    4. Gleitender Durchschnitt, Min., Max. über def. Zeitraum
      paul53 @sigi234 last edited by
      @sigi234 sagte:
      Habe den DP Statisic Json
      Der enthält nur die Datenpunkt-IDs und die Temperatur-Listen. Die berechneten Werte sind nicht enthalten.
        sigi234 Forum Testing Most Active @paul53 last edited by
        @paul53 sagte in Gleitender Durchschnitt, Min., Max. über def. Zeitraum:
        @sigi234 sagte:
        Doch:
        [{"value":"javascript.0.Status.Temperatur.Bad","max24h":"javascript.0.Status.Temperatur.Bad.Max_24h","min24h":"javascript.0.Status.Temperatur.Bad.Min_24h","mean24h":"javascript.0.Status.Temperatur.Bad.Mean_24h","median24h":"javascript.0.Status.Temperatur.Bad.Median_24h","max1h":"javascript.0.Status.Temperatur.Bad.Max_1h","min1h":"javascript.0.Status.Temperatur.Bad.Min_1h","mean1h":"javascript.0.Status.Temperatur.Bad.Mean_1h","data":[23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.9,23.9,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,24,24,24,24,24,24,24.1,24,24.1,24.1,24.1,24.2,24.2,24.4,24.6,24.2,24.3,24.4,24.3,24.1,24.1,24.1,24.1,24.1,24.1,24.1,24.2,24.1,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.3,24.3,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.2,24.1,24.2,24.2,24.2,24.2,24.2,24.2,24.1,24.1,24.1,24.1,24.1,24.1,24.1,24.1,24.1,24.1,24,24.1,24.1,24,24,24,24,24,24,24,24,24,24.1,24,24,24,24,24,24,24,24,23.9,24,24,24,23.9,23.9,23.9,23.9,23.9,23.9,23.9,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8,23.8]},{"value":"javascript.0.Status.Luftfeuchtigkeit.Bad","max24h":"javascript.0.Status.Luftfeuchtigkeit.Bad.Max_24h","min24h":"javascript.0.Status.Luftfeuchtigkeit.Bad.Min_24h","mean24h":"javascript.0.Status.Luftfeuchtigkeit.Bad.Mean_24h","median24h":"javascript.0.Status.Luftfeuchtigkeit.Bad.Median_24h","max1h":"javascript.0.Status.Luftfeuchtigkeit.Bad.Max_1h","min1h":"javascript.0.Status.Luftfeuchtigkeit.Bad.Min_1h","mean1h":"javascript.0.Status.Luftfeuchtigkeit.Bad.Mean_1h","data":[59,59,59,60,60,60,61,61,61,61,61,61,61,61,61,61,61,61,62,62,62,62,63,63,64,64,64,64,65,65,64,64,64,64,64,65,65,66,67,68,69,70,72,71,74,75,71,64,59,58,58,58,58,58,59,59,59,59,59,60,60,60,60,60,60,60,60,61,61,61,61,61,61,61,61,61,61,60,60,60,60,60,61,61,61,61,61,61,60,60,60,60,60,60,60,60,60,60,60,60,60,60,60,60,60,60,60,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,61,62,62,62]},{"value":"javascript.0.Status.Temperatur.Außen","max24h":"javascript.0.Status.Temperatur.Außen.Max_24h","min24h":"javascript.0.Status.Temperatur.Außen.Min_24h","mean24h":"javascript.0.Status.Temperatur.Außen.Mean_24h","median24h":"javascript.0.Status.Temperatur.Außen.Median_24h","max1h":"javascript.0.Status.Temperatur.Außen.Max_1h","min1h":"javascript.0.Status.Temperatur.Außen.Min_1h","mean1h":"javascript.0.Status.Temperatur.Außen.Mean_1h","data":[20,20,20,20,19,19,19,19,19,19,18,18,18,18,18,18,17,17,17,17,17,17,16,16,16,16,16,16,15,16,16,16,16,16,16,16,16,16,16,16,16,17,17,17,17,17,17,18,18,18,18,18,18,18,18,18,18,18,18,19,19,19,19,19,19,19,19,19,19,19,19,19,19,19,19,19,19,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,18,17,17,17,17,17,17,17,17,17,17,17,17,16,16,16,16,16,16,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15,15]},{"value":"javascript.0.Status.Luftfeuchtigkeit.Außen","max24h":"javascript.0.Status.Luftfeuchtigkeit.Außen.Max_24h","min24h":"javascript.0.Status.Luftfeuchtigkeit.Außen.Min_24h","mean24h":"javascript.0.Status.Luftfeuchtigkeit.Außen.Mean_24h","median24h":"javascript.0.Status.Luftfeuchtigkeit.Außen.Median_24h","max1h":"javascript.0.Status.Luftfeuchtigkeit.Außen.Max_1h","min1h":"javascript.0.Status.Luftfeuchtigkeit.Außen.Min_1h","mean1h":"javascript.0.Status.Luftfeuchtigkeit.Außen.Mean_1h","data":[67,67,67,67,74,74,74,74,74,74,80,80,80,80,80,80,84,84,84,84,84,84,87,87,87,87,87,87,86,82,82,82,82,82,82,79,79,79,79,79,79,76,76,76,76,76,76,72,72,72,72,72,72,68,68,68,68,68,68,66,66,66,66,66,66,69,69,69,69,69,69,73,73,73,73,73,73,78,78,78,78,78,78,81,81,81,81,81,81,75,75,75,75,75,75,72,72,72,72,72,72,75,75,75,75,75,75,81,81,81,81,81,81,86,86,86,86,86,86,88,88,88,88,88,88,89,89,89,89,89,89,89,89,89,89,89,89,90,90,90,90,90,90,90]}]
