    4. [Aufruf] HAM (Homebridge) Adapter 1.1.1 verfügbar
      apollon77 @nanekx last edited by
      @nanekx Was hat avahi mit ssh zu tun? Sollte an sich nicht ... egal
      • N
        Ich dachte nur ... da bei der Homebridge einiges mitinstalliert wird und beim wapper Modus nicht... aber egal! Läuft! Und ich bin glücklich 😃
          fisch last edited by
          Moin, moin...
          kann hier jemand was zu dem Fehler sagen?
          Danke Greetz
          am.1	2019-07-21 10:38:40.349	warn	Exception: TypeError: Class constructor homebridgeLib cannot be invoked without 'new'
          ham.1	2019-07-21 10:38:40.347	info	cleaned everything up...
          ham.1	2019-07-21 10:38:40.345	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          ham.1	2019-07-21 10:38:40.345	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          ham.1	2019-07-21 10:38:40.345	error	at Socket.that.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2695:25)
          ham.1	2019-07-21 10:38:40.345	error	at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:177:27)
          ham.1	2019-07-21 10:38:40.345	error	at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:276:39)
          ham.1	2019-07-21 10:38:40.345	error	at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:279:14)
          ham.1	2019-07-21 10:38:40.345	error	at new Server (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:57:24)
          ham.1	2019-07-21 10:38:40.345	error	at Server._loadPlugins (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:145:22)
          ham.1	2019-07-21 10:38:40.345	error	at Array.forEach (<anonymous>)
          ham.1	2019-07-21 10:38:40.345	error	at Server.<anonymous> (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:171:14)
          ham.1	2019-07-21 10:38:40.345	error	TypeError: Class constructor homebridgeLib cannot be invoked without 'new'
          ham.1	2019-07-21 10:38:40.343	error	uncaught exception: Class constructor homebridgeLib cannot be invoked without 'new'
            apollon77 @fisch last edited by
            @fisch ohne mehr Infos zu deiner konfig und deinen homebridge Plugins fürchte ich kann da keiner was sagen. Sieht mir aus wie ein Plugin Fehler.
              fisch last edited by fisch
              ok, so wie es aussieht handelt sich um das plugin homebridgelib, welches ich installiert habe...wie kann ich das wieder löschen?
              ok ich habs
              npm uninstall homebridge-wieauchimmer
                fisch @fisch last edited by
                ok, doch noch eine Frage...
                wo finde ich die homebridge.log wenn ich die lokale Version via ham installiert habe?
                  @fisch Nirgends ... wenn Du die Adapter-Instanz auf "Debug" stellst kommt genau dieses Log ins ioBroker-Log
                    fisch @apollon77 last edited by
                    @apollon77
                    Ol, danke dir für die Info!!!
                    Ingo , wenn ick den Adapter homebridge-lib installiere kommt die Fehlermeldung von oben und ham verhindert den Start bzw. bricht ab.
                    Deinstallliere ich diesen wieder, startet ham einwandfrei durch. Das heißt für mich, dass der Adapter das Problem ist -oder liege ich da falsch?
                    Kann man herausfinden wo es genau hakt?
                    Besten Dank!!
                    Grüße nach KA aus OG 😉
                      @fisch ich denke du meinst „plugin“ und nicht adapter oder?
                      Hast du mal den Link zu dem Plugin was Probleme macht?
                        Mmmm ganz genau ich meine das Plugin 🙈
                        Link kommt gleich ...
                        https://github.com/ebaauw/homebridge-lib
                        Das wird für folgendes Plugin benötigt....
                        https://github.com/ebaauw/homebridge-hue/blob/master/README.md
                          @fisch Welche Versionen hast du ... ich sehe Dinge wie:
                          https://www.gitmemory.com/issue/ebaauw/homebridge-lib/11/502158619
                            fisch @apollon77 last edited by fisch
                            @apollon77
                            ich habe die homebridge-lib@4.3.0 und die homebridge-lib@4.2.9 getestet...
                            es kommt beim Starten leider immer diese Meldung:
                            host.samsung	2019-07-22 12:13:11.606	error	instance system.adapter.ham.1 terminated with code 0 (OK)
                            Caught	2019-07-22 12:13:11.605	error	by controller[5]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                            Caught	2019-07-22 12:13:11.605	error	by controller[5]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                            Caught	2019-07-22 12:13:11.605	error	by controller[5]: at Socket.that.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2693:25)
                            Caught	2019-07-22 12:13:11.604	error	by controller[5]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:177:27)
                            Caught	2019-07-22 12:13:11.604	error	by controller[5]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:276:39)
                            Caught	2019-07-22 12:13:11.604	error	by controller[5]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:279:14)
                            Caught	2019-07-22 12:13:11.604	error	by controller[5]: at new Server (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:57:24)
                            Caught	2019-07-22 12:13:11.603	error	by controller[5]: at Server._loadPlugins (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:145:22)
                            Caught	2019-07-22 12:13:11.603	error	by controller[5]: at Array.forEach (<anonymous>)
                            Caught	2019-07-22 12:13:11.603	error	by controller[5]: at Server.<anonymous> (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:171:14)
                            Caught	2019-07-22 12:13:11.603	error	by controller[5]: TypeError: Class constructor homebridgeLib cannot be invoked without 'new'
                            Caught	2019-07-22 12:13:11.602	error	by controller[4]: [2019-7-22 12:13:11] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-lib requires Node version of ^10.16.0 which does not satisfy the current Node version of
                            Caught	2019-07-22 12:13:11.602	error	by controller[3]: [2019-7-22 12:13:10] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-hue requires Node version of ^10.16.0 which does not satisfy the current Node version of
                            Caught	2019-07-22 12:13:11.602	error	by controller[2]: [2019-7-22 12:13:09] Warning: skipping plugin found at '/usr/lib/node_modules/homebridge-lib' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker.ham/n
                            Caught	2019-07-22 12:13:11.601	error	by controller[1]: [2019-7-22 12:13:08] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                            Caught	2019-07-22 12:13:11.600	error	by controller[0]: [2019-7-22 12:13:08] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                            ham.1	2019-07-22 12:13:11.582	info	terminating
                            ah ich glaube es liegt an der Node Version! Ich brauch 10.16.0...
