    4. [Aufruf] Alexa2 2.6.0 Testen
    • I
      I-Punkt last edited by I-Punkt
      Hmm, bei mir kommen trotz aktueller 2.6.3 und iobroker-Neustart folgende Fehler im log und der Adapter startet immer wieder neu.
      host.ioBroker	2019-07-25 09:16:16.527	error	instance system.adapter.alexa2.0 terminated with code 0 (OK)
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[2]: at process._tickCallback (internal/process/next_tick.js:181:9)
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[2]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[2]: at endReadableNT (_stream_readable.js:1064:12)
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[2]: at IncomingMessage.emit (events.js:208:7)
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[2]: at emitNone (events.js:111:20)
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[2]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:752:58)
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:1208:17
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[2]: at alexa.getContacts (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2068:30)
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[2]: 2019-07-25 09:16:16.494 - alexa2.0 TypeError: commContacts.forEach is not a function
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[1]: 2019-07-25 09:16:16.494 - alexa2.0 uncaught exception: commContacts.forEach is not a function
      host.ioBroker	2019-07-25 09:16:16.527	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
      host.ioBroker	2019-07-25 09:16:16.526	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
      host.ioBroker	2019-07-25 09:16:16.526	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1064:12)
      host.ioBroker	2019-07-25 09:16:16.526	error	Caught by controller[0]: at IncomingMessage.emit (events.js:208:7)
      host.ioBroker	2019-07-25 09:16:16.526	error	Caught by controller[0]: at emitNone (events.js:111:20)
      host.ioBroker	2019-07-25 09:16:16.526	error	Caught by controller[0]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:752:58)
      host.ioBroker	2019-07-25 09:16:16.526	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:1208:17
      host.ioBroker	2019-07-25 09:16:16.526	error	Caught by controller[0]: at alexa.getContacts (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2068:30)
      host.ioBroker	2019-07-25 09:16:16.525	error	Caught by controller[0]: TypeError: commContacts.forEach is not a function
      alexa2.0	2019-07-25 09:16:07.417	info	Alexa-Push-Connection established. Disable Polling
      alexa2.0	2019-07-25 09:16:01.972	info	starting. Version 2.6.3 in /opt/iobroker/node_modules/iobroker.alexa2, node: v8.15.0
      host.ioBroker	2019-07-25 09:16:01.140	info	instance system.adapter.alexa2.0 started with pid 1346
      Habe ich einen Schritt übersehen?
        apollon77 last edited by
        @I-Punkt sagte in [Aufruf] Alexa2 2.6.0 Testen:
        commContacts
        Bitte mal auf Debug logging stellen und mir die Logzeilen von davor senden.
          Die 2.6-4 auf GitHub und später im Latest sollte den Fehler jetzt besser abfangen, dennoch wäre so ein Debuglog von der 2.6.3 interessant weil ich sehen muss was genau Amazon da sendet ... strange
            sigi234 Forum Testing Most Active @apollon77 last edited by
            @apollon77 sagte in [Aufruf] Alexa2 2.6.0 Testen:
            Kann dir ein Debug senden, wenn du willst von V 2.6.3?
              apollon77 @sigi234 last edited by
              @sigi234 Nur wenn Du auch den Fehler hattest in der 2.6.3 und ich brauche nur die paar zeilen über der Fehlermeldung
              • Negalein
                2.6.4 funktioniert
                • I
                  Hier die Zeilen vor dem Fehler:
                  alexa.txt
                  hier vielleicht nochmal etwas längere Zeilen:
                  2019-07-25 10:42:12.282  - error: Caught by controller[115]: 2019-07-25 10:42:11.558  - debug: alexa2.0 Alexa-Remote: No authentication check needed (time elapsed 13253)
                  2019-07-25 10:42:12.282  - error: Caught by controller[116]: 2019-07-25 10:42:11.558  - debug: alexa2.0 Alexa-Remote: Sending Request with {"host":"alexa-comms-mobile-service.amazon.de","path":"/users/amzn1.comms.id.person.amzn1~amzn1.account.AFBIBGXXXXXXXAQKEPY5U2OPWA/identities?includeUserName=true","method":"GET","timeout":10000,"headers":{}}
                  2019-07-25 10:42:12.283  - error: Caught by controller[117]: 2019-07-25 10:42:11.749  - debug: alexa2.0 Alexa-Remote: Response: {"status":403,"message":"User is forbidden","redirectUrlPath":null}
                  2019-07-25 10:42:12.283  - error: Caught by controller[118]: 2019-07-25 10:42:11.751  - debug: alexa2.0 Alexa-Remote: No authentication check needed (time elapsed 13446)
                  2019-07-25 10:42:12.283  - error: Caught by controller[119]: 2019-07-25 10:42:11.751  - debug: alexa2.0 Alexa-Remote: Sending Request with {"host":"alexa-comms-mobile-service.amazon.de","path":"/users/amzn1.comms.id.person.amzn1~amzn1.account.AFBIBGDXXXXXXQKEPY5U2OPWA/contacts?includePreferencesByLevel=HomeGroup&includeNonAlexaContacts=true&includeHomeGroupMembers=true&bulkImportOnly=false&includeBlockStatus=false&dedupeMode=RemoveCloudOnlyContactDuplicates&homeGroupId=","method":"GET","timeout":10000,"headers":{}}
                  2019-07-25 10:42:12.283  - error: Caught by controller[120]: 2019-07-25 10:42:12.221  - debug: alexa2.0 Alexa-Remote: Response: {"status":400,"message":"Invalid parameter supplied to controller. Please check inputs","redirectUrlPath":null}
                  2019-07-25 10:42:12.283  - error: Caught by controller[121]: TypeError: commContacts.forEach is not a function
                    sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
                    Nein , habe aber einige andere:
                    	Smarthome-Device Action rampBrightness unknown. Report to developer this and next log line from logfile on disk!
