    4. JavaScript
    5. Skripten des E-Control Spritpreisrechners
      Georgius last edited by
      Also so schaut mal meine Lösung aus:
      on({id: 'javascript.0.Sprit.Sprit_JSON'/*Sprit JSON*/, change: 'any'}, function(obj)
          var index = 0;
          /*var gasStation = JSON.parse('parser.0.Tanken');*/
          var gasStation = JSON.parse(obj.state.val);
           /*if (gasStation.length === 0) return;*/
           console.log((String('Durchlauf')));
           createState("javascript.0.Sprit.Tankstelle_Test.Index", false,{type: 'number',name: 'index', read: true,write: true});
           for (index = 0; index < gasStation.length; ++index) {
          createState("javascript.0.Sprit.Tankstelle_"+index+".Index", 0,{type: 'number',name: 'index', read: true,write: true});
          setState("javascript.0.Sprit.Tankstelle_"+index+".Index", gasStation[index].id);
          createState("javascript.0.Sprit.Tankstelle_"+index+".name", 0,{type: 'string',name: 'name', read: true,write: true});
          setState("javascript.0.Sprit.Tankstelle_"+index+".name", gasStation[index].name);
          createState("javascript.0.Sprit.Tankstelle_"+index+".prices", 0,{type: 'string',name: 'Preis ges', read: true,write: true});
          if ((gasStation[index].prices[0])!=undefined){
              setState("javascript.0.Sprit.Tankstelle_"+index+".prices", (gasStation[index].prices[0].amount).toString().replace(".",","));
          createState("javascript.0.Sprit.Tankstelle_"+index+".adresse", 0,{type: 'string',name: 'name', read: true,write: true});
          setState("javascript.0.Sprit.Tankstelle_"+index+".adresse", gasStation[index].location.address);
          createState("javascript.0.Sprit.Tankstelle_"+index+".adresse2", 0,{type: 'string',name: 'name', read: true,write: true});
          setState("javascript.0.Sprit.Tankstelle_"+index+".adresse2", gasStation[index].location.postalCode + " "+ gasStation[index].location.city);
      Sortiert nur nach billigst zu teuer.
      metaxa 1 Reply Last reply Reply Quote 2
      • metaxa
        metaxa @Georgius last edited by
        @Georgius Hm, ich krieg nur "0"
        Bei dir hagelts aber einmal keine Fehlermeldungen .....
          Beim 2. Durchlauf sollte es dann funktionieren.
          Ich verwende das Blocky zum einlesen des JSON
            sigi234 Forum Testing Most Active @metaxa last edited by
            @metaxa sagte in Skripten des E-Control Spritpreisrechners:
            Lieber Rainer, du hast den schier unerschöpflich, ewigen Dank, deiner unmittelbaren Nachbarn, den Ösis +
            Auch von mir ein Danke..............ein Ösi....☺
              sigi234 Forum Testing Most Active @Georgius last edited by sigi234
              @Georgius
              Danke, erledigt, arbeite schon daran mit Vis.
              Da ist noch Feintuning angesagt....
              Was habe ich noch vor, tja wenn es geht möchte ich noch folgendes einblenden:
              • Öffnungszeiten
              • Geöffnet/Geschlossen
              • Kilometer zur Tankstelle
              • Logo der Tankstelle (geht sicher mit Sichtbarkeit)
              metaxa 1 Reply Last reply Reply Quote 1
                Georgius last edited by Georgius
                Öffnungszeiten sind aufwendig. Für jeden Tag gibt es ein Von und ein Endefeld +Feiertage.
                Logo der Tankstelle geht in meinen Augen nicht über die Sichtbarkeit. Da würde ich für jede Tankstelle bzw. Kette ein Logo ablegen und dann einen Link erzeugen auf das Bild. Wie das im VIS geht weiß ich (noch) nicht.
                Geöffnet/geschlossen und km sind jeweils ein eigenes Feld.
                Man kann auch auf offene Tankstellen filtern im Weblink
                Wenn mir fad ist baue ich noch einen Durchschnittspreis der letzten 30 Tage ein.
                • metaxa
                  metaxa @sigi234 last edited by
                  @sigi234
                  ((Math.round((gasStation[index].distance)*100)/100).toString().replace(".",","))
                  (gasStation[index].open).toString()
                  LG, mxa
                    @Georgius sagte in Skripten des E-Control Spritpreisrechners:
                    Denke vielleicht mit Signalbilder und Text besteht aus : Name Tankstelle (avanti)
                    Da spiele ich mal ein bisschen damit.........
                    Q Negalein 2 Replies Last reply Reply Quote 1
                      gerald123 last edited by
                      Hallo sigi234,
                      Mich würde interessieren ob du das mit den Logos schon im Vis hinbekommen hast?
                      Welches Script verwendest du jetzt, hab irgendwann beim Lesen den Faden verloren welches jetzt das Aktuelle ist.
                      Sg. Gerald
                        sigi234 Forum Testing Most Active @gerald123 last edited by sigi234
                        @gerald123
                        Leider nein.............
