    5. Script Hilfe licht über Xiaomi Switch anschalten.
    • Nito33
      Nito33 @iomountain last edited by
      @iomountain <xml xmlns="http://www.w3.org/1999/xhtml">
      <block type="comment" id="@cY?z8Mo[rp~6xjYRB9" x="88" y="-462">
      <field name="COMMENT">Taster XIAOMI Nr. 3</field>
      <block type="on_ext" id="PB-24CkO9W+A,wx(U/~p">
      <mutation items="6"></mutation>
      <field name="CONDITION">gt</field>
      <field name="ACK_CONDITION">true</field>
      <value name="OID0">
      <shadow type="field_oid" id=")Qi
      F{:XZIsphth0IP^H">
      <block type="field_oid" id="rgjNSi2xzP32iFTE[Zr"> <field name="oid">mihome.0.devices.switch_158d0001e5c139.click</field> </block> </value> <value name="OID1"> <shadow type="field_oid" id="iaF=)P=-;PAAd,)/4%vi"> <field name="oid">default</field> </shadow> <block type="field_oid" id="ea3t6_MlYEPR}*?yzCqA"> <field name="oid">zigbee.0.00158d0002b02f86.double_click</field> </block> </value> <value name="OID2"> <shadow type="field_oid" id="^US+uZxi^vOuQI|KuALq"> <field name="oid">default</field> </shadow> <block type="field_oid" id="Ro15Nv;8Sl9+.0nGHq^%"> <field name="oid">zigbee.0.00158d0002b02f86.triple_click</field> </block> </value> <value name="OID3"> <shadow type="field_oid" id="R2Lb}B~M^5V1#^vXl,xw"> <field name="oid">default</field> </shadow> <block type="field_oid" id="=?EUmg0.O3+z.RryC=xB"> <field name="oid">zigbee.0.00158d0002b02f86.quad_click</field> </block> </value> <value name="OID4"> <shadow type="field_oid" id="9i}=7+CVZh@d7@#)C3;}"> <field name="oid">default</field> </shadow> <block type="field_oid" id="?ojg03%rW]}Gl-_0!1x">
      <field name="oid">zigbee.0.00158d0002b02f86.many_click</field>
      <value name="OID5">
      <shadow type="field_oid" id="?EarP}N#oxmuZYcD#w?A">
      <block type="field_oid" id="Qn6/h8f3[DPd@i5_M8">
      <field name="oid">zigbee.0.00158d0002b02f86.long_click</field>
      <block type="debug" id="r/YqCq!4BPo^D%562f@H">
      <value name="TEXT">
      <shadow type="text" id="5hv99z~G)/zHUNWPf~">
      <field name="TEXT">es wurde geklickt</field>
      <block type="controls_if" id="^%rfwf,9(7^?Gd1W(2rH">
      <mutation elseif="5"></mutation>
      <block type="logic_compare" id="B7oHd]+ob+83AYT#!UOR">
      <field name="OP">EQ</field>
      <block type="get_value" id="%l[Ebz+^3abG+/nZ_|%6">
      <field name="OID">zigbee.0.00158d0002b02f86.click</field>
      <block type="logic_boolean" id="ciW[o-HOq!fpNWr0GQx">
      <block type="debug" id="77)Pc:(kqD!l@AdFktg"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="?D:soVS]Ik_MSh,2sepk"> <field name="TEXT">click</field> </shadow> </value> <next> <block type="comment" id="i*jra%1wLggjCGzi/q{W"> <field name="COMMENT">je nach click</field> <next> <block type="controls_if" id="EG3ol;@J!t^@8umkneD">
      <block type="logic_operation" id="K{W%]KSw7P4gp:O[UgD">
      <field name="OP">OR</field>
      <block type="logic_compare" id="h^93g38,nk?n5B7-T|-2">
      <block type="get_value" id="{LHVnt1Z}O9p}y;p9yW)">
      <field name="OID">sonoff.0.Licht.POWER</field>
      <block type="logic_boolean" id="i]3e]XF.PqOq6jySU-7A">
      <block type="logic_compare" id="Q_d6K+s7Xy3z=yM8JKI"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="N:?5:-:R9O-Gf(9;Y4*4"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Licht.POWER</field> </block> </value> <value name="B"> <block type="logic_boolean" id="[2d@d1(/KA:U_9qBxzt|"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="comment" id="5{]Wn0u@#w@rdTXb)SiY"> <field name="COMMENT">Wenn eine Lampe an dann alle aus</field> <next> <block type="debug" id="D1jJ!hg8?416.fo8A]Ig"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="EQV5T+^(Oc^%jddr?Ed/"> <field name="TEXT">ausschalten</field> </shadow> </value> <next> <block type="control" id="QyX=!8$VR$)D=UhC1sa1"> <mutation delay_input="false"></mutation> <field name="OID">sonoff.0.Licht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="V2End:lo3Xwl#Gp^:9ne"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> <statement name="ELSE"> <block type="comment" id=":x2uA2sM^Tb!]7~%Y@3."> <field name="COMMENT">Objekt schalten, bitte anpassen</field> <next> <block type="control" id="79;%-wMLM(l4pnH}_Ug?"> <mutation delay_input="false"></mutation> <field name="OID">sonoff.0.Licht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="OqQ-6Zdl=qm``H}c+r1">
      <block type="comment" id="L?|+,b8)F9%Bpv]ZlSK/">
      <field name="COMMENT">Sonst lampe an</field>
      <block type="debug" id="[7.r]dibVzq:nExle;C"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="AjqibEkM(*AUc-I[Fh.">
      <field name="TEXT">einschalten</field>
      <block type="comment" id="khXz:g:a01UL0NVB(/0A">
      <block type="control" id="i4iv,I2$L
      g=Y3hXGM">
      <block type="logic_boolean" id="$7ncThkUUTn~-05X$uEg">
      <value name="IF1">
      <block type="logic_compare" id="{RB1T]6_|We%X^x8y,e3">