                            alexa2.0	2019-07-25 10:50:50.599	debug	Value not provided in answer for Smart-Home-Devices.c9be6c28-xxxxx-441e-8d32-b512a3bf976b.colorRgb
                            alexa2.0	2019-07-25 10:50:50.599	debug	Value not provided in answer for Smart-Home-Devices.c9be6c28-xxxxx-441e-8d32-b512a3bf976b.colorName
                            alexa2.0	2019-07-25 10:50:50.599	debug	unsupported namespace "Alexa.PlaybackStateReporter" for Smart-Home-Devices.6b1a78ef-0524-xxxxx-b5db-6c0d4f11f07b.playbackState```
                      @sigi234 Da bitte mal komplettes Start-Log an mich per email... ist nix wildes aber vllt was neues 🙂
                        apollon77 @I-Punkt last edited by
                        @I-Punkt Interessant der User darf die Kontakte nicht abfragen. Hast Du welche in der App? Was ist denn da bei dem Menüpunkt`(ganz unten zweiter von links)
                        I liv-in-sky 2 Replies Last reply Reply Quote 0
                        • I
                          I-Punkt @apollon77 last edited by I-Punkt
                          @apollon77
                          unter der Pkt. "Kommunikation" steht nur mein eigener Name. Eine Testnachricht aus der App an diesen Kontakt wurde vom Echo auch mit einem gelben Ring angezeigt und vorgelesen.
                          Mögliche "Fehlerquellen" (?): Die Echos sind mit dem Amazon-Account meiner Frau verknüpft (weil sie Prime hat). Deren Zugangsdaten (Email/PW) sind aber auch im Iobroker hinterlegt.
                          PS: Gerade nochmal in den Einstellungen des Adapters nachgesehen. Standen da nicht früher immer die Login-Daten? Oder werden die "ausgeblendet", wenn der Cookie aktuell ist und funktioniert?
                            Ja das kann es sein. Ja die Daten gab es früher aber das hat ja alles nicht mehr gescheit funktioniert, daher jetzt ohne. Man muss dann einmalig den Weg über diese Login-Seite gehen und ab dann refresht der Adapter Cookies automatisch.
                              liv-in-sky @apollon77 last edited by
                              @apollon77 welche kontakte sollten zu sehen sein - habe nur 4 kontakte in den objekten - in der alexa app sehe ich alle telefonkontakte
                                apollon77 @liv-in-sky last edited by
                                @liv-in-sky Achtung in der App nicht bei dem Telefonicon schauen sondern bei dem Nachrichten icon! Ich versuche nur die anzuzeigen die auch mit einer Alexa erreichbar wären für Nachrichten
                                  @apollon77 ja das macht sinn -
                                  • einer bin ich selbst
                                  • bei 2 weiß ich, dass sie alexa haben
                                  • der 4te wohl auch
                                  also alles gut - dank
                                  • Diginix
                                    Diginix last edited by Diginix
                                    Ich sehe bisher keinen Contacts Knoten in den Objekten. Egal ob 2.6.0 oder 2.6.4 In der App sehe ich alle Tel.Kontakte. Was muss ich machen damit die erscheinen?
                                    Woher weiß Amazon wer von meinen Kontakten ein Echo Gerät hat? Theoretisch dürften ja nur diese sinnvoll in ioBroker sein oder?
                                      apollon77 @Diginix last edited by
                                      @Diginix Wie gerade weiter oben geschrieben: In der App unter Kommunikation hast Du einerseits "Anruf" und anderseits "Nachricht". Telefon ist egal, Nachricht ist das relevante
                                      • Diginix
                                        Ja, habe 3 Chats. In zwei habe ich eben noch mal einen Text geschrieben. Danach den Adapter neu gestartet. Keine "Contacts".
                                        Edit: Jetzt hat er anscheinend einen Trigger erhalten. Nun sehe ich auf einmal 19 Kontakte. Von 3 wusste ich dass sie Alexa haben. 😉
                                          @Diginix Naja sagen wir so - je nachdem wieviele Daten und Geräte Du hast kann inzwischen das volle Starten des Alexa2 Adapters auch mal 30 Sekunden oder so dauern ... also Geduld 🙂
                                          • padrino
                                            padrino Most Active @apollon77 last edited by
                                            @apollon77 sagte in [Aufruf] Test Alexa2 2.4.1 auf GitHub:
                                            @padrino Ich nehme gern einen PR mit einem Image dafür.
                                            Im Anhang wäre ein transparentes PNG für den Input... 😇
                                            Und, wo ich grad dabei bin, auch eins für den Echo2, denn das in ioBroker hat 117x117 statt der normalen 128x128 Pixel. 😛
                                            Hm ... ich finde keinerlei Code der das tun sollte ...
                                            Du hast natürlich Recht. 😳
                                            Ich prüfe in meinem Skript nicht auf "reminder.new", sondern auf "reminder...time".
                                            Von daher, eine unix timestamp dort drin wäre herzallerliebst. 😉
                                            Übrigens, denke mal, auch wenn das "Datum" in der Vergangenheit läge, bei einem "reminder...enabled=true" kann man doch auf einen Wiederholungstimer schließen, oder? Also zumindest so, dass sich der User nicht wundert, wieso es in der Vergangenheit liegt. 😄
                                            31.7k
                                            79.8k
                                            alexa 2 adapter
                                            25
                                            254
                                            27296
