Script Hilfe licht über Xiaomi Switch anschalten.
@iomountain Wo soll ich da einen Baustein anhängen?
@iomountain
so also? Welches Objekt kommt dort rein? -
das, welches dein Licht an aus schaltet
@iomountain Hab ich jetzt drin. Passiert leider nichts.
mach mal einen Export von deinem Code
@iomountain <xml xmlns="http://www.w3.org/1999/xhtml">
<block type="comment" id="@cY?z8Mo[rp~6xjYRB9" x="88" y="-462">
<field name="COMMENT">Taster XIAOMI Nr. 3</field>
<block type="on_ext" id="PB-24CkO9W+A,wx(U/~p">
<mutation items="6"></mutation>
<field name="CONDITION">gt</field>
<field name="ACK_CONDITION">true</field>
<value name="OID0">
<shadow type="field_oid" id=")QiF{:XZIsphth0IP^H">
<block type="field_oid" id="rgjNSi2xzP32iFTE[Zr"> <field name="oid">mihome.0.devices.switch_158d0001e5c139.click</field> </block> </value> <value name="OID1"> <shadow type="field_oid" id="iaF=)P=-;PAAd,)/4%vi"> <field name="oid">default</field> </shadow> <block type="field_oid" id="ea3t6_MlYEPR}*?yzCqA"> <field name="oid">zigbee.0.00158d0002b02f86.double_click</field> </block> </value> <value name="OID2"> <shadow type="field_oid" id="^US+uZxi^vOuQI|KuALq"> <field name="oid">default</field> </shadow> <block type="field_oid" id="Ro15Nv;8Sl9+.0nGHq^%"> <field name="oid">zigbee.0.00158d0002b02f86.triple_click</field> </block> </value> <value name="OID3"> <shadow type="field_oid" id="R2Lb}B~M^5V1#^vXl,xw"> <field name="oid">default</field> </shadow> <block type="field_oid" id="=?EUmg0.O3+z.RryC=xB"> <field name="oid">zigbee.0.00158d0002b02f86.quad_click</field> </block> </value> <value name="OID4"> <shadow type="field_oid" id="9i}=7+CVZh@d7@#)C3;}"> <field name="oid">default</field> </shadow> <block type="field_oid" id="?ojg03%rW]}Gl-_0!1x">
<field name="oid">zigbee.0.00158d0002b02f86.many_click</field>
<value name="OID5">
<shadow type="field_oid" id="?EarP}N#oxmuZYcD#w?A">
<block type="field_oid" id="Qn6/h8f3[DPd@i5_M8">
<field name="oid">zigbee.0.00158d0002b02f86.long_click</field>
<block type="debug" id="r/YqCq!4BPo^D%562f@H">
<value name="TEXT">
<shadow type="text" id="5hv99z~G)/zHUNWPf~">
<field name="TEXT">es wurde geklickt</field>
<block type="controls_if" id="^%rfwf,9(7^?Gd1W(2rH">
<mutation elseif="5"></mutation>
<block type="logic_compare" id="B7oHd]+ob+83AYT#!UOR">
<field name="OP">EQ</field>
<block type="get_value" id="%l[Ebz+^3abG+/nZ_|%6">
<field name="OID">zigbee.0.00158d0002b02f86.click</field>
<block type="logic_boolean" id="ciW[o-HOq!fpNWr0GQx">
<block type="debug" id="77)Pc:(kqD!l@AdFktg"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="?D:soVS]Ik_MSh,2sepk"> <field name="TEXT">click</field> </shadow> </value> <next> <block type="comment" id="i*jra%1wLggjCGzi/q{W"> <field name="COMMENT">je nach click</field> <next> <block type="controls_if" id="EG3ol;@J!t^@8umkneD">
<block type="logic_operation" id="K{W%]KSw7P4gp:O[UgD">
<field name="OP">OR</field>
<block type="logic_compare" id="h^93g38,nk?n5B7-T|-2">
<block type="get_value" id="{LHVnt1Z}O9p}y;p9yW)">
<field name="OID">sonoff.0.Licht.POWER</field>
<block type="logic_boolean" id="i]3e]XF.PqOq6jySU-7A">
<block type="logic_compare" id="Q_d6K+s7Xy3z=yM8JKI"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="N:?5:-:R9O-Gf(9;Y4*4"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Licht.POWER</field> </block> </value> <value name="B"> <block type="logic_boolean" id="[2d@d1(/KA:U_9qBxzt|"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="comment" id="5{]Wn0u@#w@rdTXb)SiY"> <field name="COMMENT">Wenn eine Lampe an dann alle aus</field> <next> <block type="debug" id="D1jJ!hg8?416.fo8A]Ig"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="EQV5T+^(Oc^%jddr?Ed/"> <field name="TEXT">ausschalten</field> </shadow> </value> <next> <block type="control" id="QyX=!8$VR$)D=UhC1sa1"> <mutation delay_input="false"></mutation> <field name="OID">sonoff.0.Licht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="V2End:lo3Xwl#Gp^:9ne"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> <statement name="ELSE"> <block type="comment" id=":x2uA2sM^Tb!]7~%Y@3."> <field name="COMMENT">Objekt schalten, bitte anpassen</field> <next> <block type="control" id="79;%-wMLM(l4pnH}_Ug?"> <mutation delay_input="false"></mutation> <field name="OID">sonoff.0.Licht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="OqQ-6Zdl=qm``H}c+r1">
