    4. [Aufruf] Alexa2 2.6.0 Testen
      apollon77 last edited by
      Retry ...Fixed ... mensch bist Du schnell
      • Negalein
        Negalein Global Moderator @apollon77 last edited by
        @apollon77 sagte in [Aufruf] Alexa2 2.6.0 Testen:
        hat jetzt geklappt 🙂
        $ ./iobroker url "https://github.com/Apollon77/ioBroker.alexa2/tarball/master" alexa2
        install https://github.com/Apollon77/ioBroker.alexa2/tarball/master
        npm install https://github.com/Apollon77/ioBroker.alexa2/tarball/master --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
        npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        got /opt/iobroker/node_modules/iobroker.alexa2/admin
        upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
        upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
        upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
        upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
        upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
        upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
        upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
        upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
        upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
        upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
        upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
        upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
        upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
        upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
        upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
        upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
        upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
        upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
        upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
        upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/apps.png icons/apps.png image/png
        upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
        process exited with code 0
        • Negalein
          alle Kontakte sind da
          Nachrichten schicken funktioniert
          eigene Nachricht löschen (Button) funktioniert
            sigi234 Forum Testing Most Active @Negalein last edited by
            @Negalein sagte in [Aufruf] Alexa2 2.6.0 Testen:
            Ja, bei mir auch..........Danke.
            • Negalein
              bei manchen Kontakten steht noch null dabei
              zB
              aber dann ein zusätzlicher Eintrag vom selben Kontakt ohne null
              • Mic
                Mic Developer last edited by
                Getestet, funktioniert wunderbar 🙂
                Seh cool Ingo, vielen Dank!
                Das mit "null" habe ich auch bei ein paar Kontakten. Aber die will ich eh nicht kontaktieren 😁
                Interessant, von wo jetzt diese Kontakte herkommen, war mir nicht bewusst. Wohl aus dem Telefonbuch (Handy), und alle, die eine Alexa haben?
                  apollon77 @Negalein last edited by
                  @Negalein Dann ist bei einem Kontakt nur ein Vorname gesetzt und kein Nachname ...
                  Bitte nochmal neu von Github laden (immer noch 2.6.0). Ist immer noch da aber ohne dem null.
                  Der erste in deiner Liste ist irgendwas spezielles ... müsste man mal sehen was passiert wenn Du da was hin sendest 🙂
                    apollon77 @Mic last edited by
                    @Mic sagte in [Aufruf] Alexa2 2.6.0 Testen:
                    Geh in die Alexa App, zweites Icon unten von links ... da hast Du genau das ...
                    Mic 1 Reply Last reply Reply Quote 0
                      sigi234 Forum Testing Most Active @apollon77 last edited by
                      Der Adapter liesst nun auch die Kontakte aus und listet diese unter "alexa2.0.Contacts" auf
                      Hm......ist es vielleicht machbar das es eine Option gibt mit Contacts einlesen ja/nein? Oder einen Filter welche angezeigt werden sollen?
                      apollon77 Garfonso 2 Replies Last reply Reply Quote 0
                        apollon77 @sigi234 last edited by
                        @sigi234 Warum?
                        • Negalein
                          die null sind noch da
                          • Mic
                            Mic Developer @apollon77 last edited by
                            Da sind aber deutlich mehr Kontakte geführt als im Adapter. Weil diese keine Alexa haben, verknüpft mit Telefon? Echt interessant...
                            • Garfonso
                              Garfonso Developer @sigi234 last edited by
                              @sigi234
                              die Funktion wünsche ich mir dringend für die Alexa App... aber das ist hier leider der falsche Rahmen. 😉
                                @Negalein Dann brauche ich log, gern per email an iobroker@fischer-ka.de. Am Ende vom Starten des Adapters hängt das Kontakt-Zeug. Ein Request lädt ie gesamte Kontaktliste und daraus wird dann aussortiert was der Adapter anzeigt.
                                  apollon77 @Garfonso last edited by
                                  @Garfonso Wie meinst Du das? Die Alexa-App hat genau diese Option ... Sie wurde mehrfach für den Adapter gewünscht, also hier ists. Man muss es ja nicht nutzen 🙂 (Ich persönlich habe auch keine Anwendung dafür)
                                  • Negalein
                                    jetzt sind sie ohne null da. Hat wohl etwas länger gedauert.
                                    • Negalein
                                      ssml funktioniert auch
                                        @sigi234 Warum?
                                        Bin kein Freund von Nachnahmen, aber ich sehe gerade das man die Namen ändern kann...........
                                          @Negalein Bitte auch Gruppen testen
                                          • padrino
                                            padrino Most Active @apollon77 last edited by padrino
                                            Changelog:
                                            Hmm, habe zwar keine Kontakte, aber installiere und teste mal... 😉
                                            Mal eine Nachricht an mich geschickt.
                                            Klappt. Aber beim Benachrichtigung abspielen kommt nur "Eine neue Benachrichtigung für padrino". Das war's der Ring bleibt weiter gelb (gut, dass es den "löschen" button gibt 😆 ).
                                            Schätze aber, das ist ein Problem seitens amazon - oder ein Anwendungsfehler meinerseits. 😳
                                            BTW, "liebe" mal wieder "Alexa"... 🙄
                                            Ring gelb,
                                            ich: "alexa, spiele Benachrichtigung ab"
                                            alexa: "Abfallkalender ist aktiviert, möchtest Du den Skill öffnen" 😶
                                            31.7k
                                            79.8k
                                            alexa 2 adapter
                                            25
                                            254
                                            27253
