    4. IoBroker.scenes
    IoBroker.scenes
    • ruhr70
      ruhr70 last edited by
      Die Installation ging irgendwie schief 😞
      root@iobroker:~# cd /opt/iobroker
      root@iobroker:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.scenes/tarball/master
      > iobroker.scenes@0.0.1 install /opt/iobroker/node_modules/iobroker.scenes
      > node main.js --install
      2015-08-04 21:50:26.430  - info: scenes.0 starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.scenes
      ^Croot@iobroker:/opt/iobroker# 2015-08-04 21:51:43.404  - info: scenes.0 terminating
      nach 1,5 Minuten mit strg + c abgebrochen
      dann, trotzdem mutig:
      root@iobroker:/opt/iobroker# ./iobroker add scenes
      install adapter scenes
      npm install --production --prefix "/opt/iobroker/node_modules/iobroker.scenes" (System call)
      npm WARN cannot run in wd iobroker.scenes@0.0.1 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.scenes)
      got /opt/iobroker/node_modules/iobroker.scenes/admin
      upload [4] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/words.js words.js application/javascript
      upload [3] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/tab.js tab.js application/javascript
      upload [2] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/tab.html tab.html text/html
      upload [1] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/scenes.png scenes.png image/png
      upload [0] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/index.html index.html text/html
      object system.adapter.scenes created
      create instance scenes
      object system.adapter.scenes.0.uptime created
      object system.adapter.scenes.0.memRss created
      object system.adapter.scenes.0.memHeapTotal created
      object system.adapter.scenes.0.memHeapUsed created
      object system.adapter.scenes.0.connected created
      object system.adapter.scenes.0.alive created
      object system.adapter.scenes.0 created
      seitdem komme ich nicht mehr auf ioBroker/admin 😞
      es lädt nur eine weiße Seite, zwischendurch dreht sich mal kurz das Zahnrad.
      ioBroker habe ich mit stop/start einmal neu gestartet
      VIS, VIS Edit, Flot,funktionieren
        Danach taucht gar nichts mehr auf 😢
        bleibt hier irgendwie hängen:
        root@quad-pi:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.scenes/tarball/master
        npm http GET https://github.com/ioBroker/ioBroker.scenes/tarball/master
        npm http 200 https://github.com/ioBroker/ioBroker.scenes/tarball/master
        2015-08-04 21:52:09.531  - info: scenes.0 starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.scenes
        wenn ich vorher iobroker stoppe:
        root@quad-pi:/opt/iobroker# iobroker stop
        Stopping ioBroker controller daemon...
        ioBroker controller daemon stopped.
        2015-08-04 21:50:14.388  - warn: scenes.0 no connection to objects DB
        iobroker.scenes@0.0.1 node_modules/iobroker.scenes
        Da kommt er wenigstens wieder zu sich 😉
        auf den admin komme ich nicht mehr, auch kein drehendes Zahnrad (nur ganz kurz - dann alles weiß)
        Zweimal CTRL-C dann: adapter scenes terminating
        und jetzt kann ich eingeben:
        root@quad-pi:/opt/iobroker# iobroker add scenes
        root@quad-pi:/opt/iobroker# reboot
        Nach dem reboot auch nichts mehr.
        Rainer
        • ruhr70
          Du hast von mir abgeschrieben 😉
          bei mir ist es nur leider das Produktivsystem 😞
            @ruhr70:
            bei mir ist es nur leider das Produktivsystem 😞 `
            Dito!!!
            Rainer
              pix last edited by
              Trau mich jetzt gar nicht, zu testen. Hab nur das Produktivsystem.
              Gesendet von meinem iPhone mit Tapatalk
              • ruhr70
                root@iobroker:/opt/iobroker# ./iobroker del scenes
                delete /opt/iobroker/node_modules/iobroker.js-controller/lib/../../iobroker.scenes
                Counted 1 instances of scenes
                Counted 6 states (system.adapter.scenes.*) from states
                Counted 1 adapters for scenes
                Counted 6 states of scenes
                Deleting 8 object(s).
                root@iobroker:/opt/iobroker# ./iobroker stop
                root@iobroker:/opt/iobroker# ./iobroker start
                Starting ioBroker controller daemon...
                ioBroker controller daemon started. PID: 5115
                hat geholfen…
                • ruhr70
                  pix, Du hattest doch immer geschrieben… Datensicherung, Datensicherung, ...
                  trau Dich :twisted: 🙂
                  Das mit den Szenen ist schon cool.
                    Da bist du mir schon wieder zuvorgekommen!
                    ich geh jetzt ins Bett, es läuft ja wieder.
                    Rainer
                    • Bluefox
                      Bluefox last edited by
                      Installation habe ich jetzt gefixt.
                      Mit neuer Version vom admin sehe ich das Problem nicht mehr:
                      cd /opt/iobroker
                      npm install https://github.com/ioBroker/ioBroker.admin/tarball/master
                      iobroker add scenes
                      • ruhr70
                        Funktioniert! Sieht aus, als ob der Adapter Potential hat!
                        Man kann wunderbar die Szenen definieren, für true und für false. Mit dem aktuellen hue Adapter können auch die hue Lampen ganz gezielt eingestellt werden.
                        Sieht klasse aus!