          @sigi234 sagte:
          Doch:
          Nein. Beispiel:
          Bezeichner ist "value", Wert ist "javascript.0.Status.Luftfeuchtigkeit.Bad" (ID).
            @sigi234 sagte:
            Doch:
            Nein. Beispiel:
            Ok, was sind dann die Werte nach "data"?
              @sigi234 sagte:
              Das ist die Werte-Liste zum jeweiligen Sensor, aus der die Berechnungen erfolgen.
                @sigi234 sagte:
                Ok, Danke.......werde mir mal eine Vis basteln, DP sind ja da und geht ja auch mit dem History Adapter und Flot.
                  @sigi234
                  Du kannst mal die erweiterte Funktion testen, die ein JSON mit Werten erzeugen soll. Den Datenpunkt zu idTable musst Du erzeugen und die ID im Skript deklarieren und zuweisen.
                  //Berechnung der Werte
                  function calcStatData() {
                     if (!listStatData || (idData.length != listStatData.length)) {
                          initializeStatData();
                      //logDebug('starting calcStatData');
                     var table = [];
                     for (var i = 0; i < idData.length; i++) {
                        var obj = {};
                        var sensor = listStatData[i].value.split('.');
                        obj.Sensor = sensor[4] + ' ' + sensor[3];
                        listStatData[i].data.pop(); //Remove the last element of an array
                        var x = parseFloat(getState(idData[i][0]).val);
                        obj.Wert = x;
                        listStatData[i].data.unshift(x); //Add new items to the beginning of an array
                        setState(listStatData[i].value, x);
                        var min = x;
                        var max = x;
                        var sum = 0.0;
                        for (var j = 0; j < statDataLength24; j++) {
                           var s = parseFloat(listStatData[i].data[j]);
                           if (s < min) min = s;
                           if (s > max) max = s;
                           sum += s;
                           if (j == (statDataLength1-1)) {
                              setState(listStatData[i].min1h, min);
                              setState(listStatData[i].max1h, max);
                              setState(listStatData[i].mean1h, round(sum / statDataLength1, 2));
                        setState(listStatData[i].min24h, min);
                        setState(listStatData[i].max24h, max);
                        setState(listStatData[i].mean24h, round(sum / statDataLength24, 2));
                        setState(listStatData[i].median24h, getMedian(listStatData[i].data));
                        obj.Min_24h = min;
                        obj.Max_24h = max;
                        obj.Mean_24h = round(sum / statDataLength24, 2);
                        obj.Median_24h = getMedian(listStatData[i].data);
                        table[i] = obj;
                     setState(dpData, JSON.stringify(listStatData));
                     setState(idTable, JSON.stringify(table), true);
                    @sigi234
                       var table = [];
                          var obj = {};
                          obj.Wert = x;
                          var min = x;
                          var max = x;
                          var sum = 0.0;
                             sum += s;
                          obj.Min_24h = min;
                          obj.Max_24h = max;
                          table[i] = obj;
                    Danke, also Skript ist nicht mein Ding, aber ich versuche es mal.Ist das ein eigens Skript oder gehört es in meines?
