    4. [How-to] Node.js für ioBroker richtig updaten
    • smartboart
      smartboart last edited by
      Hallo Gemeinde, kann mir einer sagen, wie ich diese Fehlermeldungen bei Adapter aktualisierungen reduzieren kann..System läuft unauffälig. Die Fehlerliste betrifft alle npm Installationen / Adapterupdates...
      $ ./iobroker upgrade hm-rega
      Update hm-rega from @2.4.0 to @2.4.1
      NPM version: 6.9.0
      npm install iobroker.hm-rega@2.4.1 --production --save --prefix "/opt/iobroker" (System call)
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:
      ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
      ../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }
      In file included from ../src/validation.cc:7:0:/home/iobroker/.node-gyp/10.16.0/include/node/v8.h:10046:15: note: declared here
       Local<Object> Value::ToObject() const {
      make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
      gyp
      ERR!
       build error
      gyp
       ERR!
      stack
       Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp
      ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.4.182-rockchip64
      gyp
       ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validategyp
      ERR! node -v v10.16.0gyp ERR!
      node-gyp -v v3.8.0gyp
       ERR! not ok
      npm
      WARN
       babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
      npm
      WARN
       xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm
      WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional
       SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.hm-rega"
      npm
      notice
       created a lockfile as package-lock.json. You should commit this file.
      got /opt/iobroker/node_modules/iobroker.hm-rega/admin
      upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
      Update "system.adapter.hm-rega.0"
      upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
      upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
      upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
      Adapter "hm-rega" updated
      process exited with code 0
      • marcuskl
        marcuskl last edited by
        Beimir klappt alles nur wen ich node -v eingebe kommt immernoch Node js 8.x ?
        root@iobroker:~# node -v
        v8.16.0
        root@iobroker:~# nodejs -v
        v10.16.0
        root@iobroker:~#
          Homoran Global Moderator Administrators @marcuskl last edited by Homoran
          @marcuskl sagte in [How-to] Node.js für ioBroker richtig updaten:
          Dann hast du -warum auch immer (einmal einen Befehl im falschen Verzeichnis ausgeführt...)- zwei node installationen parallel laufen.
          Das wird zu Problemen führen
          marcuskl 1 Reply Last reply Reply Quote 0
          • marcuskl
            marcuskl @Homoran last edited by
            @Homoran was mache ich nun ?
            • marcuskl
              Ich habe damal die node 6 mit dem Befehl
              Sudo n 8.12.0
              geupdatet.
              Liegt da der Fehler ?
                was mache ich nun ?
                Dazu bin ich nicht fit genug.
                @paul53 hatte bereits mehrfach das procedere zum Auffinden der Versionen und Entfernen der falschen hier im Forum gepostet.
                Da musst du mal suchen
                  FuLLHDvs480p last edited by FuLLHDvs480p
                  habe folgendes Problem:
                  rock64@rock64:/opt/iobroker$ iobroker stop
                  rock64@rock64:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                  ## Installing the NodeSource Node.js 10.x repo...
                  ## Populating apt-get cache...
                  + apt-get update
                  Hit:1 http://security.debian.org stretch/updates InRelease
                  Hit:2 http://ppa.launchpad.net/ayufan/rock64-ppa/ubuntu xenial InRelease
                  Get:3 http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease [1339 B]
                  Ign:4 http://cdn-fastly.deb.debian.org/debian stretch InRelease
                  Get:5 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease [91.0 kB]
                  Hit:6 https://deb.nodesource.com/node_10.x stretch InRelease
                  Hit:7 http://cdn-fastly.deb.debian.org/debian stretch Release
                  Fetched 92.4 kB in 2s (39.7 kB/s)
                  Reading package lists... Done
                  ## Confirming "stretch" is supported...
                  + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_10.x/dists/stretch/Release'
                  ## Adding the NodeSource signing key to your keyring...
                  + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                  OK
                  ## Creating apt sources list file for the NodeSource Node.js 10.x repo...
                  + echo 'deb https://deb.nodesource.com/node_10.x stretch main' > /etc/apt/sources.list.d/nodesource.list
                  + echo 'deb-src https://deb.nodesource.com/node_10.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