                        Jetzt geht ich erst einmal schlafen. Morgen teste ich damit. Gefällt mir auf jeden Fall bisher sehr gut 🙂
                          pix last edited by
                          ich habe mich getraut und wurde belohnt.Ich bin begeistert. 😄
                          Ein paar Fragen zum Verständnis:
                          Kann man Gruppen, wie Direktverknüpfungen verstehen?
                          Werden die festgelegten States bei der Realisierung einer Scene im Burstmodus gesetzt (Funkhygiene) oder irgendwie nacheinander?
                          Macht es Sinn zB Abwesenheit als Szene oder als Gruppe zu beschreiben (alle Lichter aus, einzelne [nicht alle] Geräte aus, Anwesenheit=aus, Alarmanlage=aus [Delay 45s])?
                          Auf jeden Fall ein Top-Geschichte, die sehr viel Scripte spart.
                          Kleine Anregeung: Bitte die Spalte "Name" etwas breiter (auf Kosten der flexiblen Spalte Beschreibung).
                          Pix
                            pix last edited by
                            Noch eine Kleinigkeit:
                            Wenn ich Zustände erneut hinzufüge (mit dem + Button), werden die bisher schon hinzugefügten noch einmal zugefügt.
                            Pix
                              pix last edited by
                              Es gibt wohl doch etwas mehr Probleme:
                              2015-08-04 23:13:30.213  - info: host.MacMini-Ethernet.fritz.box instance system.adapter.scenes.0 started with pid 43079
                              2015-08-04 23:13:30.844  - info: scenes.0 starting. Version 0.0.1 in /Users/pix/Desktop/iobroker/node_modules/iobroker.scenes
                              2015-08-04 23:14:46.609  - error: uncaught exception: Cannot call method 'toString' of undefined
                              2015-08-04 23:14:46.613  - error: TypeError: Cannot call method 'toString' of undefined
                                  at checkTrigger (/Users/pix/Desktop/iobroker/node_modules/iobroker.scenes/main.js:187:118)
                                  at Adapter.id (/Users/pix/Desktop/iobroker/node_modules/iobroker.scenes/main.js:32:17)
                                  at Adapter.emit (events.js:98:17)
                                  at null._onTimeout (/Users/pix/Desktop/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1865:34)
                                  at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
                              2015-08-04 23:14:46.920  - error: host.MacMini-Ethernet.fritz.box instance system.adapter.scenes.0 terminated with code 6 (uncaught exception)
                              Lasse es erstmal dabei. Morgen gehts weiter 😉
                              • Bluefox
                                @pix:
                                Lasse es erstmal dabei. Morgen gehts weiter 😉 `
                                Danke. Im letzen Moment eingebaute Debug-Outputs haben versagt.
                                jetzt sollte gehen.
                                Ja
                                Das ist die Aufgabe von hm-rpc Adapter. Obwohl falls es wirklich nicht geht, ich kann eine Einstellung einbauen: Intervall zwischen Befehlen.
                                Alarmanlage=ein ?
                                Ja, genau das.
                                Sollte auch gefixt werden.
                                Nicht vergessen nach update einen Upload aufrufen.
                                iobroker upload scenes
                                • ruhr70
                                  Die Objekte (Szenen) werden nicht in einer Baumstruktur abgelegt, wie bei den anderen Adapter. Für jede Szene wird in Ebene 1 in den Objekten eine neue Zeile erzeugt.
                                  • Bluefox
                                    @ruhr70:
                                    Die Objekte (Szenen) werden nicht in einer Baumstruktur abgelegt, wie bei den anderen Adapter. Für jede Szene wird in Ebene 1 in den Objekten eine neue Zeile erzeugt. `
                                    Na ja. Um eine Ebene zu erschaffen, braucht ein Objekt zwei stufen zu haben.
                                    Falls du deine Szenen "common.szene1" und "common.szene2" nennst, dann wird es gruppiert.
                                    Ich kann wirklich machen, dass die Szenen erst mal unter "scene.all" abgelegt werden.
                                    Oder ich werde machen, dass alle Szenen "scenes.scene.xxx" heißen. Bin noch nicht schlüssig.
                                    GEHT das überhaupt?
                                    • ruhr70
                                      Ich dachte an scenes.0
                                      Aber jetzt wo Du das schreibt, ist mir gerade bewusst geworden, dass man die Szenennamen mit bedacht wählen sollte. Wenn man sie fleissig verwendet (Vis, Javascript, suw.) und dann auf die Idee kommt, die Szenen umzubenennen, bzw. die Namen neu zu strukturieren, stimmen alle Datenpunkte nicht mehr (Vis, Javascript, usw).
                                      @Bluefox:
                                      GEHT das überhaupt? `
                                      • Bluefox
                                        > GEHT das überhaupt?
                                        Geht iobroker.scenes? Kannst du was schalten damit?
                                        scenes.0 geht nicht, weil man kann mehrere scenes Adapterinstanzen haben (weiß noch nicht wozu :lol: ) und man kann jede Szene zu einer Instanz zuweisen.
                                        Dann kommt so was wie scene.0.blabla wird auf dem Adapter scenes.1 ausgeführt. Verwirrt.
                                        Richtig…
                                        Also "scenes.scene.blabla" ?
                                        • Bluefox
                                          Es gibt neue Version. Man muss aber die Szenen neu konfigurieren.
                                          • ruhr70
                                            @Bluefox:
                                            > GEHT das überhaupt?
                                            Geht iobroker.scenes? Kannst du was schalten damit? `
                                            ja, geht 🙂
                                            64
                                            14410
