    5. [gelöst] Osmose Wasser Aktuell & Max Verbrauch
      paul53 @Aphofis last edited by paul53
      @Aphofis sagte:
      Ich verstehe nicht warum es nicht läuft!?
      Ich schon: Der Tigger darf nicht der Wert vom Objekt ID ... sein, sondern muss die ID selbst sein, so wie hier.
       <variables>
         <variable type="" id="V]/%u4JGSoxh-Al{eT.g">ml_pro_Tag</variable>
         <variable type="" id="ihvas_{d.kg4gRlA_SmF">ml_Kumulativ</variable>
         <variable type="" id="n:v;eT@?L%cbL{M}xt_E">Differenz</variable>
         <variable type="" id="ckVaiUkVWNw*nrHYt1ho">ml_Aktuell</variable>
       </variables>
       <block type="variables_set" id="J.74*3iWof~,6Kx}~#T," x="-562" y="-137">
         <field name="VAR" id="V]/%u4JGSoxh-Al{eT.g" variabletype="">ml_pro_Tag</field>
           <block type="get_value_var" id=";qx8Kd*D1vAL]U;}P6L^">
             <value name="OID">
               <shadow type="text" id="6::J6t9Iao[MD{-O9uwB">
                 <field name="TEXT">admin.1.Aquarium_Control.ml_pro_Tag</field>
           <block type="variables_set" id="r9eO:=nj*R8[_VP#N.B#">
             <field name="VAR" id="ihvas_{d.kg4gRlA_SmF" variabletype="">ml_Kumulativ</field>
               <block type="get_value" id="o`iB.H?7RH[)vaB~x33:">
                 <field name="OID">admin.1.Aquarium_Control.Osmose_Max</field>
               <block type="comment" id="5_dAu$u@jE|TAgl|;,XY">
                 <field name="COMMENT">Magnetventil</field>
                   <block type="on_ext" id=":Nr`7Jva*j~6F*k.h/^F">
                     <value name="OID0">
                       <shadow type="field_oid" id="eXd?Hfx6K/{9#D2So~zg">
                         <field name="oid">rpi2.0.gpio.21.state</field>
                       <block type="controls_if" id=",3lQx[D^fe0|wZv07i:F">
                           <block type="logic_negate" id="5YH|]f]Y8q~OZzn6dp~c">
                             <value name="BOOL">
                               <block type="on_source" id="7V.$(3ehpmvx4I8d18aw">
                           <block type="variables_set" id="72%z_H5G5)(I?g,6w}y4">
                             <field name="VAR" id="n:v;eT@?L%cbL{M}xt_E" variabletype="">Differenz</field>
                               <block type="math_arithmetic" id="hbDOS/*?OV7f*;K%5]/B">
                                   <shadow type="math_number" id="1qz=5}09VW70aU;#1XFo">
                                     <field name="NUM">1</field>
                                   <block type="on_source" id="vRHoi8S{X(;fi6|?CNdR">
                                     <field name="ATTR">state.lc</field>
                                   <shadow type="math_number" id="igjc3(uZ:S);a(CB+~6G">
                                   <block type="on_source" id="4o,`J,IU$mwUfG~ldTcS">
                                     <field name="ATTR">oldState.lc</field>
                               <block type="variables_set" id="m=_{N_=!`*U)%~+=6k)M">
                                 <field name="VAR" id="ckVaiUkVWNw*nrHYt1ho" variabletype="">ml_Aktuell</field>
                                   <block type="math_arithmetic" id="4kRl.?`8|Mh3F%NpuU)o">
                                       <block type="variables_get" id="Mhz6a_f|)g9t_NoX-J4o">
                                       <block type="get_value" id="JvRB[I?w$,K)uyI4f^bs">
                                         <field name="OID">admin.1.Aquarium_Control.ml_multiplikator</field>
                                   <block type="update" id="$L)rekVx6$I,%e;4apgW">
                                     <field name="OID">admin.1.Aquarium_Control.Osmose_Aktuell</field>
                                       <block type="math_rndfixed" id="`T$g_{-$PLe-SSBp~eRc">
                                         <field name="n">2</field>
                                         <value name="x">
                                           <shadow type="math_number" id="+-xoJC%#+sANg_OJ={H8">
                                             <field name="NUM">3.1234</field>
                                           <block type="variables_get" id="f0]0D7lYkKvj8_p~z.%d">
                                       <block type="math_change" id="i##pC}m@FZYhZ+UJ#P?b">
                                         <value name="DELTA">
                                           <shadow type="math_number" id="rjS|:BdoUJX*N=n`Ji[]">
