    4. Einfach mal zeigen will….. :-) - Teil 2
      sigi234 Forum Testing Most Active @maniac last edited by
      @maniac sagte in Einfach mal zeigen will….. 🙂 - Teil 2:
      Geht das einfach so mit dem Link?
      Ja, man muss:
      Rechts Klick, als Adresse kopieren, dann in Browser einfügen
      http://192.168.222.41:8082/flot/index.html...........................
      IP anpassen und index auf edit ändern
      • Negalein
        Negalein Global Moderator @maniac last edited by
        Funktioniert so leider nicht, da er die Sonderzeichen in komische Zeichenfolgen ändert.
        Kannst du den Link als Code hier reinstellen?
          Dann probier nochmal
          http://xxx.xxx.xxx.xxx:8082/flot/edit.html?l%5B0%5D%5Bid%5D=javascript.0.Speed-Test.download&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bcolor%5D=%23ff3333&l%5B0%5D%5Bmin%5D=50&l%5B0%5D%5Bmax%5D=120&l%5B0%5D%5Bthickness%5D=2&l%5B0%5D%5Bshadowsize%5D=2&l%5B0%5D%5Bunit%5D=m%2Fbit&l%5B0%5D%5Bname%5D=Download&l%5B0%5D%5Byaxe%5D=leftColor&l%5B0%5D%5Bxaxe%5D=off&l%5B0%5D%5Bpoints%5D=false&l%5B0%5D%5Bv%5D=landroid-s.0.mower.status&l%5B0%5D%5Bvl%5D=landroid-s.0.mower.status&l%5B0%5D%5BchartType%5D=spline&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Byticks%5D=6&l%5B0%5D%5Binstance%5D=history.0&l%5B0%5D%5Bfill%5D=0&l%5B1%5D%5Bid%5D=javascript.0.Speed-Test.ping&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2333ff33&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=1&l%5B1%5D%5Bunit%5D=ms&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bname%5D=Ping&l%5B1%5D%5Bxaxe%5D=bottomColor&l%5B1%5D%5Bmin%5D=-0.1&l%5B1%5D%5Bmax%5D=120&l%5B1%5D%5BafterComma%5D=0&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5BchartType%5D=line&l%5B1%5D%5Binstance%5D=history.0&l%5B1%5D%5Bfill%5D=0&l%5B1%5D%5Bpoints%5D=false&l%5B2%5D%5Bid%5D=javascript.0.Speed-Test.upload&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=average&l%5B2%5D%5Bcolor%5D=%2344ffFF&l%5B2%5D%5Bmin%5D=50&l%5B2%5D%5Bmax%5D=120&l%5B2%5D%5Bthickness%5D=2&l%5B2%5D%5Bshadowsize%5D=2&l%5B2%5D%5Bunit%5D=m%2FBit&l%5B2%5D%5Bname%5D=Upload&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BignoreNull%5D=false&l%5B2%5D%5BafterComma%5D=1&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B2%5D%5Byticks%5D=3&l%5B2%5D%5BchartType%5D=spline&l%5B2%5D%5Binstance%5D=history.0&l%5B2%5D%5Bfill%5D=0&l%5B2%5D%5Bpoints%5D=false&timeType=relative&relativeEnd=now&range=2880&live=900&aggregateType=step&aggregateSpan=300&window_bg=%23222222&bg=1&grid_color=%23dcdcdc&legend=nw&hoverDetail=true&useComma=false&zoom=true&noedit=false&animation=0&noBorder=noborder&barLabels=topover&titlePos=top%3A35%3Bleft%3A65&titleColor=%23000000&titleSize=15&legColumns=5&timeFormat=%25H%3A%25M&legBgOpacity=0.5&border_color=%23ffffff&m%5B0%5D%5Bl%5D=0&m%5B0%5D%5Bv%5D=82&m%5B0%5D%5Bf%5D=false&m%5B0%5D%5Bc%5D=%23ff7777&m%5B0%5D%5Bt%5D=3&m%5B0%5D%5Bs%5D=3&m%5B0%5D%5Bd%5D=Soll+Up%2FDown&m%5B0%5D%5Bp%5D=l&m%5B0%5D%5Bpy%5D=22&m%5B0%5D%5Bfc%5D=%23ff7777&m%5B0%5D%5Bfs%5D=12&m%5B0%5D%5Bvl%5D=82&m%5B1%5D%5Bl%5D=1&m%5B1%5D%5Bv%5D=15&m%5B1%5D%5Bf%5D=false&m%5B1%5D%5Bc%5D=%2388ff88&m%5B1%5D%5Bt%5D=3&m%5B1%5D%5Bs%5D=3&m%5B1%5D%5Bd%5D=Soll+Ping&m%5B1%5D%5Bp%5D=l&m%5B1%5D%5Bpy%5D=-4&m%5B1%5D%5Bfc%5D=%2388ff88&m%5B1%5D%5Bfs%5D=12&m%5B1%5D%5Bvl%5D=15&barColor=dsf
          • Negalein
            Danke, hat mittlerweile funktioniert.
              PatrickFro last edited by PatrickFro
              bisher habe ich nur Fragen hier gestellt, nun zeige ich auch mal das Produkt. Es ist nicht überall stringent umgesetzt, aber ich arbeite noch dran und hab erst vor 1,5 Monat mit IoBroker angefangen (und bin gleichzeitig umgezogen) 😉
              Die Zentrale:
              Interne Informationen:
              Fliwa, unser Saugroboter:
              Anwesenheitssimulation:
              Rücksetzung der Countdowns:
              Externe Informationen:
              Bus-Abfahrzeiten in der Nähe:
              Veranstaltungen:
              Wetter:
              Regenradar:
              Nachrichten:
              Gästeinformation:
              Da ggf. nicht nur wir sondern auch Gäste an das Tab gehen (wg. Gästenetz, Schaltungen oder Gästeinformationen), habe ich den Kalender ausblendbar gemacht. Es ist zwar nur ein Schieberegler, aber immerhin.
              Die "Wo ist mein Handy"-Funktion habe ich per http Request über ifttt mit VoIP-Anruf gelöst.
              Zusätzlich zum Dashboard habe ich auch an mehreren Stellen EnOcean-Schalter, welche Licht an/aus schalten, Stromquellen schalten oder am Eingang ansagen lassen, welche Geräte angeschaltet sind.
              An der Stelle sag ich nochmal Danke an alle, die meine Fragen hier beantwortet haben bzw. von denen ich Scripte nutzen konnte...
              • Nashra
                Nashra Most Active Forum Testing @maniac last edited by
                Das ist dieser hier.
                https://forum.iobroker.net/topic/3760/script-für-einen-speedtest-über-speedtest-net
                Und dann mit History und Flot dargestellt.
                Danke dir, Script läuft. Aber die Werte sind schlicht daneben. Download 41 MBits, Upload 96 MBits 😬
                Und das bei einem 200er Anschluss 😂
                  maniac @Nashra last edited by
                  @Nashra sagte in Einfach mal zeigen will….. 🙂 - Teil 2:
                  Druck beim Provider machen 🙂
                    berniiiii @maniac last edited by
                    @maniac
                    Danke!
                    Schaue und melde mich.
                    Bernii
                    • Nashra
                      Hm, verschiedene Tests ergeben
                      also alles Ok. Die Daten in den DP schwanken aber auch extrem.
                      Werde es mal weiter beobachten.
                      • Jey Cee
                        Da der Thread wieder ziemlich lang wurde gibt es jetzt den dritten Teil der Serie 😉
                        916
                        422471