                  ## Running `apt-get update` for you...
                  + apt-get update
                  Ign:3 http://cdn-fastly.deb.debian.org/debian stretch InRelease
                  Hit:4 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
                  Get:5 http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease [1339 B]
                  Hit:6 http://cdn-fastly.deb.debian.org/debian stretch Release
                  Hit:7 https://deb.nodesource.com/node_10.x stretch InRelease
                  Fetched 1339 B in 2s (583 B/s)
                  ## Run `sudo apt-get install -y nodejs` to install Node.js 10.x and npm
                  ## You may also need development tools to build native addons:
                       sudo apt-get install gcc g++ make
                  ## To install the Yarn package manager, run:
                       curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                       echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                       sudo apt-get update && sudo apt-get install yarn
                  rock64@rock64:/opt/iobroker$ sudo apt-get install -y nodejs
                  Building dependency tree
                  nodejs is already the newest version (10.16.0-1nodesource1).
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  rock64@rock64:/opt/iobroker$ node -v
                  v10.16.0
                  rock64@rock64:/opt/iobroker$ curl -sL https://iobroker.net/fix.sh | bash -
                      Welcome to the ioBroker installation fixer!
                      Script version: 2019-07-21
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/3)
                      Checking ioBroker user and directory permissions (2/3)
                  Created /etc/sudoers.d/iobroker
                  Fixing directory permissions...
                      Checking autostart (3/3)
                  Enabling autostart...
                  Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  rock64@rock64:/opt/iobroker$ npm rebuild
                  > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                  > npm install node-pre-gyp
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp
                  npm ERR! path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp
                  npm ERR! code EACCES
                  npm ERR! errno -13
                  npm ERR! syscall access
                  npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp'
                  npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp']
                  npm ERR!   stack:
                  npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp\'',
                  npm ERR!   errno: -13,
                  npm ERR!   code: 'EACCES',
                  npm ERR!   syscall: 'access',
                  npm ERR!   path:
                  npm ERR!    '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp' }
                  npm ERR!
                  npm ERR! The operation was rejected by your operating system.
                  npm ERR! It is likely you do not have the permissions to access this file as the current user
                  npm ERR!
                  npm ERR! If you believe this might be a permissions issue, please double-check the
                  npm ERR! permissions of the file and its containing directories, or try running
                  npm ERR! the command again as root/Administrator (though this is not recommended).
                  npm ERR!     /home/rock64/.npm/_logs/2019-07-26T09_47_03_405Z-debug.log
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 243
                  npm ERR! @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: `npm install node-pre-gyp`
                  npm ERR! Exit status 243
                  npm ERR!
                  npm ERR! Failed at the @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR!     /home/rock64/.npm/_logs/2019-07-26T09_47_03_647Z-debug.log
                  rock64@rock64:/opt/iobroker$ npm install @abandonware/bluetooth-hci-socket
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/abbrev
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ansi-regex
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/aproba
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/balanced-match
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/chownr
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/code-point-at
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/concat-map
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/brace-expansion
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/console-control-strings
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/core-util-is
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/deep-extend
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/delegates
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/detect-libc
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/fs.realpath
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/has-unicode
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/inherits
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ini
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/isarray
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minimatch
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ignore-walk
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minimist
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/mkdirp
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/needle/node_modules/debug
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/npm-bundled
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/npm-packlist
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/number-is-nan
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/is-fullwidth-code-point
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/object-assign
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/os-homedir
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/os-tmpdir
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/osenv
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/nopt
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/path-is-absolute
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/process-nextick-args
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/rc/node_modules/minimist
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/safe-buffer
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/safer-buffer
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/iconv-lite
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/sax
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/set-blocking
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/signal-exit
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/string_decoder
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/strip-ansi
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/string-width
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/strip-json-comments
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/util-deprecate
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/readable-stream
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/are-we-there-yet
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/wide-align
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/gauge
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/npmlog
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/wrappy
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/once
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/inflight
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/glob
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/rimraf
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/yallist
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minipass
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/fs-minipass
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minizlib
                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/tar
                  npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/bluetooth-hci-socket'
                  npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.radar/node_modules/bluetooth-hci-socket/package.json'
                  npm ERR! errno -13
                  npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket'
                  npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket']
                  npm ERR!   stack:
                  npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket\'',
                  npm ERR!   path:
                  npm ERR!    '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' }
                  npm ERR!
                  npm ERR!
                  npm ERR!     /home/rock64/.npm/_logs/2019-07-26T09_58_41_378Z-debug.log
                  Fixer Script habe ich laufen lassen,
                  Radar2 und Ble vorher komplett gelöscht.
