    5. Worx landroid Script
    • SeiteBallon74
      SeiteBallon74 last edited by
        <block type="on" id="=X3G[.%cNzKOW)PCgI*9" x="-731" y="-1125">
          <field name="OID">landroid-s.0.mower.status</field>
            <block type="controls_if" id="HA475iZHK,`V27*q$4:.">
              <mutation elseif="14"></mutation>
                <block type="logic_compare" id="bWJNhV/2UcZfi7L*Xcdg">
                  <field name="OP">EQ</field>
                    <block type="get_value" id="#|a+`qG$67.3y4qhoqvv">
                    <block type="math_number" id="=@U9APdC5PZUD[-a5d5z">
                      <field name="NUM">1</field>
                <block type="request" id="CeDm8|{RV@{samRJ{1wu" disabled="true">
                  <mutation with_statement="false"></mutation>
                  <field name="WITH_STATEMENT">FALSE</field>
                  <field name="LOG"></field>
                  <value name="URL">
                    <shadow type="text" id="IQ3tE(}=apQ*uMNCwJOF">
                      <field name="TEXT">http://192.168.178.37/cm?cmnd=Led15 000000</field>
                    <block type="request" id="vWHq!rtHo!?RW1AAC9O*" disabled="true">
                      <value name="URL">
                        <shadow type="text" id="?@XEXNEjOj16Q!VJ}W-E">
                          <field name="TEXT">http://192.168.178.37/cm?cmnd=Led6 006400</field>
                        <block type="telegram" id="T1wvX9#}192X8M?Z.-FT">
                          <field name="INSTANCE">.1</field>
                          <value name="MESSAGE">
                            <shadow type="text" id="JPZa4w.@j!HT/g~KM^Zn">
                              <field name="TEXT">Worxi: Bin Zuhause.</field>
              <value name="IF1">
                <block type="logic_compare" id="9hE!a~{5ue(E,Y2}nRmK">
                    <block type="get_value" id="oyQiZ*4i$f2u)UWgP67a">
                    <block type="math_number" id="0=nz(Jba*[Jp/!)Q+ACo">
                      <field name="NUM">2</field>
              <statement name="DO1">
                <block type="request" id="l]E/4jNdR$H6uH9~_Wai" disabled="true">
                  <value name="URL">
                    <shadow type="text" id="!F.YZSsIW8ktiY4|Uy,8">
                    <block type="request" id="Fp=1vIQe?p,q2%ac8Q-O" disabled="true">
                      <value name="URL">
                        <shadow type="text" id="47g2#3,$Ip`}5?p;8A$W">
                          <field name="TEXT">http://192.168.178.37/cm?cmnd=Led5 FF0000</field>
                        <block type="telegram" id="HPjo{n^yg1?epaCdUFUu">
                            <shadow type="text" id=",b5bXOS^m4dW{RD{Fzz.">
                              <field name="TEXT">Worxi: Fahre los.</field>
              <value name="IF2">
                <block type="logic_compare" id="cvy0HsnW^yoCIJ[Wb_$G">
                    <block type="get_value" id="0%7dZcaGf^10WG~X*^-_">
                    <block type="math_number" id=":@Jl?@G,F~?bV{@tXwa9">
                      <field name="NUM">3</field>
              <statement name="DO2">
                <block type="request" id="W|_H28Bpb2T[*zj;S?}," disabled="true">
                  <value name="URL">
                    <shadow type="text" id="g$p@sS@{41:KU8QqnyO6">
                    <block type="request" id="+.o{ZSva|2#Ngo[A^)OJ" disabled="true">
                      <value name="URL">
                        <shadow type="text" id="(ohb{)8AL#c3/QOa;Ui?">
                        <block type="telegram" id="KD#:{[{t8O@0n=|hx?3r">
                            <shadow type="text" id="dU*{Y@=Bumn3v%fPnPH@">
                              <field name="TEXT">Worxi: Zuhause verlassen.</field>
              <value name="IF3">
                <block type="logic_compare" id="*J+$HJRH~4JgEJQ|w7.L">
                    <block type="get_value" id="o,_[PRZXd~OLzz3JU9ZS">
                    <block type="math_number" id="A]*gZ^/;e*sC)i]z@#c|">
                      <field name="NUM">4</field>
              <statement name="DO3">
                <block type="request" id="-Y^(n:/$=P@A?|!8V7:Y" disabled="true">
                  <value name="URL">
                    <shadow type="text" id="Li0Sa%3S]lK6;VP(gX+7">
