    5. Fernseher Zeitverzögert ausschalten
      liv-in-sky last edited by
      hier die version ohne timeouts - paul hat natürlich recht
      <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="HXhV]8:d}^}K8?b7[Va(" x="1262" y="812">
      <value name="OID0">
      <shadow type="field_oid" id="w_hUg12Mk9RBlmbIE}m]">
      <field name="oid">controll-own.0.AAATEST.TestZahl</field>
      <block type="debug" id="7-R(y3)A3b}Hhn9qAYDm">
      <field name="Severity">warn</field>
      <value name="TEXT">
      <shadow type="text" id="ab1lbd(L}AEA2!pALw="> <field name="TEXT">an</field> </shadow> </value> <next> <block type="variables_set" id="6vFjV?lvMLG}1,c7y=[y"> <field name="VAR" id="$M8UD=r,/^k]3im{HLX-" variabletype="">warten</field> <value name="VALUE"> <block type="math_number" id="=$Ypv6$E---iUC28RaG6"> <field name="NUM">0</field> </block> </value> <next> <block type="timeouts_setinterval" id="afmm(8JY;`vG1/!b}?:">
      <field name="NAME">Intervall</field>
      <field name="INTERVAL">1</field>
      <block type="math_change" id="o?49A.*tCKj3ZAg=#.xr">
      <value name="DELTA">
      <shadow type="math_number" id="tdp}A{~=x$5aJI{h]n9~">
      <field name="NUM">1</field>
      <block type="math_number" id="b8799A{f$2K,=i}Qw)N">
      <block type="controls_if" id="a5vt2QtIR{@LCs].ZYdk">
      <block type="logic_compare" id="Z(aoX
      Ofc%|BJdTHxc)U">
      <field name="OP">GTE</field>
      <block type="variables_get" id="z4fTTUwL.Ul{+K=!G8[n">
      <block type="get_value" id="b[xuuAE53{j-],U%=cGv">
      <field name="OID">controll-own.0.AAATEST.TestZahl</field>
      <block type="debug" id=";C#;8fDH%Zr^@ZpsM_mk">
      <value name="TEXT">
      <shadow type="text" id="9p,6fgZrY%-.e0W75F57">
      <field name="TEXT">jetzt aus</field>
      <block type="control" id="vSche)0SB-C1%{#gMX1." disabled="true">
      <block type="text" id="$#+B8L[CSMq?^RuxQqX^">
      <field name="TEXT">hier tv ausschalten</field>
      <block type="timeouts_clearinterval" id="T,1W]N,o1kIAguqnPXP$">
        paul53 @liv-in-sky last edited by
        @liv-in-sky sagte:
        ich dachte das läuft alles "parallel" ab oder hab ich da noch was falsches im kopf (asynchrones synchrones - javascript) ?
        Nein, die meisten Befehle werden nacheinander abgearbeitet. Nur Funktionen mit Callback, wie Trigger, setState(), createState() ... arbeiten asynchron.
        liv-in-sky 2 Replies Last reply Reply Quote 1
          liv-in-sky @paul53 last edited by
          @paul53 danke dir- seit 2 jahren falsch gedacht 😞
            liv-in-sky @paul53 last edited by liv-in-sky
            @paul53 darf ich dir noch eine frage stellen?
            gibt es ein tool oder etwas, dass ausgeschriebene zahlen (fünf, drei, dreiundzwanzig,...) in ein integer verwandelt (5,3,23,...oder muss man da mit einer eigenen tabelle arbeiten ?
            if ( x=="fünf" ) { y=5;};
              paul53 @liv-in-sky last edited by paul53
              @liv-in-sky sagte:
              gibt es ein tool ?
              Mir ist kein Tool bekannt. Wie weit soll es denn reichen ?
              Ich würde die Texte in ein Array schreiben und den Index als Ergebnis verwenden.
              const texte = ['null','eins','zwei',...];
                @paul53 eigentlich bis 90
                im moment nutze ich noch die tabelle und habe halt gängige werte gemacht - es geht um den alexa timer - im summery macht alexa bei: alexa timer 3 minuten -> timer drei minuten
                habe einfach 1-20 und dann in 5er schritten bis 60 - dabei geht es eigentlich um minutentimer beim kochen - da reicht das erstmal
                werd mal über das array nachdenken
                vielen dank
                  Freakezoid last edited by
                  Vielen Dank für die Hilfe jetzt geht es aber jetzt habe ich das Problem das mein Fernseher den Adapter irgendwie nicht frisst 😞
                  habe nen Samsung MU8009
                  • Glasfaser
                    Glasfaser @Freakezoid last edited by
                    @Freakezoid
                    Welchen Adapter nutzt du denn ???
                      den samsung adapter
                      Glasfaser 4 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        Glasfaser @Freakezoid last edited by Glasfaser
                        @Freakezoid
                        Wäre schon gewesen welcher Samsung Adapter 😉 , da es mehrere Version bzw. Anbieter gibt .
                        Den Adapter habe ich , Version 0.0.2 und er funktioniert.
                        Link Text
                        • 4
                          4-Real @Freakezoid last edited by
                          @Freakezoid glaube der ist nicht mehr sehr zuverlässig.
                          habe auch nichts mehr mit dem adapter steuern können.
                          glaube da bleibt dir nur der umweg mit nen harmony hub oder broadlink.
                            will eigentlich nur nen timer für den fernseher bauen wer will ich garnicht
                            • BBTown
                              BBTown @Freakezoid last edited by BBTown
                              @Freakezoid
                              Wäre für deine Anforderung eine einfache "Schaltverzögrung" im Blocky-Element des TV denn nicht ausreichend?
                              Wenn Du zufällig auch einen "Broadlink" hast (für Fernbedienungssignale?), dann hätte ich eine Alternative für dich zum Ausschalten des SAMSUNG, sofern der Sasmsung Adapter nicht zuverlässig funktioniert.
                              Brroadlink-Code zum Eiinschalten von SAMSUNG TVs
                              2600d200949413371237133712121213121212131212123713371238121212121213121212121337121212131138123812121213113812131138123812121212123812381212120006009494123713371238121212121213121212121238123713371212121312121213121212371312121212381237121311131238121212371238121213121237123812121200060094941238123713371212121312121212121312371238123713121212121311131212123812121213113812381212121212381212123812371312121212381237121312000d050000000000000000
                              Brroadlink-Code zum Ausschalten von SAMSUNG TVs
                              2600d200969413361337123812121212131211131113123812381237131210141212121310141113121311131136153712131014123713371238133612131113123712381212120006009494123813361436121311131212121310141237133712381311121212131113121211141113121212381238131111131139123713371337111311131139123713121200060094941336123813361411121212131113121212381237133712121213111312121312111312131113123712381311121311381238123713371212121311381337121212000d050000000000000000
                              1382
