    4. Adapter "smartmeter"
      martinschm @apollon77 last edited by
      @apollon77
      Hab das log mal runter geladen und eine Zeile raus kopiert:
      2019-08-05 00:02:10.023 - info: smartmeter.0 Error: Error while parsing SML message: Error: Unknown TL-Field 0x53 for OctetString [Offset: 312]!: Message: 1b1b1b1b010101017607000c0608272f620062007263010176010107000c0c5b62650b06454d480104456c2a67010163167b007607000c06082730620062007263070177010b06454d480104456c2a67070100620a7f7f726201650c5b56067a770701014702037f0101010104454d4801770701000000097f010101010b06454d480104456c2a6701770701000108007f6401010201621e527f56000620433201770701000208007f6401010201621e527f56002619563501770701000108017f0101621e527f56000620433201770701000208017f0101621e527f56002619563501770701000108027f0101621e527f56000000000001770701000208027f0101621e527f56000000000001770701001007007f0101621b527f550000067d01770701014702057f01726201650c5b56060101030247532b6b15594c1e52206a0c77054c201b0068176a5b652a347b105e74106d4f37794e306e6b73130d245a6c32660818010101637459007607000c0608273362006200726302017101632c2e00001b1b1b1b1a014539
      2019-08-05 00:02:10.024 - warn: smartmeter.0 Error while parsing SML message: Error: Unknown TL-Field 0x53 for OctetString [Offset: 312]!: Message: 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
      2019-08-05 00:02:10.025 - info: smartmeter.0 ERROR CLOSING SERIALPORT
      Das Kabel ist knapp 1m lang und hängt direkt am Raspberry. Ich hab einen Volkszähler Lesekopf mit RS232 Anschluß. Den hab ich über einen Konverter auf USB umgemodelt.
      Unter Windows hab ich mit hterm gecheckt ob überhaupt etwas übermittelt wird. Was da genau kommt hab ich aber nicht gesehen.
      So sieht meine Konfig aus:
      Homoran apollon77 4 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @martinschm last edited by
        @martinschm sagte in Adapter "smartmeter":
        wenn der unter WIN funktioniert muss so eion Konverter unter Linux noch lange nicht funktionieren
          martinschm @Homoran last edited by
          @Homoran said in Adapter "smartmeter":
          Klar verstehe ich. Kann ich das irgendwie testen ?
          Ist Neuland für mich, daher taste ich mich da grade ran.
            Es scheint ja etwas zu kommen.
            Allerdings unverständliches.
            Stelle mal auf D0 um und sieh was dann im log steht
              ehz-iw8e2a5l0eq2p
              Nehme alles zurück!
              Der Zähler verfügt über 2 optische Datenschnittstellen, die in Anlehnung
              an die IEC 62056-21 ausgeführt sind.
              Auf der Vorderseite befindet sich eine unidirektionale Schnittstelle
              (INFO-Schnittstelle), die dem Endkunden zugänglich ist und per Konfiguration
              freigegeben wird.
              Auf der Rückseite befindet sich eine bidirektionale D0-Schnittstelle, die
              durch eine Betriebsplombe schützbar ist und dem MSB als Kommunikationsschnittstelle
              dient.
              Auf beiden Schnittstellen wird ein identischer Datensatz ausgegeben,
              der durch den MSB konfigurierbar ist.
              Als Kommunikationsprotokoll wird SML verwendet. Die Baudrate
              beträgt 9600 Baud fest. Die maximale Übertragungszeit eines Datentelegramms
              beträgt ca. 400 ms
              Laut Foto sind da die beiden optischen Schnittstellen direkt nebeneinander, einmal zum Programmieren, einmal zum auslesen (rechts)
              SML ist also korrekt - ist es auch die richtige LED?
              Habe auf die Schnelle jetzt nicht deinen Zähler gefunden. Nur den ehz-K nicht den eHZ-I - hat der überhaupt eine Datenschnittstelle oder nur eine Impuslschnittstelle?
                apollon77 @martinschm last edited by
                @martinschm Du hast doch schon auf GitHub ein Issue angelegt oder ?! Dann jetzt bitte Geduld bis ich Zeit finde mir das anzusehen. Wenn es immer das gleiche und der gleiche Offset ist dann muss ich ganz tief in die Message und die SML-Specs reinschauen was da wieder abgeht.
