Summenberechnung
Vielleicht verhält sich die Liste anders?
@iomountain sagte in Summenberechnung:
<block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="5?vq
u?_mJ-rJ/5.kFXC" x="-287" y="-12"> <field name="SCHEDULE">*/20 */4 * * *</field> <statement name="STATEMENT"> <block type="control" id="|KG?~ooJUg*L#-H^.c=."> <mutation delay_input="false"></mutation> <field name="OID">.Meine_Geräte.BKosten</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_on_list" id="(:;g^.KsDJLYhyZrP
Y=">
<mutation op="SUM"></mutation>
<field name="OP">SUM</field>
<value name="LIST">
<block type="lists_create_with" id="3|{F6[Szkq;Dn,vsssa"> <mutation items="5"></mutation> <value name="ADD0"> <shadow type="math_number" id="=8RTGsET.*qMzuYp/K_("> <field name="NUM">3.1</field> </shadow> <block type="math_rndfixed" id="xJ
^7Md:9Dm2*,-Qk[j"> <field name="n">2</field> <value name="x"> <shadow type="math_number" id="]ICY1Ngu|;}c5,8
)V3z">
<field name="NUM">3.1234</field>
<block type="get_value" id="@_=BGar]8y^w9m^vWjz}">
<field name="OID">sourceanalytix.0.sonoff__0__Sonoff-Furanlage__ENERGY_Total.cost.05_current_year</field>
<value name="ADD1">
<block type="math_rndfixed" id="?Pf-!z-MUB#z~vO)hoD/">
<value name="x">
<shadow type="math_number" id="]ICY1Ngu|;}c5,8)V3z"> <field name="NUM">3.1234</field> </shadow> <block type="get_value" id="AeJeNLKqWaLy.#Q{t_Kr"> <field name="ATTR">val</field> <field name="OID">sourceanalytix.0.sonoff__0__Sonoff-Kühlschrank__ENERGY_Total.cost.05_current_year</field> </block> </value> </block> </value> <value name="ADD2"> <block type="math_rndfixed" id="Pf~k0
%duv?MM=NeA{{q">
<value name="x">
<shadow type="math_number" id="DNB|.f5e~ysOUVEoHZ}"> <field name="NUM">3.1234</field> </shadow> <block type="get_value" id="HJo:j+l~e:O
]Y!qz(O"> <field name="ATTR">val</field> <field name="OID">sourceanalytix.0.sonoff__0__Sonoff-Spuelmaschine1__ENERGY_Total.cost.05_current_year</field> </block> </value> </block> </value> <value name="ADD3"> <block type="math_rndfixed" id="Qoa:-~5}n1HWG,v+p=a-"> <field name="n">2</field> <value name="x"> <shadow type="math_number" id="nBG,p20D:TDm[4)I2fij"> <field name="NUM">3.1234</field> </shadow> <block type="get_value" id="gK^}i*;u~+~AHVzOM_2+"> <field name="ATTR">val</field> <field name="OID">sourceanalytix.0.sonoff__0__Sonoff-Trockner__ENERGY_Total.cost.05_current_year</field> </block> </value> </block> </value> <value name="ADD4"> <block type="math_rndfixed" id="dtK8(V,W!@a^J)!O9ye:"> <field name="n">2</field> <value name="x"> <shadow type="math_number" id="sG,v~RS[Y9~VEw*lHw4_"> <field name="NUM">3.1234</field> </shadow> <block type="get_value" id="6M#rhb
pzL@oDEh`{Shv">
<field name="OID">sourceanalytix.0.sonoff__0__Sonoff-Waschmaschiene__ENERGY_Total.cost.05_current_year</field>
</block>Danke das versuche ich mal
@iomountain
war fast gut es kommt aber ne komplett falsche Summe raus.
wenn du noch Lust hast, viele Debugbausteine, vielleicht zeigt das den Fehler:
wenn wir den Fehler so nicht finden musst du wohl auf Javascript umsteigen
@iomountain habe das blocklyscript eingerichtet mal sehen was jetzt dabei raus kommt.
@iomountain wo kann man die Infos auslesen?
@ostseereiter Im Skript-Log
@AlCalzone
da ist nichts zu finden.alles sauber -
@ostseereiter Dann ggf. auch nur im System-Log. Aber wenn der Code ausgeführt wird, müsste da was sein.