                                           <block type="variables_get" id="CpXbPP;H9nIQMrU;Uq)1">
                                           <block type="math_change" id="{qy46Yh1+,z@=wazF=Sa">
                                               <shadow type="math_number" id=":iELaSM8MUE{v_j{wKtM">
                                               <block type="variables_get" id="Uln@f]L*.73;Q))();nx">
                                               <block type="update" id="Aoq8WBDY@Hokp`)m4/4X">
                                                   <block type="math_rndfixed" id="OzOc$JV79+l5~%[*Ls3q">
                                                     <value name="x">
                                                       <block type="variables_get" id="BspaT@-^5ZEI+SkZI[Mk">
                                                   <block type="update" id="@DXH()Q[2XD)B|wzZ3,1">
                                                     <field name="OID">admin.1.Aquarium_Control.ml_pro_Tag</field>
                                                       <block type="math_round" id="0:*{$@p/*@-:+y#dr$zh">
                                                         <field name="OP">ROUND</field>
                                                         <value name="NUM">
                                                           <shadow type="math_number" id="@}^3%9A.jmf{F%7.Li8b">
                                                             <field name="NUM">3.1</field>
                                                           <block type="variables_get" id="QCo;X6-+|)pOF#Zl*cIe">
                                                       <block type="debug" id=";-vf26IOUB^od6zf#o6s">
                                                         <value name="TEXT">
                                                           <shadow type="text" id=".;Y[}a(8N_h0U)l?C.9:">
                                                           <block type="text_join" id="8!r$|^=,t[#JNZLQx94j">
                                                             <value name="ADD0">
                                                               <block type="text" id="r;GezYi}HE=H%]vDDLw4">
        <field name="TEXT">Dosierung aktuell </field>
                                                             <value name="ADD1">
                                                               <block type="math_rndfixed" id="61m!Va3FI+*)OeaUc!J]">
        <value name="x">
        <block type="variables_get" id="jlT*`^NkkJGXF1HToYGY">
                                                           <block type="debug" id="HTt5R[I*-hwd.gKyl0{{">
                                                             <value name="TEXT">
                                                               <block type="text_join" id="FErg(6m]tZt5$=?8Ut5^">
        <value name="ADD0">
        <block type="text" id="h|=sT+)M-v/mq%hrnL5a">
        <field name="TEXT">Dosierung Gesamt </field>
        <value name="ADD1">
        <block type="math_rndfixed" id="8J1lCb1g%$wdUkP,-#l|">
        <value name="x">
        <block type="variables_get" id="hm55C@pg}Ti[rjK+,]k|">
                       <block type="schedule" id="@{?t*Kbp)#F%kZ.QV7-P">
                         <field name="SCHEDULE">0 0 * * *</field>
                           <block type="variables_set" id="]hBT|HYa,^+;/_URpFpc">
                               <block type="math_number" id="/3j~a_2+DU]a%4W0RpQ(">
                                 <field name="NUM">0</field>
                               <block type="update" id=",5mG65Imrygz=PxUUDZ:">
                                   <block type="math_number" id="IEw|b8lc[)=9`zq5COIW">
      • Aphofis
        Aphofis last edited by Aphofis
        Was soll ich sagen es läuft!!!
        Der Hammer das ist es Mega spitze
        Ich danke dir vielmals.
        Jetzt muss ich mich dran machen die Werte in eine Datenbank zu bekommen damit ich Diagramme per vis darstellen kann.
        Maria DB ist schon auf meinem NAS installiert!
        Nur wie am besten mit ioBroker verknüpfen und wie ich per Blockly die Daten da rein bekomme muss ich mich erstmal schlau machen.
        Man lernt ja nie aus.
        Nur verstehe ich es noch nicht wie der Zusammenhang ist
        Wert; letzteÄnderung ; vorherigeLetzteÄnderung
        Warum nicht Wert ist mir noch nicht verständlich.
