    4. [Aufruf] Alexa2 2.6.0 Testen
      $ ./iobroker url "https://github.com/Apollon77/ioBroker.alexa2.git"
      install https://github.com/Apollon77/ioBroker.alexa2/tarball/master
      npm install https://github.com/Apollon77/ioBroker.alexa2/tarball/master --production --save --prefix "C:/ioBroker" (System call)
      ERROR: internal/modul
      ERROR: es/cjs/loader.js:798
          throw err;
      SyntaxError: C:\ioBroker\node_modules\iobroker.alexa2\io-package.json: Unexpected token , in JSON at position 18635
          at JSON.parse (<anonymous>)
          at Object.Module._extensions..json (internal/modules/cjs/loader.js:795:27)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          at Module.require (internal/modules/cjs/loader.js:690:17)
          at requi
      ERROR: re (internal/modules/cjs/helpers.js:25:18)
          at Upload.uploadAdapter (C:\ioBroker\node_modules\iobroker.js-controller\lib\setup\setupUpload.js:266:19)
          at install.npmInstall (C:\ioBroker\node_modules\iobroker.js-controller\lib\setup.js:775:40)
          at ChildProcess.child.on (C:\ioBroker\node_modules\iobroker.js-controller\lib\setup\setupInstall.js:382:31)
      ERROR: process exited with code 1
        apollon77 last edited by
        Retry ...Fixed ... mensch bist Du schnell
        • Negalein
          Negalein Global Moderator @apollon77 last edited by
          @apollon77 sagte in [Aufruf] Alexa2 2.6.0 Testen:
          hat jetzt geklappt 🙂
          $ ./iobroker url "https://github.com/Apollon77/ioBroker.alexa2/tarball/master" alexa2
          npm install https://github.com/Apollon77/ioBroker.alexa2/tarball/master --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
          npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          got /opt/iobroker/node_modules/iobroker.alexa2/admin
          upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
          upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
          upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
          upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
          upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
          upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
          upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
          upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
          upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
          upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
          upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
          upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
          upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
          upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
          upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
          upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
          upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
          upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
          upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
          upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/apps.png icons/apps.png image/png
          upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
          process exited with code 0
          • Negalein
            alle Kontakte sind da
            Nachrichten schicken funktioniert
            eigene Nachricht löschen (Button) funktioniert
              sigi234 Forum Testing Most Active @Negalein last edited by
              @Negalein sagte in [Aufruf] Alexa2 2.6.0 Testen:
              Ja, bei mir auch..........Danke.
              • Negalein
                bei manchen Kontakten steht noch null dabei
                zB
                aber dann ein zusätzlicher Eintrag vom selben Kontakt ohne null
                • Mic
                  Mic Developer last edited by
                  Getestet, funktioniert wunderbar 🙂
                  Seh cool Ingo, vielen Dank!
                  Das mit "null" habe ich auch bei ein paar Kontakten. Aber die will ich eh nicht kontaktieren 😁
                  Interessant, von wo jetzt diese Kontakte herkommen, war mir nicht bewusst. Wohl aus dem Telefonbuch (Handy), und alle, die eine Alexa haben?
                    apollon77 @Negalein last edited by
                    @Negalein Dann ist bei einem Kontakt nur ein Vorname gesetzt und kein Nachname ...
                    Bitte nochmal neu von Github laden (immer noch 2.6.0). Ist immer noch da aber ohne dem null.
                    Der erste in deiner Liste ist irgendwas spezielles ... müsste man mal sehen was passiert wenn Du da was hin sendest 🙂
                      apollon77 @Mic last edited by
                      @Mic sagte in [Aufruf] Alexa2 2.6.0 Testen:
                      Geh in die Alexa App, zweites Icon unten von links ... da hast Du genau das ...
                      Mic 1 Reply Last reply Reply Quote 0
                        sigi234 Forum Testing Most Active @apollon77 last edited by
                        Der Adapter liesst nun auch die Kontakte aus und listet diese unter "alexa2.0.Contacts" auf
                        Hm......ist es vielleicht machbar das es eine Option gibt mit Contacts einlesen ja/nein? Oder einen Filter welche angezeigt werden sollen?
                        apollon77 Garfonso 2 Replies Last reply Reply Quote 0
                          apollon77 @sigi234 last edited by
                          @sigi234 Warum?
                          • Negalein
                            die null sind noch da
                            • Mic
                              Mic Developer @apollon77 last edited by
                              Da sind aber deutlich mehr Kontakte geführt als im Adapter. Weil diese keine Alexa haben, verknüpft mit Telefon? Echt interessant...
                              • Garfonso
                                Garfonso Developer @sigi234 last edited by
                                @sigi234
                                die Funktion wünsche ich mir dringend für die Alexa App... aber das ist hier leider der falsche Rahmen. 😉
                                  @Negalein Dann brauche ich log, gern per email an iobroker@fischer-ka.de. Am Ende vom Starten des Adapters hängt das Kontakt-Zeug. Ein Request lädt ie gesamte Kontaktliste und daraus wird dann aussortiert was der Adapter anzeigt.
                                    apollon77 @Garfonso last edited by
                                    @Garfonso Wie meinst Du das? Die Alexa-App hat genau diese Option ... Sie wurde mehrfach für den Adapter gewünscht, also hier ists. Man muss es ja nicht nutzen 🙂 (Ich persönlich habe auch keine Anwendung dafür)
                                    • Negalein
                                      jetzt sind sie ohne null da. Hat wohl etwas länger gedauert.
                                      • Negalein
                                        ssml funktioniert auch
                                          @sigi234 Warum?
                                          Bin kein Freund von Nachnahmen, aber ich sehe gerade das man die Namen ändern kann...........
                                            @Negalein Bitte auch Gruppen testen
                                            31.7k
                                            79.8k
                                            alexa 2 adapter
                                            25
                                            254
                                            27253
