    4. [Aufruf] HAM (Homebridge) Adapter 1.1.1 verfügbar
      fisch last edited by fisch
      Mmmm ganz genau ich meine das Plugin 🙈
      Link kommt gleich ...
      https://github.com/ebaauw/homebridge-lib
      Das wird für folgendes Plugin benötigt....
      https://github.com/ebaauw/homebridge-hue/blob/master/README.md
        apollon77 @fisch last edited by
        @fisch Welche Versionen hast du ... ich sehe Dinge wie:
        https://www.gitmemory.com/issue/ebaauw/homebridge-lib/11/502158619
          fisch @apollon77 last edited by fisch
          @apollon77
          ich habe die homebridge-lib@4.3.0 und die homebridge-lib@4.2.9 getestet...
          es kommt beim Starten leider immer diese Meldung:
          host.samsung	2019-07-22 12:13:11.606	error	instance system.adapter.ham.1 terminated with code 0 (OK)
          Caught	2019-07-22 12:13:11.605	error	by controller[5]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          Caught	2019-07-22 12:13:11.605	error	by controller[5]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          Caught	2019-07-22 12:13:11.605	error	by controller[5]: at Socket.that.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2693:25)
          Caught	2019-07-22 12:13:11.604	error	by controller[5]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:177:27)
          Caught	2019-07-22 12:13:11.604	error	by controller[5]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:276:39)
          Caught	2019-07-22 12:13:11.604	error	by controller[5]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:279:14)
          Caught	2019-07-22 12:13:11.604	error	by controller[5]: at new Server (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:57:24)
          Caught	2019-07-22 12:13:11.603	error	by controller[5]: at Server._loadPlugins (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:145:22)
          Caught	2019-07-22 12:13:11.603	error	by controller[5]: at Array.forEach (<anonymous>)
          Caught	2019-07-22 12:13:11.603	error	by controller[5]: at Server.<anonymous> (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:171:14)
          Caught	2019-07-22 12:13:11.603	error	by controller[5]: TypeError: Class constructor homebridgeLib cannot be invoked without 'new'
          Caught	2019-07-22 12:13:11.602	error	by controller[4]: [2019-7-22 12:13:11] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-lib requires Node version of ^10.16.0 which does not satisfy the current Node version of
          Caught	2019-07-22 12:13:11.602	error	by controller[3]: [2019-7-22 12:13:10] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-hue requires Node version of ^10.16.0 which does not satisfy the current Node version of
          Caught	2019-07-22 12:13:11.602	error	by controller[2]: [2019-7-22 12:13:09] Warning: skipping plugin found at '/usr/lib/node_modules/homebridge-lib' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker.ham/n
          Caught	2019-07-22 12:13:11.601	error	by controller[1]: [2019-7-22 12:13:08] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
          Caught	2019-07-22 12:13:11.600	error	by controller[0]: [2019-7-22 12:13:08] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
          ham.1	2019-07-22 12:13:11.582	info	terminating
          ah ich glaube es liegt an der Node Version! Ich brauch 10.16.0...
            @fisch seems so 🙂
              @apollon77
              mmmm jetzt suche ich mal die Doku..wie ich das ohne zerschiessen hinbekomme :-), dass ich node update machen kann..habe da immer etwas Bammel.
              mmm leider scheint der link nicht zu gehen...
              https://www.iobroker.net/docu/?page_id=8323&lang=de#Upgrade_von_nodejs_und_npm
                https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                  @apollon77
                  super danke...
                  leider gibt es für den host keine node10...naja dann muss ich es wohl auf dem pi versuchen...
                  Plattform: linux
                  Die Architektur: ia32
                  CPUs: 4
                  Geschwindigkeit: 1000 MHz
                  Modell: Intel(R) Atom(TM) CPU N550 @ 1.50GHz
                  RAM: 1.9 GB
                  System uptime: 00:24:05
                  Node.js: v8.16.0
                  NPM: 6.4.1
                  Festplattengröße: 226.3 GiB
                  Festplatten frei: 220.2 GiB
                  Adapter zählen: 282
                  Uptime: 00:01:28
                  Aktivierte Instanzen: 7
                  • SBorg
                    @fisch sagte in [Aufruf] HAM (Homebridge) Adapter 1.1.1 verfügbar:
                    = Linux 32Bit
                    Node >=10 läuft nur auf Linux 64 Bit 😞
                      fisch @SBorg last edited by
                      @SBorg
                      mmm das habe och mir schon gedacht.... ist das nur aktuell so oder kann da auch mal nich was kommen?
                      • SBorg
                        Zumindest, man mag es eigentlich nicht so recht glauben, für Windows gibt es auch eine 32 Bit Variante.
                        Man könnte sich aber, wenn man so diversen Quellen glauben schenken mag, eine funktionsfähige 32 Bit Version aus den Sourcen selbst bauen.