        Ich gucke mir heute Abend mal an was ich falsch gemacht habe.
        Vielen Dank
          @Aphofis sagte:
          nicht Wert : Wert == falsch : Ventil schließt
          @Aphofis sagte in Osmose Wasser Aktuell & Max Verbrauch Hilfe!!!:
          letzte Änderung: Zeitpunkt vom Schließen des Ventils (in ms seit 1.1.1970)
          vorherige letzte Änderung: Zeitpunkt vom Öffnen des Ventils
          Aphofis 1 Reply Last reply Reply Quote 1
          • Aphofis
            Aphofis @paul53 last edited by
            Ok verstanden!
            Vielen dank
            So langsam steige ich hinter die Logik von Blockly
              @Aphofis sagte:
              sind ioBroker-spezifisch.
              Aphofis 1 Reply Last reply Reply Quote 0
              • Aphofis
                Die Liste ist gut! Dann kann ich mir eine Menge ableiten.
                Habe jetzt auf deinen Rat einen neuen Datenpunkt im root erstellt und alle Unter Datenpunkte darin neu erstellt.
                Aus dem Admin ist der Haupt Datenpunkt jetzt raus! und alle Steuerungen umgestellt auf die neuen Datenpunkte.
                Ich denke Datenbank wird auch eine härtere Nuß für mich.
                MariaDB ist schon per sql Adapter verknüpft aber um da was einzutragen muss ich mich erstmal ein wenig einlesen.
                Schon mal toll solche Menschen wie dich hier zu haben, die einem so enorm weiter helfen.
                Danke noch mal
                • Aphofis
                  Wen es interessiert, und @paul53
                  ich hoffe ich habe das so richtig übersetzt.
                  Das ist eine Steuerung die meinen Vlies Verbrauch anzeigt und ermittelt.
                  Durch stoppen der Zeit für 10 cm habe ich den multiplikator ermittelt.
                  Die erstellten Datenpunkte zu dieser Steuerung
                  Mit cm pro Tag count habe ich noch was anderes vor aber ist erstmal außen vor und der Max Wert und cm pro Tag Werte stimmen natürlich nicht da ich zum testen den Vlies Motor mehrmals laufen lassen musste.
                  Der Tagesverbrauch liegt bei mir ca bei 30-40 cm. Den ich jetzt sehr genau ausgegeben bekomme.
                  • Aphofis
                    Der Code dazu Teil 1
                      <variables>
                        <variable type="" id="V]/%u4JGSoxh-Al{eT.g">cm_pro_Tag</variable>
                        <variable type="" id="ihvas_{d.kg4gRlA_SmF">cm_komulativ</variable>
                        <variable type="" id="ckVaiUkVWNw*nrHYt1ho">cm_Aktuell</variable>
                      </variables>
                      <block type="variables_set" id="J.74*3iWof~,6Kx}~#T," x="-487" y="-87">
                        <field name="VAR" id="V]/%u4JGSoxh-Al{eT.g" variabletype="">cm_pro_Tag</field>
                          <block type="get_value" id="!`-7w4Ob%M?7ztU!UD!8">
                            <field name="OID">Aqua_Control.0.cm_pro_Tag</field>
                            <field name="VAR" id="ihvas_{d.kg4gRlA_SmF" variabletype="">cm_komulativ</field>
                                <field name="OID">Aqua_Control.0.cm_Max</field>
                                    <value name="OID0">
                                        <field name="oid">rpi2.0.gpio.13.state</field>
                                            <value name="BOOL">
                                          <block type="comment" id="0_SP-:jo/~zs;Y(enH9B">
                                            <field name="COMMENT">1.1.1970 bis wert aktiv minus aktuelle zeit</field>
                                                  <block type="comment" id="biINHf0{3Ed{bF)P{V].">
                                                    <field name="COMMENT">gemessene Zeit mal multiplikator um cm zu erlangen</field>
                                                        <field name="VAR" id="ckVaiUkVWNw*nrHYt1ho" variabletype="">cm_Aktuell</field>
        <field name="OID">Aqua_Control.0.cm_multiplikator</field>
                                                          <block type="comment" id="-qlvZlbKsCcmbXA9[|dQ">