      <block type="get_value" id="]JqpodS[1k}8wvU%ljY"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d0002b02f86.double_click</field> </block> </value> <value name="B"> <block type="logic_boolean" id="D({5v+n5fghCkGs68}ch"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO1"> <block type="debug" id="]OGemcpFY;b;lh4Z[aK/"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="fO(2D5-!_m|U:zj[5fsa"> <field name="TEXT">double click</field> </shadow> </value> <next> <block type="comment" id="B7Y#DekBTX23lCB-|,L]"> <field name="COMMENT">je nach click</field> </block> </next> </block> </statement> <value name="IF2"> <block type="logic_compare" id="Awyl1ugjhBcRcUAJOL+l"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="l4xIsUAecIpJqodgO-4">
      <field name="OID">zigbee.0.00158d0002b02f86.triple_click</field>
      <block type="logic_boolean" id="g]#YKK0GlZp
      2U(E|G|(">
      <statement name="DO2">
      <block type="debug" id="gr9O^S~?R+-0b:S-sb!L">
      <value name="TEXT">
      <shadow type="text" id="1[hmvn+t^pr2j.fEi2rb">
      <field name="TEXT">tripple click</field>
      <block type="comment" id="0,;Y]y4[u[]+Bs1s=Epw">
      <value name="IF3">
      <block type="logic_compare" id="5Ultno,QEkbPOIz4+x="> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="^,!TJk?QHXNhp0f24SIM"> <field name="ATTR">val</field> <field name="OID">zigbee.0.00158d0002b02f86.quad_click</field> </block> </value> <value name="B"> <block type="logic_boolean" id="^0tE{Uw^Aw9]{aM4v%#,"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO3"> <block type="debug" id="uM,~ogj7YUW+_9GH@qK">
      <value name="TEXT">
      <shadow type="text" id="vf-TRBU!EW^99MhKz-^D">
      <field name="TEXT">vierfach click</field>
      <block type="comment" id="b)rKt;?q#O/WQ!S8W">
      <value name="IF4">
      <block type="logic_compare" id="5P6jpTQ+SQg)Z-ZWuBCK">
      <block type="get_value" id="LPfGX2rys@=v3mC2^-73">
      <field name="OID">zigbee.0.00158d0002b02f86.many_click</field>
      <block type="logic_boolean" id="ris=X#TgK=1+0COq?uuC">
      <statement name="DO4">
      <block type="debug" id="Br~kIi5^8x!xr.94.PB:">
      <value name="TEXT">
      <shadow type="text" id="ZrcdR6T{YcUD=]O;S+-"> <field name="TEXT">viele click</field> </shadow> </value> <next> <block type="comment" id="@d7VxOC1QmAoaKcahHk3"> <field name="COMMENT">je nach click</field> </block> </next> </block> </statement> <value name="IF5"> <block type="logic_compare" id="Gt2b(|.gt?d1z,%g%99I"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="4[vb;-7^8ow]IE0ZF~[">
      <field name="OID">zigbee.0.00158d0002b02f86.long_click</field>
      <block type="logic_boolean" id="ay}{%b(r.^GlnijvJuN^">
      <statement name="DO5">
      <block type="debug" id="OU:gQT3@u=HQrMl8Hq+%">
      <value name="TEXT">
      <shadow type="text" id="M(F:?:]%Jg?msY]k^F)n">
      <field name="TEXT">lang click</field>
      <block type="comment" id="8R^HYo2yE!:l@set
      :4i">
      <field name="COMMENT">je nach click </field>
      • Nito33
        @iomountain Wie mache ich das denn eigentlich in so nem Kasten 😄 ?
        iomountain 1 Reply Last reply Reply Quote 0
        • iomountain
          iomountain @Nito33 last edited by
          @Noé1237
          erst auf Spoiler drücken, dann auf Code, dann einfügen
          hab's mal ein wenig gekürzt und aufgeräumt
           <block type="comment" id="@cY?z8Mo[rp~6xjYRB9" x="788" y="-837">
               <block type="on_ext" id="IM=K$r`vCMSq5Ry?s:~7">
                 <value name="OID0">
                   <shadow type="field_oid" id=")QiF{:XZIsphth0IP^H">
                   <block type="field_oid" id="^ipDGr0w*ura!}49qCL#">
                 <value name="OID1">
                   <block type="field_oid" id="fJwFo$^m7N2ojv]3p/QM">
                 <value name="OID2">
                   <block type="field_oid" id="Qh2HV$lcJ,ank8t8VYl|">
                   <block type="debug" id="eMyo{0+~BA^+F_j)nF!q">
                     <value name="TEXT">
                       <shadow type="text" id="aEIbF.mX|@FSE)x~u`Pc">
                       <block type="controls_if" id="LwYwYyELzNmNsP12(PJ9">
                         <mutation elseif="2"></mutation>
                           <block type="logic_compare" id="oY/OwE$,$:B-LaqyH+uG">
                               <block type="get_value" id="Y]Shb09a[-~$9jg9CvFp">
                               <block type="logic_boolean" id="!Nsd[-FkW{f-Tafh(di?">
                           <block type="debug" id="`L|)(C=-?JEKZQ=/y_p3">
                             <value name="TEXT">
                               <shadow type="text" id="{9ywGmI{lky~86n;CK;M">
                                 <field name="TEXT">simple click</field>
                               <block type="comment" id="84wWuU*|2E#eVDJ[;xSq">
                                   <block type="controls_if" id="cI_ZQ:;t@XJ.sKY,duG{">
