    4. IoBroker.scenes
    IoBroker.scenes
    • Bluefox
      Bluefox last edited by
      > Ich lege in Skript einige Trigger Variablen an (Beispiel: createState("Szene.TV", false); ) und löse die per VIS oder Homematic Taster aus. Dann kann ich im Szenen-Adapter leicht die zu schaltenden Geräte einstellen.
      Du kannst doch direkt deine Szene in vis triggern?
      • ruhr70
        ruhr70 last edited by
        ich hab das direkt in vis probiert.
        Funktioniert!
          Ich habe gerade über den admin versucht scenes upzudaten:
          $ ./iobroker upgrade scenes
          npm install iobroker.scenes --production --prefix "/opt/iobroker" (System call)
          npm http GET https://registry.npmjs.org/iobroker.scenes
          npm http 404 https://registry.npmjs.org/iobroker.scenes
          npm ERR! TypeError: Cannot call method 'match' of undefinednpm ERR!     at RegClient. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:119:29)
          npm ERR!     at cb (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:158:9)
          npm ERR!     at RegClient. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:252:14)npm ERR!     at Request.self.callback (/usr/local/lib/node_modules/npm/node_modules/request/request.js:129:22)
          npm ERR!     at Request.EventEmitter.emit (events.js:98:17)
          npm ERR!     at Request. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/request/request.js:873:14)
          npm ERR!     at Request.EventEmitter.emit (events.js:117:20)
          npm ERR!     at IncomingMessage. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/request/request.js:824:12)
          npm ERR!     at IncomingMessage.EventEmitter.emit (events.js:117:20)
          npm ERR!     at _stream_readable.js:920:16
          npm ERR! If you need help, you may report this log at:
          npm ERR!     <http: github.com/isaacs/npm/issues="">
          npm ERR! or email it to:npm ERR!     <npm-@googlegroups.com>
          npm ERR! System Linux 3.18.11-v7+
          npm
           ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.scenes" "--production" "--prefix" "/opt/iobroker"npm ERR! cwd /
          npm ERR! node -v v0.10.22
          npm ERR! npm -v 1.3.14
          npm ERR! type
           non_object_property_call
          npm ERR! npm ERR!
           Additional logging details can be found in:npm ERR!     /npm-debug.log
          npm ERR! not ok code 0
          Cannot install iobroker.scenes: 1
          ERROR: process exited with code 25</npm-@googlegroups.com></http:></anonymous></anonymous></anonymous></anonymous>
          Rainer
          • Bluefox
            @Homoran:
            npm
            npm ERR! type
            npm ERR! npm ERR!
            Rainer `
            http://forum.iobroker.org/viewtopic.php … 1152#p9346
            habe ich extra geschrieben 🙂
            > P.S. Scenes kann man noch nicht installieren.
              Das hatte ich anders verstanden 😞
              War ja schon installiert - sollte NUR upgedated werden.
              Ok - dann eben nicht, gibt schlimmeres!
              Rainer
                Pman last edited by
                Die Szenen haben echt Potential! Ich hänge gerade allerdings an einer Sache, vielleicht ist es auch garnicht möglich:
                Ich möchte, sobald der Harmony Adapter eine Aktivität erkennt, eine Steckdose ohne Verzögerung einschalten. Wird die Aktivität beendet soll die Steckdose wieder ausgeschaltet werden, aber diesmal mit Verzögerung, damit Beamer oder andere Geräte noch in Ruhe auslaufen können.
                  Kann man das vielleicht mit 2 Szenen "Kino" und "Kino Ende" machen?
                  Die Frage hatte ich mir gerade gestellt während dein Adapter installiert.
                  Rainer
                  Gesendet von meinem LIFETAB_S785X mit Tapatalk
                  • Bluefox
                    @Homoran:
                    Kann man das vielleicht mit 2 Szenen "Kino" und "Kino Ende" machen? `
                    Das ist die Lösung. 😉
                      Pman last edited by
                      @Bluefox:
                      Das ist die Lösung. 😉 `
                      So grob habe ich es hinbekommen, bin dabei aber glaube ich auf noch mehr Fehler im Adapter gestoßen, siehe github.
