    4. Script editor - problem after change sc_xx option
    UNSOLVED Script editor - problem after change sc_xx option
      mguc last edited by
      When i try to edit js script in scripts tab after pressed CRON icon:
      and change to sc_simple or sc_cron i see.. nothing:
      (it's dark mode example - for light mode is the same problem...)
      • AlCalzone
        AlCalzone Developer @mguc last edited by
        @mguc That looks like an error. Please open the browser console (F12) and check if there are any errors logged.
          mguc @AlCalzone last edited by
          @AlCalzone
          SC_SIMPLE console log:
          jquery.fancytree-all.js:113 Fancytree@1 Fancytree.filterNodes() leavesOnly option is deprecated since 2.9.0 / 2015-04-19. Use opts.leavesOnly instead.
          v @ jquery.fancytree-all.js:113
          Connection.js:250 Subscribe logs
          blockly_compressed.js:893 WARNING: No message string for %{BKY_TEXT_APPEND_TOOLTIP}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_EQ}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_NEQ}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_LT}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_LTE}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_GT}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_GTE}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_OPERATION_TOOLTIP_AND}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_OPERATION_TOOLTIP_OR}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_WHILEUNTIL_TOOLTIP_WHILE}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_WHILEUNTIL_TOOLTIP_UNTIL}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FLOW_STATEMENTS_TOOLTIP_BREAK}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FLOW_STATEMENTS_TOOLTIP_CONTINUE}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FOR_TOOLTIP}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_CONTROLS_FOREACH_TOOLTIP}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_ADD}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_MINUS}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_MULTIPLY}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_DIVIDE}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ARITHMETIC_TOOLTIP_POWER}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_ROOT}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_ABS}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_NEG}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_LN}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_LOG10}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_EXP}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_SINGLE_TOOLTIP_POW10}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_SIN}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_COS}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_TAN}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ASIN}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ACOS}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_TRIG_TOOLTIP_ATAN}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_SUM}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MIN}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MAX}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_AVERAGE}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MEDIAN}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_MODE}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_STD_DEV}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_ONLIST_TOOLTIP_RANDOM}.
          blockly_compressed.js:893 WARNING: No message string for %{BKY_MATH_CHANGE_TOOLTIP}.
          BlocklyEditor.js:94 Detected custom blockly: email
          SelectID.js:1077 render
          react-dom.production.min.js:4408 TypeError: Cannot read property 'Every' of undefined
              at cron2text.js:395
              at Ps (cron2text.js:507)
              at Ys (cronText.js:43)
              at t.value (SimpleCron.js:611)
              at Ti (react-dom.production.min.js:3785)
              at Mi (react-dom.production.min.js:3776)
              at ji (react-dom.production.min.js:3960)
              at $a (react-dom.production.min.js:5514)
              at qa (react-dom.production.min.js:5536)
              at Tl (react-dom.production.min.js:5958)
          fa @ react-dom.production.min.js:4408
          react-dom.production.min.js:5940 Uncaught TypeError: Cannot read property 'Every' of undefined
              at cron2text.js:395
          SC_CRON console log
              at cron2text.js:395
              at t.value (ComplexCron.js:372)
              at t.value (ComplexCron.js:383)
              at cron2text.js:395
          • Bluefox
            Bluefox last edited by
            What the language do you have selected?
              mguc @Bluefox last edited by
              @Bluefox
              Polish (Polski). Now i switch on english.. and all works.
              Bluefox 1 Reply Last reply Reply Quote 0
              • Bluefox
                Bluefox @mguc last edited by
                @mguc PL is really missed by cron.
                But now in the latest version of "javascript" (4.1.14) there is a fallback to english.
                May be can you extend in this file the "pl" part?
                https://github.com/ioBroker/ioBroker.javascript/blob/master/src/src/Components/simple-cron/jquery.cron.locale.js
                  @Bluefox
                  JQUERY_CRON_LOCALE.pl = {
                      ORDINALS: {
                          th: 'th',
                          st: 'st',
                          nd: 'nd',
                          rd: 'rd'
                      MONTH: [ //short or full names
                          'Sty', or 'Styczeń'
                          'Lut', or 'Luty'
                          'Mar', or 'Marzec'
                          'Kwi', or 'Kwiecień'
                          'Maj', or 'Maj'
                          'Cze', or 'Czerwiec'
                          'Lip', or 'Lipiec'
                          'Sie', or 'Sierpień'
                          'Wrz', or 'Wrzesień'
                          'Paź', or 'Październik'
                          'Lis', or 'Listopad'
                          'Gru'  or 'Grudzień'
                      DOW: [ //short or full days name
                          'Nie', or 'Niedziela'
                          'Pon', or 'Poniedziałek'
                          'Wto', or 'Wtorek'
                          'Śro', or 'Środa'
                          'Czw', or 'Czwartek'
                          'Pią', or 'Piątek'
                          'Sob' or 'Sobota
                      'Every':            'Każde(go)', // start of expression
                      'and':              'i', // 1, 2, 3 and 15th
                      'every day':        'codziennie',
                      'minute past the':  'minut po', //minute past the hour ?
                      'hour':             'godzina',
                      'minute':           'minut(a)',
                      'minute of':        'minut po',
                      'second':           'sekunda',
                      'second in minute': 'sekund na minutę',
                      'second of every':  'sekund co',
                      'minute every hour': 'minut co godzinę',
                      'on the':           'w',
                      'of every month':   'każdego miesiąca',
                      'and every':        'i każdego',
                      'At':               'O',
                      'on':               'w', // on sun, mon
                      'in':               'w' // in jan, apr
                  The Polish language version is a very important and joyful element of using this program for me (and especially for other members of my family)
                    shamsmehra90 last edited by shamsmehra90
                    i have same issue but bit different can any one help me, please just reply asap
                    Regards..
                    cron mode script editor