@AlCalzone
ja wenn das script ausgeführt wird steht da was. Im Log-Verzeichnis habe ich mal nachgeschaut da steht zwar was aber nicht was das Script betrifft.javascript.0 2019-07-05 09:22:00.166 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:21:22.332 warn at TCP.onread (net.js:601:20) javascript.0 2019-07-05 09:21:22.331 warn at Socket.Readable.push (_stream_readable.js:208:10) javascript.0 2019-07-05 09:21:22.331 warn at readableAddChunk (_stream_readable.js:250:11) javascript.0 2019-07-05 09:21:22.331 warn at addChunk (_stream_readable.js:263:12) javascript.0 2019-07-05 09:21:22.331 warn at Socket.emit (events.js:211:7) javascript.0 2019-07-05 09:21:22.331 warn at emitOne (events.js:116:13) javascript.0 2019-07-05 09:21:22.331 warn at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20) javascript.0 2019-07-05 09:21:22.331 warn at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24) javascript.0 2019-07-05 09:21:22.331 warn at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31) javascript.0 2019-07-05 09:21:22.331 warn at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12) javascript.0 2019-07-05 09:21:22.331 warn at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3) javascript.0 2019-07-05 09:21:22.331 warn at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14 javascript.0 2019-07-05 09:21:22.331 warn at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5) javascript.0 2019-07-05 09:21:22.330 warn at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18 javascript.0 2019-07-05 09:21:22.330 warn at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) javascript.0 2019-07-05 09:21:22.330 warn at WebSocket.emit (events.js:214:7) javascript.0 2019-07-05 09:21:22.330 warn at emitTwo (events.js:126:13) javascript.0 2019-07-05 09:21:22.330 warn at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) javascript.0 2019-07-05 09:21:22.330 warn at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) javascript.0 2019-07-05 09:21:22.330 warn at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) javascript.0 2019-07-05 09:21:22.330 warn at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) javascript.0 2019-07-05 09:21:22.330 warn at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:21:22.330 warn at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) javascript.0 2019-07-05 09:21:22.330 warn at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) javascript.0 2019-07-05 09:21:22.330 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:21:22.330 warn at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) javascript.0 2019-07-05 09:21:22.330 warn at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) javascript.0 2019-07-05 09:21:22.329 warn at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) javascript.0 2019-07-05 09:21:22.329 warn at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) javascript.0 2019-07-05 09:21:22.329 warn at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) javascript.0 2019-07-05 09:21:22.329 warn at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) javascript.0 2019-07-05 09:21:22.329 warn at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:21:22.329 warn at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) javascript.0 2019-07-05 09:21:22.329 warn at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) javascript.0 2019-07-05 09:21:22.329 warn at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) javascript.0 2019-07-05 09:21:22.329 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:21:22.329 warn at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) javascript.0 2019-07-05 09:21:22.329 warn at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37) javascript.0 2019-07-05 09:21:22.329 warn at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25) javascript.0 2019-07-05 09:21:22.329 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38) javascript.0 2019-07-05 09:21:22.329 warn at Object.<anonymous> (script.js.Flur.Flurlicht:6:5) javascript.0 2019-07-05 09:21:22.328 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20) javascript.0 2019-07-05 09:21:22.326 warn Wrong type of lightify.0.0200000000000000.bri: "string". Please fix, while deprecated and will not work in next versions. javascript.0 2019-07-05 09:21:00.165 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:20:22.218 warn at TCP.onread (net.js:601:20) javascript.0 2019-07-05 09:20:22.218 warn at Socket.Readable.push (_stream_readable.js:208:10) javascript.0 2019-07-05 09:20:22.217 warn at readableAddChunk (_stream_readable.js:250:11) javascript.0 2019-07-05 09:20:22.217 warn at addChunk (_stream_readable.js:263:12) javascript.0 2019-07-05 09:20:22.217 warn at Socket.emit (events.js:211:7) javascript.0 2019-07-05 09:20:22.217 warn at emitOne (events.js:116:13) javascript.0 2019-07-05 09:20:22.217 warn at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20) javascript.0 2019-07-05 09:20:22.217 warn at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24) javascript.0 2019-07-05 