                        Fugazzy last edited by
                        wie lassen sich bestehende Szenen kopieren? Wenn ich auf den Button ganz hinten in der Reihe clicke, dann passiert leider nichts.
                        EDIT:
                        der jeweils letzte Eintrag lässt sich nicht kopieren, also ein einzelner auch nicht
                        EDIT2:
                        Es hat nicht funktioniert, da am Ende des Namens eine Nummer stand
                        Beim kopieren bekommt auch der Ursprung eine Nummer angehängt
                          Bei mir klappts.
                          Win7 Home
                          Chrome
                          Also wieder die üblichen verdächtigen:
                          • Browser cache
                          • anderer Browser
                          Rainer
                            Arminhh last edited by
                            moin, moin
                            ich spiele gerade mit dem Scenen Adapter rum. Ich meine mich erinnern zu können, das für die Cron Einstellungen ein Assistent auf ging. Der Assistent fehlt jetzt! Ist das beabsichtigt?
                            Hilfreich für z.B Bewegungsmelder wäre, wenn man mehrere Trigger eintragen könnte. (Bewegung und Helligkeit z.B.)
                            Ich wollte im Cron Job einstellen das die Beleuchtung für 5 min eingeschaltet bleiben soll. Der Trigger für On kommt von einer Variable. Was muss ich eintragen für die 5 min on?
                            mfg
                            Armin
                              Auch ich spiele mit dem scenes adapter herum, zum testen und um die Doku vorzubereiten.
                              Mein Szenario soll werden:
                              Film ansehen - Heimkino, bestehend aus:
                              Auslöser: manuelles herunterfahren der Leinwand
                              Szene soll (erst einmal) bestehen aus:
                              • sofort über Harmony-Hub die activity "Kino-Bluray" starten
                              • Rolladen Tür und Fenster sofort schließen
                              • Licht (Kranz und Decke) sofort 50%
                              • Licht Decke ziemlich bald auf 0 dimmen
                              • Licht Kranz etwas später auf 0 dimmen
                              bei mir sieht das so aus:
                              Abgesehen von den evtl. vorhandenen Problemen mit den Einheiten beim Level vom Rolladenaktor und Dimmer (0-1 oder 0-100??) habe ich nicht gefunden in welcher Einheit die Ramptime im Dimmer (5 war sofort aus - also nicht Minuten), die Verzögerung der Aktionen (Millisekunden???) einzutragen sind.
                              Weiterhin finde ich unter Zustände Werte, die anscheinend überhaupt nicht mit dem Zustand korrelieren.
                              Der harmony-Adapter zeigt nach wie vor als activity TV_Sat an, sowohl asl actual, als auch als Einzeldatenpunkt mit Wert 2
                              Die Leinwand ist angeblich auf 100, obwohl sie unten ist, in der CCU wird auch 0 angezeigt
                              und die Rollläden ebenfalls, nur das Licht stimmt:
                              und das log gefällt mir auch nicht:
                              scenes-0	2015-09-03 19:35:21	info	restartAdapter
                              scenes-0	2015-09-03 19:35:16	info	restartAdapter
                              scenes-0	2015-09-03 19:35:15	info	restartAdapter
                              scenes-0	2015-09-03 19:35:07	info	restartAdapter
                              scenes-0	2015-09-03 19:35:06	info	restartAdapter
                              hm-rpc-0	2015-09-03 19:32:38	info	setValue ["JEQ0202324:1","LEVEL",{"explicitDouble":0}] FLOAT
                              hm-rpc-0	2015-09-03 19:32:37	info	setValue ["JEQ0202324:1","RAMP_TIME",{"explicitDouble":300}] FLOAT
                              hm-rpc-0	2015-09-03 19:32:37	info	setValue ["JEQ0201654:1","LEVEL",{"explicitDouble":0}] FLOAT
                              hm-rpc-0	2015-09-03 19:32:37	info	setValue ["JEQ0201654:1","RAMP_TIME",{"explicitDouble":300}] FLOAT
                              hm-rpc-0	2015-09-03 19:32:36	info	setValue ["JEQ0202324:1","LEVEL",{"explicitDouble":0.5}] FLOAT