<block type="comment" id="L?|+,b8)F9%Bpv]ZlSK/">
<field name="COMMENT">Sonst lampe an</field>
<block type="debug" id="[7.r]dibVzq:nExle;C"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="AjqibEkM(*AUc-I[Fh.">
<field name="TEXT">einschalten</field>
<block type="comment" id="khXz:g:a01UL0NVB(/0A">
<block type="control" id="i4iv,I2$Lg=Y3hXGM">
<block type="logic_boolean" id="$7ncThkUUTn~-05X$uEg">
<value name="IF1">
<block type="logic_compare" id="{RB1T]6_|We%X^x8y,e3">
<block type="get_value" id="]JqpodS[1k}8wvU%ljY"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d0002b02f86.double_click</field> </block> </value> <value name="B"> <block type="logic_boolean" id="D({5v+n5fghCkGs68}ch"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO1"> <block type="debug" id="]OGemcpFY;b;lh4Z[aK/"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="fO(2D5-!_m|U:zj[5fsa"> <field name="TEXT">double click</field> </shadow> </value> <next> <block type="comment" id="B7Y#DekBTX23lCB-|,L]"> <field name="COMMENT">je nach click</field> </block> </next> </block> </statement> <value name="IF2"> <block type="logic_compare" id="Awyl1ugjhBcRcUAJOL+l"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="l4xIsUAecIpJqodgO-4">
<field name="OID">zigbee.0.00158d0002b02f86.triple_click</field>
<block type="logic_boolean" id="g]#YKK0GlZp2U(E|G|(">
<statement name="DO2">
<block type="debug" id="gr9O^S~?R+-0b:S-sb!L">
<value name="TEXT">
<shadow type="text" id="1[hmvn+t^pr2j.fEi2rb">
<field name="TEXT">tripple click</field>
<block type="comment" id="0,;Y]y4[u[]+Bs1s=Epw">
<value name="IF3">
<block type="logic_compare" id="5Ultno,QEkbPOIz4+x="> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="^,!TJk?QHXNhp0f24SIM"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d0002b02f86.quad_click</field> </block> </value> <value name="B"> <block type="logic_boolean" id="^0tE{Uw^Aw9]{aM4v%#,"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO3"> <block type="debug" id="uM,~ogj7YUW+_9GH@qK">
<value name="TEXT">
<shadow type="text" id="vf-TRBU!EW^99MhKz-^D">
<field name="TEXT">vierfach click</field>
<block type="comment" id="b)rKt;?q#O/WQ!S8W">
<value name="IF4">
<block type="logic_compare" id="5P6jpTQ+SQg)Z-ZWuBCK">
<block type="get_value" id="LPfGX2rys@=v3mC2^-73">
<field name="OID">zigbee.0.00158d0002b02f86.many_click</field>
<block type="logic_boolean" id="ris=X#TgK=1+0COq?uuC">
<statement name="DO4">
<block type="debug" id="Br~kIi5^8x!xr.94.PB:">
<value name="TEXT">
<shadow type="text" id="ZrcdR6T{YcUD=]O;S+-"> <field name="TEXT">viele click</field> </shadow> </value> <next> <block type="comment" id="@d7VxOC1QmAoaKcahHk3"> <field name="COMMENT">je nach click</field> </block> </next> </block> </statement> <value name="IF5"> <block type="logic_compare" id="Gt2b(|.gt?d1z,%g%99I"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="4[vb;-7^8ow]IE0ZF~[">
<field name="OID">zigbee.0.00158d0002b02f86.long_click</field>
<block type="logic_boolean" id="ay}{%b(r.^GlnijvJuN^">
<statement name="DO5">
<block type="debug" id="OU:gQT3@u=HQrMl8Hq+%">
<value name="TEXT">
<shadow type="text" id="M(F:?:]%Jg?msY]k^F)n">
<field name="TEXT">lang click</field>
<block type="comment" id="8R^HYo2yE!:l@set:4i">
<field name="COMMENT">je nach click </field>
</xml> -
@iomountain Wie mache ich das denn eigentlich in so nem Kasten
@Noé1237
erst auf Spoiler drücken, dann auf Code, dann einfügenhab's mal ein wenig gekürzt und aufgeräumt
@iomountain achso okey, danke. Weißt du woran es liegt?