09:20:22.217 warn at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31) javascript.0 2019-07-05 09:20:22.217 warn at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12) javascript.0 2019-07-05 09:20:22.217 warn at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3) javascript.0 2019-07-05 09:20:22.217 warn at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14 javascript.0 2019-07-05 09:20:22.216 warn at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5) javascript.0 2019-07-05 09:20:22.214 warn at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18 javascript.0 2019-07-05 09:20:22.214 warn at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) javascript.0 2019-07-05 09:20:22.214 warn at WebSocket.emit (events.js:214:7) javascript.0 2019-07-05 09:20:22.214 warn at emitTwo (events.js:126:13) javascript.0 2019-07-05 09:20:22.214 warn at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) javascript.0 2019-07-05 09:20:22.214 warn at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) javascript.0 2019-07-05 09:20:22.214 warn at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) javascript.0 2019-07-05 09:20:22.214 warn at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) javascript.0 2019-07-05 09:20:22.214 warn at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:20:22.214 warn at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) javascript.0 2019-07-05 09:20:22.213 warn at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) javascript.0 2019-07-05 09:20:22.213 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:20:22.213 warn at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) javascript.0 2019-07-05 09:20:22.213 warn at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) javascript.0 2019-07-05 09:20:22.213 warn at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) javascript.0 2019-07-05 09:20:22.213 warn at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) javascript.0 2019-07-05 09:20:22.213 warn at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) javascript.0 2019-07-05 09:20:22.213 warn at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) javascript.0 2019-07-05 09:20:22.213 warn at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:20:22.213 warn at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) javascript.0 2019-07-05 09:20:22.213 warn at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) javascript.0 2019-07-05 09:20:22.213 warn at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) javascript.0 2019-07-05 09:20:22.213 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:20:22.213 warn at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) javascript.0 2019-07-05 09:20:22.212 warn at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37) javascript.0 2019-07-05 09:20:22.212 warn at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25) javascript.0 2019-07-05 09:20:22.212 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38) javascript.0 2019-07-05 09:20:22.212 warn at Object.<anonymous> (script.js.Flur.Flurlicht:6:5) javascript.0 2019-07-05 09:20:22.212 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20) javascript.0 2019-07-05 09:20:22.208 warn Wrong type of lightify.0.0200000000000000.bri: "string". Please fix, while deprecated and will not work in next versions. javascript.0 2019-07-05 09:20:00.214 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:19:00.248 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:18:00.282 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:17:39.594 warn at TCP.onread (net.js:601:20) javascript.0 2019-07-05 09:17:39.594 warn at Socket.Readable.push (_stream_readable.js:208:10) javascript.0 2019-07-05 09:17:39.594 warn at readableAddChunk (_stream_readable.js:250:11) javascript.0 2019-07-05 09:17:39.594 warn at addChunk (_stream_readable.js:263:12) javascript.0 2019-07-05 09:17:39.594 warn at Socket.emit (events.js:211:7) javascript.0 2019-07-05 09:17:39.593 warn at emitOne (events.js:116:13) javascript.0 2019-07-05 09:17:39.593 warn at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20) javascript.0 2019-07-05 09:17:39.593 warn at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24) javascript.0 2019-07-05 09:17:39.593 warn at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31) javascript.0 2019-07-05 09:17:39.593 warn at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12) javascript.0 2019-07-05 09:17:39.593 warn at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3) javascript.0 2019-07-05 09:17:39.593 warn at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14 javascript.0 2019-07-05 09:17:39.593 warn at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5) javascript.0 2019-07-05 09:17:39.593 warn at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18 javascript.0 2019-07-05 09:17:39.593 warn at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) javascript.0 2019-07-05 09:17:39.593 warn at WebSocket.emit (events.js:214:7) javascript.0 2019-07-05 09:17:39.593 warn at emitTwo (events.js:126:13) javascript.0 2019-07-05 09:17:39.593 warn at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) javascript.0 2019-07-05 09:17:39.593 warn at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) javascript.0 2019-07-05 09:17:39.592 warn at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) javascript.0 2019-07-05 09:17:39.592 warn at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) javascript.0 2019-07-05 09:17:39.592 warn at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:17:39.592 warn at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) javascript.0 2019-07-05 09:17:39.592 warn at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) javascript.0 2019-07-05 09:17:39.592 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:17:39.592 warn at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) javascript.0 2019-07-05 09:17:39.592 warn at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) javascript.0 2019-07-05 09:17:39.592 warn at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) javascript.0 2019-07-05 09:17:39.592 warn at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) javascript.0 2019-07-05 09:17:39.592 warn at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) javascript.0 2019-07-05 09:17:39.592 warn at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) javascript.0 2019-07-05 09:17:39.592 warn at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:17:39.592 warn at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) javascript.0 2019-07-05 09:17:39.591 warn at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) javascript.0 2019-07-05 09:17:39.591 warn at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) javascript.0 2019-07-05 09:17:39.591 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) javascript.0 2019-07-05 09:17:39.591 warn at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) javascript.0 2019-07-05 09:17:39.591 warn at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37) javascript.0 2019-07-05 09:17:39.591 warn at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25) javascript.0 2019-07-05 09:17:39.591 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38) javascript.0 2019-07-05 09:17:39.591 warn at Object.<anonymous> (script.js.Probe.rfidtuer:8:4) javascript.0 2019-07-05 09:17:39.590 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20) javascript.0 2019-07-05 09:17:39.585 warn Wrong type of javascript.0.Tuer: "object". Please fix, while deprecated and will not work in next versions. javascript.0 2019-07-05 09:17:00.172 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:16:00.155 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:15:00.154 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:14:00.154 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:13:00.145 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:12:00.246 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:11:00.165 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:10:00.242 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:09:00.143 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:08:18.410 info script.js.Probe.mathe2: registered 0 subscriptions and 1 schedule javascript.0 2019-07-05 09:08:18.395 info Start javascript script.js.Probe.mathe2 javascript.0 2019-07-05 09:08:15.588 info Stop script script.js.Probe.mathe2 javascript.0 2019-07-05 09:08:00.162 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:07:00.135 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:06:00.136 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:05:00.149 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:04:00.343 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:03:00.164 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:02:00.157 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:01:00.335 info script.js.Probe.Wetter: []
@ostseereiter sagte :
Bei dem gewählten CRON-Job kann um 9:xx Uhr auch nichts aus dem Skript im Log erscheinen.
@AlCalzone
habe ich mal geändert nun kommt dieses.5.7.2019, 09:44:17.627 [info ]: javascript.0 Stop script script.js.Probe.mathe2 5.7.2019, 09:44:17.687 [info ]: javascript.0 Start javascript script.js.Probe.mathe2 5.7.2019, 09:44:17.688 [info ]: javascript.0 script.js.Probe.mathe2: registered 1 subscription and 1 schedule 5.7.2019, 09:44:27.697 [info ]: javascript.0 script.js.Probe.mathe2: 62.04 5.7.2019, 09:44:27.698 [info ]: javascript.0 script.js.Probe.mathe2: 32.46 5.7.2019, 09:44:27.698 [info ]: javascript.0 script.js.Probe.mathe2: 56.99 5.7.2019, 09:44:27.698 [info ]: javascript.0 script.js.Probe.mathe2: 48.62 5.7.2019, 09:44:27.698 [info ]: javascript.0 script.js.Probe.mathe2: 13.58 5.7.2019, 09:44:27.698 [info ]: javascript.0 script.js.Probe.mathe2: Liste: 5.7.2019, 09:44:27.698 [info ]: javascript.0 script.js.Probe.mathe2: 62.04,32.46,56.99,48.62,13.58 5.7.2019, 09:44:27.698 [info ]: javascript.0 script.js.Probe.mathe2: Summe: 5.7.2019, 09:44:27.698 [info ]: javascript.0 script.js.Probe.mathe2: 213.69000000000003 5.7.2019, 09:44:36.809 [info ]: javascript.0 script.js.Probe.mathe2: 62.04 5.7.2019, 09:44:36.810 [info ]: javascript.0 script.js.Probe.mathe2: 32.46 5.7.2019, 09:44:36.810 [info ]: javascript.0 script.js.Probe.mathe2: 56.99 5.7.2019, 09:44:36.810 [info ]: javascript.0 script.js.Probe.mathe2: 48.62 5.7.2019, 09:44:36.810 [info ]: javascript.0 script.js.Probe.mathe2: 13.58 5.7.2019, 09:44:36.810 [info ]: javascript.0 script.js.Probe.mathe2: Liste: 5.7.2019, 09:44:36.810 [info ]: javascript.0 script.js.Probe.mathe2: 62.04,32.46,56.99,48.62,13.58 5.7.2019, 09:44:36.810 [info ]: javascript.0 script.js.Probe.mathe2: Summe: 5.7.2019, 09:44:36.810 [info ]: javascript.0 script.js.Probe.mathe2: 213.69000000000003