                    <block type="request" id="E=(P.e.f@xU[_)R1In(2" disabled="true">
                      <value name="URL">
                        <shadow type="text" id="n2/=gi=5K$.n=X],Iq0e">
                        <block type="telegram" id="$Ps%7KkgRoSG;S#:jbVH">
                            <shadow type="text" id="Gg+o)!OAJJ/Xf2qQ%%n+">
                              <field name="TEXT">Worxi: Folge Begrenzungsdraht.</field>
              <value name="IF4">
                <block type="logic_compare" id="Ymdeo%]f]|g~?qQ/8(;k">
                    <block type="get_value" id="C3BRq%.+@3ER5r%_|5$W">
                    <block type="math_number" id="),}H3An+1L@,Wd`u{Y-d">
                      <field name="NUM">5</field>
              <statement name="DO4">
                <block type="request" id="WXuj]p|Pt*_BN=dkx5P6" disabled="true">
                  <value name="URL">
                    <shadow type="text" id="OBMHa?{Vai.@ZbhyRAmU">
                    <block type="request" id="0Nmkj8:4xCP(^4~?qn(y" disabled="true">
                      <value name="URL">
                        <shadow type="text" id="lEkZhl13rpsTXfx,5Wa,">
                        <block type="telegram" id="%8Li0s`s:~!E!#gpnDA}">
                            <shadow type="text" id="Z`jzRYj}QgaE.=|Rc[kL">
                              <field name="TEXT">Worxi: Suche Zuhause.</field>
              <value name="IF5">
                <block type="logic_compare" id="(r0;HTlmQ|1jf3PZdPW(">
                    <block type="get_value" id="WAC:y3`3%!lDM9J1U#?]">
                    <block type="math_number" id="@kEfjcq^nUAWMZ5l8tEO">
                      <field name="NUM">6</field>
              <statement name="DO5">
                <block type="request" id="lJNgBLY{HDY/3/[j9$zO" disabled="true">
                  <value name="URL">
                    <shadow type="text" id="=RBoEyvHhZW#v+T,qKC{">
                    <block type="request" id="x2TvyjhY=0|bVNz=A?d}" disabled="true">
                      <value name="URL">
                        <shadow type="text" id="JcnlDiVTX7SV({bXKRs9">
                        <block type="telegram" id="?K)]%u-z0;5ylEF$i3k:">
                            <shadow type="text" id="zx-Thu,l+4lhI0x1tt-?">
                              <field name="TEXT">Worxi: Suche Draht.</field>
              <value name="IF6">
                <block type="logic_compare" id="R$AR4l/C!eR[JS#kN(:G">
                    <block type="get_value" id="Hz1dlr0c0`Kh}O;q;~GZ">
                    <block type="math_number" id="Gor#HSMHV={6|eix[4*c">
                      <field name="NUM">7</field>
              <statement name="DO6">
                <block type="request" id="Nqg,_;I0cxakD:W_-C+j" disabled="true">
                  <value name="URL">
                    <shadow type="text" id="EO=LhoqT%a#w_8:0a{M}">
                    <block type="request" id=",rdDnNqf3]4jITVWoOK(" disabled="true">
                      <value name="URL">
                        <shadow type="text" id="?gIhJi:z*F*cLdv?WH.C">
                          <field name="TEXT">http://192.168.178.37/cm?cmnd=Led6 000000</field>
                        <block type="telegram" id="+%orL?$Y9x,|=3}fMn%C">
                            <shadow type="text" id="oL17om853E.Uni7|:6dm">
                              <field name="TEXT">Worxi: Ich mähe.</field>
              <value name="IF7">
                <block type="logic_compare" id="?Qg!+$xz@]zf([Gp]GWN">
                    <block type="get_value" id="-%/y2v+mDzo)j_*o1NW;">
                    <block type="math_number" id="4{HqDTfl07SsL*x}-;@K">
                      <field name="NUM">9</field>
              <statement name="DO7">
                <block type="telegram" id=".%*pf-,M)_p.;R7fxoE!">
                    <shadow type="text" id="gPB3A:27HvBTA%5Ssre?">
                      <field name="TEXT">Worxi: Festgefahren.</field>
              <value name="IF8">
                <block type="logic_compare" id="yv8pX|-^%edyuhKv(mwX">
                    <block type="get_value" id="2^8,UPE@R`F9H%x~n,OW">
                    <block type="math_number" id=",ka(|p6}]%rJD_W[Pd37">
                      <field name="NUM">10</field>
              <statement name="DO8">