@Noé1237 sagte in Script Hilfe licht über Xiaomi Switch anschalten.:
was?
funktioniert dein "simple click" -
@iomountain Ne ich frage ja ob du weißt wieso es nicht funktioniert. Aktuell passiert gar nichts wenn ich drücke.
so ist das Script gestoppt.
was sagt das Log?
Das was in den Debug Baustein steht müsste im LOG auftauchen. -
@iomountain Script ist an.
so sieht mein log aus -
das letzte Script, das gekürzte und aufgeräumte, und was kommt im Log wenn du bei diesem einen Click machst?
2019-07-11 14:31:17.380 - [32minfo[39m: radar2.0 Adapter disconnected and stopped with dostop(false) and callback(true) 2019-07-11 14:31:17.733 - [32minfo[39m: radar2.0 found '@abandonware/noble' 2019-07-11 14:31:17.742 - [33mwarn[39m: radar2.0 node-bluetooth not found! 2019-07-11 14:31:17.743 - [32minfo[39m: radar2.0 radar2 set to flag items away if they are not seen for 6 minutes 2019-07-11 14:31:17.745 - [32minfo[39m: radar2.0 use known BT list: [ '01:12:23:34:45:56' ] 2019-07-11 14:31:17.746 - [32minfo[39m: radar2.0 use known IP list: [ '1.1.1.1' ] 2019-07-11 14:31:17.747 - [32minfo[39m: radar2.0 Remove name end for host names: .fritz.box 2019-07-11 14:31:17.750 - [32minfo[39m: radar2.0 arp-scan will use the following interfaces: [ 'eth0' ] 2019-07-11 14:31:17.751 - [32minfo[39m: radar2.0 radar2 set to scan every 30 seconds and printers every 720 minutes. 2019-07-11 14:31:17.833 - [31merror[39m: Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67 2019-07-11 14:31:17.834 - [31merror[39m: Caught by controller[0]: at _handle.lookup (dgram.js:266:18) 2019-07-11 14:31:17.834 - [31merror[39m: Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:142:11) 2019-07-11 14:31:17.834 - [31merror[39m: Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9) 2019-07-11 14:31:17.834 - [31merror[39m: Caught by controller[0]: errno: 'EACCES', 2019-07-11 14:31:17.834 - [31merror[39m: Caught by controller[0]: code: 'EACCES', 2019-07-11 14:31:17.834 - [31merror[39m: Caught by controller[0]: syscall: 'bind', 2019-07-11 14:31:17.834 - [31merror[39m: Caught by controller[0]: address: '0.0.0.0', 2019-07-11 14:31:17.834 - [31merror[39m: Caught by controller[0]: port: 67 } 2019-07-11 14:31:17.835 - [31merror[39m: host.ioBroker-Pi instance system.adapter.radar2.0 terminated with code 0 (OK) 2019-07-11 14:31:17.835 - [32minfo[39m: host.ioBroker-Pi Restart adapter system.adapter.radar2.0 because enabled 2019-07-11 14:31:20.651 - [31merror[39m: rpi2.0 No Value found for cpu_frequency 2019-07-11 14:31:20.961 - [32minfo[39m: javascript.0 script.js.Schalter_Tür_und_Bett: es wurde geklickt 2019-07-11 14:31:20.962 - [33mwarn[39m: javascript.0 getState "zigbee.0.00158d0002b02f86.click" not found (3) 2019-07-11 14:31:20.965 - [33mwarn[39m: javascript.0 at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:4:7) 2019-07-11 14:31:20.965 - [33mwarn[39m: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38) 2019-07-11 14:31:20.965 - [33mwarn[39m: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25) 2019-07-11 14:31:20.965 - [33mwarn[39m: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37) 2019-07-11 14:31:20.965 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) 2019-07-11 14:31:20.966 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.966 - [33mwarn[39m: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) 2019-07-11 14:31:20.966 - [33mwarn[39m: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) 2019-07-11 14:31:20.966 - [33mwarn[39m: javascript.0 at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.966 - [33mwarn[39m: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.966 - [33mwarn[39m: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) 2019-07-11 14:31:20.966 - [33mwarn[39m: javascript.0 at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.966 - [33mwarn[39m: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) 2019-07-11 14:31:20.967 - [33mwarn[39m: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) 2019-07-11 14:31:20.967 - [33mwarn[39m: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) 2019-07-11 14:31:20.967 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.967 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.967 - [33mwarn[39m: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) 2019-07-11 14:31:20.967 - [33mwarn[39m: javascript.0 at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) 2019-07-11 14:31:20.967 - [33mwarn[39m: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.967 - [33mwarn[39m: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) 2019-07-11 14:31:20.967 - [33mwarn[39m: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) 2019-07-11 14:31:20.968 - [33mwarn[39m: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) 2019-07-11 14:31:20.968 - [33mwarn[39m: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) 2019-07-11 14:31:20.968 - [33mwarn[39m: javascript.0 at emitTwo (events.js:126:13) 2019-07-11 14:31:20.968 - [33mwarn[39m: javascript.0 at WebSocket.emit (events.js:214:7) 2019-07-11 14:31:20.968 - [33mwarn[39m: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) 2019-07-11 14:31:20.968 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18 2019-07-11 14:31:20.968 - [33mwarn[39m: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5) 2019-07-11 14:31:20.968 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14 2019-07-11 14:31:20.968 - [33mwarn[39m: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3) 2019-07-11 14:31:20.969 - [33mwarn[39m: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12) 2019-07-11 14:31:20.969 - [33mwarn[39m: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31) 2019-07-11 14:31:20.969 - [33mwarn[39m: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24) 2019-07-11 14:31:20.969 - [33mwarn[39m: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20) 2019-07-11 14:31:20.969 - [33mwarn[39m: javascript.0 at emitOne (events.js:116:13) 2019-07-11 14:31:20.969 - [33mwarn[39m: javascript.0 at Socket.emit (events.js:211:7) 2019-07-11 14:31:20.969 - [33mwarn[39m: javascript.0 at addChunk (_stream_readable.js:263:12) 2019-07-11 14:31:20.969 - [33mwarn[39m: javascript.0 at readableAddChunk (_stream_readable.js:250:11) 2019-07-11 14:31:20.969 - [33mwarn[39m: javascript.0 at Socket.Readable.push (_stream_readable.js:208:10) 2019-07-11 14:31:20.970 - [33mwarn[39m: javascript.0 at TCP.onread (net.js:601:20) 2019-07-11 14:31:20.970 - [33mwarn[39m: javascript.0 getState "zigbee.0.00158d0002b02f86.double_click" not found (3) 2019-07-11 14:31:20.973 - [33mwarn[39m: javascript.0 at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:19:14) 2019-07-11 14:31:20.973 - [33mwarn[39m: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38) 2019-07-11 14:31:20.973 - [33mwarn[39m: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25) 2019-07-11 14:31:20.974 - [33mwarn[39m: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37) 2019-07-11 14:31:20.974 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) 2019-07-11 14:31:20.974 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.974 - [33mwarn[39m: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) 2019-07-11 14:31:20.974 - [33mwarn[39m: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) 2019-07-11 14:31:20.974 - [33mwarn[39m: javascript.0 at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.974 - [33mwarn[39m: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.974 - [33mwarn[39m: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) 2019-07-11 14:31:20.974 - [33mwarn[39m: javascript.0 at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.975 - [33mwarn[39m: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) 2019-07-11 14:31:20.975 - [33mwarn[39m: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) 2019-07-11 14:31:20.975 - [33mwarn[39m: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) 2019-07-11 14:31:20.975 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.975 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.975 - [33mwarn[39m: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) 2019-07-11 14:31:20.975 - [33mwarn[39m: javascript.0 at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) 2019-07-11 14:31:20.975 - [33mwarn[39m: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.975 - [33mwarn[39m: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) 2019-07-11 14:31:20.976 - [33mwarn[39m: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) 2019-07-11 14:31:20.976 - [33mwarn[39m: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) 2019-07-11 14:31:20.976 - [33mwarn[39m: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) 2019-07-11 14:31:20.976 - [33mwarn[39m: javascript.0 at emitTwo (events.js:126:13) 2019-07-11 14:31:20.976 - [33mwarn[39m: javascript.0 at WebSocket.emit (events.js:214:7) 2019-07-11 14:31:20.976 - [33mwarn[39m: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) 2019-07-11 14:31:20.976 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18 2019-07-11 