                                       <block type="logic_compare" id="447cil7dkU}qdikEWF{o">
                                           <block type="get_value" id="j}kI`?]x)Voq(g2^Deg`">
                                           <block type="logic_boolean" id="+]Ky-zdx$#O7G75!3nmC">
                                       <block type="comment" id="Ui*|-IIZkk~5qp]Sh{iC">
                                           <block type="debug" id="MYATXbE=nd]`P]]#|cWS">
                                             <value name="TEXT">
                                               <shadow type="text" id="-jjSMw/F|x(P^.`}y_+8">
                                               <block type="control" id="s^37|2Q;*n^+1Su)jr2z">
                                                   <block type="logic_boolean" id="X6hC`)c~pbK95M;IEo8w">
                                       <block type="comment" id="3XBp0.uai|Z,MxtnS79B">
                                           <block type="debug" id="~88$c[[;d*mtS/?zDuZ}">
                                             <value name="TEXT">
                                               <shadow type="text" id="KFK}kt7RygKz6PX7(H+a">
                                               <block type="comment" id="#w=#88#QYefI9D=uW$12">
                                                   <block type="control" id=".bhIw.73p9H[$2iZ,pil">
                                                       <block type="logic_boolean" id="atYDubn5(IL[[E?W[=.f">
                         <value name="IF1">
                           <block type="logic_compare" id="?y[}1Aa[MJMYV]rNUt6B">
                               <block type="get_value" id="RW~%WAZEGn:M5I=~{nRf">
                               <block type="logic_boolean" id="v4yf~+u+*SQ(Bnr^0dWO">
                           <block type="debug" id="FKC@ddUdUG._U.3*PW%u">
                             <value name="TEXT">
                               <shadow type="text" id="QIHNuvl;%2Ko|N^xigHb">
                               <block type="comment" id="-Gm=B3%WG4-0.ShL9sC8">
                         <value name="IF2">
                           <block type="logic_compare" id="q_b/zN!56q)s0J8+Yjos">
                               <block type="get_value" id="/K{7E}+T7K$})pS6=2md">
                               <block type="logic_boolean" id="EG?~N7wx*d-optI47WLe">
                           <block type="debug" id="t1[K}FImd-EU6r@$-Ok*">
                             <value name="TEXT">
                               <shadow type="text" id="p:D!*b]*bXZ`-i%bu/H=">
                               <block type="comment" id="%zhWT=pM5@yWuU2aBQ)#">
          Nito33 iomountain 2 Replies Last reply Reply Quote 0
          • Nito33
            @iomountain achso okey, danke. Weißt du woran es liegt?
            • iomountain
              @Noé1237 sagte in Script Hilfe licht über Xiaomi Switch anschalten.:
              was?
              funktioniert dein "simple click"
              Nito33 1 Reply Last reply Reply Quote 0
              • Nito33
                @iomountain Ne ich frage ja ob du weißt wieso es nicht funktioniert. Aktuell passiert gar nichts wenn ich drücke.
                • iomountain
                  so ist das Script gestoppt.
                  was sagt das Log?
                  Das was in den Debug Baustein steht müsste im LOG auftauchen.
                  • Nito33
                    @iomountain Script ist an. Opera Momentaufnahme_2019-07-11_134121_192.168.178.93.png
                    so sieht mein log aus
                    • iomountain
                      das letzte Script, das gekürzte und aufgeräumte, und was kommt im Log wenn du bei diesem einen Click machst?
                      Nito33 2 Replies Last reply Reply Quote 0
                      • Nito33
                        Nito33 @iomountain last edited by Nito33
                        2019-07-11 14:31:17.380  - info: radar2.0 Adapter disconnected and stopped with dostop(false) and callback(true)
                        2019-07-11 14:31:17.733  - info: radar2.0 found '@abandonware/noble'
                        2019-07-11 14:31:17.742  - warn: radar2.0 node-bluetooth not found!
                        2019-07-11 14:31:17.743  - info: radar2.0 radar2 set to flag items away if they are not seen for 6 minutes
                        2019-07-11 14:31:17.745  - info: radar2.0 use known BT list: [ '01:12:23:34:45:56' ]
                        2019-07-11 14:31:17.746  - info: radar2.0 use known IP list: [ '1.1.1.1' ]
                        2019-07-11 14:31:17.747  - info: radar2.0 Remove name end for host names: .fritz.box
                        2019-07-11 14:31:17.750  - info: radar2.0 arp-scan will use the following interfaces: [ 'eth0' ]
                        2019-07-11 14:31:17.751  - info: radar2.0 radar2 set to scan every 30 seconds and printers every 720 minutes.