                <block type="telegram" id="9[jmKJ5iU3wf2!tQkhHr">
                    <shadow type="text" id="/$r@p@EV;FC$0cKBxdfi">
                      <field name="TEXT">Worxi: Messer blockiert.</field>
              <value name="IF9">
                <block type="logic_compare" id="rDz1PtWZ5yuWOCWhNRt{">
                    <block type="get_value" id="3JUX*+.}@JzLIbZXC~AQ">
                    <block type="math_number" id="#3UN+S-BA=,O3}D!4rre">
                      <field name="NUM">11</field>
              <statement name="DO9">
                <block type="telegram" id="ZiuvLX5#WxMVMiDDsel]">
                    <shadow type="text" id="T.TaWU]+9wUQ)Ngs0l@R">
                      <field name="TEXT">Worxi: Debug.</field>
              <value name="IF10">
                <block type="logic_compare" id="t`[X,M3!J$7Kkq7Z/!:5">
                    <block type="get_value" id="gm)X,=`[Fq%}^:XvlQ:N">
                    <block type="math_number" id="^d1mn`w}5KTsX6rwK%t1">
                      <field name="NUM">12</field>
              <statement name="DO10">
                <block type="telegram" id="#ozm$sgjcDAewx9IBUKr">
                    <shadow type="text" id="#c29I6{6MYBeF.q6eyFL">
                      <field name="TEXT">Worxi: Fern Steuerung.</field>
              <value name="IF11">
                <block type="logic_compare" id="fl#]zVNu.6{j6P^HEFi-">
                    <block type="get_value" id="r80*`UI)}1f4G{Y|8y+o">
                    <block type="math_number" id="8%MGsjrsL7^.rSDLotvT">
                      <field name="NUM">8</field>
              <statement name="DO11">
                <block type="telegram" id="D:J:GWM_$Vr=O,Dwk$F,">
                    <shadow type="text" id="w-#*(}9E1s?Vi1HmO-8}">
                      <field name="TEXT">Worxi: Hoch gehoben.</field>
              <value name="IF12">
                <block type="logic_compare" id="Za:vw[+m%h`oi3*xZFY#">
                    <block type="get_value" id="G^URrt`X=O/D?{U^:b;4">
                    <block type="math_number" id="{ex~]0FM[6q9^0z?pbLM">
                      <field name="NUM">34</field>
              <statement name="DO12">
                <block type="telegram" id="XWofI8dE]2,cD;[zj%66">
                    <shadow type="text" id="%ml[a4c=vY6w[TjaM=3N">
                      <field name="TEXT">Worxi: Pause.</field>
                    <block type="request" id="$K-RdUC7a?(i}~DZ/6k=" disabled="true">
                      <value name="URL">
                        <shadow type="text" id="tL?mZp3Bk60x1*Hxu`~l">
                          <field name="TEXT">http://192.168.178.37/cm?cmnd=Led15 006400</field>
              <value name="IF13">
                <block type="logic_compare" id="J$bUn7Uh]C:~=d$NN{q%">
                    <block type="get_value" id="ZIw,LA~aJ?CuttB?p3:=">
                    <block type="math_number" id="JAoXf0#`2I/t|J|]d+?*">
                      <field name="NUM">0</field>
              <statement name="DO13">
                <block type="telegram" id="h_9.{42|D=YIH=jqLS$E">
                    <shadow type="text" id="66F!_yYbdQ7(a-ve(z!V">
                      <field name="TEXT">Worxi: Manueller Stop.</field>
                    <block type="request" id="Xs)mY$nf%u;W2lB9H6jP" disabled="true">
                      <value name="URL">
                        <shadow type="text" id="yP]L8QFyRg^J$CIT1Gjd">
              <value name="IF14">
                <block type="logic_compare" id="Ty9t(@zUaSsYo-:+Ow4%">
                    <block type="get_value" id="V?^DZ%T=%4^*E,F`66uW">
                    <block type="math_number" id="3KI1Mj-;DVzK-.r=oj(e">
                      <field name="NUM">33</field>
              <statement name="DO14">
                <block type="request" id="x/,R@2ql*8#|Q:Qbm:C^" disabled="true">
                  <value name="URL">
                    <shadow type="text" id=".[{;oCHPu:_~I3guzaju">
                    <block type="telegram" id="`#lo}c:JcubdBxl:GYRQ">
                        <shadow type="text" id="n0KN9j~K_He]UPOyuscW">
                          <field name="TEXT">Worxi: Suche Mähzone.</field>
      • SeiteBallon74
        Wird aber nicht in Blockly angezeigt..?