                    Also hier: setState(idTable, JSON.stringify(table), true); muss der neue DP rein
                    und die ID im Skript deklarieren und zuweisen?
                      @sigi234 sagte:
                      Das ist eine erweiterte Funktion calcStatData(), die Teil Deines Skriptes ist.
                      @sigi234 sagte in Gleitender Durchschnitt, Min., Max. über def. Zeitraum:
                      Ziemlich am Anfang des Skriptes (Vorschlag)
                      const idTable = 'javascript.0.Status.Tabelle';
                      createState(idTable, '', {type: 'string'});
                        sigi234 Forum Testing Most Active @paul53 last edited by sigi234
                        @sigi234 sagte:
                        Ok, habe es so gemacht: Edit 2
                        // Berechnung von gleitendem Durchschnitt, Minimum und Maximum über einen Zeitraum
                        // Version 1.4.1
                        "use strict";
                        // Berechnet Min/Max, Durschschnitt und Median über die letzten 24h.
                        // Berechnet Min/Max, Durschschnitt über die letzte 1h.
                        // IDs aller benötigten Datenpunkte
                        // Als Array im Array mit folgendem Format:
                        //  1\.   original Datenpunktname
                        //  2\.  neuer Datenpunktname
                        //         Beispiel:   javascript.0.Status.Temperatur.Außen
                        //                  javascript.0.Status.Luftfeuchtigkeit.Außen
                        //  3\.   Beschreibung des Messwertes (zur Erzeugung neue Datenpunkte)
                        //         Beispliele:   Temperatur
                        //                  Luftfeuchtigkeit
                        //   4\.  Einheit (zur Erzeugung neue Datenpunkte)
                        //         Beispiele:   °C, %
                        // Ist beliebig erweiterbar und für beliebige Werte nutzbar.
                        // Beispiel 1:
                        // const idData = [['hm-rpc.3.CUX3200312.1.TEMPERATURE','javascript.0.Status.Temperatur.Außen','Temperatur','°C'],
                        //                 ['hm-rpc.3.CUX9002580.1.HUMIDITY'   ,'javascript.0.Status.Luftfeuchtigkeit.Außen','Luftfeuchtigkeit','%']];
                        // Beispiel 2:
                        // const idData = [['hm-rpc.3.CUX3200312.1.TEMPERATURE','javascript.0.Status.Außen.Temperatur','Temperatur','°C'],
                        //                 ['hm-rpc.3.CUX9002580.1.HUMIDITY'   ,'javascript.0.Status.Außen.Luftfeuchtigkeit','Luftfeuchtigkeit','%'],
                        //                 ['hm-rpc.3.CUX4007637.1.Data'   ,'javascript.0.Status.Außen.Lichtstärke','Lichtstärke','lux']];
                        const idData = [['hm-rpc.1.OEQ0670648.1.TEMPERATURE','javascript.0.Status.Temperatur.Bad','Temperatur','°C'],
                                        ['hm-rpc.1.OEQ0670648.1.HUMIDITY','javascript.0.Status.Luftfeuchtigkeit.Bad','Luftfeuchtigkeit','%'],
                                        ['daswetter.0.NextHours.Location_1.Day_1.current.temp_value','javascript.0.Status.Temperatur.Außen','Temperatur','°C'],
                                        ['daswetter.0.NextHours.Location_1.Day_1.current.humidity_value','javascript.0.Status.Luftfeuchtigkeit.Außen','Luftfeuchtigkeit','%'],
                        //Datenpunkt zur Speicherung aller internen Daten
                        const dpData='javascript.0.Status.Statistic';
                        // Implementierung -- hier nichts mehr ändern
                        // globale Konstanten
                        const tc = 10;         // Abtastrate in Minuten
                        const statDataLength24 = Math.round((24 * 60) / tc); // Anzahl der Werte für 24h
                        const statDataLength1 = Math.round(60 / tc); // Anzahl der Werte für stündlich
                        // globale Variablen
                        var listStatData;  //interne Speicherung aller Werte
                        //Funktion zum einmaligem initialisieren aller Datenpunkte
                        function initializeStatData() {
                           // Datenpunkt zur Speicherung der internen Werte erzeugen
                           createState(dpData, 0, false, {
                              read: true,
                              write: true,
                              desc: 'Statistische Daten',
                              type: 'string',
                              def: '',
                              role: 'json'
                           //internes Array initialisieren