                        Leider kann man Linux 32 Bit auch nicht so ohne weiteres auf 64 Bit upgraden, da hilft eigentlich nur Neuinstallation.
                          Denzel1994 last edited by Denzel1994
                          ich habe mich jetzt auch mal für den lokalen Modus des Adapters entschieden.
                          Mein Problem besteht allerdings mit dem homebridge-samsung-tizen Plugin.
                          Auf meiner alten Homebridge Installation lief das Ganze mit einer identischen Config problemlos.
                          Im ham-adapter wird allerdings weder ein Objekt für ioBroker angelegt, noch kriege ich den Fernseher in HomeKit hinzugefügt. Die Homebridge-Bridge war nach Eingabe des Pins sofort drin in HomeKit.
                          Wenn man versucht den Fernseher hinzuzufügen und den Pin eingibt (= Bridge-Pin) passiert in HomeKit nichts und in ioBroker stürzt der Adapter ab und im Log bekomme ich folgende Meldung:
                          Und hier nochmal meine Config.
                            "bridge": {
                              "name": "Homebridge",
                              "username": "CC:22:3D:E3:CE:99",
                              "port": 51826,
                              "pin": "090-99-090"
                            "accessories": [],
                            "platforms": [
                                "platform": "config",
                                "name": "Config-UI-X",
                                "port": 8080,
                                "restart": "sudo systemctl restart homebridge",
                                "log": "systemd",
                                "theme": "blue"
                                "platform": "SamsungTizen",
                                "devices": [
                                    "name": "Wohnzimmer TV",
                                    "ip": "192.168.178.25",
                                    "mac": "7C:64:22:A2:6E:XQ",
                                    "inputs": [
                                        "name": "Live TV",
                                        "type": "command",
                                        "value": [
                                          "KEY_SOURCE",
                                          "KEY_LEFT*3",
                                          "KEY_ENTER"
                                        "name": "Netflix",
                                        "type": "app",
                                        "value": "11101200001"
                                        "name": "Amazon Prime",
                                        "type": "app",
                                        "value": "3201512006785"
                                        "name": "YouTube",
                                        "type": "app",
                                        "value": "111299001912"
                            @Denzel1994 sagte in [Aufruf] HAM (Homebridge) Adapter 1.1.1 verfügbar:
                            hm ... also du es stand alone getestst hast war die Homebridge version die gleiche wie im Lokalen Modus? Wir nutzen 0.4.50.
                            Der Fehler scheint mir irgendwie tief aus node-Hap zu kommen und die haben in den letzten Versionen die verschlüsselung umgebaut.
                            Kannst Du mal schaen ob es mit der 0.4.50 ausserhalb von ioBroker noch läuft?
                              Denzel1994 @apollon77 last edited by
                              @apollon77 Also die Homebridge hab ich gestern testweise installiert. Ist also die aktuelle 0.4.50. Version gewesen auf der ich das getestet habe.
                                apollon77 @Denzel1994 last edited by
                                @Denzel1994 Schau mal bitte ob es in ioBroker ein verzeichnis iobroker-data/ham.0 oder so gibt und lösch das mal .Versuch dann bitte nochmal mit dem Adapter
                                • X
                                  Xanon last edited by
                                  Hallo, ich habe nun auch mal eine Frage.
                                  Ich benutze zur Zeit den Yahka adapter.
                                  Früher habe ich mal eine eigene Homebridge auf nem Raspberry eingesetzt mit einem Homebridge-Homematic plugin.
                                  Dieser hat super funktioniert und man musste (im vergleich zu Yahka) wenig konfigurieren.
                                  Nun zu meiner Frage:
                                  Kann ich den HAM Adapter als Yakha alternative sehen?
                                  Kann ich da auch wieder das Homebridge-Homematic plugin einsetzten um meine Homematic Komponenten in der Home App zu nutzen?
                                  Wenn ja, habe ich dann nicht die Komponenten doppelt in iobroker?
                                  Oder verstehe ich hier alles falsch 🤦‍♂️
                                  Möchte weg von Yahka (obwohl es sehr stabil läuft und nie Probleme machte)
                                  Aber ich finde die Konfiguration einfach unübersichtlich.
                                    Du verwechselt wozu die Adapter da sind.
                                    Yahka stellt beliebige iobroker States in der Home App zur Verfügung.
                                    Der ham Adapter ist entstanden um Geräte für die es ein homebridge Plugin gibt aber keinen iobroker Adapter in iobroker anzubinden.
                                    Wenn Dir yahka nicht mehr zusagt und Dir die homematic Geräte reichen dann nimm ein gesondert installiertes homebridge. Hat dann ja nichts mit iobroker zu tun.
                                    • X
                                      Xanon @apollon77 last edited by
                                      @apollon77
                                      Vielen Dank für die Erklärung.
                                      31.7k
                                      79.8k
                                      ham homebridge
                                      2827