                              hm-rpc-0	2015-09-03 19:32:36	info	setValue ["JEQ0201654:1","LEVEL",{"explicitDouble":0.5}] FLOAT
                              hm-rpc-0	2015-09-03 19:32:35	info	setValue ["JEQ0112564:1","LEVEL",{"explicitDouble":0}] FLOAT
                              hm-rpc-0	2015-09-03 19:32:35	info	setValue ["JEQ0112436:1","LEVEL",{"explicitDouble":0}] FLOAT
                              scenes-0	2015-09-03 19:31:49	info	restartAdapter
                              scenes-0	2015-09-03 19:31:18	info	restartAdapter
                              scenes-0	2015-09-03 19:31:14	info	restartAdapter
                              scenes-0	2015-09-03 19:31:13	info	restartAdapter
                              scenes-0	2015-09-03 19:31:11	info	restartAdapter
                              scenes-0	2015-09-03 19:31:09	info	restartAdapter
                              scenes-0	2015-09-03 19:31:06	info	restartAdapter
                              scenes-0	2015-09-03 19:31:05	info	restartAdapter
                              scenes-0	2015-09-03 19:30:53	info	restartAdapter
                              scenes-0	2015-09-03 19:30:51	info	restartAdapter
                              scenes-0	2015-09-03 19:30:48	info	restartAdapter
                              scenes-0	2015-09-03 19:30:47	info	restartAdapter
                              scenes-0	2015-09-03 19:30:41	info	restartAdapter
                              scenes-0	2015-09-03 19:30:23	info	restartAdapter
                              scenes-0	2015-09-03 19:30:16	info	restartAdapter
                              scenes-0	2015-09-03 19:30:15	info	restartAdapter
                              Kann mir da jemand helfen?
                              Rainer
                              PS ich hatte zwischendrin mal die Leinwand wieder hoch und runter gefahren.
                                habe es jetzt anscheinend am laufen.
                                ich hatte beim Dimmer die Ramptime auf 400 statt auf 40 gestellt, dadurch dauerte der Dimmvorgang sehr lange.
                                Irrtümlich nahm ich erst an, dass die Verzögerung zu spät kommt.
                                Habe dann meine zweite Szene angefangen.
                                Nach abschalten des TV sollen die Lampe verzögert ausgehen.
                                Klappt auch so weit, jedoch ist das Ergebnis wie so oft zwar das, was programmiert ist, aber nicht das was gewollt war. 😉
                                Kann man den Auslöser für die Szene auch aus verschiedenen Bedingungen zusammensetzen, oder muss sowas wieder über js gemacht werden?
                                ggf, cron + Bedingung??, so dass die Szene durch die Bedingung nur in einem Zeitfenster z.B. zwischen 22h und 24h ausgelöst wird
                                Rainer
                                • Bluefox
                                  ` > Kann man den Auslöser für die Szene auch aus verschiedenen Bedingungen zusammensetzen, oder muss sowas wieder über js gemacht werden?
                                  ggf, cron + Bedingung??, so dass die Szene durch die Bedingung nur in einem Zeitfenster z.B. zwischen 22h und 24h ausgelöst wird `
                                  Momentan nur mit JS möglich.
                                  • Bluefox
                                    Ich habe jetzt Szenen erweitert, so dass man virtuelle Gruppen bilden konnte. Z.B. man hat 3 Thermostaten im Raum.
                                    Man kann jetzt die zu eine virtuelle Gruppe binden und über vis mit einem Widget steuern.
                                    • Bluefox
                                      Ich habe ziemlich wenig Feedback über Scenes bekommen. Obwohl ich den Adapter ziemlich wichtig finde.
                                      Ist alles verständlich? Was konnte man besser oder noch machen?
                                      • V
                                        vader722 last edited by
                                        Hi Bluefox,
                                        ich nutze den Adapter Scenes gerne und häufig. In der letzten Zeit sind mir keine Fehler aufgefallen, alles funktioniert wie es soll 🙂
                                        Er spart einige Javascripte, in denen ich früher halt nacheinander mühselig zeitversetzt einzelne Lampen/Geräte geschaltet habe.
