    4. Adapter: DasWetter
    Adapter: DasWetter
      crunchip Forum Testing Most Active @der-eine last edited by crunchip
      @der-eine ist es diese Einstellung eventuell basic-Border
        sigi234 Forum Testing Most Active @der-eine last edited by
        @der-eine
        So, habe mal ein neues Projekt erstellt, da ist es bei mir auch blau.............., wir kommen noch darauf....
          der-eine @crunchip last edited by
          hab ich leider auch schon vom importieren übernommen...
            der-eine @sigi234 last edited by
            @sigi234 danke schon mal für die Hilfe!
            Wie gesagt komisch das man darüber nicht wirklich "Anleitungen" findet...
              @der-eine füg mal das widget bei dir ein
              [{"tpl":"tplTableBody","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","static_value":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"table_oid":"javascript.0.mylog.logWarnanderrorJSON","new_on_top":true,"show_scroll":true,"colCount":"4","hide_header":true,"colName2":"","colName4":"","class":"test","views":["test"]},"style":{"left":"70px","top":"40px","width":"810px","height":"760px","background":"","background-color":""},"widgetSet":"basic"}]
                der-eine last edited by der-eine
                @crunchip sagte in Adapter: DasWetter:
                Wo genau? Ist ja ein Table?
                  @der-eine ja, hatte grad einen Denkfehler, kannst so ja gar nicht anzeigen lassen, wollte wissen in welcher farbe das angezeigt wird
                    @crunchip ok
                      @der-eine
                      So getestet im neuen Projekt. Also beim Popup zu einer neuen View : blau
                      Meine View importiert: schwarz
                      Es hat also mit der importieren View was auf sich.
                      Ich glaube das du den z-index verstellt hast?
                      Zeig mal einen Screenshot davon.
                        @sigi234 von welchen Widget der Z-Index? Das Widget das das Popup aufrufen soll hat aktuell garkeinen Z-Index
                          @der-eine
                          basic-Border
                            @sigi234 der is 2
                              @sigi234 ich muss jetzt ins Bett Wecker läutet um 0430 meld mich dann morgen nachmittag wieder.
                                @der-eine
                                OK..................
                                  Hallo @sigi234 ,
                                  hast Du noch eine Option gefunden?
                                  Grüsse
                                    dtp last edited by dtp
                                    Hier mal mein Wetter-View mit der dreistündigen 5-Tages-Vorhersage, den DWD-Wetterwarnungen und den wesentlichen Informationen des HomeMatic Wettersensors HmIP-SWO-PR.
                                    Mir genügt das so voll und ganz an Informationen. Die Wind-Anzeige des Wettersensors wechselt übrigens alle drei Sekunden zwischen der Windrichtung und der Windgeschwindigkeit.
                                      Sagt mal, der Adapter legt ja unter der Instanz daswetter.0 eine Location_1 an. Wie kann ich denn da eine zweite Location anlegen? Oder muss ich dazu eine weitere Instanz daswetter.1 erzeugen?
                                      Ach, und noch was. Mir scheint, der Adapter kann nur mit Wettersymbolen für den Tag (also, wenn es hell ist) arbeiten. Oder gibt es da auch Wettersymbole für die Nacht, die man in die 3-Stunden-Vorschau einbinden kann?
                                      Direkt auf der Homepage von daswetter.com gibt es auf jeden Fall solche Symbole:
                                      sigi234 D 2 Replies Last reply Reply Quote 0
                                        sigi234 Forum Testing Most Active @der-eine last edited by sigi234
                                        Hallo @sigi234 ,
                                        @der-eine
                                        Leider noch nicht.......
                                          sigi234 Forum Testing Most Active @dtp last edited by sigi234
                                          @dtp sagte in Adapter: DasWetter:
                                          Ja....und die entsprechende Url für deinen 2.Ort erstellen.
                                            dtp @sigi234 last edited by
                                            @sigi234 sagte in Adapter: DasWetter:
                                            Danke für die Info. Sprich, der Unterordner "Location_1" ist eigentlich überflüssig, oder?
                                            1208
                                            411789