        • dslraser
          dslraser Forum Testing Most Active @SeiteBallon74 last edited by
          @SeiteBallon74
          Dein Trigger steht auf wurde aktualisiert und Du verwendest keinen eigenen Datenpunkt.
          Heißt also, immer wenn der Mäher seinen Status aktualisiert bekommst Du eine Nachricht.
          (stelle mal auf wurde geändert)
          Importiere doch einfach mal mein Blockly bei Dir, dann siehst Du den Unterschied. (denke Ich)
          • SeiteBallon74
            @dslraser Was meinst du mit eigenen Datenpunkt? Wo diesen einstellen?
            Probier dein Script gleich mal aus. Danke
            • dslraser
              dslraser Forum Testing Most Active @SeiteBallon74 last edited by dslraser
              @SeiteBallon74
              eigene Datenpunkte musst Du ja nicht nehmen, da Du ja in Deine Telegram Meldung auch schreiben kannst was Du willst. (ich übersetze nur die Begriffe vom Worx Adapter und schreibe die in meinen Datenpunkt, die nehme ich dann)
              Bei Dir reicht wahrscheinlich schon auf wurde geändert zu stellen, dann kommt Dein Telegram nur, wenn sich der Status vom Mäher geändert hat.
              also so:
              nicht so:
              • SeiteBallon74
                Habe ich gemacht. Bin gespannt.
                Noch eine Frage. Ich schalte dann per URL noch bestimmte LEDS ein und aus.
                Beim Worxi gibt es aber für Start/Stop nur einen Status. Wenn er stopt dann wird "Pause" ebenfalls aktiviert. Außerdem finde ich den Status für "Bin Zuhause" nicht. Bzw. weiß ich wenn Landroid Status = 1 dann is er Zuhause aber meine LED zeigt dies nicht an. Habe diesen Punkt nun mit Batterycharging verknüpft. Dieser geht bei 100% Akkuladung aber wieder auf false und mein Licht geht wieder aus(das er Zuhause ist). Ich hoffe ihr könnt mir folgen..
                Wie kann ich das verhindern?
                • dslraser
                  @SeiteBallon74 sagte in Worx landroid Script:
                  verstehe ich nicht, sollte angezeigt werden. (natürlich erst nach der nächsten Änderung, wenn Du das Blockly eben erst umgestellt hast)
                  Meiner zeigt das so an.
                  Mit Start/Stop meinst Du aber nicht den Status, oder ? Du meinst den hier, oder ?
                  Der ist zum steuern und nicht als Statusanzeige zu verstehen.
                  (nicht über Mähvorgang wundern, das habe ich selbst überschrieben, das würde aber bei Updates vom Adapter überschrieben, deshalb habe ich mir den eigenen Datenpunkt erstellt, der den Status quasi übersetzt)
                  • SeiteBallon74
                      <variables>
                        <variable type="" id="?.X}:+qP;_,d.grLd{~r">wert</variable>
                        <variable type="" id="_s9CkI3Y2UXib@{|[mwP">farbe</variable>
                      </variables>
                      <block type="procedures_callnoreturn" id="U^{_yDj9h]iZkZ}KF(Z;" x="-188" y="288">
                        <mutation name="schalteLED">
                          <arg name="wert"></arg>
                        </mutation>
                        <value name="ARG0">
                          <block type="get_value" id="`A/HGI0i56RDb{gjVwI5">
                            <field name="OID">worx.0.30174102170106020127.mower.state</field>
                          <block type="on_ext" id="CWLuc*YPKXkrn}opuH94">
                            <value name="OID0">
                              <shadow type="field_oid" id="sp5uAt/!6{[l8-q[xGY`">
                                <field name="oid">worx.0.30174102170106020127.mower.state</field>
                              <block type="procedures_callnoreturn" id="iJ.)]C)8X(HWs=J=.9#z">
                                </mutation>
                                <value name="ARG0">
                                  <block type="on_source" id="m#K`@{h9i*jR)i{_.QQn">
                      <block type="procedures_defnoreturn" id="kXIGCI:FuUA9TO?2JJ2D" x="-188" y="512">
                        <mutation>
                          <arg name="wert" varid="?.X}:+qP;_,d.grLd{~r"></arg>
                        </mutation>
                        <field name="NAME">schalteLED</field>
                        <statement name="STACK">
                          <block type="controls_if" id="j,ci88W_xwVzyahWNq}d">
                              <block type="variables_get" id="W;i36TYdx[A[op3;R3?Z">
                                <field name="VAR" id="?.X}:+qP;_,d.grLd{~r" variabletype="">wert</field>
                              <block type="variables_set" id="q{5ef3A2B$:bX5}pxuM`">
