    4. [gelöst] Fehler bei 'iobroker clean yes' - TypeError: undefi
      frankie last edited by
      beim Aufruf von
      iobroker clean yes
      gibt es folgende Fehlermeldung:
      root@raspberrypi:/opt/iobroker# iobroker clean
      Command "clean" clears all Objects and States. To execute it write "iobroker clean yes"
      root@raspberrypi:/opt/iobroker# iobroker clean yes
      /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1677
              objects.destroyDB(function () {
      TypeError: undefined is not a function
          at cleanDatabase (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1677:17)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:882:21
          at Object.States.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2284:70)
          at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/statesInMemClient.js:80:68)
          at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
          at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:129:10)
          at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:308:8)
          at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:208:12)
          at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      root@raspberrypi:/opt/iobroker#</anonymous></anonymous>
      Gibt es noch eine Einstellung, welche ich übersehen habe, oder handelt es sich um einen "echten" Fehler.
      Frank
      • Bluefox
        Bluefox last edited by
        Es ist ein echter Fehler. Muss schauen. Danke.
        • Bluefox
          Falls du ioBroker vorher stoppst, dann kriegst diese Fehlermeldung nicht. Habe gefixt. Danke.
            @Bluefox:
            Falls du ioBroker vorher stoppst, dann kriegst diese Fehlermeldung nicht. Habe gefixt. Danke. `
            Super schnelle Antwort!!!!!!!!!!!!!!
            Wie komme ich denn Deinen Fix? Denn ich würde den Befehl "iobroker clean yes" gerne im Zusammenhang mit http://forum.iobroker.org/viewtopic.php?f=22&t=1129 testen wollen.
            • Bluefox
              cd /opt/iobroker
              npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
              Du kannst aber einfach /opt/iobroker/iobroker-data Verzeichnis löschen und dann
              cd /opt/iobroker
              iobroker setup
              aufrufen.
                Habe heute nach einem erfolgreichem Update die Funktion testen können.
                Stop ioBroker first!
                root@raspberrypi:/opt/iobroker# iobroker stop
                Stopping ioBroker controller daemon...
                ioBroker controller daemon stopped.
                Deleted 219 states
                Starting node restart.js
                Restarting ioBroker...