                  Auch die Neuinstallation von bluetooth-hci-socket schlägt fehl.
                  js-controller: 1.5.14
                  Jemand eine Idee?
                  • AlCalzone
                    AlCalzone Developer @FuLLHDvs480p last edited by
                    @FuLLHDvs480p Eigentlich dürfte das nicht passieren, aber probier mal im Ordner /opt/iobroker folgendes:
                    sudo -H -u iobroker npm install @abandonware/bluetooth-hci-socket
                    um die Installation als Benutzer iobroker auszuführen, der dort Schreibrechte haben müsste.
                      FuLLHDvs480p @AlCalzone last edited by
                      @AlCalzone Wenn ich mich über Putty als iobroker anmelde schließt sich das Fenster direkt wieder.
                      Wenn ich mich als root anmelde und danach auf den Benutzer iobroker wechseln will kommt:
                      root@rock64:~# su iobroker
                      This account is currently not available.
                      Hab die Installation mal als rock64 laufen lassen und bekomme diese Fehler:
                      rock64@rock64:~$ cd /opt/iobroker/
                      rock64@rock64:/opt/iobroker$ sudo -H -u iobroker npm install @abandonware/bluetooth-hci-socket
                      [sudo] password for rock64:
                      npm notice created a lockfile as package-lock.json. You should commit this file.
                      + node-pre-gyp@0.12.0
                      added 63 packages from 24 contributors, updated 1 package and audited 97 packages in 13.598s
                      found 0 vulnerabilities
                      > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                      > node-pre-gyp install --fallback-to-build
                      node-pre-gyp WARN Using request for node-pre-gyp https download
                      node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v64-linux-arm64.tar.gz
                      node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@10.16.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                      make: Entering directory '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build'
                        CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
                      ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::poll()':
                      ../src/BluetoothHciSocket.cpp:252:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                           Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
                      In file included from ../src/BluetoothHciSocket.cpp:8:0:
                      ../../../nan/nan.h:1045:46: note: declared here
                         NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                      ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::emitErrnoError()':
                      ../src/BluetoothHciSocket.cpp:283:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                      ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)':
                      ../src/BluetoothHciSocket.cpp:396:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
                             devId = arg0->IntegerValue();
                      In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                       from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                       from /home/iobroker/.node-gyp/10.16.0/include/node/node_buffer.h:25,
                                       from ../src/BluetoothHciSocket.cpp:7:
                      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2476:46: note: declared here
                         V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);
                      /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'
                         declarator __attribute__((deprecated(message)))
                      ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)':
                      ../src/BluetoothHciSocket.cpp:418:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
                        SOLINK_MODULE(target) Release/obj.target/binding.node
                        COPY Release/binding.node
                        COPY /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node
                        TOUCH Release/obj.target/action_after_build.stamp
                      make: Leaving directory '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build'
                      > bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket
                      > node-gyp rebuild
                      make: Entering directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/build'
                      ../src/BluetoothHciSocket.cpp:251:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                      ../../../../nan/nan.h:980:46: note: declared here
                      ../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to 'v8::Function::NewInstance(int, v8::Local<v8::Value> [1])'
                         Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
                      In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,
                      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
                         V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
                      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
                      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
                      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
                      ../src/BluetoothHciSocket.cpp:282:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                      ../src/BluetoothHciSocket.cpp:395:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
                      ../src/BluetoothHciSocket.cpp:417:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
                      binding.target.mk:99: recipe for target 'Release/obj.target/binding/src/BluetoothHciSocket.o' failed
                      make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
                      make: Leaving directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/build'
                      gyp ERR! build error
                      gyp ERR! stack Error: `make` failed with exit code: 2
                      gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                      gyp ERR! System Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524
                      gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket
                      gyp ERR! node -v v10.16.0
                      gyp ERR! node-gyp -v v3.8.0
                      gyp ERR! not ok
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
                      + @abandonware/bluetooth-hci-socket@0.5.3-1
                      removed 63 packages, updated 1 package and audited 19313 packages in 242.798s
                      found 99 vulnerabilities (54 low, 5 moderate, 40 high)
                        run `npm audit fix` to fix them, or `npm audit` for details
                      • AlCalzone
                        @FuLLHDvs480p sagte in [How-to] Node.js für ioBroker richtig updaten:
                        Das ist gewollt.