                              @fisch seems so 🙂
                                @apollon77
                                mmmm jetzt suche ich mal die Doku..wie ich das ohne zerschiessen hinbekomme :-), dass ich node update machen kann..habe da immer etwas Bammel.
                                mmm leider scheint der link nicht zu gehen...
                                https://www.iobroker.net/docu/?page_id=8323&lang=de#Upgrade_von_nodejs_und_npm
                                  https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                                    @apollon77
                                    super danke...
                                    leider gibt es für den host keine node10...naja dann muss ich es wohl auf dem pi versuchen...
                                    Plattform: linux
                                    Die Architektur: ia32
                                    CPUs: 4
                                    Geschwindigkeit: 1000 MHz
                                    Modell: Intel(R) Atom(TM) CPU N550 @ 1.50GHz
                                    RAM: 1.9 GB
                                    System uptime: 00:24:05
                                    Node.js: v8.16.0
                                    NPM: 6.4.1
                                    Festplattengröße: 226.3 GiB
                                    Festplatten frei: 220.2 GiB
                                    Adapter zählen: 282
                                    Uptime: 00:01:28
                                    Aktivierte Instanzen: 7
                                    • SBorg
                                      @fisch sagte in [Aufruf] HAM (Homebridge) Adapter 1.1.1 verfügbar:
                                      = Linux 32Bit
                                      Node >=10 läuft nur auf Linux 64 Bit 😞
                                        fisch @SBorg last edited by
                                        @SBorg
                                        mmm das habe och mir schon gedacht.... ist das nur aktuell so oder kann da auch mal nich was kommen?
                                        • SBorg
                                          Zumindest, man mag es eigentlich nicht so recht glauben, für Windows gibt es auch eine 32 Bit Variante.
                                          Man könnte sich aber, wenn man so diversen Quellen glauben schenken mag, eine funktionsfähige 32 Bit Version aus den Sourcen selbst bauen.
                                          Leider kann man Linux 32 Bit auch nicht so ohne weiteres auf 64 Bit upgraden, da hilft eigentlich nur Neuinstallation.
                                            Denzel1994 last edited by Denzel1994
                                            ich habe mich jetzt auch mal für den lokalen Modus des Adapters entschieden.
                                            Mein Problem besteht allerdings mit dem homebridge-samsung-tizen Plugin.
                                            Auf meiner alten Homebridge Installation lief das Ganze mit einer identischen Config problemlos.
                                            Im ham-adapter wird allerdings weder ein Objekt für ioBroker angelegt, noch kriege ich den Fernseher in HomeKit hinzugefügt. Die Homebridge-Bridge war nach Eingabe des Pins sofort drin in HomeKit.
                                            Wenn man versucht den Fernseher hinzuzufügen und den Pin eingibt (= Bridge-Pin) passiert in HomeKit nichts und in ioBroker stürzt der Adapter ab und im Log bekomme ich folgende Meldung:
                                            Und hier nochmal meine Config.
                                              "bridge": {
                                                "name": "Homebridge",
                                                "username": "CC:22:3D:E3:CE:99",
                                                "port": 51826,
                                                "pin": "090-99-090"
                                              "accessories": [],
                                              "platforms": [
                                                  "platform": "config",
                                                  "name": "Config-UI-X",
                                                  "port": 8080,
                                                  "restart": "sudo systemctl restart homebridge",
                                                  "log": "systemd",
                                                  "theme": "blue"
                                                  "platform": "SamsungTizen",
                                                  "devices": [
                                                      "name": "Wohnzimmer TV",
                                                      "ip": "192.168.178.25",
                                                      "mac": "7C:64:22:A2:6E:XQ",
                                                      "inputs": [
                                                          "name": "Live TV",
                                                          "type": "command",
                                                          "value": [
                                                            "KEY_SOURCE",
                                                            "KEY_LEFT*3",
                                                            "KEY_ENTER"
                                                          "name": "Netflix",
                                                          "type": "app",
                                                          "value": "11101200001"
                                                          "name": "Amazon Prime",
                                                          "type": "app",
                                                          "value": "3201512006785"
                                                          "name": "YouTube",
                                                          "type": "app",
                                                          "value": "111299001912"
                                            31.7k
                                            79.8k
                                            ham homebridge
                                            2827
