @Stuebi last edited by
            @Stuebi Hat geklappt 🙂
              Shwowak @Shwowak last edited by
              @Shwowak said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
              @Stuebi Hat geklappt 🙂 Danke
                @Stuebi
                Das erstellen hat gekappt ,wenn ich den Container jetzt zum diesen Netzwerk hinzufüge , geht die weboberfläche nicht mehr .
                • Stuebi
                  @Shwowak , wenn Du mit Weboberfläche ioBroker meinst, musst Du beim Web Adapter unter Instanzen am besten bei IP 0.0.0.0 auswählen.
                    @Stuebi
                    läuft es schon :
                    root@d7547b050a0f:/opt/iobroker# iobroker list instances
                    system.adapter.admin.1 : admin - enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    • system.adapter.admin.2 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.alexa2.0
                      @Stuebi
                      läuft es schon :
                        Telefisch last edited by
                        Nach langer Zeit ein neuer Versuch...
                        Hallo erstmal.
                        Ich hab vor einigen Monaten einen ioBroker auf meiner Synology installiert (mit dem ersten Tutorial, danke an Andre).
                        Dabei hatte ich immer Probleme, dass ich einen ZWave-USB-Stick nicht zum Laufen bekam.
                        Hab ich mit den Netzwerkeinstellungen rumgebastelt lief mein Modbus-Adapter nicht mehr.
                        Ich hab keine Ahnung was genau wie war aber ich hab aufgegeben den ZWave zu installieren.
                        Nun gibt es ja ein neues Tutorial und ich habe auch Ewigkeiten kein Update des Containers mehr gemacht, also dachte ich, installiere ich den ganzen Container mal komplett neu.
                        Jetzt lese ich, dass es da Probleme mit dem Netzwerk geben soll, wenn man nicht im Bridge-Mode arbeitet, andersrum im Bridgemode Adapter mit Multicast nicht funktionieren.
                        Deshalb meine Fragen:
                        • gibt es diesen Bug noch immer?
                        • was ist ein Adapter mit Multicast, bzw. woran erkenne ich die?
                        Danke schonmal
                        Carsten
                          @Shwowak
                          mit dem MACVLAN Methode funktioniert es leider nicht erstelle die container per compose und das MACVLAN netzwerk per hand , füge dann per hand den Io broker container zu dem MACVLAN netzwerk hin zu (siehe foto oben ) danach kann ich den Io broker aber über das Webinterface nicht mehr erreichen bitte um hilfe.
                          Negalein Stuebi 2 Replies Last reply Reply Quote 0
                          • Negalein
                            Negalein Global Moderator @Shwowak last edited by
                            @Shwowak sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                            @Shwowak
                            Mit dem Portainer (siehe Tutorial vom V3) funktioniert das erstellen vom MACVLAN einwandfrei.
                              Ja erstellt bekomme ich den auch. Nur das Webinterface ist nicht erreichbar.
                              • Stuebi
                                Stuebi @Shwowak last edited by Stuebi
                                @Shwowak , wenn ich es richtig sehe, hat ioBroker im Docker Container die IP Adresse 192.168.200.208 .
                                Du kannst also nicht die ioBroker Admin Oberfläche (web) über http://192.168.20.208:8081 bzw. http://192.168.20.208:8084 aufrufen?
                                Kannst Du die Adresse 192.168.20.208 per Ping von Deinem Client von dem Du auch ioBroker per Webbrowser http://192.168.20.208:8081 aufrufen möchtest erreichen?
                                  Nein Zeitüberschreitung kommt.
                                  • Stuebi
                                    @Shwowak , ich hoffe Du hast mit 192.168.200.208 und nicht 192.168.20.208 getestet?
                                    Kannst Du denn wenn Du per ssh auf der NAS angemeldet bist die Adresse 192.168.200.208 anpingen?
                                      Shwowak @Stuebi last edited by Shwowak
                                      @Stuebi
                                      Ja klar mit 200. 😄 es ist ein virtual Maschine ohne Weboberfläche.
                                      Habe den Container per Hand gerade mal erstellt nach v3 Anleitung. Starte aber auch kein Zugriff auf Admin weboberfläsche.
                                      intelnuc@intelnuc:~$ ping 192.168.200.2 >>> IP CONTAINER
                                      PING 192.168.200.2 (192.168.200.2) 56(84) bytes of data.
                                      From 192.168.200.55 icmp_seq=1 Destination Host Unreachable IP Virtual Maschine:
                                      From 192.168.200.55 icmp_seq=2 Destination Host Unreachable
                                      From 192.168.200.55 icmp_seq=3 Destination Host Unreachable
                                      From 192.168.200.55 icmp_seq=4 Destination Host Unreachable
                                      • Stuebi
                                        @Shwowak , dann hast du ein Problem mit dem Routing. Liegt nicht an iobroker
                                          Also der Io broker läuft im hintergrund , nur kann per Ip nicht zugreifen und die Admin oberfläsche geht nicht auf.
                                          Kann mir jemanden sagen wie die Port richtig einstelle oder wie ich überhaupt vorgehen muss.
                                          • Stuebi
                                            @Shwowak , wenn du den ioBroker Docker Container nicht einmal per Ping erreichen kannst, stimmt irgendetwas nicht an den Netzeinstellungen. Das kann z.B. am Routing, MACVLAN Einstellungen, ... liegen.
                                            Um das Problem einzugrenzen, kannst du denn den ioBroker Docker Containet einmal versuchen von der NAS aus anzupingen und vom PC. Funktioniert das?
                                            81.1k
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1549152