                        Das scheint funktioniert zu haben. Der Fehler kommt von dem Versuch, eine ältere Version davon zu kompilieren.
                        Nein, du hast sie als iobroker ausgeführt, deswegen ja auch das umständlichere Kommando sudo -H -u iobroker ...
                          @AlCalzone Okay.
                          Der npm rebuild läuft trotzdem nicht durch:
                          npm ERR! errno -13
                          npm ERR!   stack:
                          npm ERR!   path:
                          npm ERR!
                          npm ERR!
                          npm ERR!     /home/rock64/.npm/_logs/2019-07-26T14_46_23_187Z-debug.log
                          npm ERR! errno 243
                          npm ERR!
                          npm ERR!     /home/rock64/.npm/_logs/2019-07-26T14_46_23_397Z-debug.log
                          Kann ich hingehen und den ganzen Ordner von dem bluetooth-hci-socket löschen?
                          Stabilostick 1 Reply Last reply Reply Quote 0
                          • Stabilostick
                            Stabilostick @FuLLHDvs480p last edited by
                            @FuLLHDvs480p
                            Führe bitte die folgenden Befehle aus:
                            cd /opt/iobroker
                            iobroker stop
                            sudo rm -r /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                            npm install @abandonware/bluetooth-hci-socket --force
                            iobroker start
                              FuLLHDvs480p @Stabilostick last edited by FuLLHDvs480p
                              @Stabilostick
                              cd /opt/iobroker
                              iobroker stop
                              ergab folgendes:
                              rock64@rock64:/opt/iobroker$ sudo rm -r /opt/iobroker/node_modules/@abandonware/        bluetooth-hci-socket
                              rock64@rock64:/opt/iobroker$ npm install @abandonware/bluetooth-hci-socket --force
                              npm WARN using --force I sure hope you know what you are doing.
                              > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/@abandonware/bluetoot        h-hci-socket
                              added 63 packages from 24 contributors, updated 1 package and audited 97 packages in 12.486s
                              > bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_        modules/bluetooth-hci-socket
                              > node-gyp rebuild
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/blu        etooth-hci-socket/build'
                              ../src/BluetoothHciSocket.cpp:251:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                              ../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to 'v8::Function::NewInstanc        e(int, v8::Local<v8::Value> [1])'
                              In file included from /home/rock64/.node-gyp/10.16.0/include/node/node.h:63:0,
                                               from /home/rock64/.node-gyp/10.16.0/include/node/node_buffer.h:25,
                              /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v        8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
                              /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 prov        ided
                              /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v        8::Function::NewInstance(v8::Local<v8::Context>) const
                              /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provi        ded
                              ../src/BluetoothHciSocket.cpp:282:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                              ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothH        ciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)':
                              In file included from /home/rock64/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                               from /home/rock64/.node-gyp/10.16.0/include/node/node.h:63,
                              /home/rock64/.node-gyp/10.16.0/include/node/v8.h:2476:46: note: declared here
                              /home/rock64/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECAT        ED'
                              ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothH        ciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)':
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/blue        tooth-hci-socket/build'
                              gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/bu        ild.js:262:23)
                              gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js        " "rebuild"
                              gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-so        cket
                              gyp ERR! not ok
                              > osx-temperature-sensor@1.0.3 install /opt/iobroker/node_modules/osx-temperature-sensor
                              > node-gyp rebuild
                              make: Entering directory '/opt/iobroker/node_modules/osx-temperature-sensor/build'
                                SOLINK_MODULE(target) Release/obj.target/none.node
                                COPY Release/none.node
                              make: Leaving directory '/opt/iobroker/node_modules/osx-temperature-sensor/build'
                              > xpc-connection@0.1.4 install /opt/iobroker/node_modules/xpc-connection
                              > node-gyp rebuild
                              make: Entering directory '/opt/iobroker/node_modules/xpc-connection/build'
                              make: Leaving directory '/opt/iobroker/node_modules/xpc-connection/build'
                              > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/@abandonware/bluetooth-h        ci-socket
                              node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/re        leases/download/0.5.3-1/binding-0.5.3-1-node-v64-linux-arm64.tar.gz
                              node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@1        0.16.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                              ../src/BluetoothHciSocket.cpp:252:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                              ../src/BluetoothHciSocket.cpp:283:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                              npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/bluetooth-hci-soc        ket'
                              npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-det        ector'
                              npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.radar/node        _modules/bluetooth-hci-socket/package.json'
                              added 8 packages from 7 contributors and audited 19313 packages in 210.767s
                              darauf das npm rebuild ergab:
