    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
      Shwowak @Stuebi last edited by Shwowak
      @Stuebi
      Habe es jetzt mit docker compose mal erstellen lassen.
      version: '2.4'
      services:
        mqtt:
         restart: always
         ports:
           - "1883:1883"
           - "9001:9001"
         image: toke/mosquitto
         networks:
            fhem-network: {}
         volumes:
           - ./mqtt/config/:/mqtt/config/
           - ./mqtt/log/:/mqtt/log/
           - ./mqtt/data/:/mqtt/data/
        nodered:
          restart: always
          ports:
            - "1880:1880"
          image: nodered/node-red-docker:0.18.4
          volumes:
            - ./nodered/data/:/root/data/
          networks:
            fhem-network: {}
          depends_on:
            - "mqtt"
        portainer:
          restart: always
          image: portainer/portainer:1.21.0
          volumes:
            - ./portainer/:/data
            - /var/run/docker.sock:/var/run/docker.sock
          ports:
            - "9000:9000"
        magic_mirror:
          restart: always
          image: bastilimbach/docker-magicmirror
          ports:
            - "8080:8080"
          volumes:
            - ./magic_mirror/config:/opt/magic_mirror/config \
            - ./magic_mirror/modules:/opt/magic_mirror/modules \
            - ./magic_mirror/css:/opt/magic_mirror/css/custom.css \
          networks:
            fhem-network: {}
        iobroker:
          restart: always
          image: buanet/iobroker:latest
          volumes:
            -  /etc/localtime:/etc/localtime:ro
            - ./home/intelnuc/fhem-docker/iobroker:/opt/iobroker
            - ./home/intelnuc/fhem-docker/iobroker/transfer:/tmp
          networks:
            macvlan0:
              ipv4_address: 192.168.200.17
            fhem-network: {}
      networks:
        fhem-network:
          driver: bridge
        macvlan0:
          driver: macvlan
          driver_opts:
            parent: enp0s3
          ipam:
            config:
            - subnet: 192.168.200.0/24
              gateway: 192.168.200.1
              ip_range: 192.168.200.17/32
      Dann kommt das im Log:
      -----     Image-Version: 3.0.0     -----
      -----      2019-07-16 09:04:15     -----
      Startupscript running...
      Installing additional packages...
      The following packages will be installed: nano
      Installing additional packages done...
      Changing permissions upon first run (This might take a while! Please be patient!)...
      Changing permissions done...
      Starting ioBroker...
      Starting ioBroker done...
      Aber im Ornder iobroker sind keine Dateien ... Ich kann auch in der Console von Iobroker keine befehle ausführen die mit iobroker .... beginnen.
        Holzlenkrad @Shwowak last edited by
        @Shwowak
        Ist die Pfadangabe richtig? Die beginnt mit ./ Das braucht man doch nur bei relativen Pfaden, du nutzt aber ohnehin absolute?
          Ja läuft jetzt daran lag es und der Ordner muss leer sein.
          Habe das problem nun das eine Macvlan eingerichtet habe auf Docker ... siehe oben ( Docker Compose.) Die ip Adresse 192.168.200.17 bekomme ich aufgerufen aber nur auf dem Host System also wo die Virtualmaschine lauft .
          Zu dem bekomme überall von allen Adapter fehler .. siehe
          telegram.0	2019-07-17 22:13:54.138	error	polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org:443
          cloud.0	2019-07-17 22:13:53.148	error	Error while connecting to cloud: Error: websocket error
          cloud.0	2019-07-17 22:13:43.139	info	Trying to connect as system.user.admin
          telegram.0	2019-07-17 22:13:33.789	error	polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org:443
          telegram.0	2019-07-17 22:12:21.747	error	polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org:443
          cloud.0	2019-07-17 22:11:19.058	error	Error while connecting to cloud: Error: websocket error
          telegram.0	2019-07-17 22:11:18.971	error	polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org:443
          cloud.0	2019-07-17 22:11:09.017	info	Trying to connect as system.user.admin
          telegram.0	2019-07-17 22:10:58.628	error	polling_error:EFATAL, EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org:443
            ChrisXY last edited by
            wieso eigentlich kein Node10 ?
              dtp last edited by
              ich habe Probleme beim Update des js-controllers. In der ioBroker-Container-Konsole des Portainers erhalte ich immer folgende Meldungen:
              Jemand einen Tipp?
                dtp last edited by
                Hat sich erledigt. Hab ein Update des Containers gemacht.
                • cash
                  Ich habe ein kleines Problem. Ich wollte einen Adapter löschen leider über die Admioberfläche. Leider funktioniert das nicht.
                  Im Log kommt folgender Fehler:
                  obroker	2019-07-21 07:53:28.766	info	exit 0
                  iobroker	2019-07-21 07:53:28.757	error	You might have to delete it yourself!
                  iobroker	2019-07-21 07:53:28.756	error	Error deleting adapter iqontrol from disk: Error: host.iobroker_v2_19-05-19: Cannot uninstall iobroker.iqontrol: 216
                  host.iobroker_v2_19-05-19	2019-07-21 07:53:09.736	error	Cannot write files: /opt/iobroker/iobroker-data/files/iqontrol.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/iqontrol.admin/_data.json'
                  host.iobroker_v2_19-05-19	2019-07-21 07:53:09.735	error	Cannot write files: /opt/iobroker/iobroker-data/files/iqontrol/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/iqontrol/_data.json'
                  iobroker	2019-07-21 07:53:09.136	info	npm uninstall iobroker.iqontrol --silent --save --prefix "/opt/iobroker" (System call)
                  Wie kann ich den Adapter über die Konsole löschen oder wie bekomme ich den Fehler weg?