                                <field name="VAR" id="_s9CkI3Y2UXib@{|[mwP" variabletype="">farbe</field>
                                  <block type="text" id="{/(^2pi]={C25ZIDH9.[">
                                    <field name="TEXT">FF0000</field>
                            <statement name="ELSE">
                              <block type="variables_set" id="?$Zv|C,#W3p4Z|PWPKd(">
                                  <block type="text" id="H~Z?MZsYVR?j]HFFMbf1">
                                    <field name="TEXT">000000</field>
                              <block type="request" id="~v`hVTA$7z2j}+Xb;HY]">
                                <field name="LOG">log</field>
                                <value name="URL">
                                  <shadow id="Q~5e]ye{ouRwEC/tOV(U" type="text">
                                    <field name="TEXT">http://192.168.178.37/cm?cmnd=Led1 006400</field>
                                  <block type="text_join" id="Z;p819Z+?2c=d)Df7[Su">
                                    <value name="ADD0">
                                      <block type="text" id="5?[%B{fO`=NVmuDo1^5~">
                                        <field name="TEXT">http://192.168.178.37/cm?cmnd=Led5 </field>
                                    <value name="ADD1">
                                      <block type="variables_get" id=":*-X/r!A#c_X%xp@-gLU">
                    • SeiteBallon74
                      SeiteBallon74 last edited by SeiteBallon74
                      Genau. Hab anscheinend da den falschen Punkt verknüpft. Danke für den Tipp.
                      Aber wie kann ich jetzt in diesem Script zb. meine Worx States verknüpfen?
                      Das quasi =1 Bin Zuhause bedeudet und dann die entsprechende LED ein oder ausschaltet.
                      Das war jetzt ein Beispiel von meinem "mähen" Script.
                      • dslraser
                        @SeiteBallon74
                        ich bin jetzt erstmal unterwegs....(bis später)
                        • dslraser
                          welche LED willst Du denn wie schalten ? Ich finde in Deinem Blockly LED 5 / LED 6 und LED 15
                          Und welche von den LED soll wann welche Farbe annehmen ?
                          • SeiteBallon74
                            Ich wollte eine Statusanzeige mit 30er LED Streifen machen. Immer wenn der Worxi zb fährt dann soll das entsprechende Lämpchen an oder ausgehen.
                            So sieht mein Script für Worxi Pause aus. Klappt aber nicht. So habe ich auch alle anderen Dinge mit dem LED Streifen schalten lassen. Nur leider funktioniert dies nicht. Hier bei Pause nimmt er immer den Wert von true obwohl keine Pause an ist zb.
                            • SeiteBallon74
                              Soo sieht meine Anzeige aus und wurde mit einem Nodemcu umgesetzt.
                              • dslraser
                                @SeiteBallon74
                                ich frage nochmal, welche LED brauchst Du für den Worx ?
                                " Ich finde in Deinem Blockly LED 5 / LED 6 und LED 15"
                                • SeiteBallon74
                                  Dafür benötige ich die 5,6,15,16
                                  5 = Worxi mähen
                                  6 = Worxi Zuhause
                                  15 =Worxi Pause
                                  16 = Worxi Error
                                  • dslraser
                                    @SeiteBallon74
                                    okay, ich melde mich nachher
                                    • SeiteBallon74
                                      Danke. Sehr nett von dir
                                      • dslraser
                                        @SeiteBallon74
                                        noch eine Frage (habe diese LED nicht), was sind das für Farben ?
                                        FF0000 (rot ?)
                                        000000 (???)
                                        • SeiteBallon74
                                          Genau. FF0000 ist rot
                                                    000000 ist aus
                                                     006400 ist grün
                                          • SeiteBallon74
                                            Kann sie so schalten per request URL:
                                            http://192.168.178.37/cm?cmnd=LED5 FF0000
                                            Dann wird die led 5 in rot geschalten zb.
                                            6061