14:31:20.976 - [33mwarn[39m: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5) 2019-07-11 14:31:20.977 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14 2019-07-11 14:31:20.977 - [33mwarn[39m: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3) 2019-07-11 14:31:20.977 - [33mwarn[39m: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12) 2019-07-11 14:31:20.977 - [33mwarn[39m: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31) 2019-07-11 14:31:20.977 - [33mwarn[39m: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24) 2019-07-11 14:31:20.977 - [33mwarn[39m: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20) 2019-07-11 14:31:20.977 - [33mwarn[39m: javascript.0 at emitOne (events.js:116:13) 2019-07-11 14:31:20.977 - [33mwarn[39m: javascript.0 at Socket.emit (events.js:211:7) 2019-07-11 14:31:20.977 - [33mwarn[39m: javascript.0 at addChunk (_stream_readable.js:263:12) 2019-07-11 14:31:20.978 - [33mwarn[39m: javascript.0 at readableAddChunk (_stream_readable.js:250:11) 2019-07-11 14:31:20.978 - [33mwarn[39m: javascript.0 at Socket.Readable.push (_stream_readable.js:208:10) 2019-07-11 14:31:20.978 - [33mwarn[39m: javascript.0 at TCP.onread (net.js:601:20) 2019-07-11 14:31:20.978 - [33mwarn[39m: javascript.0 getState "zigbee.0.00158d0002b02f86.triple_click" not found (3) 2019-07-11 14:31:20.981 - [33mwarn[39m: javascript.0 at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:22:14) 2019-07-11 14:31:20.981 - [33mwarn[39m: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38) 2019-07-11 14:31:20.981 - [33mwarn[39m: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25) 2019-07-11 14:31:20.982 - [33mwarn[39m: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37) 2019-07-11 14:31:20.982 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) 2019-07-11 14:31:20.982 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.982 - [33mwarn[39m: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) 2019-07-11 14:31:20.982 - [33mwarn[39m: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) 2019-07-11 14:31:20.982 - [33mwarn[39m: javascript.0 at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.982 - [33mwarn[39m: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.982 - [33mwarn[39m: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) 2019-07-11 14:31:20.982 - [33mwarn[39m: javascript.0 at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.983 - [33mwarn[39m: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) 2019-07-11 14:31:20.983 - [33mwarn[39m: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) 2019-07-11 14:31:20.983 - [33mwarn[39m: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) 2019-07-11 14:31:20.983 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.983 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.988 - [33mwarn[39m: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) 2019-07-11 14:31:20.988 - [33mwarn[39m: javascript.0 at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) 2019-07-11 14:31:20.988 - [33mwarn[39m: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.988 - [33mwarn[39m: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) 2019-07-11 14:31:20.988 - [33mwarn[39m: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) 2019-07-11 14:31:20.988 - [33mwarn[39m: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) 2019-07-11 14:31:20.988 - [33mwarn[39m: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) 2019-07-11 14:31:20.989 - [33mwarn[39m: javascript.0 at emitTwo (events.js:126:13) 2019-07-11 14:31:20.989 - [33mwarn[39m: javascript.0 at WebSocket.emit (events.js:214:7) 2019-07-11 14:31:20.989 - [33mwarn[39m: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) 2019-07-11 14:31:20.989 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18 2019-07-11 14:31:20.989 - [33mwarn[39m: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5) 2019-07-11 14:31:20.989 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14 2019-07-11 14:31:20.989 - [33mwarn[39m: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3) 2019-07-11 14:31:20.989 - [33mwarn[39m: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12) 2019-07-11 14:31:20.989 - [33mwarn[39m: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31) 2019-07-11 14:31:20.990 - [33mwarn[39m: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24) 2019-07-11 14:31:20.990 - [33mwarn[39m: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20) 2019-07-11 14:31:20.990 - [33mwarn[39m: javascript.0 at