    4. ioBroker.upnp - please test
    • Jey Cee
      Jey Cee Developer @sigi234 last edited by
      @sigi234 das übernehmen ist nicht das Problem, die Basis ist einfach mies.
        sigi234 Forum Testing Most Active @Jey Cee last edited by
        @Jey-Cee sagte in ioBroker.upnp - please test:
        Ist einer meiner Lieblingsadapter..........
        • Jey Cee
          @sigi234 sagte in ioBroker.upnp - please test:
          Was machst du alles damit?
            IT Status :
            Jey Cee 1 Reply Last reply Reply Quote 1
            • Jey Cee
              @sigi234 das ist doch aber nur info von der Fritz Box oder?
                Nein, Daten kommen vom Adapter
                  vllt kann mir hier jemand helfen, hatte schon einen Thread eröffnet aber bisher keine Hilfe.
                  2019-07-07 00:49:31.614 - error: upnp.0 uncaught exception: Cannot read property 'match' of undefined
                  2019-07-07 00:49:31.615 - error: upnp.0 TypeError: Cannot read property 'match' of undefined
                  at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1390:28)
                  at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
                  at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                  at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                  at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                  at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                  at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                  at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                  at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                  at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                  at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                  at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                  at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                  2019-07-07 00:49:32.647 - error: Caught by controller[0]: TypeError: Cannot read property 'match' of undefined
                  2019-07-07 00:49:32.647 - error: Caught by controller[0]: at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1390:28)
                  2019-07-07 00:49:32.647 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
                  2019-07-07 00:49:32.647 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                  2019-07-07 00:49:32.647 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                  2019-07-07 00:49:32.647 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                  2019-07-07 00:49:32.648 - error: Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                  2019-07-07 00:49:32.648 - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 6 (uncaught exception)
                  2019-07-07 00:49:32.648 - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
                  Bluefox 1 Reply Last reply Reply Quote 0
                  • Bluefox
                    Bluefox @crunchip last edited by
                    @crunchip Version upnp?
                    sigi234 crunchip 2 Replies Last reply Reply Quote 0
                      sigi234 Forum Testing Most Active @Bluefox last edited by sigi234
                      @Bluefox
                      version 1.0.12 laut Thread
                        crunchip Forum Testing Most Active @Bluefox last edited by
                        @Bluefox ja wie @sigi234 schon geschrieben
                        • Jey Cee
                          Jey Cee Developer @crunchip last edited by
                          @crunchip kannst du mal den Adapter löschen und von Github neu installieren? Der Fehler sollte jetzt abgefangen werden und im Log wird ausgegeben bei welchem Objekt das Passiert.
                          crunchip 3 Replies Last reply Reply Quote 0
                            crunchip Forum Testing Most Active @Jey Cee last edited by
                            @Jey-Cee ok, werd ich laufe des Tages mal machen und berichten
                              @Jey-Cee hab nun istalliert von git
                              was mir noch eingefallen ist, früher wurden die sky receiver mit gelistet, die aber seit der umstellung auf community nicht mehr im Verzeichnisbaum erscheinen
                              nur im log zu sehen unendlich fortlaufend
                              upnp.0	2019-07-09 16:36:39.575	info	Found new device: http://192.168.xxx.xx:49153/description17.xml
                              upnp.0	2019-07-09 16:36:37.771	info	Found new device: http://192.168.xxx.xx:49153/description8.xml
                              • Jey Cee
                                @crunchip die Meldung hat nix mit dem Fehler zu tun. Wohin gehören den die IP Adressen? Er scheint die Geräte zu finden kann sie aber nicht anlegen und deshalb kommt die Meldung immer wieder.
                                Du kannst auch die XML datei im Browser aufrufen, da steht drin zu welchem Gerät/Dienst sie gehört, das hilft vielleicht auch weiter.
                                  crunchip Forum Testing Most Active @Jey Cee last edited by crunchip
                                  @Jey-Cee das sind meine beiden sky -receiver.
                                  wie gesagt, mit dem alten upnp Adapter wurden diese beiden angelegt, seit der Umstellung des Adapters wird nichts mehr angelegt
                                  aufrufen kann ich da nichts
                                  • Jey Cee
                                    @crunchip und da haben wir das problem, warum die nicht erkannt werden. Der Zugriff auf die XML ist notwendig um die Geräte an zu legen.
                                      @Jey-Cee so sehen nun meine Fehler aus
                                      einzigste ist, das nun nicht mehr jeden Tag, die Fehlermeldungen kommen
                                      2019-07-15 07:54:51.629 - error: upnp.0 uncaught exception: Cannot read property 'LastChange' of undefined
                                      2019-07-15 07:54:51.630 - error: upnp.0 TypeError: Cannot read property 'LastChange' of undefined
                                      at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1384:70)
                                      2019-07-15 07:54:52.664 - error: Caught by controller[0]: TypeError: Cannot read property 'LastChange' of undefined
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1384:70)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                                      2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                      2019-07-15 07:54:52.666 - error: Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                      2019-07-15 07:54:52.666 - error: Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                                      2019-07-15 07:54:52.666 - error: Caught by controller[0]: at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                                      2019-07-15 07:54:52.666 - error: Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                      2019-07-15 07:54:52.666 - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 6 (uncaught exception)
                                      2019-07-15 07:54:52.666 - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
                                      2019-07-15 07:55:22.691 - info: host.IoBroker instance system.adapter.upnp.0 started with pid 30593
                                      2019-07-15 07:55:24.266 - info: upnp.0 starting. Version 1.0.13 in /opt/iobroker/node_modules/iobroker.upnp, node: v10.16.0
                                      2019-07-15 07:55:24.300 - info: upnp.0 Auto discover: false
                                        Andre R. last edited by
                                        kann ich die Geräte die ich nicht brauche unter Objekte eigentlich löschen?
                                        • SBorg
                                          Ich sag mal Jein. Löschen an sich stellt kein Problem dar, nur wenn das entsprechende Gerät selbst UPnP macht, werden sie erneut angelegt 😉
                                            sigi234 Forum Testing Most Active @Andre R. last edited by
                                            @Andre-R sagte in ioBroker.upnp - please test:
                                            Ja, aber beim Adapter die automatische Erkennung ausschalten..........
                                            31.7k
                                            79.8k
                                            adapter test
                                            18
                                            196
                                            19451