                        //  "Spritpreise_AT v.0.5"        //
                        //  e-control Spritpreise        //
                        //  ursprüngl. Script von steinejo_io vom        //
                        //  Zwingend erforderlich sind der Parser Adapter und die URL aus der API. Links und Hilfe zum Erstellemn findet ihr im Folgenden Lnk:  //
                        //  https://forum.iobroker.net/topic/20314/skripten-des-e-control-spritpreisrechners                                                    //
                        //  Das manuelle Anlegen von Daenpunkten ist nicht mehr notwendig. erledigt das Script beim ersten Aufruf.                              //
                        //  Auf das "E" Zeichen habe ich verzichtet, da es in VIS genz einfach an der jeweils gewünschten Stelle produzierbar ist.              //
                        on({id: "parser.0.Spritpreisrechner", change: 'any'}, function(obj)
                        log("Start Spritvergleich");
                            var i = 0;
                            for (var i = 1; i <= 5; i++) {
                                console.log(i);
                                console.log("scriptDatenPunkte.Sprit_AT.name_"+i);
                                createState("scriptDatenPunkte.Sprit_AT.Treffer_"+i+".Name_"+i, {type: "string", name: "Platz "+i, read: true, write: true});
                                createState("scriptDatenPunkte.Sprit_AT.Treffer_"+i+".Preis_"+i, {type: "number", name: "Platz "+i, read: true, write: true});
                                createState("scriptDatenPunkte.Sprit_AT.Treffer_"+i+".Strasse_"+i, {type: "string", name: "Platz "+i, read: true, write: true});
                                createState("scriptDatenPunkte.Sprit_AT.Treffer_"+i+".PLZ_Ort_"+i, {type: "string", name: "Platz "+i, read: true, write: true});
                            var index = 0;
                            //for (index = 0; index < gasStation.length; ++index) {
                            for (index = 0; index <= 4; ++index) {
                            setState("scriptDatenPunkte.Sprit_AT.Treffer_"+(index+1)+".Name_"+(index+1), gasStation[index].name);
                            setState("scriptDatenPunkte.Sprit_AT.Treffer_"+(index+1)+".Preis_"+(index+1), (gasStation[index].prices[0].amount));
                            setState("scriptDatenPunkte.Sprit_AT.Treffer_"+(index+1)+".Strasse_"+(index+1), (gasStation[index].location.address));
                            setState("scriptDatenPunkte.Sprit_AT.Treffer_"+(index+1)+".PLZ_Ort_"+(index+1), (gasStation[index].location.postalCode) + " " + (gasStation[index].location.city));
                        log("Ende Spritvergleich");
                        https://api.e-control.at/sprit/1.0/search/gas-stations/by-address?latitude=xx.xxxxx&longitude=xx.xxxxx&fuelType=DIE&includeClosed=false
                        Die XXX mit deinen ersetzten........
                          gerald123 @sigi234 last edited by
                          @sigi234
                          Kannst du mir trotzdem noch sagen welches Script du verwendest?
                          • Negalein
                            Negalein Global Moderator @gerald123 last edited by
                            @gerald123 sagte in Skripten des E-Control Spritpreisrechners:
                            @sigi234
                            hat er 1 Beitrag über dir gepostet
                              Super Danke, habs bei mir jetzt auch am laufen.
                              • Negalein
                                @metaxa
                                Ich bekomm von Zeit zu Zeit immer wieder Fehlermeldungen im Log.
                                Das Script bleibt dann mit einem gelben Pausezeichen stehen.
                                2019-11-25 12:07:35.026  - error: javascript.0 (608) Error in callback: TypeError: Cannot read property 'amount' of undefined
                                2019-11-25 12:07:35.027  - error: javascript.0 (608)     at Object.<anonymous> (script.js.common.Spritpreisrechner:34:107)
                                2019-11-25 12:07:35.027  - error: javascript.0 (608)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                2019-11-25 12:07:35.027  - error: javascript.0 (608)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                2019-11-25 12:07:35.027  - error: javascript.0 (608)     at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4744:37)
                                2019-11-25 12:07:35.027  - error: javascript.0 (608)     at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
                                2019-11-25 12:07:35.028  - error: javascript.0 (608)     at runCallback (timers.js:705:18)
                                2019-11-25 12:07:35.028  - error: javascript.0 (608)     at tryOnImmediate (timers.js:676:5)
                                2019-11-25 12:07:35.028  - error: javascript.0 (608)     at processImmediate (timers.js:658:5)
                                Liegt das an der e-Control?
                                • metaxa
                                  Servus, da tue ich mir schwer was dazu zu sagen. Bin kein Scripter, mehr der Kopierer. Bei mir läuft das Script nach Umstieg auf JS Controller 2.1.0 & JS Script Engine 4.3.2 fehlerfrei.