                              rock64@rock64:/opt/iobroker$ ^C
                              rock64@rock64:/opt/iobroker$ clear
                              updated 1 package and audited 97 packages in 8.593s
                              [@abandonware/bluetooth-hci-socket] Success: "/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" already installed
                              Pass --update-binary to reinstall or --build-from-source to recompile
                              > usb@1.6.0 install /opt/iobroker/node_modules/iobroker.ble/node_modules/usb
                              > prebuild-install --verbose || node-gyp rebuild
                              prebuild-install info begin Prebuild-install version 5.3.0
                              prebuild-install info looking for cached prebuild @ /home/rock64/.npm/_prebuilds/c716aa-usb-v1.6.0-node-v64-linux-arm64.tar.gz
                              prebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.0/usb-v1.6.0-node-v64-linux-arm64.tar.gz
                              prebuild-install http 404 https://github.com/tessel/node-usb/releases/download/v1.6.0/usb-v1.6.0-node-v64-linux-arm64.tar.gz
                              prebuild-install WARN install No prebuilt binaries found (target=10.16.0 runtime=node arch=arm64 libc= platform=linux)
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
                                CC(target) Release/obj.target/libusb/libusb/libusb/core.o
                                CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
                                CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
                                CC(target) Release/obj.target/libusb/libusb/libusb/io.o
                                CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
                                CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
                                CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
                                CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
                                CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
                                CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
                                AR(target) Release/obj.target/usb.a
                                COPY Release/usb.a
                                CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
                              ../src/node_usb.cc: In function 'void handleHotplug(std::pair<libusb_device*, libusb_hotplug_event>)':
                              ../src/node_usb.cc:151:58: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                                Nan::MakeCallback(Nan::New(hotplugThis), "emit", 2, argv);
                              In file included from ../src/helpers.h:3:0,
                                               from ../src/node_usb.h:21,
                                               from ../src/node_usb.cc:1:
                              ../node_modules/nan/nan.h:1001:46: note: declared here
                                CXX(target) Release/obj.target/usb_bindings/src/device.o
                              ../src/device.cc: In static member function 'static void Req::default_after(uv_work_t*)':
                              ../src/device.cc:237:64: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declaratio                                                ns]
                                  Nan::MakeCallback(device, Nan::New(baton->callback), 1, argv);
                                               from ../src/device.cc:1:
                              ../node_modules/nan/nan.h:959:46: note: declared here
                                CXX(target) Release/obj.target/usb_bindings/src/transfer.o
                              ../src/transfer.cc: In function 'void handleCompletion(Transfer*)':
                              ../src/transfer.cc:126:72: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarat                                                ions]
                                 Nan::MakeCallback(self->handle(), Nan::New(self->v8callback), 3, argv);
                                               from ../src/transfer.cc:1:
                                SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
                                COPY Release/usb_bindings.node
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
                              > @abandonware/noble@1.9.2-2 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                              > node-gyp rebuild
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
                                SOLINK_MODULE(target) Release/obj.target/noble.node
                                COPY Release/noble.node
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
                                COPY Release/usb.a
                              > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket
                              updated 1 package and audited 95 packages in 8.66s
                              > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket
                              [@abandonware/bluetooth-hci-socket] Success: "/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" already installed
                              > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
                              > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build'
                                CXX(target) Release/obj.target/bindings/src/serialport.o
                                CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                                CXX(target) Release/obj.target/bindings/src/poller.o
                                CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                                SOLINK_MODULE(target) Release/obj.target/bindings.node
                                COPY Release/bindings.node
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build'
                              > grpc@1.20.3 install /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc
                              > node-pre-gyp install --fallback-to-build --library=static_library
                              [grpc] Success: "/opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm64-glibc/grpc_node.node" already installed
                              > protobufjs@6.8.8 postinstall /opt/iobroker/node_modules/iobroker.iogo/node_modules/@grpc/proto-loader/node_modules/protobufjs
                              > node scripts/postinstall
                              (node:19565) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 SIGINT listeners added. Use emitter.setMaxListeners() to increase limit
                              > iobroker.javascript@4.1.14 postinstall /opt/iobroker/node_modules/iobroker.javascript
                              > node ./install/installTypings.js
                              Installing NodeJS typings...