emitOne (events.js:116:13) 2019-07-11 14:31:20.990 - [33mwarn[39m: javascript.0 at Socket.emit (events.js:211:7) 2019-07-11 14:31:20.990 - [33mwarn[39m: javascript.0 at addChunk (_stream_readable.js:263:12) 2019-07-11 14:31:20.990 - [33mwarn[39m: javascript.0 at readableAddChunk (_stream_readable.js:250:11) 2019-07-11 14:31:20.990 - [33mwarn[39m: javascript.0 at Socket.Readable.push (_stream_readable.js:208:10) 2019-07-11 14:31:20.990 - [33mwarn[39m: javascript.0 at TCP.onread (net.js:601:20) 2019-07-11 14:31:20.991 - [33mwarn[39m: javascript.0 getState "zigbee.0.00158d0002b02f86.quad_click" not found (3) 2019-07-11 14:31:20.994 - [33mwarn[39m: javascript.0 at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:25:14) 2019-07-11 14:31:20.994 - [33mwarn[39m: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38) 2019-07-11 14:31:20.994 - [33mwarn[39m: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25) 2019-07-11 14:31:20.994 - [33mwarn[39m: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37) 2019-07-11 14:31:20.994 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) 2019-07-11 14:31:20.994 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.995 - [33mwarn[39m: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) 2019-07-11 14:31:20.995 - [33mwarn[39m: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) 2019-07-11 14:31:20.995 - [33mwarn[39m: javascript.0 at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.995 - [33mwarn[39m: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.995 - [33mwarn[39m: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) 2019-07-11 14:31:20.995 - [33mwarn[39m: javascript.0 at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.995 - [33mwarn[39m: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) 2019-07-11 14:31:20.995 - [33mwarn[39m: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) 2019-07-11 14:31:20.995 - [33mwarn[39m: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) 2019-07-11 14:31:20.996 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:20.996 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.996 - [33mwarn[39m: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) 2019-07-11 14:31:20.996 - [33mwarn[39m: javascript.0 at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) 2019-07-11 14:31:20.996 - [33mwarn[39m: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:20.996 - [33mwarn[39m: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) 2019-07-11 14:31:20.996 - [33mwarn[39m: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) 2019-07-11 14:31:20.996 - [33mwarn[39m: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) 2019-07-11 14:31:20.997 - [33mwarn[39m: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) 2019-07-11 14:31:20.997 - [33mwarn[39m: javascript.0 at emitTwo (events.js:126:13) 2019-07-11 14:31:20.997 - [33mwarn[39m: javascript.0 at WebSocket.emit (events.js:214:7) 2019-07-11 14:31:20.997 - [33mwarn[39m: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) 2019-07-11 14:31:20.997 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18 2019-07-11 14:31:20.997 - [33mwarn[39m: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5) 2019-07-11 14:31:20.997 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14 2019-07-11 14:31:20.997 - [33mwarn[39m: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3) 2019-07-11 14:31:20.997 - [33mwarn[39m: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12) 2019-07-11 14:31:20.998 - [33mwarn[39m: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31) 2019-07-11 14:31:20.998 - [33mwarn[39m: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24) 2019-07-11 14:31:20.998 - [33mwarn[39m: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20) 2019-07-11 14:31:20.998 - [33mwarn[39m: javascript.0 at emitOne (events.js:116:13) 2019-07-11 14:31:20.998 - [33mwarn[39m: javascript.0 at Socket.emit (events.js:211:7) 2019-07-11 14:31:20.998 - [33mwarn[39m: javascript.0 at addChunk (_stream_readable.js:263:12) 2019-07-11 14:31:20.998 - [33mwarn[39m: javascript.0 at readableAddChunk (_stream_readable.js:250:11) 2019-07-11 14:31:20.998 - [33mwarn[39m: javascript.0 at Socket.Readable.push (_stream_readable.js:208:10) 2019-07-11 14:31:20.998 - [33mwarn[39m: javascript.0 at TCP.onread (net.js:601:20) 2019-07-11 14:31:20.999 - [33mwarn[39m: javascript.0 getState "zigbee.0.00158d0002b02f86.many_click" not found (3) 2019-07-11 14:31:21.002 - [33mwarn[39m: javascript.0 