javascript.0 2019-07-05 09:46:00.169 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:45:00.145 info script.js.Probe.Wetter: [] javascript.0 2019-07-05 09:44:36.808 info script.js.Probe.mathe2: 213.69000000000003 javascript.0 2019-07-05 09:44:36.808 info script.js.Probe.mathe2: Summe: javascript.0 2019-07-05 09:44:36.808 info script.js.Probe.mathe2: 62.04,32.46,56.99,48.62,13.58 javascript.0 2019-07-05 09:44:36.808 info script.js.Probe.mathe2: Liste: javascript.0 2019-07-05 09:44:36.808 info script.js.Probe.mathe2: 13.58 javascript.0 2019-07-05 09:44:36.808 info script.js.Probe.mathe2: 48.62 javascript.0 2019-07-05 09:44:36.808 info script.js.Probe.mathe2: 56.99 javascript.0 2019-07-05 09:44:36.807 info script.js.Probe.mathe2: 32.46 javascript.0 2019-07-05 09:44:36.807 info script.js.Probe.mathe2: 62.04 javascript.0 2019-07-05 09:44:27.696 info script.js.Probe.mathe2: 213.69000000000003 javascript.0 2019-07-05 09:44:27.696 info script.js.Probe.mathe2: Summe: javascript.0 2019-07-05 09:44:27.696 info script.js.Probe.mathe2: 62.04,32.46,56.99,48.62,13.58 javascript.0 2019-07-05 09:44:27.696 info script.js.Probe.mathe2: Liste: javascript.0 2019-07-05 09:44:27.695 info script.js.Probe.mathe2: 13.58 javascript.0 2019-07-05 09:44:27.695 info script.js.Probe.mathe2: 48.62 javascript.0 2019-07-05 09:44:27.695 info script.js.Probe.mathe2: 56.99 javascript.0 2019-07-05 09:44:27.695 info script.js.Probe.mathe2: 32.46 javascript.0 2019-07-05 09:44:27.695 info script.js.Probe.mathe2: 62.04
Wie es aussieht wird es richtig berechnet aber warum ist die Ausgabe dann falsch?
@ostseereiter sagte:
Du solltest die Datenpunkte neu anlegen unter "Meine_Geraete.0", also den ersten z.B. als "Meine_Geraete.0.BKosten". Bei der von Dir gewählten ID, beginnend mit einem Punkt und ohne eine Ziffer zwischen dem ersten und zweiten Punkt gibt es regelmäßig Probleme.
Habe ich geändert auch da wird falsch ausgegeben.schedule("*/20 */4 * * *", function () { }); on({id: ".Meine_Geräte.wohnunglicht"/*wohnunglicht*/, change: "ne"}, function (obj) { var value = obj.state.val; var oldValue = obj.oldState.val; console.log(Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Furanlage__ENERGY_Total.cost.05_current_year").val*100)/100); console.log(Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Kühlschrank__ENERGY_Total.cost.05_current_year").val*100)/100); console.log(Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Spuelmaschine1__ENERGY_Total.cost.05_current_year").val*100)/100); console.log(Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Trockner__ENERGY_Total.cost.05_current_year").val*100)/100); console.log(Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Waschmaschiene__ENERGY_Total.cost.05_current_year").val*100)/100); Liste = [Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Furanlage__ENERGY_Total.cost.05_current_year").val*100)/100, Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Kühlschrank__ENERGY_Total.cost.05_current_year").val*100)/100, Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Spuelmaschine1__ENERGY_Total.cost.05_current_year").val*100)/100, Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Trockner__ENERGY_Total.cost.05_current_year").val*100)/100, Math.round(getState("sourceanalytix.0.sonoff__0__Sonoff-Waschmaschiene__ENERGY_Total.cost.05_current_year").val*100)/100]; console.log('Liste: '); console.log(Liste); console.log('Summe: '); console.log((Liste.reduce(function(x, y) {return x + y;}))); setState(".Meine_Geräte.BK"/*BK*/, (Liste.reduce(function(x, y) {return x + y;}))); }); 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
Ich sehe keine Veränderung bzgl. der ID-Struktur.
@iomountain
Dein Script funktioniert der Fehler war im Datenpunkt stand max.wert 100 den habe ich nun geändert. und siehe da die Ausgabe ist richtig Mein Script funktioniert nicht da wird nur aneinander gereiht. Danke euch allen -
Nun doch noch nicht ganz gelöst.folgendes es wird ja nun alles wunderbar und richtig errechnet nur die Ausgabe zeigt nach einiger Zeit dies an
.die nullen nach den Nachkommerstellen .Das passt nicht.
@ostseereiter Das liegt daran, wie Computer intern mit Gleitkommazahlen rechnen. Der Wert 214,42 ist wohl nicht exakt darstellbar.
Nicht die einzelnen Werte für die Liste runden, sondern das Ergebnis (Summe über die Liste) runden !