                              latest @types: 12, installed node: 10
                              > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                              > node lib/preinstallCheck.js
                              NPM version: 6.4.1
                              npm version >= 5: disabling package-lock
                              > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
                              > node iobroker.js setup first
                              > unix-dgram@2.0.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram
                              > node-gyp rebuild
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
                                CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                                COPY Release/unix_dgram.node
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
                              > websocket@1.0.28 install /opt/iobroker/node_modules/iobroker.lgtv/node_modules/websocket
                              > (node-gyp rebuild 2> builderror.log) || (exit 0)
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.lgtv/node_modules/websocket/build'
                                CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                                SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                                COPY Release/bufferutil.node
                                CXX(target) Release/obj.target/validation/src/validation.o
                                SOLINK_MODULE(target) Release/obj.target/validation.node
                                COPY Release/validation.node
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.lgtv/node_modules/websocket/build'
                              > ws@0.7.0 install /opt/iobroker/node_modules/iobroker.owntracks/node_modules/ws
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/ws/build'
                              bufferutil.target.mk:101: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/ws/build'
                              > ws@0.6.5 install /opt/iobroker/node_modules/iobroker.owntracks/node_modules/websocket-stream/node_modules/ws
                              make: Entering directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/websocket-stream/node_modules/ws/build'
                              make: Leaving directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/websocket-stream/node_modules/ws/build'
                              > usb@1.5.0 install /opt/iobroker/node_modules/iobroker.radar/node_modules/usb
                              [usb] Success: "/opt/iobroker/node_modules/iobroker.radar/node_modules/usb/src/binding/usb_bindings.node" already installed
                              > node-gyp rebuild
                              ../src/BluetoothHciSocket.cpp:251:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated                                                -declarations]
                              /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
                              /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
                              /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
                              /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
                              ../src/BluetoothHciSocket.cpp:282:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated                                                -declarations]
                              /home/rock64/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'
                              gyp ERR! not ok
                              npm ERR! errno 1
                              npm ERR! bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the bluetooth-hci-socket@0.5.1 install script.
                              npm ERR!     /home/rock64/.npm/_logs/2019-07-27T16_07_21_234Z-debug.log
                              Hab gerade Versucht ble auf die neue Version zu bringen, bekomme dann die Fehler:
                              $ ./iobroker upgrade ble
                              Update ble from @0.7.4 to @0.8.1
                              NPM version: 6.4.1
                              npm install iobroker.ble@0.8.1 --production --save --prefix "/opt/iobroker" (System call)
                              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gypnpm
                              npm
                               WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/bluetooth-hci-socket'npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
                              npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gypnpm ERR! code EACCES
                              npm ERR! errno -13
                              npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp']
                              npm ERR!
                                 stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp\'',
                              npm
                               ERR!   errno: -13,npm ERR!   code: 'EACCES',
                              npm ERR!   path:
                              npm
                              ERR!    '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp' }npm ERR!
                              npm ERR!
                               The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current user
                              npm ERR!
