    4. [Fehler] nach Neustart des Systems # module.js:340
    • derAuge
      derAuge last edited by
      > npm install iobroker.admin
      root@pi2:/mnt/ioBroker/iobroker.Pi2# npm install iobroker.admin
      npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
      > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
      > (node-gyp rebuild 2> builderror.log) || (exit 0)
      make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
        CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
        SOLINK_MODULE(target) Release/obj.target/bufferutil.node
        SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
        COPY Release/bufferutil.node
        CXX(target) Release/obj.target/validation/src/validation.o
        SOLINK_MODULE(target) Release/obj.target/validation.node
        SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
        COPY Release/validation.node
      make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
      > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
      make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/                      ws/build'
      make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/w                      s/build'
      iobroker.admin@0.3.23 node_modules/iobroker.admin
      ├── connect-flash@0.1.1
      ├── cookie-parser@1.3.4 (cookie-signature@1.0.6, cookie@0.1.2)
      ├── passport-local@1.0.0 (passport-strategy@1.0.0)
      ├── passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
      ├── xtend@2.0.6 (is-object@0.1.2, object-keys@0.2.0)
      ├── express-session@1.7.6 (cookie@0.1.2, utils-merge@1.0.0, cookie-signature@1.0.4, on-headers@1.0.0, parseurl@1.3.0, buffer-crc32@0.2.3, depd@0.4.4, debug@1.0.4, uid-safe@1.0.1                      )
      ├── express@4.4.5 (parseurl@1.0.1, utils-merge@1.0.0, merge-descriptors@0.0.2, escape-html@1.0.1, cookie@0.1.2, cookie-signature@1.0.4, range-parser@1.0.0, fresh@0.2.2, vary@0.1                      .0, qs@0.6.6, methods@1.0.1, serve-static@1.2.3, buffer-crc32@0.2.3, path-to-regexp@0.1.2, debug@1.0.2, proxy-addr@1.0.1, send@0.4.3, type-is@1.2.1, accepts@1.0.7)
      ├── body-parser@1.5.2 (qs@0.6.6, media-typer@0.2.0, raw-body@1.3.0, bytes@1.0.0, depd@0.4.4, type-is@1.3.2, iconv-lite@0.4.4)
      ├── request@2.38.0 (json-stringify-safe@5.0.0, forever-agent@0.5.2, aws-sign2@0.5.0, qs@0.6.6, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, node-uuid@1.4.3, form-da                      ta@0.1.4, mime-types@1.0.2, http-signature@0.10.1, tough-cookie@0.12.1, hawk@1.1.1)
      └── socket.io@1.0.6 (debug@0.7.4, has-binary-data@0.1.1, socket.io-parser@2.2.0, socket.io-adapter@0.2.0, engine.io@1.3.1, socket.io-client@1.0.6)
      > iobroker add admin –enabled --port 8090
      root@pi2:/mnt/ioBroker/iobroker.Pi2# iobroker add admin --enabled --port 8090
      create instance admin
      object system.adapter.admin.1.uptime created
      object system.adapter.admin.1.memRss created
      object system.adapter.admin.1.memHeapTotal created
      object system.adapter.admin.1.memHeapUsed created
      object system.adapter.admin.1.connected created
      object system.adapter.admin.1.alive created
      object system.adapter.admin.1 created
      root@pi2:/mnt/ioBroker/iobroker.Pi2# ps -A |grep io.
       2313 ?        00:07:42 io.js-controlle
       2422 ?        00:02:17 io.history.0
       2432 ?        00:00:34 io.hm-rpc.0
       2455 ?        00:00:41 io.hm-rega.0
       2476 ?        00:02:15 io.javascript.0
       2482 ?        00:00:12 io.ping.0
       2507 ?        00:00:06 io.sayit.0
       2513 ?        00:02:25 io.web.0
       2519 ?        00:00:35 io.sonos.0
       2540 ?        00:00:10 io.hm-rpc.1
       2555 ?        00:00:08 io.node-red.0
       6990 ?        00:00:21 io.admin.1
      Das adminUI ist unter Pi2:8090 errechbar
      • derAuge
        Es sind nun beide Instanzen installiert
        der admin.0 läuft nicht
        nach Konfigurieren von :
        nach
        wird admin.0 zwar gestartet, jadoch ist die Oberfläche nicht erreichbar (Kreisel)
        • Bluefox
          Bluefox last edited by
          Es heißt, dass Port ist belegt und eine Instanz immer noch läuft und will nicht runtergehen. Das sollte vorbei sein, wenn man komplett reboot macht. Um zu prüfen ob ich recht habe, kann man:
          netstat -n -a | grep 8081
          ausführen und schauen, ob was da ist.
          • derAuge
            😉 Und täglich grüßt das Murmeltier 😉
            root@pi2:/mnt/ioBroker/iobroker.Pi2# init 6
            Nach neustart des Pi2
                [ OK ] Starting system message bus: dbus.