                        2019-07-11 14:31:17.833  - error: Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
                        2019-07-11 14:31:17.834  - error: Caught by controller[0]:     at _handle.lookup (dgram.js:266:18)
                        2019-07-11 14:31:17.834  - error: Caught by controller[0]:     at _combinedTickCallback (internal/process/next_tick.js:142:11)
                        2019-07-11 14:31:17.834  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:181:9)
                        2019-07-11 14:31:17.834  - error: Caught by controller[0]:   errno: 'EACCES',
                        2019-07-11 14:31:17.834  - error: Caught by controller[0]:   code: 'EACCES',
                        2019-07-11 14:31:17.834  - error: Caught by controller[0]:   syscall: 'bind',
                        2019-07-11 14:31:17.834  - error: Caught by controller[0]:   address: '0.0.0.0',
                        2019-07-11 14:31:17.834  - error: Caught by controller[0]:   port: 67 }
                        2019-07-11 14:31:17.835  - error: host.ioBroker-Pi instance system.adapter.radar2.0 terminated with code 0 (OK)
                        2019-07-11 14:31:17.835  - info: host.ioBroker-Pi Restart adapter system.adapter.radar2.0 because enabled
                        2019-07-11 14:31:20.651  - error: rpi2.0 No Value found for cpu_frequency
                        2019-07-11 14:31:20.961  - info: javascript.0 script.js.Schalter_Tür_und_Bett: es wurde geklickt
                        2019-07-11 14:31:20.962  - warn: javascript.0 getState "zigbee.0.00158d0002b02f86.click" not found (3)
                        2019-07-11 14:31:20.965  - warn: javascript.0     at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:4:7)
                        2019-07-11 14:31:20.965  - warn: javascript.0     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                        2019-07-11 14:31:20.965  - warn: javascript.0     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                        2019-07-11 14:31:20.965  - warn: javascript.0     at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
                        2019-07-11 14:31:20.965  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                        2019-07-11 14:31:20.966  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.966  - warn: javascript.0     at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                        2019-07-11 14:31:20.966  - warn: javascript.0     at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                        2019-07-11 14:31:20.966  - warn: javascript.0     at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.966  - warn: javascript.0     at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.966  - warn: javascript.0     at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                        2019-07-11 14:31:20.966  - warn: javascript.0     at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.966  - warn: javascript.0     at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                        2019-07-11 14:31:20.967  - warn: javascript.0     at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                        2019-07-11 14:31:20.967  - warn: javascript.0     at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                        2019-07-11 14:31:20.967  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.967  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.967  - warn: javascript.0     at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                        2019-07-11 14:31:20.967  - warn: javascript.0     at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                        2019-07-11 14:31:20.967  - warn: javascript.0     at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.967  - warn: javascript.0     at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                        2019-07-11 14:31:20.967  - warn: javascript.0     at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                        2019-07-11 14:31:20.968  - warn: javascript.0     at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                        2019-07-11 14:31:20.968  - warn: javascript.0     at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                        2019-07-11 14:31:20.968  - warn: javascript.0     at emitTwo (events.js:126:13)
                        2019-07-11 14:31:20.968  - warn: javascript.0     at WebSocket.emit (events.js:214:7)
                        2019-07-11 14:31:20.968  - warn: javascript.0     at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                        2019-07-11 14:31:20.968  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                        2019-07-11 14:31:20.968  - warn: javascript.0     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                        2019-07-11 14:31:20.968  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                        2019-07-11 14:31:20.968  - warn: javascript.0     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                        2019-07-11 14:31:20.969  - warn: javascript.0     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                        2019-07-11 14:31:20.969  - warn: javascript.0     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                        2019-07-11 14:31:20.969  - warn: javascript.0     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                        2019-07-11 14:31:20.969  - warn: javascript.0     at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                        2019-07-11 14:31:20.969  - warn: javascript.0     at emitOne (events.js:116:13)
                        2019-07-11 14:31:20.969  - warn: javascript.0     at Socket.emit (events.js:211:7)
                        2019-07-11 14:31:20.969  - warn: javascript.0     at addChunk (_stream_readable.js:263:12)
                        2019-07-11 14:31:20.969  - warn: javascript.0     at readableAddChunk (_stream_readable.js:250:11)
                        2019-07-11 14:31:20.969  - warn: javascript.0     at Socket.Readable.push (_stream_readable.js:208:10)
                        2019-07-11 14:31:20.970  - warn: javascript.0     at TCP.onread (net.js:601:20)
                        2019-07-11 14:31:20.970  - warn: javascript.0 getState "zigbee.0.00158d0002b02f86.double_click" not found (3)
                        2019-07-11 14:31:20.973  - warn: javascript.0     at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:19:14)
                        2019-07-11 14:31:20.973  - warn: javascript.0     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                        2019-07-11 14:31:20.973  - warn: javascript.0     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                        2019-07-11 14:31:20.974  - warn: javascript.0     at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
                        2019-07-11 14:31:20.974  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                        2019-07-11 14:31:20.974  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.974  - warn: javascript.0     at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                        2019-07-11 14:31:20.974  - warn: javascript.0     at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                        2019-07-11 14:31:20.974  - warn: javascript.0     at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.974  - warn: javascript.0     at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.974  - warn: javascript.0     at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                        2019-07-11 14:31:20.974  - warn: javascript.0     at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.975  - warn: javascript.0     at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                        2019-07-11 14:31:20.975  - warn: javascript.0     at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                        2019-07-11 14:31:20.975  - warn: javascript.0     at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                        2019-07-11 14:31:20.975  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.975  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.975  - warn: javascript.0     at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                        2019-07-11 14:31:20.975  - warn: javascript.0     at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                        2019-07-11 14:31:20.975  - warn: javascript.0     at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.975  - warn: javascript.0     at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                        2019-07-11 14:31:20.976  - warn: javascript.0     at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                        2019-07-11 14:31:20.976  - warn: javascript.0     at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                        2019-07-11 14:31:20.976  - warn: javascript.0     at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                        2019-07-11 14:31:20.976  - warn: javascript.0     at emitTwo (events.js:126:13)