                            var needInit = false;
                           try {
                              listStatData = JSON.parse(getState(dpData).val);
                           } catch (ex) {
                              needInit = true;
                           if (needInit || !listStatData || (listStatData.length < idData.length)) {
                              listStatData = new Array(idData.length);
                           //logDebug('initializeStatData for', dpData, listStatData);
                                if (!listStatData[i]) { listStatData[i] = {}; }
                                listStatData[i].value       = idData[i][1];
                                listStatData[i].max24h		= idData[i][1] + '.Max_24h';
                                listStatData[i].min24h		= idData[i][1] + '.Min_24h';
                                listStatData[i].mean24h		= idData[i][1] + '.Mean_24h';
                                listStatData[i].median24h	= idData[i][1] + '.Median_24h';
                        	listStatData[i].max1h		= idData[i][1] + '.Max_1h';
                        	listStatData[i].min1h		= idData[i][1] + '.Min_1h';
                        	listStatData[i].mean1h		= idData[i][1] + '.Mean_1h';
                        	createState(listStatData[i].value, 0, false, {
                                    read: true,
                                    write: true,
                                    desc: idData[i][2]+ ' Aktueller Wert',
                              	    type: 'number',
                                    def: 0,
                                    unit: idData[i][3],
                                    role: 'value'
                        	createState(listStatData[i].max24h, 0, false, {
                                    read: true,
                                    write: true,
                                    desc: idData[i][2] + ' Maximum',
                                    type: 'number',
                                    def: 0,
                                    unit: idData[i][3],
                                    role: 'value'
                               createState(listStatData[i].min24h, 0, false, {
                                    read: true,
                                    write: true,
                                    desc: idData[i][2] + ' Minimum',
                                    type: 'number',
                                    def: 0,
                        	    unit: idData[i][3],
                                    role: 'value'
                               createState(listStatData[i].mean24h, 0, false, {
                                    read: true,
                                    write: true,
                                    desc: idData[i][2] + ' Mittelwert',
                                    type: 'number',
                                    def: 0,
                                    unit: idData[i][3],
                                    role: 'value'
                              createState(listStatData[i].median24h, 0, false, {
                                    read: true,
                                    write: true,
                                    desc: idData[i][2] + ' Median',
                                    type: 'number',
                                    def: 0,
                        	        unit: idData[i][3],
                                    role: 'value'
                              createState(listStatData[i].max1h, 0, false, {
                                    read: true,
                                    write: true,
                                    type: 'number',
                                    def: 0,
                                    unit: idData[i][3],
                                    role: 'value'
                              createState(listStatData[i].min1h, 0, false, {
                                    read: true,
                                    write: true,
                                    type: 'number',
                                    def: 0,
                                    unit: idData[i][3],
                                    role: 'value'
                              createState(listStatData[i].mean1h, 0, false, {
                                    read: true,
                                    write: true,
                                    type: 'number',
                                    def: 0,
                        	    unit: idData[i][3],
                        	    role: 'value'
                              if (needInit || !listStatData[i].data || (listStatData[i].data.length != statDataLength24)) {