at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:28:14) 2019-07-11 14:31:21.002 - [33mwarn[39m: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38) 2019-07-11 14:31:21.002 - [33mwarn[39m: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25) 2019-07-11 14:31:21.002 - [33mwarn[39m: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37) 2019-07-11 14:31:21.002 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) 2019-07-11 14:31:21.002 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:21.003 - [33mwarn[39m: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) 2019-07-11 14:31:21.003 - [33mwarn[39m: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) 2019-07-11 14:31:21.003 - [33mwarn[39m: javascript.0 at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:21.003 - [33mwarn[39m: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:21.003 - [33mwarn[39m: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) 2019-07-11 14:31:21.003 - [33mwarn[39m: javascript.0 at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:21.003 - [33mwarn[39m: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) 2019-07-11 14:31:21.003 - [33mwarn[39m: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) 2019-07-11 14:31:21.003 - [33mwarn[39m: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) 2019-07-11 14:31:21.004 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:21.004 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:21.004 - [33mwarn[39m: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) 2019-07-11 14:31:21.004 - [33mwarn[39m: javascript.0 at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) 2019-07-11 14:31:21.004 - [33mwarn[39m: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:21.004 - [33mwarn[39m: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) 2019-07-11 14:31:21.004 - [33mwarn[39m: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) 2019-07-11 14:31:21.004 - [33mwarn[39m: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) 2019-07-11 14:31:21.004 - [33mwarn[39m: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) 2019-07-11 14:31:21.005 - [33mwarn[39m: javascript.0 at emitTwo (events.js:126:13) 2019-07-11 14:31:21.005 - [33mwarn[39m: javascript.0 at WebSocket.emit (events.js:214:7) 2019-07-11 14:31:21.005 - [33mwarn[39m: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) 2019-07-11 14:31:21.005 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18 2019-07-11 14:31:21.005 - [33mwarn[39m: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5) 2019-07-11 14:31:21.005 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14 2019-07-11 14:31:21.005 - [33mwarn[39m: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3) 2019-07-11 14:31:21.005 - [33mwarn[39m: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12) 2019-07-11 14:31:21.005 - [33mwarn[39m: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31) 2019-07-11 14:31:21.006 - [33mwarn[39m: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24) 2019-07-11 14:31:21.006 - [33mwarn[39m: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20) 2019-07-11 14:31:21.006 - [33mwarn[39m: javascript.0 at emitOne (events.js:116:13) 2019-07-11 14:31:21.006 - [33mwarn[39m: javascript.0 at Socket.emit (events.js:211:7) 2019-07-11 14:31:21.006 - [33mwarn[39m: javascript.0 at addChunk (_stream_readable.js:263:12) 2019-07-11 14:31:21.006 - [33mwarn[39m: javascript.0 at readableAddChunk (_stream_readable.js:250:11) 2019-07-11 14:31:21.006 - [33mwarn[39m: javascript.0 at Socket.Readable.push (_stream_readable.js:208:10) 2019-07-11 14:31:21.006 - [33mwarn[39m: javascript.0 at TCP.onread (net.js:601:20) 2019-07-11 14:31:21.007 - [33mwarn[39m: javascript.0 getState "zigbee.0.00158d0002b02f86.long_click" not found (3) 2019-07-11 14:31:21.010 - [33mwarn[39m: javascript.0 at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:31:14) 2019-07-11 14:31:21.010 - [33mwarn[39m: javascript.0 at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38) 2019-07-11 14:31:21.010 - [33mwarn[39m: javascript.0 at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25) 2019-07-11 14:31:21.010 - [33mwarn[39m: javascript.0 at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37) 2019-07-11 14:31:21.010 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) 2019-07-11 14:31:21.010 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:21.011 - [33mwarn[39m: javascript.0 at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) 2019-07-11 14:31:21.011 - [33mwarn[39m: javascript.0 