                                                            <field name="COMMENT">Datenpunkt cm Aktuell wird mit intern </field>
                                                              <block type="comment" id="=TI;v|K0P/XkMYJe@(7t">
        <field name="COMMENT">cm Aktuell aktualisiert</field>
        <field name="OID">Aqua_Control.0.cm_Aktuell</field>
        <value name="x">
        <block type="comment" id="8a~s%M,NvYZjsSVhP.Ud">
        <field name="COMMENT">Gesamtverbrauch intern wird derm aktuell </field>
        <block type="comment" id="vk3Hj5QI)t6bELlMM-PT">
        <field name="COMMENT">gemessenem internen Wert dazu addiert</field>
        <block type="comment" id="w6gH[QW1DueK!oW_i)jC">
        <field name="COMMENT">aktueller interner Wert wird zum Tagesverbrauch</field>
        <block type="comment" id="U(z%AO%43jU$y9N,z+58">
        <field name="COMMENT">intern dazu addiert</field>
        <block type="comment" id="dlfZO9!sy]A{G$K%3LgU">
        <field name="COMMENT">Datenpunkt Max Verbrauch wird um </field>
        <block type="comment" id="G7JT#a`YFY$^Z8D@[(aj">
        <field name="COMMENT">den wert cm komulativ erweitert</field>
        <value name="x">
        <block type="comment" id="IpzJrPC/%Z]h.1cC%Rb%">
        <field name="COMMENT">Datenpunkt cm pro Tag wird um </field>
        <block type="comment" id="mfr{3K9P[Z)cl(lf$fdO">
        <field name="COMMENT">den internen wert cm pro Tag erweitert</field>
        <value name="NUM">
        <block type="update" id="W(KDa:5=i!wuWK%}[)9v">
        <field name="OID">Aqua_Control.0.cm_pro_Tag_count</field>
        <block type="math_round" id="UDqHQ8(*Q:mP3pndH_=`">
        <value name="NUM">
        <block type="variables_get" id="g_^nhz*Y6k=+pA2.2;U:">
                    • Aphofis
                      Code Teil 2:
        <block type="comment" id="YBYn$);:m{JKll-eoAq*">
        <field name="COMMENT">debug Information cm Aktuell wird geschrieben</field>
        <value name="TEXT">
        <value name="ADD0">
        <field name="TEXT">Vliesverbrauch Aktuell </field>
        <value name="ADD1">
        <value name="x">
        <value name="ADD2">
        <block type="text" id="GJgiit^A/ocxR|R1|=Ec">
        <field name="TEXT"> cm</field>
        <block type="comment" id="ycRu-bUF@.zKp{0$T(.x">
        <field name="COMMENT">debug Information Max Verbrauch wird geschrieben</field>
        <value name="TEXT">
        <value name="ADD0">
        <field name="TEXT">Vliesverbrauch Gesamt </field>
        <value name="ADD1">
        <value name="x">
        <value name="ADD2">
        <block type="text" id="`?Q85d+`MK=Y/5c,(Pp#">
        <block type="comment" id="cD*27_Y2tdw_GIyTU:Nv">
        <field name="COMMENT">Telegram Nachricht mit allen drei internen Werten</field>
        <block type="comment" id="-L^:9Vmxh6uV*(W2t7uk">
        <block type="telegram" id=",@Yhs5!tBj$jfQkF(0D{">
        <field name="INSTANCE">.0</field>
        <field name="LOG"></field>
        <value name="MESSAGE">
        <shadow type="text" id="$7Ei82pQ9.H~Qau_xGtl">
        <block type="text_join" id="ZF0d^xTq54,5[,cG_O~^">
        <mutation items="11"></mutation>
        <value name="ADD0">
        <block type="text" id="~fGE@/olLb6IARVi5rQ0">
        <value name="ADD1">
        <block type="math_rndfixed" id="BX|mK)HM[k!~]pXVFWH)">
        <value name="x">
        <block type="variables_get" id="-C`@AJ-i!d6s{8M}#msA">
        <value name="ADD2">
        <block type="text" id="Z]N}.Z]:$!G4#Opbd;A6">
        <value name="ADD3">
        <block type="text_newline" id="ml(ZU9/TVRa?B*_=V3yu">
        <field name="Type">\n</field>
        <value name="ADD4">
        <block type="text" id="=uXX~-{YU!^Hg7j(4g^2">
        <field name="TEXT">Vlies Tagesverbrauch </field>
        <value name="ADD5">
        <block type="math_rndfixed" id="8OofUBN*wRP)VlI#cP(z">
        <value name="x">
        <block type="variables_get" id="2hm2SmFaEsAB5U0=G+f?">
        <value name="ADD6">
        <block type="text" id="c~Ze|7F~$iC]x[VTs=T3">
        <value name="ADD7">