                Startion ioBroker
                module.js:340
                    throw err;
                Error: Cannot find module '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (module.js:338:15)
                    at Function.Module._load (module.js:280:25)
                    at Function.Module.runMain (module.js:497:10)
                    at startup (node.js:119:16)
                    at node.js:935:3
                [ OK ] Starting RPi-Monitor: rpimonitord
            Zur Zeit wird das NAS geprüft. dort liegt die Installation und wird vom Pi2 gemountet.
            • derAuge
              Das NAS-System ist sauber.
              Nun stehe ich vor der Frage: Wie kann ich herausfinden wo das Problem liegt?
              Kann ich irgend welche prüfroutinen einbauen um festzustellen warun dort etwas "zerschossen" wird?
              • Bluefox
                Alle erste, muss du gesamte Installation zu Rpi2 holen. Und beobachten ob das Problem sich reproduziert.
                • derAuge
                  @Bluefox:
                  Alle erste, muss du gesamte Installation zu Rpi2 holen. Und beobachten ob das Problem sich reproduziert. `
                  OK
                  da brauche ich aber dann etwas mehr Zeit…. Werde es testen. 😉 So schnell geben wir ja nicht auf 😉
                  zur Info
                  nach einigen Updates folgendes im LOG:
                  iobroker	2015-03-26 20:18:45	info	exit 8
                  iobroker	2015-03-26 20:18:45	error	at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
                  iobroker	2015-03-26 20:18:45	error	at null._onTimeout (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/setup.js:1514:27)
                  iobroker	2015-03-26 20:18:45	error	at new ObjectsInMemServer (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:146:7)
                  iobroker	2015-03-26 20:18:45	error	at /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:139:9
                  iobroker	2015-03-26 20:18:45	error	at _initWebServer (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:958:24)
                  iobroker	2015-03-26 20:18:45	error	at Server.listen (net.js:1139:5)
                  iobroker	2015-03-26 20:18:45	error	at listen (net.js:1065:10)
                  iobroker	2015-03-26 20:18:45	error	at Server._listen2 (net.js:1043:14)
                  iobroker	2015-03-26 20:18:45	error	Error: listen EADDRINUSE at errnoException (net.js:905:11)
                  iobroker	2015-03-26 20:18:45	error	throw er; // Unhandled 'error' event ^
                  iobroker	2015-03-26 20:18:45	error	events.js:72
                  iobroker	2015-03-26 20:18:36	info	upgrade hm-rega
                  • Bluefox
                    Es läuft was auf dem System.
                    Neu starten (init 6)
                    • derAuge
                      @Bluefox:
                      Neu starten (init 6) `
                      ja,
                      ich hatte das System noch mal manuell gestartet.
                      Danach liefen die Adapter natürlich wieder.
                      Habe dann nach updates geschaut….
                      Gerade habe ich das "defekte" System auch noch mal (zum Test) manuell gestartet und die anstehenden Updates eingespielt.
                        pix last edited by
                        Halo,
                        könnt Ihr mir bitte noch einmal erklären, wie das funktioniert! Ich habe leider wieder das Problem:
                        2015-08-19 00:25:10.573  - info: host.Mini-Wohnzimmer.fritz.box ioBroker.js-controller version 0.7.8 js-controller starting
                        2015-08-19 00:25:10.575  - info: host.Mini-Wohnzimmer.fritz.box Copyright (c) 2014-2015 bluefox, hobbyquaker
                        2015-08-19 00:25:10.575  - info: host.Mini-Wohnzimmer.fritz.box hostname: Mini-Wohnzimmer.fritz.box
                        2015-08-19 00:25:10.575  - info: host.Mini-Wohnzimmer.fritz.box ip addresses: XXXXXXXANONYMISIERTXXXXXX
                        2015-08-19 00:25:12.389  - info: inMem-states listening on port 9000
                        2015-08-19 00:25:12.801  - info: inMem-objects listening on port 9001
                        2015-08-19 00:25:12.803  - info: host.Mini-Wohnzimmer.fritz.box InMemoryDB connected
                        2015-08-19 00:25:12.818  - info: host.Mini-Wohnzimmer.fritz.box 33 instances found
                        2015-08-19 00:25:12.819  - warn: host.Mini-Wohnzimmer.fritz.box does not start any instances on this host
                        Der JS-Controler startet als einziger und dann bleibt es stehen. Ich habe bereits den obigen Weg probiert. Eine weitere Admin Instanz angeschmissen und sie läuft auch. Aber wie geht es dann weiter? amin.0 löschen hat nichts gebracht.
                        Habe bereits über Timemachine ein altes Backup von heute Mittag genutzt. Leider kein Erfolg.