at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) 2019-07-11 14:31:21.011 - [33mwarn[39m: javascript.0 at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:21.011 - [33mwarn[39m: javascript.0 at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:21.011 - [33mwarn[39m: javascript.0 at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) 2019-07-11 14:31:21.011 - [33mwarn[39m: javascript.0 at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:21.011 - [33mwarn[39m: javascript.0 at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) 2019-07-11 14:31:21.011 - [33mwarn[39m: javascript.0 at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) 2019-07-11 14:31:21.011 - [33mwarn[39m: javascript.0 at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) 2019-07-11 14:31:21.012 - [33mwarn[39m: javascript.0 at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) 2019-07-11 14:31:21.012 - [33mwarn[39m: javascript.0 at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:21.012 - [33mwarn[39m: javascript.0 at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) 2019-07-11 14:31:21.012 - [33mwarn[39m: javascript.0 at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) 2019-07-11 14:31:21.012 - [33mwarn[39m: javascript.0 at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) 2019-07-11 14:31:21.012 - [33mwarn[39m: javascript.0 at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) 2019-07-11 14:31:21.012 - [33mwarn[39m: javascript.0 at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) 2019-07-11 14:31:21.012 - [33mwarn[39m: javascript.0 at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) 2019-07-11 14:31:21.012 - [33mwarn[39m: javascript.0 at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) 2019-07-11 14:31:21.013 - [33mwarn[39m: javascript.0 at emitTwo (events.js:126:13) 2019-07-11 14:31:21.013 - [33mwarn[39m: javascript.0 at WebSocket.emit (events.js:214:7) 2019-07-11 14:31:21.013 - [33mwarn[39m: javascript.0 at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) 2019-07-11 14:31:21.013 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18 2019-07-11 14:31:21.013 - [33mwarn[39m: javascript.0 at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5) 2019-07-11 14:31:21.013 - [33mwarn[39m: javascript.0 at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14 2019-07-11 14:31:21.013 - [33mwarn[39m: javascript.0 at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3) 2019-07-11 14:31:21.013 - [33mwarn[39m: javascript.0 at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12) 2019-07-11 14:31:21.013 - [33mwarn[39m: javascript.0 at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31) 2019-07-11 14:31:21.014 - [33mwarn[39m: javascript.0 at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24) 2019-07-11 14:31:21.014 - [33mwarn[39m: javascript.0 at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20) 2019-07-11 14:31:21.014 - [33mwarn[39m: javascript.0 at emitOne (events.js:116:13) 2019-07-11 14:31:21.014 - [33mwarn[39m: javascript.0 at Socket.emit (events.js:211:7) 2019-07-11 14:31:21.014 - [33mwarn[39m: javascript.0 at addChunk (_stream_readable.js:263:12) 2019-07-11 14:31:21.014 - [33mwarn[39m: javascript.0 at readableAddChunk (_stream_readable.js:250:11) 2019-07-11 14:31:21.014 - [33mwarn[39m: javascript.0 at Socket.Readable.push (_stream_readable.js:208:10) 2019-07-11 14:31:21.014 - [33mwarn[39m: javascript.0 at TCP.onread (net.js:601:20) 2019-07-11 14:31:47.879 - [32minfo[39m: host.ioBroker-Pi instance system.adapter.radar2.0 started with pid 26629Das kommt im log bei einem Klick
@iomountain ahh jetzt. hatte oben den Klick noch nicht ausgewählt. Also Licht an und aus funktioniert schon mal über einen einzelnen Klick. Super
auch verstanden? dann das gleiche bei double click und long click
@iomountain mehr oder weniger ja. Das muss ich ja dann nur noch unten einfügen richtig? Setzt mich später noch mal ran und probiere alles einzusetzen. Das gleiche mache ich dann noch mal in einem anderen Script für den anderen Schalter oder?
Noch eine kurze frage, du hast ja den Zigbee Stick. Ich nutze aktuell das Xiaomi gateway welche vorteile hat der Stick denn? Habe nämlich auch einen hier liegen aber es gibt doch keine Unterschiede oder? -
@iomountain Wie muss das ganze denn für eine Szene von dem Harmony hub aussehen? Dort gibt es 0,1,2,3 und nicht nur wahr und falsch. 1=Schaltet gerade an, 2=an, 3=Schaltet gerade aus und 0=aus. Möchte mit dem Long Klick ein und aus schalten.