        <block type="text_newline" id=")HorE+M1}k1cG#P4Nn_+">
        <value name="ADD8">
        <block type="text" id="I/X9x)QtAlGRgQI^qzLq">
        <field name="TEXT">Vliesverbrauch gesamt </field>
        <value name="ADD9">
        <block type="math_rndfixed" id="P;:cCx/oPZM-1^LquZ/p">
        <value name="x">
        <block type="variables_get" id="yifK::$6eUEi^oGk_(q[">
        <value name="ADD10">
        <block type="text" id="!IRV9q+z,[`0#l]#ea]!">
                                        <block type="comment" id="[*LdX;p+0u?!x)JR`Tuu">
                                          <field name="COMMENT">Datenpunkt wie interner Wert vom Tagesverbrauch</field>
                                            <block type="comment" id="rgm3:XiS;abWA[JD$V![">
                                              <field name="COMMENT">werden alle 24 Std. zurückgesetzt</field>
                                                    <block type="comment" id="RYsm.L_lmjBfK5|Rw]Vl">
                                                      <field name="COMMENT">cm pro Tag intern wird auf null gesetzt</field>
                                                            <block type="comment" id="oj#8:ul0P~=_t/o$:i57">
                                                              <field name="COMMENT">Datenpunkt cm pro Tag wird auf null gesetzt</field>
        <field name="OID">Aqua_Control.0.ml_pro_Tag</field>
                      • Aphofis
                        ist es möglich Osmose_Max den Wert manuell intern zu setzen?
                        Da ich mist gebaut habe und der zähler wieder von vorne anfängt !?
                        Weil wenn ich den Wert im Datenpunkt korrigiere wird er beim nachsten Pumpen wieder zurück auf Anfang gesetzt.
                        woher bekommt ml_komulativ den Wert wenn nicht aus dem Datenpunkt!?
                          @Aphofis sagte:
                          Du kannst den Wert manuell korrigieren und anschließend das Skript neu starten, damit der Wert in die Variable übernommen wird.
                          • Aphofis
                            ok i will try
                            • Aphofis
                              Du bist ne Wucht !!! Auch wenns einfach ist, muss man sowas erstmal wissen.
                              Es hat geklappt, beim Vlies und beim Osmose Verbrauch. Danke
                              Daten werden auch alle fleißig in der Datenbank geloggt.
                              Nur werden auch werte mit Wert - null - geloggt, das natürlich nicht so schön und dazu kommt noch das mein Flot Adapter nicht funktioniert. Hab schon Flot deinstalliert ob über iobroker und über ssh und auch über beide Wege neu installiert! keine Chance.
                              Wenn ich Flot aufrufen will, kommt eine Fehler Meldung auf dem neuen Tab:
                              File edit.html not found: permissionError
                              Wenn ich mir die Charts angucken will in einem Datenpunkt von dem sql Adapter kommt keine Grafik.
                              Hab schon überall im Netz nach dem Fehler gesucht, doch leider kein Erfolg.
                                @Aphofis sagte:
                                Wenn ich Flot aufrufen will, kommt eine Fehler Meldung auf dem neuen Tab: File edit.html not found: permissionError
                                Mache dazu besser ein neues Thema auf, denn es geht in diesem Thema hier unter.
                                Bitte noch die Überschrift um [gelöst] ergänzen.
                                • Aphofis
                                  Na klar mach ich das ! Wollte dir nur den Stand der Dinge mitteilen.
                                  • Aphofis
                                    Kannst du mir einen Riesen gefallen tun und mal drüber gucken
                                    Beide Steuerungen für Vlies Verbrauch in cm und osmose Verbrauch in ml spinnen.
                                    Ich habe neue datenpunkte angelegt in datenpunkt Ordnern und in den Steuerungen alles sauber neu verknüpft.