                                        Vielen Dank 🙂
                                        Gruss Marco
                                          Pman last edited by
                                          Ich nutze den Adapter auch für einige Funktionen. Oft kann man sich ein Skript dadurch sparen.
                                          Während dem Bearbeiten/Hinzufügen von Szenen stürzt der Adapter allerdings permanent ab:
                                          host-raspberrypi	2015-10-29 14:06:18	error	instance system.adapter.scenes.0 terminated with code 6 (uncaught exception)
                                          TypeError:	2015-10-29 14:06:18	error	at Timer.listOnTimeout (timers.js:92:15)
                                          TypeError:	2015-10-29 14:06:18	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:367:30)
                                          TypeError:	2015-10-29 14:06:18	error	at Adapter.emit (events.js:172:7)
                                          TypeError:	2015-10-29 14:06:18	error	at emitTwo (events.js:87:13)
                                          TypeError:	2015-10-29 14:06:18	error	at Adapter. (/opt/iobroker/node_modules/iobroker.scenes/main.js:99:13)
                                          TypeError:	2015-10-29 14:06:18	error	at restartAdapter (/opt/iobroker/node_modules/iobroker.scenes/main.js:113:13)
                                          TypeError:	2015-10-29 14:06:18	error	at exports.clearTimeout (timers.js:213:42)
                                          TypeError:	2015-10-29 14:06:18	error	Cannot assign to read only property '_onTimeout' of scene.Harmony_an
                                          uncaught	2015-10-29 14:06:18	error	exception: Cannot assign to read only property '_onTimeout' of scene.Harmony_an
                                            Pman last edited by
                                            Hier noch eine ausführlicher Beitrag zu dem Adapter:
                                            Das Idee des Adapter finde ich sehr gut, die Wichtigkeit für die Automation von Abläufen ist enorm. Natürlich kann man alles per Skript lösen, aber das ist dank des Scene Adapter in vielen Fällen nicht mehr nötig. Allerdings finde ich, dass man noch an der Bedienbarkeit des Adapter verbessern kann, ich komme trotz intensiver Nutzung oft durcheinander was nun "Setzen" und "Setzen bei false" bedeutet usw., auch fällt es mir schwer komplexe Szene nachträglich zu bearbeiten. Was mir ein paar mal gefehlt hat ist das verknüpfen von Triggern, also Löse Szene aus wenn "x == 1 ODER y == 2 UND z == 0".
                                            Inspiriert durch einige Erfahrung mit dem Harmony System (Activities) habe ich mir ein paar Gedanken zur besseren Bedienung gemacht:
                                            Eine Szene sollte (auch optisch) unterteilt werden in einen Triggerausdruck, eine Startsequenz und eine Endsequenz.
                                            Einen Triggerausdruck ist eine Liste aus Datenpunkten, Vergleichswerten und UND/ODER-Verknüfungen:
                                            hm-rpc.0.XXX.1.STATE == 1
                                            UND
                                            hm-rpc.0.YYY.1.STATE == 0
                                            Man könnte nun (ähnlich wie es jetzt schon ist) entweder die Endsequenz starten sobald der gesamte Ausdruck nicht mehr wahr ist, oder aber einen zweiten Triggerausdruck definieren, welcher die Endsequenz auslöst wenn er wahr wird. Das hat aber den Nachteil, dass beide Ausdrücke gleichzeitig wahr sein können. Alternativ sollte eine Szene einfach nach einer definierten Zeit enden.
                                            Start- und Endsequenzen bestehen aus Datenpunkten, Werten welche gesetzt werden sollen sowie Verzögerungen:
                                            Startsequenz:
                                            hm-rpc.0.XXX.1.STATE.1 = 1
                                            1000ms Verzögerung
                                            hm-rpc.0.YYY.1.STATE.1 = 0
                                            Endsequenz:
                                            hm-rpc.0.YYY.1.STATE.1 = 1
                                            1000ms Verzögerung
                                            hm-rpc.0.XXX.1.STATE.1 = 0
                                            64
                                            14410