                        2019-07-11 14:31:20.976  - warn: javascript.0     at WebSocket.emit (events.js:214:7)
                        2019-07-11 14:31:20.976  - warn: javascript.0     at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                        2019-07-11 14:31:20.976  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                        2019-07-11 14:31:20.976  - warn: javascript.0     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                        2019-07-11 14:31:20.977  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                        2019-07-11 14:31:20.977  - warn: javascript.0     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                        2019-07-11 14:31:20.977  - warn: javascript.0     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                        2019-07-11 14:31:20.977  - warn: javascript.0     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                        2019-07-11 14:31:20.977  - warn: javascript.0     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                        2019-07-11 14:31:20.977  - warn: javascript.0     at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                        2019-07-11 14:31:20.977  - warn: javascript.0     at emitOne (events.js:116:13)
                        2019-07-11 14:31:20.977  - warn: javascript.0     at Socket.emit (events.js:211:7)
                        2019-07-11 14:31:20.977  - warn: javascript.0     at addChunk (_stream_readable.js:263:12)
                        2019-07-11 14:31:20.978  - warn: javascript.0     at readableAddChunk (_stream_readable.js:250:11)
                        2019-07-11 14:31:20.978  - warn: javascript.0     at Socket.Readable.push (_stream_readable.js:208:10)
                        2019-07-11 14:31:20.978  - warn: javascript.0     at TCP.onread (net.js:601:20)
                        2019-07-11 14:31:20.978  - warn: javascript.0 getState "zigbee.0.00158d0002b02f86.triple_click" not found (3)
                        2019-07-11 14:31:20.981  - warn: javascript.0     at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:22:14)
                        2019-07-11 14:31:20.981  - warn: javascript.0     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                        2019-07-11 14:31:20.981  - warn: javascript.0     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                        2019-07-11 14:31:20.982  - warn: javascript.0     at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
                        2019-07-11 14:31:20.982  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                        2019-07-11 14:31:20.982  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.982  - warn: javascript.0     at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                        2019-07-11 14:31:20.982  - warn: javascript.0     at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                        2019-07-11 14:31:20.982  - warn: javascript.0     at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.982  - warn: javascript.0     at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.982  - warn: javascript.0     at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                        2019-07-11 14:31:20.982  - warn: javascript.0     at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.983  - warn: javascript.0     at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                        2019-07-11 14:31:20.983  - warn: javascript.0     at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                        2019-07-11 14:31:20.983  - warn: javascript.0     at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                        2019-07-11 14:31:20.983  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.983  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.988  - warn: javascript.0     at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                        2019-07-11 14:31:20.988  - warn: javascript.0     at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                        2019-07-11 14:31:20.988  - warn: javascript.0     at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.988  - warn: javascript.0     at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                        2019-07-11 14:31:20.988  - warn: javascript.0     at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                        2019-07-11 14:31:20.988  - warn: javascript.0     at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                        2019-07-11 14:31:20.988  - warn: javascript.0     at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                        2019-07-11 14:31:20.989  - warn: javascript.0     at emitTwo (events.js:126:13)
                        2019-07-11 14:31:20.989  - warn: javascript.0     at WebSocket.emit (events.js:214:7)
                        2019-07-11 14:31:20.989  - warn: javascript.0     at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                        2019-07-11 14:31:20.989  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                        2019-07-11 14:31:20.989  - warn: javascript.0     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                        2019-07-11 14:31:20.989  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                        2019-07-11 14:31:20.989  - warn: javascript.0     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                        2019-07-11 14:31:20.989  - warn: javascript.0     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                        2019-07-11 14:31:20.989  - warn: javascript.0     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                        2019-07-11 14:31:20.990  - warn: javascript.0     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                        2019-07-11 14:31:20.990  - warn: javascript.0     at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                        2019-07-11 14:31:20.990  - warn: javascript.0     at emitOne (events.js:116:13)
                        2019-07-11 14:31:20.990  - warn: javascript.0     at Socket.emit (events.js:211:7)
                        2019-07-11 14:31:20.990  - warn: javascript.0     at addChunk (_stream_readable.js:263:12)
                        2019-07-11 14:31:20.990  - warn: javascript.0     at readableAddChunk (_stream_readable.js:250:11)
                        2019-07-11 14:31:20.990  - warn: javascript.0     at Socket.Readable.push (_stream_readable.js:208:10)
                        2019-07-11 14:31:20.990  - warn: javascript.0     at TCP.onread (net.js:601:20)
                        2019-07-11 14:31:20.991  - warn: javascript.0 getState "zigbee.0.00158d0002b02f86.quad_click" not found (3)
                        2019-07-11 14:31:20.994  - warn: javascript.0     at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:25:14)
                        2019-07-11 14:31:20.994  - warn: javascript.0     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                        2019-07-11 14:31:20.994  - warn: javascript.0     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                        2019-07-11 14:31:20.994  - warn: javascript.0     at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
