    • s.bormann
      s.bormann Most Active @smile last edited by
      @smile sagte in [Neuer Adapter] Visualisierung iQontrol:
      Okay naklar, hier einmal der Debug Log:
      "Edit Constant:": {"en": "Edit Constant:", "de": "Edit Constant:", "ru": "Edit Constant:", "pt": "Edit Constant:", "nl": "Edit Constant:", "fr": "Edit Constant:", "es": "Edit Constant:", "pl": "Edit Constant:", "it": "Edit Constant:", "zh-cn": "Edit Constant:"}, translate.js:24:17
      "Edit Array:": {"en": "Edit Array:", "de": "Edit Array:", "ru": "Edit Array:", "pt": "Edit Array:", "nl": "Edit Array:", "fr": "Edit Array:", "es": "Edit Array:", "pl": "Edit Array:", "it": "Edit Array:", "zh-cn": "Edit Array:"}, translate.js:24:17
      "Image:": {"en": "Image:", "de": "Image:", "ru": "Image:", "pt": "Image:", "nl": "Image:", "fr": "Image:", "es": "Image:", "pl": "Image:", "it": "Image:", "zh-cn": "Image:"}, translate.js:24:17
      Loading Settings index_m.js:131:10
      getLink of first Web-Adapter index_m.js:192:10
      Got Link: http://172.16.2.47:8082/iqontrol index_m.js:196:12
      "Brigthness-Sensor": {"en": "Brigthness-Sensor", "de": "Brigthness-Sensor", "ru": "Brigthness-Sensor", "pt": "Brigthness-Sensor", "nl": "Brigthness-Sensor", "fr": "Brigthness-Sensor", "es": "Brigthness-Sensor", "pl": "Brigthness-Sensor", "it": "Brigthness-Sensor", "zh-cn": "Brigthness-Sensor"}, translate.js:24:17
      "Blind": {"en": "Blind", "de": "Blind", "ru": "Blind", "pt": "Blind", "nl": "Blind", "fr": "Blind", "es": "Blind", "pl": "Blind", "it": "Blind", "zh-cn": "Blind"}, translate.js:24:17
      "Popup": {"en": "Popup", "de": "Popup", "ru": "Popup", "pt": "Popup", "nl": "Popup", "fr": "Popup", "es": "Popup", "pl": "Popup", "it": "Popup", "zh-cn": "Popup"}, translate.js:24:17
      "External Link": {"en": "External Link", "de": "External Link", "ru": "External Link", "pt": "External Link", "nl": "External Link", "fr": "External Link", "es": "External Link", "pl": "External Link", "it": "External Link", "zh-cn": "External Link"}, translate.js:24:17
      Try to init socket.io index_m.js:206:13
      Inited socket.io index_m.js:233:13
      Object { target: "inpage", data: {…} }
      adminConfig.js:17
      Unknown event: [object Object] adminConfig.js:24
      onboardingcomplete adminConfig.js:17
      Unknown event: onboardingcomplete adminConfig.js:24
      Quellübergreifende (Cross-Origin) Anfrage blockiert: Die Gleiche-Quelle-Regel verbietet das Lesen der externen Ressource auf http://172.16.2.47:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=MliUV27. (Grund: CORS-Anschlag schlug fehl).
      Trying connect...
      Quellübergreifende (Cross-Origin) Anfrage blockiert: Die Gleiche-Quelle-Regel verbietet das Lesen der externen Ressource auf http://172.16.2.47:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=MliUWRE. (Grund: CORS-Anschlag schlug fehl).
      Ist socket.io auf integriert gestellt und 'Nur Web-Sockets' ausgeschaltet im web-adapter?
      smile 1 Reply Last reply Reply Quote 0
      • s.bormann
        s.bormann Most Active @Gerni last edited by
        @Gerni sagte in [Neuer Adapter] Visualisierung iQontrol:
        Soweit funktioniert alles ganz gut. Bei Xiaomi Tür/Fensterkontakten wird mir jedoch kein Bat% angezeigt. Ist es möglich das einzubinden? Das Akkusymbol passt auch nicht ganz; lt. ioBroker sind es 81,5%, das Symbol müsste dann ja grün sein.
        Ansonsten bisher wirklich echte super Dein Adapter!!!! Endlich eine UI ohne umständliches VIS
        Der BATTERY-Datenpunkt ist bislang nur als boolean (wahr/falsch) integriert. Wenn wahr, wird das Batterie leer Symbol gezeigt.
        • s.bormann
          Anregung oder anderen Lösungsansatz: Ich habe jetzt pro Raum ein Symbol in der Symbolleiste erstellt. Je nach Anzahl wird das uU unübersichtlich. Sind Verschachtelungen möglich? ZB 1. Ebene Erdgeschoss -> 2. Ebene Wohnzimmer, Küche usw?
          Oder wonach habt ihr kategorisiert?
          Schau mal weiter oben im thread, da steht, wie es geht. Stichwort: Link to other view bzw. Verknüpfung zu anderer Ansicht. Damit kann man sich Menüs bauen. Beispiel:
          • smile
            smile @s.bormann last edited by
            @s-bormann Ja soweit ist das alles eingestellt. Anbei ein Screenshot
              dsmax last edited by
              ich lese nun schon eine ganze Weile mit und bin eifrig am Testen.
              Ich wollte hiermit einfach nur mal DANKE @s-bormann sagen für seine tolle Arbeit und
              sein Engagement. Ich habe genau nach solch einem Adapter gesucht, welcher mir schnelle
              Ergebnisse liefert und einfach zu bedienen ist. Habe viel schon mit dem Yahka-Adapter gemacht, aber der hier ist für mich einfach besser konfigurierbar.