                                    Doch nach dem ich beide Steuerungen eingeschaltet hatte, und Osmose oder Vlies läuft
                                    Wird cm_Max auf den Wert von cm_Aktuell gestellt und cm_pro_Tag cm_pro_Tag_count werden aufgerundet auf den cm_Aktuell wert.
                                    Da stimmt was nicht und ich verstehe es nicht.
                                    Hab schon beide Steuerungen mehrfach kontrolliert und deaktiviert, werte manuell geändert Scripte gestartet und immer wieder werden die Werte nicht ergänzt sondern mit dem falschen Wert aktualisiert.
                                    Das wäre sehr nett wenn du mir helfen könntest.
                                    var cm_pro_Tag, cm_komulativ, Differenz, cm_Aktuell;
                                    cm_pro_Tag = getState("Aqua_Control.0.Vliesfilter.cm_pro_Tag").val;
                                    cm_komulativ = getState("Aqua_Control.0.Vliesfilter.cm_Max").val;
                                    on({id: 'rpi2.0.gpio.20.state', change: "ne"}, function (obj) {
                                      var value = obj.state.val;
                                      if (!(obj.state ? obj.state.val : "")) {
                                        Differenz = (obj.state ? obj.state.lc : "") - (obj.oldState ? obj.oldState.lc : "");
                                        cm_Aktuell = Differenz * getState("Aqua_Control.0.Vliesfilter.cm_multiplikator").val;
                                        setState("Aqua_Control.0.Vliesfilter.cm_Aktuell"/*cm_Aktuell*/, Math.round(cm_Aktuell*100)/100, true);
                                        cm_komulativ = (typeof cm_komulativ == 'number' ? cm_komulativ : 0) + cm_Aktuell;
                                        cm_pro_Tag = (typeof cm_pro_Tag == 'number' ? cm_pro_Tag : 0) + cm_Aktuell;
                                        setState("Aqua_Control.0.Vliesfilter.cm_Max"/*cm_Max*/, Math.round(cm_komulativ*100)/100, true);
                                        setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag"/*cm_pro_Tag*/, (Math.round(cm_pro_Tag)), true);
                                        setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag_count"/*cm_pro_Tag_count*/, (Math.round(cm_pro_Tag)), true);
                                        sendTo("telegram.0", "send", {
                                            text: (['Vliesverbrauch Aktuell ',Math.round(getState("Aqua_Control.0.Vliesfilter.cm_Aktuell").val*100)/100,' cm','\n','Vlies Tagesverbrauch ',Math.round(getState("Aqua_Control.0.Vliesfilter.cm_pro_Tag").val*100)/100,' cm','\n','Vliesverbrauch gesamt ',Math.round((getState("Aqua_Control.0.Vliesfilter.cm_Max").val / 100)*100)/100,' Meter'].join(''))
                                        console.log((['Vliesverbrauch Aktuell ',Math.round(getState("Aqua_Control.0.Vliesfilter.cm_Aktuell").val*100)/100,' cm'].join('')));
                                        console.log((['Vliesverbrauch Gesamt ',Math.round((getState("Aqua_Control.0.Vliesfilter.cm_Max").val / 100)*100)/100,'  cm'].join('')));
                                    schedule("0 0 * * *", function () {
                                      cm_pro_Tag = 0;
                                      setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag"/*cm_pro_Tag*/, 0, true);
                                      setState("Aqua_Control.0.Vliesfilter.cm_pro_Tag_count"/*cm_pro_Tag_count*/, 0, true);
                                    Und noch komischer ist, in telegram werden die richtigen Werte angezeigt. Hatte auch mal unter Objekte den Experten Modus eingeschaltet nicht das die alten datenpunkte noch da sind aber sind sie nicht das da irgendwas durcheinander gekommen ist.
                                      @Aphofis
                                      Was ist der Unterschied zwischen "cm_pro_Tag" und "cm_pro_Tag_count" ? Ich kann keinen Unterschied erkennen.
                                      Für Telegram und Log verwende die Variablen cm_Aktuell, cm_komulativ und cm_pro_Tag, denn das Einlesen der Datenpunkte liefert einen veralteten Wert vom vorherigen Trigger.
                                      • Aphofis
                                        count war eigntl gedacht um zu zählen wie oft bzw wie lange osmose oder der vlies filter am tag läuft also wie lange auf true stand und wie oft true an war.