                                    listStatData[i].data	= new Array(statDataLength24);
                                    // 1\. Script start: Liste und String-Datenpunkt füllen
                                    var x = getState(idData[i][0]).val;
                                    listStatData[i].data[j] = x;
                                  //logDebug(listStatData[i], i);
                                    setStateDelayed(listStatData[i].value, x, false, 1000);
                                    setStateDelayed(listStatData[i].min24h, x, false, 1000);
                                    setStateDelayed(listStatData[i].max24h, x, false, 1000);
                                    setStateDelayed(listStatData[i].mean24h, x, false, 1000);
                                    setStateDelayed(listStatData[i].median24h, x, false, 1000);
                                    setStateDelayed(listStatData[i].min1h, x, false, 1000);
                                    setStateDelayed(listStatData[i].max1h, x, false, 1000);
                                    setStateDelayed(listStatData[i].mean1h, x, false, 1000);
                            var table = [];
                               var obj = {};
                               obj.Wert = x;
                               var min = x;
                               var max = x;
                               var sum = 0.0;
                                  sum += s;
                               obj.Min_24h = min;
                               obj.Max_24h = max;
                               table[i] = obj;
                        function getMedian(args) {
                          if (!args.length) {return 0}
                          var numbers = args.slice(0).sort((a,b) => a - b);
                          var middle = Math.floor(numbers.length / 2);
                          var isEven = numbers.length % 2 === 0;
                          return isEven ? (numbers[middle] + numbers[middle - 1]) / 2 : numbers[middle];
                         * round a number
                         * @param    value  to round
                         * @param    exp    exponent to round
                         * @returns         the round number
                        function round(value, exp) {
                          if (typeof exp === 'undefined' || +exp === 0)
                            return Math.round(value);
                          value = +value;
                          exp = +exp;
                          if (isNaN(value) || !(typeof exp === 'number' && exp % 1 === 0))
                            return NaN;
                          // Shift
                          var values = value.toString().split('e');
                          value = Math.round(+(values[0] + 'e' + (values[1] ? (+values[1] + exp) : exp)));
                          // Shift back
                          return +(values[0] + 'e' + (values[1] ? (+values[1] - exp) : -exp));
                        schedule('*/' + tc + ' * * * *', function () {
                           calcStatData();
                          @sigi234 sagte :
                          Funktioniert es, so dass Du den Datenpunkt "javascript.0.Status.Tabelle" in Vis verwenden kannst ?
                            @sigi234 sagte :
                            Ja, Danke einfach perfekt..........👍
                              Das sieht ja super aus!
                              Fehlt nur noch die Standardabweichung.
                              Mein Geigerzähler hat seit Oktober 2017 schon 4 Fehlalarme produziert, weil ich wohl die Grenzen etwas zu stramm habe. Da hülfe wohl die Kenntnis der Standardabweichung.
                                kai_enet last edited by
                                sorry für Anfängerfragen - aber habe erst diese Woche mit iobroker angefangen:
                                Hat schon jemand den export von history Daten benutzt (https://github.com/ioBroker/ioBroker.history/blob/master/docs/de/README.md - "Zugriff auf History Werte mit JavaScript") um damit für Sensoren eine Gleitmittelung bzw min max der letzten x Werte durchzuführen ?
                                Wäre für ein Beispiel dankbar...
                                  paul53 @kai_enet last edited by
                                  @kai_enet sagte:
                                  Mit 'history.0' anstelle 'sql.0'
                                    martin last edited by martin
                                    Ich habe das Skript mit meinen Xiaomi Sensoren unter "const idData" gefüttert und ansonsten nichts verändert.