              Nochmals vielen Dank!
              Jörg
              s.bormann 1 Reply Last reply Reply Quote 1
                Kann die Spaltenanzahl irgendwo eingestellt werden? Mir werden auf meinem s9 2 Spalten mit Symbolen angezeigt. Schöner wären 3 da rechts noch Platz ist.
                sigi234 s.bormann 2 Replies Last reply Reply Quote 0
                  sigi234 Forum Testing Most Active @Gerni last edited by
                  Derzeit Nein..........
                    Gerni @sigi234 last edited by
                    @sigi234 ok Danke. liegt also am Gerät? Schade
                      Ich glaube schon, aber vielleicht kann dir @s-bormann das genauer erklären.
                        SaiBot1981 last edited by
                        Moin,
                        ich wollte auch mal wieder danke sagen für die tolle Arbeit die du leistest.
                        Kurze frage habe ich jedoch auch nochmal.
                        Ist es möglich (bevor ich einfach anfange alles neu zu machen) wenn ich eine Verknüpfung zB zu eine Raum mache dort auch angezeigt zu bekommen ob das Licht an oder aus ist?
                        Die Verknüpfung soll zB zum Zimmer einer meiner Töchter sein in dem es je ein Deckenlicht und ein Nachtlicht gibt, sowie die Heizungssteuerung.
                        Wäre für Infos dankbar.
                          sigi234 Forum Testing Most Active @SaiBot1981 last edited by
                          @TiboTake sagte in [Neuer Adapter] Visualisierung iQontrol:
                          Ja, in den Verknüpften Raum Geräte hinzufügen........
                            SaiBot1981 @sigi234 last edited by
                            @sigi234 said in [Neuer Adapter] Visualisierung iQontrol:
                            So war das leider nicht gemeint.
                            Ich meinte das in dem Icon der Verknüpfung dann eine Glühbirne oder so zu sehen ist.
                            Eigentlich wie ein normales schaltbares Icon nur ohne die Funktion zum schalten sondern um zum Raum zu kommen.
                              Du kannst ja das Hintergrundbild der Verknüpfung ändern...........
                                @sigi234
                                Dann sehe ich aber doch den state nicht.
                                Kurz um, ich möchte eine state sehen von einem Lichtschalter der über die Verknüpfung erreicht werden kann.
                                sigi234 BBTown 2 Replies Last reply Reply Quote 0
                                  sigi234 Forum Testing Most Active @SaiBot1981 last edited by sigi234
                                  Aha, ok das weis ich nicht ob das geht...........mal @dslraser fragen, oder @s-bormann
                                  • BBTown
                                    BBTown @SaiBot1981 last edited by BBTown
                                    @TiboTake
                                    Du könntest folgendes versuchen:
                                    Lege ein Script an, dass die Geräte in dem Raum abfragt und als Ergebnis trägst Du true oder false in einen neuen Datenpunkt ein
                                    Diesen Datenpunkt verknüpfst Du mit einer entsprechenden Kachel.
                                    Die Kachel selbst verlinkt zu deinem Raum
                                    sigi234 S 2 Replies Last reply Reply Quote 1
                                      sigi234 Forum Testing Most Active @BBTown last edited by
                                      @BBTown sagte in [Neuer Adapter] Visualisierung iQontrol:
                                      @TiboTake
                                      Du bist ein Fuchs................😎
                                      • s.bormann
                                        s.bormann Most Active @dsmax last edited by
                                        @dsmax sagte in [Neuer Adapter] Visualisierung iQontrol:
                                        Jörg
                                        Danke, dieses wirklich nette Kompliment freut mich!
                                        LG!
                                        • s.bormann
                                          s.bormann Most Active @sigi234 last edited by
                                          @sigi234 sagte in [Neuer Adapter] Visualisierung iQontrol:
                                          @TiboTake
                                          ich würde das genau wie es BBTown gesagt hat mit einem Script lösen und als iQontrol-Gerät dem Brightness-Sensor wählen: Die Sonne kann hell/dunkel anzeigen und ein LinkedView wird direkt beim draufklicken geöffnet.
                                          LG
                                            sigi234 Forum Testing Most Active @s.bormann last edited by
                                            @s-bormann sagte in [Neuer Adapter] Visualisierung iQontrol:
                                            Wenn mann die Admin-Seite das erste mal öffnet, werden die hochgeladenen Bilder in ein anderes Verzeichnis verschoben (iqontrol.meta), das vom ioBroker-Backup gesichert werden kann. Danach muss die Admin-Seite für jede Instanz einmal öffnen und speichern. Dabei werden die hinterlegten Pfade zu den Bildern automatisch angepasst. -> Bitte ausführlich testen! Wenn das läuft, würde ich das ganze nämlich mal in der latest stable veröffentlichen.
                                            Das hat bei mir nicht funktioniert.........
                                            Die alten Bilder wurden nicht kopiert.........Habe mal neu installiert.
                                            Hm...gibt es kein Default Verzeichnis mehr?
                                            Hast Recht, die Standard-Pfade bei Neu-Installationen sind falsch.
                                            Aber theoretisch: Wenn Du die Admin-Seite schließt und dann neu öffnest, müsste er es doch anpassen, oder nicht?
                                            Funktioniert leider noch immer nicht................
                                            Hi, kannst Du bitte auch noch mal mit F12 den Debugger starten, die Seite neu Laden und auf Fehlermeldungen in der Console schauen? Das muss doch irgendwie in den Griff zu bekommen sein...
                                            80.8k
                                            295
                                            7634
                                            6777578