                                  LG, mxa
                                  • Q
                                    Qlink @sigi234 last edited by
                                    @sigi234 said in Skripten des E-Control Spritpreisrechners:
                                    @sigi234 Könntest du dieses VIS Widget für das Spritpreis Script exportieren und hier im Forum teilen ? Das gefällt mir sehr gut 🙂
                                    beste Grüße
                                      sigi234 Forum Testing Most Active @Qlink last edited by
                                      @Qlink sagte in Skripten des E-Control Spritpreisrechners:
                                      beste Grüße
                                      [{"tpl":"tplCGradialGauge","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","factor":"1","valueOffset":"0","hCount":"5","minorTicks":"4","animation":true,"needle":"true","needleShadow":"true","needleType":"arrow","borders":true,"borderOuterWidth":"1","borderMiddleWidth":"1","borderInnerWidth":"1","borderShadowWidth":"1","valueBox":true,"ticksAngle":"270","startAngle":"45","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"minValue":"0.800","maxValue":"1.500","oid":"javascript.0.scriptDatenPunkte.Sprit_AT.Treffer_1.Preis_1","title":"Tankstelle 1","valueDec":"3","valueInt":"1","animationDuration":"1000","animationTarget":"needle","animatedValue":false,"animateOnInit":false,"valueTextShadow":true,"colorPlate":"#000000","colorBorderOuter":"#000000","colorBorderOuterEnd":"#000000","colorValueBoxRect":"#000000","colorValueBoxBackground":"#000000","colorValueBoxRectEnd":"#000000","colorPlateEnd":"#000000","colorMajorTicks":"#ffffff","colorMinorTicks":"#e6e6e6","colorTitle":"#ffffff","colorNeedle":"#29ff14","colorNeedleEnd":"#2dfa14","needleCircleInner":true,"needleCircleOuter":true,"needleCircleSize":"9","colorNeedleCircleInner":"#4af524","colorNeedleCircleInnerEnd":"#000000","colorNeedleCircleOuterEnd":"#2dfd0d","colorNeedleCircleOuter":"#000000","colorUnits":"#ffffff","colorNumbers":"transparent","colorValueText":"#ffffff","highlightsFrom1":"0.800","highlightsTo1":"1.000","highlightsColor1":"#3efc22","highlightsFrom2":"1.000","highlightsTo2":"1.100","highlightsColor2":"#147118","units":"€/Liter","highlightsFrom3":"1.100","highlightsTo3":"1.200","highlightsColor3":"#085413","highlightsFrom4":"1.200","highlightsTo4":"1.300","highlightsColor4":"#ffc524","highlightsFrom5":"1.300","highlightsTo5":"1.500","highlightsColor5":"#bd0026","animationRule":"linear","colorBorderMiddle":"#c8cacb","colorBorderMiddleEnd":"#c8cacb"},"style":{"left":"71px","top":"168px","z-index":"2","width":"179px","height":"163px","font-family":"RobotoCondensed-Light"},"widgetSet":"canvas-gauges"},{"tpl":"tplValueStringRaw","data":{"oid":"javascript.0.scriptDatenPunkte.Sprit_AT.Treffer_1.Name_1","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"39px","top":"69px","width":"240px","height":"25px","z-index":"3","font-size":"small","text-align":"center","font-family":"RobotoCondensed-Light"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"","title_color":"#FFFFFF","title_top":"-10","title_left":"30","header_height":"0","header_color":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title_back":"","title_font":"","name":"Border Tag 2","filterkey":"Wetter"},"style":{"left":"34px","top":"57px","width":"247px","height":"281px","color":"","z-index":"1","border-radius":"10px","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","background":"#202020","border-color":"","background-color":"transparent","font-family":"RobotoCondensed-Light"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"158px","top":"101px","width":"122px","height":"3px","background":"linear-gradient(to left, #282828 5px, white 200px )","z-index":"3","font-family":"RobotoCondensed-Light"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"37px","top":"101px","width":"122px","height":"3px","background":"linear-gradient(to right, #282828 5px, white 200px )","z-index":"3","font-family":"RobotoCondensed-Light"},"widgetSet":"basic"},{"tpl":"tplStatefulImage8","data":{"oid":"javascript.0.scriptDatenPunkte.Sprit_AT.Treffer_1.Name_1","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"refreshInterval":"0","count":"5","signals-cond-0":"consist","signals-val-0":"avanti","signals-icon-0":"/vis.0/Logo-Avanti.jpg","signals-icon-size-0":"62","signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"javascript.0.scriptDatenPunkte.Sprit_AT.Treffer_1.Name_1","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"43px","top":"109px","width":"60px","height":"60px","z-index":"10","font-family":"RobotoCondensed-Light"},"widgetSet":"basic"}]
                                      • Negalein
                                        @sigi234
                                        Würdest du die Tankstellenbilder zur Verfügung stellen?
                                          sigi234 Forum Testing Most Active @Negalein last edited by
                                          @Negalein
                                          • Negalein
                                            Negalein Global Moderator @sigi234 last edited by
                                            @sigi234 sagte in Skripten des E-Control Spritpreisrechners:
                                            Servus
                                            Das mit den Logos funktioniert bei dir auch nicht?
                                            Finde ebenfalls keine passende LKösung.
                                            81.1k
                                            javascript monitoring
                                            21
                                            292
                                            43161