                                        dH. ich muss count raus nehmen !?
                                        Die werte kommen doch aus den Datenpunkten doch wenn ich die beiden scripte stoppe dann die Daten in den Datenpunkten so einstelle wie es gehört und die Scripte wieder starte schmeissen beide die Daten raus bei max und bei tages verbrauch.
                                        • Aphofis
                                          Vliesverbrauch sieht dann so aus:
                                            cm_pro_Tag = 0;
                                          Osmose Verbrauch:
                                          var ml_pro_Tag, ml_Kumulativ, Differenz, ml_Aktuell;
                                          ml_pro_Tag = getState("Aqua_Control.0.Osmose_System.ml_pro_Tag").val;
                                          ml_Kumulativ = getState("Aqua_Control.0.Osmose_System.Osmose_Max").val;
                                          // Magnetventil
                                          on({id: 'rpi2.0.gpio.21.state', change: "ne"}, function (obj) {
                                              ml_Aktuell = Differenz * getState("Aqua_Control.0.Osmose_System.ml_multiplikator").val;
                                              setState("Aqua_Control.0.Osmose_System.Osmose_Aktuell"/*Osmose_Aktuell*/, Math.round(ml_Aktuell*100)/100, true);
                                              ml_Kumulativ = (typeof ml_Kumulativ == 'number' ? ml_Kumulativ : 0) + ml_Aktuell;
                                              ml_pro_Tag = (typeof ml_pro_Tag == 'number' ? ml_pro_Tag : 0) + ml_Aktuell;
                                              setState("Aqua_Control.0.Osmose_System.Osmose_Max"/*Osmose_Max*/, Math.round(ml_Kumulativ*100)/100, true);
                                              setState("Aqua_Control.0.Osmose_System.Osmose_Gesamtverbrauch"/*Osmose_Gesamtverbrauch*/, Math.round((ml_Kumulativ / 1000)*1000)/1000, true);
                                              setState("Aqua_Control.0.Osmose_System.ml_pro_Tag"/*ml_pro_Tag*/, (Math.round(ml_pro_Tag)), true);
                                              console.log((['Dosierung aktuell ',Math.round(ml_Aktuell),' ml'].join('')));
                                              console.log((['Dosierung Gesamt ',Math.round((ml_Kumulativ / parseFloat(1000))*1000)/1000,' Liter'].join('')));
                                                  text: (['Osmose Dosierung aktuell ',Math.round(getState("Aqua_Control.0.Osmose_System.Osmose_Aktuell").val),' ml','\n','Osmose Tages Dosierung ',Math.round((getState("Aqua_Control.0.Osmose_System.ml_pro_Tag").val / 1000)*100)/100,' Liter','\n','Osmose Gesamtverbrauch ',Math.round(getState("Aqua_Control.0.Osmose_System.Osmose_Gesamtverbrauch").val),' Liter'].join(''))
                                            ml_pro_Tag = 0;
                                            setState("Aqua_Control.0.Osmose_System.ml_pro_Tag"/*ml_pro_Tag*/, 0, true);
                                          wäre es dann so korrekt und die steuerungen nehmen beim starten die werte aus den datenpunkten ?
                                          • Aphofis
                                            Ich habe jetzt ml_pr_Tag_count und cm_pro_Tag_count raus geschmissen aus den steuerungen und zum testen nicht das magnet ventil oder den vlies motor manuell betätigt sondern die beiden schwimmer und siehe da, es funktioniert wieder.
                                            Was ich nur nicht verstehe wieso ging es die ganze Zeit und jetzt nicht mehr.
                                            Kann es mit den neu angelegten und neu verknüpften Datenpunkten zu tun haben !?
                                            Hatte ja vorher alle scripte gestoppt und dann die datenpunkt änderungen vorgenommen.
                                            Da ja noch reichlich Steuerungen dazu kommen musste ich aufräumen.
                                            Sonst wird es nachher ein unübersichtlicher Haufen Datenpunkte.
                                            Dazu kommen noch zwei TDS ppm Meter dann eine Leitwert Sonde, eine PH Sonde und wenns klappt die Steuerung Zeitgesteuert zu dem Tunze Controller senden.
                                            2925