                Also geduld bitte. Es sieht generell alles ok aus.
                  @martinschm Ok, hier stimmt irgendwas denke ich beim lesen nicht. Die Message ist die ersten grob 310 bytes ok und dann komisch/kaputt. Ist der "Offset" mit dem Fehler immer der gleiche? Schau mal ob der Kopf korrekt sitzt. Es ist schon ungewöhnlich das es generell klappt von daher kann es gut auch eine Kommunikationsstörung sein. Versuchs mal mit nem aktiven USB Hub anzuschliessen.
                    @martinschm Achja zur onfig nich: SML is "read only". Da brauchst Du nichts bidirektionales. Versuch mal, nicht das sich senden und lesen irgendwie in die Quere kommen
                      ehz-iw8e2a5l0eq2p
                      Nehme alles zurück!
                      Hi, so sieht mein Zähler aus. Oben rechts hab ich den Lesekopf drauf
                      Dort hab ich auch die Pin eingeleuchtet und danach den Lesekopf drauf platziert.
                        @apollon77 said in Adapter "smartmeter":
                        Nein bisher noch nicht. Würde ich machen wenn klar ist, das es ein Bug ist. Bin bisher noch von einem Fehler in meinem Setup ausgegangen.
                          Ich meine es war immer der gleiche Offset. Muss ich aber heute abend mal überprüfen. Komme von unterwegs nicht auf den Raspberry.
                          Ist der aktive USB Hub für mehr Versorgungsspannung oder hat es damit eine besondere Bewandtnis ?
                          Hab aktuell keinen da, könnte es aber mal mit einem stärkeren Netzteil probieren. Glaube aktuell sind es 2A bei einem Rasberry3. Da hängt außer dem Lesekopf nichts weiter dran.
                          Probiere ich heute abend auch mal aus.
                            @martinschm Ja mehr Spannung, damit stärkere Signale und damit weniger Chance auf Übertragungsfehler.
                              ich probiere es heute mal mit einem anderen Netzteil. Würde es aber nicht Sinn machen, das der Fehler variiert anstatt immer gleich zu sein ?
                              Es wäre doch extremer Zufall wenn die Spannung immer an der gleichen Stelle zu gering wäre und dadurch den identischen Fehler produziert.
                                Ich vermelde (Teil)Erfolg 🙂
                                Hab den Lesekopf nochmal anders platziert und dann den Adapter aktiviert. Es kam wieder die gleiche Fehlermeldung.
                                Dann hab ich noch von bidirektional auf "nur lesend" umgestellt und es klappt.
                                smartmeter.0	2019-08-06 20:31:44.508	warn	No or too long answer from Serial Device after last request.
                                smartmeter.0	2019-08-06 20:31:44.506	info	Error: No or too long answer from Serial Device after last request.
                                smartmeter.0	2019-08-06 19:31:42.281	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v8.16.0
                                host.ubntcontrol	2019-08-06 19:31:37.312	info	instance system.adapter.smartmeter.0 started with pid 30461
                                host.ubntcontrol	2019-08-06 19:31:35.363	info	instance system.adapter.smartmeter.0 terminated with code 0 (OK)
                                host.ubntcontrol	2019-08-06 19:31:34.766	info	stopInstance system.adapter.smartmeter.0 killing pid 30063
                                host.ubntcontrol	2019-08-06 19:31:34.765	info	stopInstance system.adapter.smartmeter.0
                                smartmeter.0	2019-08-06 19:31:34.771	info	ERROR CLOSING SERIALPORT
                                host.ubntcontrol	2019-08-06 19:31:34.764	info	object change system.adapter.smartmeter.0
                                smartmeter.0	2019-08-06 19:31:04.227	info	Received 10 values, 3 updated
                                smartmeter.0	2019-08-06 19:30:02.171	warn	No or too long answer from Serial Device after last request.
                                smartmeter.0	2019-08-06 19:30:02.169	info	Error: No or too long answer from Serial Device after last request.