                              npm
                               ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try running
                              npm ERR!     /home/iobroker/.npm/_logs/2019-07-27T17_03_18_601Z-debug.log
                              ERROR: host.rock64 Cannot install iobroker.ble@0.8.1: 243
                              ERROR: process exited with code 25
                              • Mic
                                Mic Developer last edited by
                                Hi Leute,
                                vielen Dank für Eure Arbeit 🙂 Ihr habt in der Zwischenzeit auch noch mal einiges verbessert wie es scheint 😎
                                Erfolgreich durchgeführt bei mir ohne Fehlermeldungen. Ich habe hierzu auf Proxmox einen neuen Debian-Container erstellt, Vorgehensweise war wie folgt:
                                1. Debian-Container (CT) erstellen
                                2. In Proxmox den CT starten und auf die Konsole gehen
                                3. Neuen Nicht-Admin-User anlegen: adduser <username>
                                4. sudo installieren: apt-get install -y sudo
                                5. User zur sudo-Gruppe hinzufügen: adduser <username> sudo
                                6. Der Befehl ip addr gibt uns die IP-Adresse. Damit können wir uns nun mit Putty verbinden, immer den neu angelegten User nehmen, nicht den admin.
                                7. Nun im Putty aktualisieren:
                                  sudo apt-get update && sudo apt-get upgrade && sudo apt-get dist-upgrade
                                8. curl installieren: sudo apt-get install curl
                                9. Zur Sicherheit in Proxmox einen Snapshot erstellen
                                10. curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                                11. sudo apt install -y nodejs
                                12. sudo npm install -g npm
                                13. sudo reboot
                                14. curl -sL https://iobroker.net/install.sh | bash -
                                15. Fertig 🙂
                                Danach noch folgendes:
                                1. Adapter „BackitUp“ installieren.
                                2. Full-Backup ins Verzeichnis „/opt/iobroker/backups” kopieren und im BackitUp-Adapter einspielen ("Wiederherstellen")
                                3. Host / IP: Beim Umzug hat sich die IP und Host-Name geändert. Daher in der Konsole folgendes ausführen:
                                  3.1 iobroker stop
                                  3.2 iobroker host this. Man kann auch einen neuen Hostnamen vergeben, dazu iobroker host set newHostName eingeben.
                                  3.3 Die folgenden Dateien bearbeiten: /opt/iobroker/iobroker-data/objects.json und /opt/iobroker/iobroker-data/states.json und dort alle IP-Adressen durch die neue IP ersetzen.
                                  3.4 iobroker start
                                  Details: siehe https://github.com/ioBroker/ioBroker/wiki/Console-commands#iobroker-host
                                4. Sonoff-Adapter: Hier in auf der jeweiligen Site des Gerätes (z.B. http://192.168.XX.XX/? unter „Configuration > Configure MQTT“ die neue IP eintragen.
                                  crunchip Forum Testing Most Active @Mic last edited by
                                  @Mic Super mit der Beschreibung/Auflistung.
                                  Hast du dein System neu aufgesetzt? Warum nun IoBroker im Container? Hattest du den nicht in ner VM laufen?
                                  Bin auch grad am überlegen, nen Container zu erstellen, für ne Testumgebung.
                                  Produktiv läuft er auf ner VM.
                                  • Mic
                                    @crunchip
                                    Ja, ich habe neu aufgesetzt, hatte aber auch vorher schon den ioBroker im Container, nicht VM. Meine persönlichen Gründe dafür:
                                    • weniger Ressourcenverbrauch
                                    • schnellere initiale Installation
                                    • kleinere Backups
                                      @Mic ok
                                      das muss ich mal testen ob alles in nem Container funktioniert, vllt stell ich dann auch um.
                                        LJSven last edited by
                                        Wenn ich den Befehl
                                        ausführe, wird das Update nur auf 10.16.0 gemacht - nicht auf 10.16.1
                                        Was mache ich falsch?
                                          sigi234 Forum Testing Most Active @LJSven last edited by
                                          @LJSven sagte in [How-to] Node.js für ioBroker richtig updaten:
                                          Wenn ich den Befehl
                                          Nix, v10.16.0 ist die empfohlene...............
                                            LJSven @sigi234 last edited by
                                            @sigi234 sagte in [How-to] Node.js für ioBroker richtig updaten:
                                            Wenn ich den Befehl
                                            Okay, im Info Adapter zeigt er mir die "gelb" an bzw. sagt "Es gibt eine neuere Version...."
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            735577
