    4. UPNP Cannot read property match of undefined
    SOLVED UPNP Cannot read property match of undefined
      crunchip Forum Testing Most Active last edited by crunchip
      hatt da eventuell jemand eine Idee?
      Diese Fehlermeldung bekomm ich täglich 1 mal und kann ehrlich gesagt nichts damit anfangen
      2019-07-06 23:49:31.512 - error: upnp.0 uncaught exception: Cannot read property 'match' of undefined
      2019-07-06 23:49:31.513 - error: upnp.0 TypeError: Cannot read property 'match' of undefined
      at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1390:28)
      at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
      at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-07-06 23:49:32.542 - error: Caught by controller[0]: TypeError: Cannot read property 'match' of undefined
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1390:28)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      2019-07-06 23:49:32.543 - error: Caught by controller[0]: at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      2019-07-06 23:49:32.544 - error: Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-07-06 23:49:32.544 - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 6 (uncaught exception)
      2019-07-06 23:49:32.544 - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
      habe schon alle Geräte rausgenommen, bis auf die Fritzbox
      das ist das einzigste was abgefragt wird
      im Adapter version 1.0.12 ist nur dieses an
      • Jey Cee
        Jey Cee Developer @crunchip last edited by
        @crunchip sagte in UPNP Cannot read property match of undefined:
        Ja, das ist ein Fehler der im Adapter nicht abgefangen wird. Da kannst du aus User Sicht nichts machen.
          sigi234 Forum Testing Most Active last edited by sigi234
          Hallo, bekommst du Werte wenn du auf den Request Button klickst?
            crunchip Forum Testing Most Active @sigi234 last edited by
            @sigi234 ja, es läuft ja auch alles, bis auf die Fehlermeldung 1mal täglich und ab und an auch ein zweites mal.
            Daten werden in Influx geschrieben und in Grafana dargestellt
            • Jey Cee
                crunchip Forum Testing Most Active @Jey Cee last edited by
                @Jey-Cee und woher kommt das, lief ja Tage und Wochen ohne jeglichen Probleme.
                • Jey Cee
                  @crunchip da steht nicht welche Daten in die Funktion gekippt werden oder woher sie kommen, also wie soll ich das beantworten?
                  Wird schon irgendein Gerät ein Update bekommen haben und jetzt andere/zusätzliche Daten senden.
                    crunchip Forum Testing Most Active @Jey Cee last edited by crunchip
                    @Jey-Cee es ist ja nur die Fritzbox drin und diese hat kein neues update bekommen.
                    code6 error match of undefined upnp