                        2019-07-11 14:31:20.994  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                        2019-07-11 14:31:20.994  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.995  - warn: javascript.0     at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                        2019-07-11 14:31:20.995  - warn: javascript.0     at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                        2019-07-11 14:31:20.995  - warn: javascript.0     at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.995  - warn: javascript.0     at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.995  - warn: javascript.0     at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                        2019-07-11 14:31:20.995  - warn: javascript.0     at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.995  - warn: javascript.0     at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                        2019-07-11 14:31:20.995  - warn: javascript.0     at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                        2019-07-11 14:31:20.995  - warn: javascript.0     at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                        2019-07-11 14:31:20.996  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:20.996  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.996  - warn: javascript.0     at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                        2019-07-11 14:31:20.996  - warn: javascript.0     at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                        2019-07-11 14:31:20.996  - warn: javascript.0     at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:20.996  - warn: javascript.0     at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                        2019-07-11 14:31:20.996  - warn: javascript.0     at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                        2019-07-11 14:31:20.996  - warn: javascript.0     at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                        2019-07-11 14:31:20.997  - warn: javascript.0     at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                        2019-07-11 14:31:20.997  - warn: javascript.0     at emitTwo (events.js:126:13)
                        2019-07-11 14:31:20.997  - warn: javascript.0     at WebSocket.emit (events.js:214:7)
                        2019-07-11 14:31:20.997  - warn: javascript.0     at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                        2019-07-11 14:31:20.997  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                        2019-07-11 14:31:20.997  - warn: javascript.0     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                        2019-07-11 14:31:20.997  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                        2019-07-11 14:31:20.997  - warn: javascript.0     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                        2019-07-11 14:31:20.997  - warn: javascript.0     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                        2019-07-11 14:31:20.998  - warn: javascript.0     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                        2019-07-11 14:31:20.998  - warn: javascript.0     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                        2019-07-11 14:31:20.998  - warn: javascript.0     at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                        2019-07-11 14:31:20.998  - warn: javascript.0     at emitOne (events.js:116:13)
                        2019-07-11 14:31:20.998  - warn: javascript.0     at Socket.emit (events.js:211:7)
                        2019-07-11 14:31:20.998  - warn: javascript.0     at addChunk (_stream_readable.js:263:12)
                        2019-07-11 14:31:20.998  - warn: javascript.0     at readableAddChunk (_stream_readable.js:250:11)
                        2019-07-11 14:31:20.998  - warn: javascript.0     at Socket.Readable.push (_stream_readable.js:208:10)
                        2019-07-11 14:31:20.998  - warn: javascript.0     at TCP.onread (net.js:601:20)
                        2019-07-11 14:31:20.999  - warn: javascript.0 getState "zigbee.0.00158d0002b02f86.many_click" not found (3)
                        2019-07-11 14:31:21.002  - warn: javascript.0     at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:28:14)
                        2019-07-11 14:31:21.002  - warn: javascript.0     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                        2019-07-11 14:31:21.002  - warn: javascript.0     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                        2019-07-11 14:31:21.002  - warn: javascript.0     at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
                        2019-07-11 14:31:21.002  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                        2019-07-11 14:31:21.002  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:21.003  - warn: javascript.0     at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                        2019-07-11 14:31:21.003  - warn: javascript.0     at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                        2019-07-11 14:31:21.003  - warn: javascript.0     at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:21.003  - warn: javascript.0     at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:21.003  - warn: javascript.0     at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                        2019-07-11 14:31:21.003  - warn: javascript.0     at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:21.003  - warn: javascript.0     at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                        2019-07-11 14:31:21.003  - warn: javascript.0     at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                        2019-07-11 14:31:21.003  - warn: javascript.0     at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                        2019-07-11 14:31:21.004  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:21.004  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:21.004  - warn: javascript.0     at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                        2019-07-11 14:31:21.004  - warn: javascript.0     at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                        2019-07-11 14:31:21.004  - warn: javascript.0     at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:21.004  - warn: javascript.0     at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                        2019-07-11 14:31:21.004  - warn: javascript.0     at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                        2019-07-11 14:31:21.004  - warn: javascript.0     at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                        2019-07-11 14:31:21.004  - warn: javascript.0     at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                        2019-07-11 14:31:21.005  - warn: javascript.0     at emitTwo (events.js:126:13)
                        2019-07-11 14:31:21.005  - warn: javascript.0     at WebSocket.emit (events.js:214:7)
                        2019-07-11 14:31:21.005  - warn: javascript.0     at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                        2019-07-11 14:31:21.005  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                        2019-07-11 14:31:21.005  - warn: javascript.0     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                        2019-07-11 14:31:21.005  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                        2019-07-11 14:31:21.005  - warn: javascript.0     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                        2019-07-11 14:31:21.005  - warn: javascript.0     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                        2019-07-11 14:31:21.005  - warn: javascript.0     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                        2019-07-11 14:31:21.006  - warn: javascript.0     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                        2019-07-11 14:31:21.006  - warn: javascript.0     at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                        2019-07-11 14:31:21.006  - warn: javascript.0     at emitOne (events.js:116:13)
                        2019-07-11 14:31:21.006  - warn: javascript.0     at Socket.emit (events.js:211:7)
                        2019-07-11 14:31:21.006  - warn: javascript.0     at addChunk (_stream_readable.js:263:12)