                  Ich bin noch bei V2
                    Shwowak @ChrisXY last edited by
                    @ChrisXY
                    es muss ja erst mal so laufen 😞
                      Host Maschine : # Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
                      DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
                      nameserver 192.168.200.1
                      search fritz.box
                      Container:
                      cat /etc/resolv.conf
                      search fritz.box
                      nameserver : <<<<<<<<<< Welche Ip muss hier stehen ?
                      options ndots:0
                      root@iobroker:/opt/iobroker#
                        dtp @dtp last edited by dtp
                        @dtp sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                        Hat sich erledigt.
                        Nun stehe ich mit dem Update des js-controllers auf die Version 1.5.14 schon wieder vor demselben Problem, wie oben.
                        Wie bekomme ich den Controller auf die aktuelle Version?
                        Klappt das bei euch im ioBroker-Container mit
                        pkill io
                        iobroker update
                        iobroker upgrade self
                        node node_modules/iobroker.js-controller/controller.js >/opt/scripts/docker_iobroker_log.txt 2>&1 &
                        oder
                        pkill io
                        npm install iobroker.js-controller –-production
                        Ich erhalte da immer diese Fehlermeldungen.
                        Bild Text
                        • Glasfaser
                          Glasfaser @andre last edited by
                          @andre / @all
                          Welchen Einfluss hat das Ende der Synology DSM License 🤔 auf ioBrocker unter Docker ❓
                          Docker DSM License activation ends on Aug. 12th, 2019
                            McD_HRTS last edited by
                            @Glasfaser
                            Hat keine Auswirkungen, geht ja nur um das DSM in Docker.
                            Steht aber auch nochmal in den Fragen / Antworten:
                              Was kann man bei dem fehler machen ?
                              root@5d84b836d60c:/opt/iobroker# node node_modules/iobroker.admin/admin.js --logs
                              module.js:550
                                  throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.admin/admin.js'
                                  at Function.Module._resolveFilename (module.js:548:15)
                                  at Function.Module._load (module.js:475:25)
                                  at Function.Module.runMain (module.js:694:10)
                                  at startup (bootstrap_node.js:204:16)
                                  at bootstrap_node.js:625:3
                              root@5d84b836d60c:/opt/iobroker# ^C
                              root@5d84b836d60c:/opt/iobroker# node -v
                              v8.16.0
                              root@5d84b836d60c:/opt/iobroker# npm -v
                              6.4.1
                              • dslraser
                                dslraser Forum Testing Most Active @dtp last edited by
                                Hat sich erledigt.
                                pkill io
                                iobroker update
                                oder
                                pkill io
                                Hast Du schon das Update gemacht ? Stehe auch vor dem Problem und will nicht wieder was zerschiessen.
                                  Das Problem scheint eine fehlerhafte DOS-zu-Linux-Konvertierung zu sein. Komischerweise hat aber nur die Version 3 des ioBroker-Container-Images damit ein Problem. Wenn ich die Version 2 mit demselben Verzeichnis ("/volume1/docker/ioBroker/") verwende, geht das Update des js-controllers per "iobroker update" und "iobroker upgrade self". Nur in der Version 3 bekomme ich ständig die Fehlermeldung mit dem falschen Zeilenende ("\r").
                                  Vielleicht liegt's an MACVLAN, vielleicht an etwas anderem. Keine Ahnung. Leider meldet sich @andré nicht.
                                  Mein Workaround ist im Moment, dass ich beide Version des Containers installiert habe und ein Update des js-controllers nun immer über die Version 2 mache, um danach wieder auf die Version 3 umzustellen.
                                  dslraser arteck andre 4 Replies Last reply Reply Quote 1
                                  • dslraser
                                    @dtp
                                    Danke für die Antwort. Ehrlich gesagt weiß ich aber trotzdem nicht wie ich das dann genau anstellen muss. (Mit dem selben Verzeichnis ?)
                                    Zwei Container anlegen ist ja nicht das Problem.
                                      arteck Developer Most Active @dtp last edited by arteck
                                      @dtp wozu machst du den
                                      iobroker update
                                      das läuft ehh immer nachts einmal... ausser du willst sofort nach dem publish was neues haben
                                      also reicht das
                                      iobroker upgrade
                                      ich hab auch die 3-er version laufen auch im Ordnersystem .. keine Probleme
                                        Nun ja, so wird es beim Update des js-controllers empfohlen. Doch auch mit "iobroker upgrade" alleine komme ich wegen der "\r"-Problematik nicht weiter. Ebenso funktioniert "iobroker backup" oder dergleichen nicht.
                                        Ist schon ziemlich blöd so.
                                        @dslraser
                                        Ich habe - wie gesagt - zwei ioBroker-Container laufen, die auf dasselbe ausgelagerte ioBroker-Verzeichnis zugreifen.
                                        ioBrokerV2 starte ich nur, um den js-controller zu aktualisieren. Ansonsten läuft immer ioBroker über den Portainer. Etwas doof ist, dass ioBrokerV2 über die 192.168.0.10 und ioBroker wegen MACVLAN über die 192.168.0.12 angesprochen werden muss.
                                        arteck dslraser 2 Replies Last reply Reply Quote 0
                                          @dtp ich seh gerade hab noch die damalige beta
                                          da ist das Problem noch nicht da
                                          • dslraser
                                            @dtp 👍
                                            danke, habe es genau so wie von Dir beschrieben gemacht, hat funktioniert und js-controller ist nun aktuell. (5Minuten und kleiner Aufwand)
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1475731