                                smartmeter.0	2019-08-06 19:29:00.144	info	Received 10 values, 10 updated
                                smartmeter.0	2019-08-06 19:28:58.739	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v8.16.0
                                host.ubntcontrol	2019-08-06 19:28:55.415	info	instance system.adapter.smartmeter.0 started with pid 30063
                                host.ubntcontrol	2019-08-06 19:28:53.448	info	instance system.adapter.smartmeter.0 terminated with code 0 (OK)
                                Hab die Abfragefrequenz anfänglich auf 60s gesetzt und dann wieder auf 300s rauf. Mal schauen wie stabil es jetzt läuft.
                                  martinschm @martinschm last edited by
                                  So, scheint jetzt stabil zu laufen
                                  smartmeter.0	2019-08-06 20:46:48.695	info	Received 10 values, 3 updated
                                  smartmeter.0	2019-08-06 20:41:46.993	info	Received 10 values, 3 updated
                                  smartmeter.0	2019-08-06 20:36:45.899	info	Received 10 values, 10 updated
                                  Jetzt muß ich den iobroker nur noch als Slave einbinden und meinem anderen unter ordnen.
                                    Die Pin müsste in die linke der zwei LEDs gehen, die Daten kommen aus der rechten Led.
                                    Da musst du exakt platzieren
                                      @martinschm Super
                                        @apollon77
                                        Musste den Raspi gestern kurz vom Netz nehmen, weil das Unwetter uns Wasser in den Keller gedrückt hat. Seit heute morgen ist er wieder online. Es scheint meistens zu klappen, gelegentlich kommt ein Fehler.
                                        Könnte das auch am Arbeitsspeicher liegen ?
                                        Auf dem gleichen Raspi läuft auch der uniFi Controller.
                                        smartmeter.0	2019-08-07 19:31:33.425	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 19:26:32.798	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 19:21:32.072	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 19:16:31.464	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 19:11:30.170	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 19:06:29.673	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 19:06:29.672	info	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 19:01:27.653	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 18:56:26.702	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 18:51:25.268	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 18:46:23.510	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 18:41:22.787	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 18:36:21.692	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 18:31:20.776	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 18:26:19.795	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 18:26:19.795	info	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 18:21:17.774	info	Received 10 values, 5 updated
                                        smartmeter.0	2019-08-07 18:16:16.219	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 18:16:16.218	info	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 18:11:14.199	info	Received 10 values, 5 updated
                                        smartmeter.0	2019-08-07 18:06:13.171	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 18:01:11.818	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 17:56:11.064	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 17:51:10.072	info	Received 10 values, 5 updated
                                        smartmeter.0	2019-08-07 17:46:09.611	info	Received 10 values, 5 updated
                                        smartmeter.0	2019-08-07 17:41:08.898	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 17:36:08.307	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 17:31:07.783	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 17:31:07.782	info	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 17:26:05.765	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 17:21:04.484	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 17:16:02.695	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 17:11:01.847	info	Received 10 values, 5 updated
                                        smartmeter.0	2019-08-07 17:06:00.164	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 17:00:59.616	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 16:55:58.212	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 16:50:57.144	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 16:45:56.214	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 16:40:54.454	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 16:35:53.427	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 16:30:52.129	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 16:25:51.093	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 16:25:51.092	info	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 16:20:49.073	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 16:15:48.466	info	Received 10 values, 5 updated
                                        smartmeter.0	2019-08-07 16:10:47.609	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 16:10:47.608	info	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 16:05:45.571	info	Received 10 values, 5 updated
                                        smartmeter.0	2019-08-07 16:00:44.803	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 16:00:44.801	info	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 15:55:42.784	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 15:50:41.653	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 15:45:40.087	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 15:40:39.621	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 15:35:37.705	info	Received 10 values, 5 updated
                                        smartmeter.0	2019-08-07 15:30:36.214	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 15:30:36.213	info	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 15:25:34.192	info	Received 10 values, 3 updated
                                        smartmeter.0	2019-08-07 15:20:33.477	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 15:20:33.476	info	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-08-07 15:15:31.454	info	Received 10 values, 3 updated
                                          setz mal den Timeout höher ... auf was steht er?
                                            martinschm @apollon77 last edited by martinschm
                                            @apollon77 aktuell 300 Sekunden, der default.
                                            Kann es auch an der seriellen Antwort Wartezeit liegen. Die steht auf 2s. Hab ich meine ich nicht geändert, im Infotext steht default wäre 120s.
                                            3625
                                            2286831
