Test Adapter ZigBee CC253x v0.11.x
Ich habe ein Doppeltaster von Aqara und ich sehe unter Objekten noch doppel click event, long click event......
Aber die kann ich alle nicht nutzen, help ?
Habe ein problem nach den update zu version 11.2
host.ioBroker-Pi 2019-07-12 21:41:40.548 error instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.ioBroker-Pi 2019-07-12 21:41:40.548 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10) host.ioBroker-Pi 2019-07-12 21:41:40.547 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30) host.ioBroker-Pi 2019-07-12 21:41:40.547 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:1:36) host.ioBroker-Pi 2019-07-12 21:41:40.547 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:112:48) host.ioBroker-Pi 2019-07-12 21:41:40.546 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18) host.ioBroker-Pi 2019-07-12 21:41:40.546 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:690:17) host.ioBroker-Pi 2019-07-12 21:41:40.546 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3) host.ioBroker-Pi 2019-07-12 21:41:40.546 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12) host.ioBroker-Pi 2019-07-12 21:41:40.545 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32) host.ioBroker-Pi 2019-07-12 21:41:40.545 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:805:18) host.ioBroker-Pi 2019-07-12 21:41:40.545 error Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`). host.ioBroker-Pi 2019-07-12 21:41:40.544 error Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing host.ioBroker-Pi 2019-07-12 21:41:40.544 error Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires host.ioBroker-Pi 2019-07-12 21:41:40.544 error Caught by controller[0]: was compiled against a different Node.js version using host.ioBroker-Pi 2019-07-12 21:41:40.544 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node' host.ioBroker-Pi 2019-07-12 21:41:40.543 error Caught by controller[0]: ^ host.ioBroker-Pi 2019-07-12 21:41:40.543 error Caught by controller[0]: throw e; host.ioBroker-Pi 2019-07-12 21:41:40.542 error Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:121
Instance ist rot und wenn ich es neu starten will bekomme ich :"zugriff fehler"
Wollte den Zigbee Adapter neu aufsetzen aber, der Adapter lässt sich nicht mehr löschen und auch der Instance lässt sich nicht löschen
@marcuskl
Hängt von der Version des Tasters ab. Es gibt soweit ich weiß 3 Versionen und nicht alle unterstützen leider die doppel click usw.
Ist aber auch leider jedes mal ein Glücksspiel welchen man bekommt.
Man sieht es im iobrocker als was er eingebunden wurde -
@Siegfried sagte in [Aufruf] ZigBee CC253x Adapter Version 0.11.x:
@marcuskl
Man sieht es im iobrocker als was er eingebunden wurdeOk in Ordnung, danke.
Hi.
Ist es möglich, die neue Adapterversion 0.11.2 mit einem CC2531 Stick der mit einer Firmware aus 11/2018 geflasht ist (Versionsnummer kann ich nirgends finden) zu betreiben oder kommt es da zu Problemen?Ich möchte nicht nochmal alle meine Zigbee Komponenten (mittlerweile über 40) neu pairen aber gern ein neues Gerät (GLEDOPTO GL-C-008) integrieren, was in meiner installierten Adapterversion 0.8.2.a noch nicht unterstützt wird.
Wenn ja, kann ich ein direktes Update auf die neueste 0.11.2 machen oder muss ich einen/mehrere Zwischenschritte machen.
@RichieXX
Ich sehe keinen Grund dafuer das das nicht geht.A.
@RichieXX ich habe genau das gemacht und bei mir läuft alles nach wie vor
Was man bei sowas aber immer machen sollte - ein BACKUP. Entweder über den Backup Adapter oder ein Backup der VM (wenn du zB Proxmox nutzt).
VG ThorstenHINWEIS: nicht an den Einstellungen im Adapter spielen
Backup geht suboptimal, da das ein Sub- eines Multihosts auf einem Raspi ist. Habe in aller größten Not ein Image der SSD, was jede Nacht geschrieben wird. Meine Hauptinstanz sichere ich täglich als VM mit Snapshot und allem Schnickschnack (auf einem QNAP NAS), da wäre das kein Problem.
Na ich werd mich das Wochenende mal ranwagen. Danke für die Antworten.
@Kueppert sagte in [Aufruf] ZigBee CC253x Adapter Version 0.11.x:
Wie meinst du das? Wärend des Updates?
@RichieXX ne,generell... Da war was mit dem Schlüssel da. Wenn man da dran rum spielt, kann es sein, dass alle Geräte neu anlernen musst
Ahh. Ja da war was. Das schau ich mir nochmal an bzw. spiel erstmal nicht dran rum. Danke für den Hinweis.
EDIT:
Bei mir ist die PANID vierstellig (6754). Ist das ein Problem? -
Update hat geklappt.
Ich schaffe es trotzdem nicht, den GL-C-008 zu pairen. Hat jemande Erfahrungen mit dem Teil? Ich schaffe es nicht ihn zum Blinken zu bekommen, wie in diesem Manual beschrieben: https://usermanual.wiki/GLEDOPTO/GL-C-008
@RichieXX
Also ich hab mehrere GLEDOPTO Geräte im Einsatz und noch nie Probleme mit dem Reset gehabt. Wie machst du das "Ausschalten" denn? Ziehst du das Netzteil aus der Steckdose und steckst es wieder rein? Falls ja, könnte das das Problem sein, denn innerhalb der 2s baut sich die Spannung von dem Netzteil nicht komplett ab. Direkt am Controller abklemmen und die "Aus An Aus An..." Prozedur durchführen.
Markus -
Hab mir extra vor dem Controller einen Schalter gesetzt um die Prozedur möglichst genau nach Plan abzuarbeiten, weil mir selbst das Abziehen des Netzteilsteckers zu "ungenau" erschien. Nichts geht.
Der Controller ist defekt. Ein neuer tut wie er soll. Danke fürs Mitdenken.
Nach Update von 0.8.2 auf die 0.11.2 gab es keinerlei Probleme, ich habe sogar inzwischen weitere Geräte angelernt. Heute habe ich bemerkt, dass unter Geräte nichts mehr gelistet wird, weil ich eines löschen wollte. Der Adapter ist grün und die Geräte funktionieren weiterhin einwandfrei (liefern Daten). Im Log kommt folgender Fehler:
zigbee.0 2019-08-13 17:21:05.753 error getDevices error: {}
Neustart Adapter und iobroker bringt nichts.
@RichieXX
Du scheinst ein Gerät in der Liste zu haben das bestimmte Eigenschaften im internen Speicher nicht sauber gefüllt hat - deswegen der Fehler. Dem nachzugehen ist nicht trivial - es sind aber trotzdem alle Geräte vorhanden und auch - der Fehler betrifft “nur” die Darstellung im Adapter.Nach meinem Urlaub würde ich anbieten das per teamviewer (o.ä) mit Dir durchzugehen das wir den Fehler weg bekommen.
A.
@Asgothian
Der Fehler ist nach dem Pairing des GL-C-008 aufgetreten, aber nicht direkt. Ich habe danach mindestens einmal die Geräteliste geöffnet. Davor habe ich aber auch das Update von der 0.8.2 auf die 0.11.2 gemacht. Gerne nehme ich deine Hilfe an. Melde dich wenn es dir passt. -
@RichieXX das hab ich schon mal bei irgendjemanden gesehen.. nach neustart war aber wieder gut
Habe alles schon neu gestartet.