                        2019-07-11 14:31:21.006  - warn: javascript.0     at readableAddChunk (_stream_readable.js:250:11)
                        2019-07-11 14:31:21.006  - warn: javascript.0     at Socket.Readable.push (_stream_readable.js:208:10)
                        2019-07-11 14:31:21.006  - warn: javascript.0     at TCP.onread (net.js:601:20)
                        2019-07-11 14:31:21.007  - warn: javascript.0 getState "zigbee.0.00158d0002b02f86.long_click" not found (3)
                        2019-07-11 14:31:21.010  - warn: javascript.0     at Object.<anonymous> (script.js.Schalter_Tür_und_Bett:31:14)
                        2019-07-11 14:31:21.010  - warn: javascript.0     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                        2019-07-11 14:31:21.010  - warn: javascript.0     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                        2019-07-11 14:31:21.010  - warn: javascript.0     at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
                        2019-07-11 14:31:21.010  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                        2019-07-11 14:31:21.010  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:21.011  - warn: javascript.0     at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                        2019-07-11 14:31:21.011  - warn: javascript.0     at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                        2019-07-11 14:31:21.011  - warn: javascript.0     at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:21.011  - warn: javascript.0     at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:21.011  - warn: javascript.0     at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                        2019-07-11 14:31:21.011  - warn: javascript.0     at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:21.011  - warn: javascript.0     at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                        2019-07-11 14:31:21.011  - warn: javascript.0     at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                        2019-07-11 14:31:21.011  - warn: javascript.0     at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                        2019-07-11 14:31:21.012  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        2019-07-11 14:31:21.012  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:21.012  - warn: javascript.0     at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                        2019-07-11 14:31:21.012  - warn: javascript.0     at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                        2019-07-11 14:31:21.012  - warn: javascript.0     at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                        2019-07-11 14:31:21.012  - warn: javascript.0     at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                        2019-07-11 14:31:21.012  - warn: javascript.0     at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                        2019-07-11 14:31:21.012  - warn: javascript.0     at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                        2019-07-11 14:31:21.012  - warn: javascript.0     at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                        2019-07-11 14:31:21.013  - warn: javascript.0     at emitTwo (events.js:126:13)
                        2019-07-11 14:31:21.013  - warn: javascript.0     at WebSocket.emit (events.js:214:7)
                        2019-07-11 14:31:21.013  - warn: javascript.0     at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                        2019-07-11 14:31:21.013  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                        2019-07-11 14:31:21.013  - warn: javascript.0     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                        2019-07-11 14:31:21.013  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                        2019-07-11 14:31:21.013  - warn: javascript.0     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                        2019-07-11 14:31:21.013  - warn: javascript.0     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                        2019-07-11 14:31:21.013  - warn: javascript.0     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                        2019-07-11 14:31:21.014  - warn: javascript.0     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                        2019-07-11 14:31:21.014  - warn: javascript.0     at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                        2019-07-11 14:31:21.014  - warn: javascript.0     at emitOne (events.js:116:13)
                        2019-07-11 14:31:21.014  - warn: javascript.0     at Socket.emit (events.js:211:7)
                        2019-07-11 14:31:21.014  - warn: javascript.0     at addChunk (_stream_readable.js:263:12)
                        2019-07-11 14:31:21.014  - warn: javascript.0     at readableAddChunk (_stream_readable.js:250:11)
                        2019-07-11 14:31:21.014  - warn: javascript.0     at Socket.Readable.push (_stream_readable.js:208:10)
                        2019-07-11 14:31:21.014  - warn: javascript.0     at TCP.onread (net.js:601:20)
                        2019-07-11 14:31:47.879  - info: host.ioBroker-Pi instance system.adapter.radar2.0 started with pid 26629
                        Das kommt im log bei einem Klick
                        • Nito33
                          @iomountain ahh jetzt. hatte oben den Klick noch nicht ausgewählt. Also Licht an und aus funktioniert schon mal über einen einzelnen Klick. Super 😄
                          • iomountain
                            iomountain @iomountain last edited by
                            auch verstanden? dann das gleiche bei double click und long click
                            • Nito33
                              @iomountain mehr oder weniger ja. Das muss ich ja dann nur noch unten einfügen richtig? Setzt mich später noch mal ran und probiere alles einzusetzen. Das gleiche mache ich dann noch mal in einem anderen Script für den anderen Schalter oder?
                              Noch eine kurze frage, du hast ja den Zigbee Stick. Ich nutze aktuell das Xiaomi gateway welche vorteile hat der Stick denn? Habe nämlich auch einen hier liegen aber es gibt doch keine Unterschiede oder?
                              • Nito33
                                @iomountain Wie muss das ganze denn für eine Szene von dem Harmony hub aussehen? Dort gibt es 0,1,2,3 und nicht nur wahr und falsch. 1=Schaltet gerade an, 2=an, 3=Schaltet gerade aus und 0=aus. Möchte mit dem Long Klick ein und aus schalten.
                                • iomountain
                                  @Noé1237
                                  das was jetzt in der "Klammer" falls steht muss so ähnlich bei den "sonst falls" stehen.
                                  Anderer Schalter neues Script, muss nicht aber macht es übersichtlicher.
                                  Zigbee Stick oder Xiaomi gateway. Zigbee war günstiger und funktioniert ohne App und nachause telefonieren.
                                  Würde aber jetzt keine Glaubensfrage daraus machen. Kenne das Xiaomi gateway nicht, musst mal das Forum durchsuchen.
                                  Glückwunsch zu deinem ersten Script, viel Spaß noch.
                                  Bei Fragen: dafür ist das Forum da.
                                  • iomountain
                                    Harmony hub kenn ich nicht, aber anstatt wahr und falsch kannst du auch Zahlen übergeben:
                                    immer viele Debug Bausteine reinmachen dann siehst du im Log was passiert 🙂
                                    • Nito33
                                      So habe ich es jetzt aktuell aber da funktioniert nichts...wie mache ich denn jetzt oben die abfrage? Im prinzip müsste er doch abfragen ob der Status auf o=aus oder auf 2=an ist oder?
                                      • Nito33
                                        @iomountain
                                        2019-07-11 16:28:54.745  - warn: javascript.0 Wrong type of harmony.0.Harmony_Hub.activities.Fire_TV_sehen: "boolean". Please fix, while deprecated and will not work in next versions.