                                    // Version 1.4.1
                                    "use strict";
                                    //                  Luftfeuchtigkeit
                                    //         Beispiele:   °C, %
                                    // Beispiel 1:
                                    // Beispiel 2:
                                    const idData = [['mihome.0.devices.weather_v1_158d0002c8f3ab.temperature','javascript.0.Status.Temperatur.Balkon','Temperatur','°C'],
                                                    ['mihome.0.devices.weather_v1_158d0002c8f3ab.humidity','javascript.0.Status.Luftfeuchtigkeit.Balkon','Luftfeuchtigkeit','%'];
                                          read: true,
                                          write: true,
                                          type: 'string',
                                          def: '',
                                          role: 'json'
                                       try {
                                       } catch (ex) {
                                          needInit = true;
                                                read: true,
                                    	        write: true,
                                          	    type: 'number',
                                                def: 0,
                                                unit: idData[i][3],
                                                role: 'value'
                                                read: true,
                                                write: true,
                                                type: 'number',
                                                def: 0,
                                                unit: idData[i][3],
                                                role: 'value'
                                                read: true,
                                                write: true,
                                                type: 'number',
                                                def: 0,
                                    	    unit: idData[i][3],
                                                role: 'value'
                                                read: true,
                                                write: true,
                                                type: 'number',
                                                def: 0,
                                                unit: idData[i][3],
                                                role: 'value'
                                                read: true,
                                                write: true,
                                                type: 'number',
                                                def: 0,
                                    	        unit: idData[i][3],
                                                role: 'value'
                                                read: true,
                                                write: true,
                                                type: 'number',
                                                def: 0,
                                                unit: idData[i][3],
                                                role: 'value'
                                                read: true,
                                                write: true,
                                                type: 'number',
                                                def: 0,
                                                unit: idData[i][3],
                                                role: 'value'
                                                read: true,
                                                write: true,
                                                type: 'number',
                                                def: 0,
                                    	    unit: idData[i][3],
                                    	    role: 'value'
                                          var min = x;
                                          var max = x;
                                          var sum = 0.0;
                                             sum += s;
                                     * round a number
                                      value = +value;
                                      exp = +exp;
                                        return NaN;
                                      // Shift
                                      // Shift back
                                       calcStatData();
                                    Es werden aber keine Datenpunkte erzeugt.
                                    Im Log finde ich nur:
                                    javascript.0	2020-09-30 18:14:21.682	info	(16357) script.js.Meine_Scripts.Temperatur_Min_Max: registered 0 subscriptions and 0 schedules
                                    javascript.0	2020-09-30 18:14:21.671	info	(16357) Start javascript script.js.Meine_Scripts.Temperatur_Min_Max
                                      paul53 @martin last edited by
                                      @martin sagte:
                                      and 0 schedules
                                      Ganz zu Beginn und am Ende sind Zeichen `, die da nicht hin gehören.
                                        martin @paul53 last edited by martin
                                        @paul53 said in Gleitender Durchschnitt, Min., Max. über def. Zeitraum:
                                        Danke!
                                        Jetzt kommt eine ganze Reihe an Warnungen mit denen ich nichts anfangen kann:
                                        javascript.0	2020-09-30 18:55:11.308	info	(16357) script.js.Meine_Scripts.Temperatur_Min_Max: registered 0 subscriptions and 1 schedule
                                        javascript.0	2020-09-30 18:55:11.300	warn	(16357) at script.js.Meine_Scripts.Temperatur_Min_Max:271:1
                                        javascript.0	2020-09-30 18:55:11.299	warn	(16357) at initializeStatData (script.js.Meine_Scripts.Temperatur_Min_Max:199:4)
                                        javascript.0	2020-09-30 18:55:11.299	warn	(16357) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
                                        javascript.0	2020-09-30 18:55:11.296	warn	(16357) State "javascript.0.Status.Statistic" not found
                                        javascript.0	2020-09-30 18:55:11.290	warn	(16357) at script.js.Meine_Scripts.Temperatur_Min_Max:271:1
                                        javascript.0	2020-09-30 18:55:11.289	warn	(16357) at initializeStatData (script.js.Meine_Scripts.Temperatur_Min_Max:71:33)
                                        javascript.0	2020-09-30 18:55:11.285	warn	(16357) getState "javascript.0.Status.Statistic" not found (3)
                                        javascript.0	2020-09-30 18:55:11.242	info	(16357) Start javascript script.js.Meine_Scripts.Temperatur_Min_Max
                                        javascript.0	2020-09-30 18:55:11.078	info	(16357) Stop script script.js.Meine_Scripts.Temperatur_Min_Max
                                          @martin
                                          In Zeile 35 fehlt am Ende (vor dem Semikolon) eine schließende eckige Klammer.
                                            @martin
                                            Das habe ich auch gerade gefunden. 🙂
                                            Jetzt kommen die Warnungen (siehe oben - habe den Beitrag bearbeitet).
                                            javascript
                                            20
                                            113
                                            23065