                        ./iobroker update bringt das:
                        ./iobroker update
                        Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/adapter/example/io-package.json. Error: Not Found
                        update done
                        Adapter "zwave" : 0.1.0
                        Adapter "yr" : 0.1.7 , installed 0.1.7
                        Adapter "web" : 0.4.3 , installed 0.4.2 [Updateable]
                        Adapter "vis-plumb" : 0.1.5
                        Adapter "vis-metro" : 0.1.7 , installed 0.1.3 [Updateable]
                        Adapter "vis-lcars" : 0.1.6 , installed 0.1.4 [Updateable]
                        Adapter "vis-hqwidgets" : 0.1.0 , installed 0.1.0
                        Adapter "vis-colorpicker": 0.1.0 , installed 0.1.0
                        Adapter "vis-bars" : 0.0.3
                        Adapter "vis" : 0.6.12 , installed 0.6.5 [Updateable]
                        Adapter "sonos" : 0.1.6 , installed 0.1.6
                        Adapter "rickshaw" : 0.2.2 , installed 0.2.2
                        Adapter "pushover" : 0.1.1 , installed 0.1.1
                        Adapter "pushbullet" : 0.0.6 , installed 0.0.6
                        Adapter "owfs" : 0.0.2
                        Adapter "onkyo" : 0.1.9
                        Adapter "socketio" : 0.4.5
                        Adapter "simple-api" : 0.1.1 , installed 0.1.1
                        Adapter "scenes" : 0.1.2 , installed 0.0.2 [Updateable]
                        Adapter "sayit" : 0.3.11 , installed 0.3.11
                        Adapter "s7" : 0.1.8
                        Adapter "ping" : 0.1.4
                        Adapter "node-red" : 0.3.4 , installed 0.3.3 [Updateable]
                        Adapter "mqtt" : 0.2.9 , installed 0.2.9
                        Adapter "megad" : 0.1.1
                        Adapter "knx" : 0.0.1
                        Controller "js-controller" : 0.7.7 , installed 0.7.8
                        Adapter "javascript" : 0.5.4 , installed 0.5.1 [Updateable]
                        Adapter "icons-ultimate-png": 0.1.0 , installed 0.1.0
                        Adapter "icons-open-icon-library-png": 0.1.1
                        Adapter "icons-mfd-svg" : 0.1.0 , installed 0.1.0
                        Adapter "icons-mfd-png" : 0.1.0 , installed 0.1.0
                        Adapter "icons-material-svg": 0.1.0 , installed 0.1.0
                        Adapter "icons-material-png": 0.1.0 , installed 0.1.0
                        Adapter "icons-addictive-flavour-png": 0.1.0 , installed 0.1.0
                        Adapter "ical" : 1.1.1 , installed 1.0.2 [Updateable]
                        Adapter "hmm" : 0.1.1
                        Adapter "hue" : 0.4.2
                        Adapter "hm-rpc" : 0.5.2 , installed 0.5.2
                        Adapter "hm-rega" : 0.2.2 , installed 0.2.2
                        Adapter "history" : 0.1.3 , installed 0.1.3
                        Adapter "harmony" : 0.5.1
                        Adapter "fritzbox" : 0.2.1 , installed 0.2.1
                        Adapter "flot" : 0.1.1 , installed 0.1.1
                        Adapter "email" : 0.1.2
                        Adapter "dwd" : 0.1.10 , installed 0.1.9 [Updateable]
                        Adapter "cul" : 0.0.4
                        Adapter "b-control-em" : 0.1.1
                        Adapter "artnet" : 0.0.3
                        Adapter "admin" : 0.5.8 , installed 0.5.7 [Updateable]
                        Ich muss das System wohl erstmal ruhen lassen. :o
                        Pix
                          pix last edited by
                          habe jetzt mit mühevoller Handarbeit alles wieder zum Laufen bekommen. Es lief ja auf einem mac mini mit OS X.
                          Achtung! Die Einstellungen der Adapter gehen verloren (egal bei VIS oder Scenes), daher unbedingt vorher Screenshots der einzelnen Einstellungen machen (aufwendig bei ical, hm-rega, hm-rpc; bei Javascript und node-red ggf. an die zusätzlichen Module denken)
                          <list type="decimal">4. Backup des Ordner iobroker/iobroker-data (waren über 5GB wegen History Daten)
                          1. neuen Benutzer mit Adminrechten angelegt (alter Benutzer hatte sehr viele verwaiste Dateien)
                          2. ./iobroker start startet nur den js-controller (siehe oben)
                          3. ./iobroker del admin.0
                          4. ./iobroker add admin –enabled --port 8081 (danach wieder Zugriff auf Admin im Browser)
                          5. auf diese Weise jeden einzelnen Adapter erst gelöscht und dann neu angelegt und gestartet (Achtung: Bei Adaptern mit mehreren Instanzen müssen erst alle Instanzen gelöscht werden, damit die alte Reihenfolge 0,1,2,… wieder hergestellt wird)
                          6. Alle History Einstellungen sind weg. Das heißt, die Objekte müssen einzeln wieder angewählt und die gewünschte History-Log-Einstellung getätigt werden (mühsam).
                            Empfehlung: Erst hm-rp-Instanzen und dann hm-rega erneuern. Dann ggf. node-red und erst danach javascript, da viele Skripte auf die Daten aus der Homematic bzw. node-red zugreifen und sonst verrückt spielen, wenn die Objekte nicht mehr da sind.
                          Vielleicht kann es jemand brauchen, notfalls sehe ich später selbst hier nach, wenn der Fehler wieder auftaucht.
                          Pix
                          2982