                                        2019-07-11 16:28:54.748  - warn: javascript.0     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
                                        2019-07-11 16:28:54.749  - warn: javascript.0     at Object.<anonymous> (script.js.Schalter_Bett:46:7)
                                        2019-07-11 16:28:54.749  - warn: javascript.0     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
                                        2019-07-11 16:28:54.749  - warn: javascript.0     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                                        2019-07-11 16:28:54.749  - warn: javascript.0     at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
                                        2019-07-11 16:28:54.749  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                                        2019-07-11 16:28:54.749  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                        2019-07-11 16:28:54.750  - warn: javascript.0     at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                                        2019-07-11 16:28:54.750  - warn: javascript.0     at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                                        2019-07-11 16:28:54.750  - warn: javascript.0     at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                        2019-07-11 16:28:54.750  - warn: javascript.0     at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                        2019-07-11 16:28:54.750  - warn: javascript.0     at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                                        2019-07-11 16:28:54.750  - warn: javascript.0     at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                        2019-07-11 16:28:54.750  - warn: javascript.0     at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                                        2019-07-11 16:28:54.750  - warn: javascript.0     at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                                        2019-07-11 16:28:54.751  - warn: javascript.0     at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                                        2019-07-11 16:28:54.751  - warn: javascript.0     at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                        2019-07-11 16:28:54.751  - warn: javascript.0     at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                        2019-07-11 16:28:54.751  - warn: javascript.0     at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                                        2019-07-11 16:28:54.751  - warn: javascript.0     at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                                        2019-07-11 16:28:54.751  - warn: javascript.0     at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                        2019-07-11 16:28:54.751  - warn: javascript.0     at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                                        2019-07-11 16:28:54.751  - warn: javascript.0     at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                                        2019-07-11 16:28:54.752  - warn: javascript.0     at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                                        2019-07-11 16:28:54.752  - warn: javascript.0     at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                                        2019-07-11 16:28:54.752  - warn: javascript.0     at emitTwo (events.js:126:13)
                                        2019-07-11 16:28:54.752  - warn: javascript.0     at WebSocket.emit (events.js:214:7)
                                        2019-07-11 16:28:54.752  - warn: javascript.0     at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                                        2019-07-11 16:28:54.752  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                                        2019-07-11 16:28:54.752  - warn: javascript.0     at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                                        2019-07-11 16:28:54.752  - warn: javascript.0     at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                                        2019-07-11 16:28:54.753  - warn: javascript.0     at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                                        2019-07-11 16:28:54.753  - warn: javascript.0     at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                                        2019-07-11 16:28:54.753  - warn: javascript.0     at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                                        2019-07-11 16:28:54.753  - warn: javascript.0     at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                                        2019-07-11 16:28:54.753  - warn: javascript.0     at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                                        2019-07-11 16:28:54.753  - warn: javascript.0     at emitOne (events.js:116:13)
                                        2019-07-11 16:28:54.753  - warn: javascript.0     at Socket.emit (events.js:211:7)
                                        2019-07-11 16:28:54.754  - warn: javascript.0     at addChunk (_stream_readable.js:263:12)
                                        2019-07-11 16:28:54.754  - warn: javascript.0     at readableAddChunk (_stream_readable.js:250:11)
                                        2019-07-11 16:28:54.754  - warn: javascript.0     at Socket.Readable.push (_stream_readable.js:208:10)
                                        2019-07-11 16:28:54.754  - warn: javascript.0     at TCP.onread (net.js:601:20)
                                        2019-07-11 16:29:00.030  - info: host.ioBroker-Pi instance system.adapter.yr.0 started with pid 6929
                                        2019-07-11 16:29:00.062  - info: host.ioBroker-Pi instance system.adapter.weatherunderground.0 started with pid 6934
                                        2019-07-11 16:29:01.686  - info: yr.0 starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v8.16.0
                                        2019-07-11 16:29:02.093  - info: yr.0 got weather data from yr.no
                                        2019-07-11 16:29:02.112  - info: weatherunderground.0 starting. Version 3.0.12 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.16.0
                                        2019-07-11 16:29:03.341  - info: host.ioBroker-Pi instance system.adapter.radar2.0 started with pid 6957
                                        2019-07-11 16:29:05.178  - info: radar2.0 starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
                                        2019-07-11 16:29:05.432  - info: radar2.0 radar2 initialization started...
                                        2019-07-11 16:29:05.455  - info: radar2.0 net-ping not available! Will try to use normal ping!
                                        2019-07-11 16:29:05.693  - error: radar2.0 uncaught exception: bind EACCES 0.0.0.0:67
                                        2019-07-11 16:29:05.693  - error: radar2.0 Error: bind EACCES 0.0.0.0:67
                                        2019-07-11 16:29:05.696  - info: radar2.0 Adapter disconnected and stopped with dostop(false) and callback(true)
                                        2019-07-11 16:29:05.948  - info: host.ioBroker-Pi instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
                                        2019-07-11 16:29:06.138  - error: Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
                                        2019-07-11 16:29:06.139  - error: Caught by controller[0]:     at _handle.lookup (dgram.js:266:18)
                                        2019-07-11 16:29:06.139  - error: Caught by controller[0]:     at _combinedTickCallback (internal/process/next_tick.js:142:11)
                                        2019-07-11 16:29:06.139  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:181:9)
                                        2019-07-11 16:29:06.139  - error: Caught by controller[0]:   errno: 'EACCES',
                                        2019-07-11 16:29:06.139  - error: Caught by controller[0]:   code: 'EACCES',
                                        2019-07-11 16:29:06.139  - error: Caught by controller[0]:   syscall: 'bind',
                                        2019-07-11 16:29:06.139  - error: Caught by controller[0]:   address: '0.0.0.0',
                                        2019-07-11 16:29:06.139  - error: Caught by controller[0]:   port: 67 }
                                        2019-07-11 16:29:06.139  - error: host.ioBroker-Pi instance system.adapter.radar2.0 terminated with code 0 (OK)
                                        2019-07-11 16:29:06.140  - info: host.ioBroker-Pi Restart adapter system.adapter.radar2.0 because enabled
                                        2019-07-11 16:29:07.627  - error: rpi2.0 No Value found for cpu_frequency
                                        2019-07-11 16:29:07.932  - info: host.ioBroker-Pi instance system.adapter.yr.0 terminated with code 0 (OK)
                                        das kommt dann wenn ich länger Drücke
                                        • iomountain
                                          Ich glaube das script läuft gar nicht!
                                          Harmony hub kenn ich nicht aber entweder 2 oder auf wahr, kann mir nicht vorstellen das beides so kurz hintereinander richtig ist.
                                          Das gekürzte aufgeräumte Script willst du nicht nehmen um daran weiterzuarbeiten?
                                          • Nito33
                                            @iomountain Script läuft. Der einzelne Klick und Doppel Klick funktioniert ja auch und es ist das gleiche Script. Das gekürze sit ja ziemlich das gleiche, das nutze ich dann später wenn ich etwas aufräume. Also wenn ich unten unter "Objekt schalten, bitte anpassen " mit 0 steuere geht er an und sofort aus. Wenn ich 2 nutze geht er nicht an. Ich glaube es muss dafür noch irgendwas eingefügt werden. Aber müsste es im prinzip nicht das gleiche wie wahr und falsch sein nur in zahlen? Also 0 für falsch und 2 für wahr?
                                            blockly communication monitoring
                                            3079
