    4. Asus Tinker
    Asus Tinker
    • AxelF1977
      AxelF1977 last edited by
      Das Log gibt folgendes her:
      iobroker	2018-03-27 19:39:38.518	info	npm ERR! tar.unp
      iobroker	2018-03-27 19:39:28.855	info	WARN deprecated node-uuid@1.4.8: Use uuid module instead
      iobroker	2018-03-27 19:39:28.850	info	npm
      iobroker	2018-03-27 19:39:19.691	info	npm install iobroker.ical --production --prefix "/opt/iobroker" (System call)
      iobroker	2018-03-27 19:39:18.151	info	install ical
      host.ioBroker-Tinker	2018-03-27 19:39:18.150	warn	startInstance cannot find adapter "ical". Try to install it... 1 attempt
      iobroker	2018-03-27 19:39:17.150	info	exit 0
      iobroker	2018-03-27 19:39:17.066	info	upload [0] lightify.admin /opt/iobroker/node_modules/iobroker.lightify/admin/index.html index.html text/html
      iobroker	2018-03-27 19:39:17.001	info	upload [1] lightify.admin /opt/iobroker/node_modules/iobroker.lightify/admin/lightify.png lightify.png image/png
      iobroker	2018-03-27 19:39:16.923	info	upload [2] lightify.admin /opt/iobroker/node_modules/iobroker.lightify/admin/words.js words.js application/javascript
      iobroker	2018-03-27 19:39:16.896	info	got /opt/iobroker/node_modules/iobroker.lightify/admin
      iobroker	2018-03-27 19:39:16.871	info	host.ioBroker-Tinker object system.adapter.lightify created
      iobroker	2018-03-27 19:38:58.704	info	npm install iobroker.lightify --production --prefix "/opt/iobroker" (System call)
      iobroker	2018-03-27 19:38:57.014	info	install lightify
      host.ioBroker-Tinker	2018-03-27 19:38:57.013	warn	startInstance cannot find adapter "lightify". Try to install it... 1 attempt
      iobroker	2018-03-27 19:38:56.013	info	exit 0
      iobroker	2018-03-27 19:38:55.933	info	upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html index.html text/html
      iobroker	2018-03-27 19:38:55.871	info	upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
      iobroker	2018-03-27 19:38:55.797	info	upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
      iobroker	2018-03-27 19:38:55.771	info	got /opt/iobroker/node_modules/iobroker.ping/admin
      iobroker	2018-03-27 19:38:55.750	info	host.ioBroker-Tinker object system.adapter.ping created
      admin.0	2018-03-27 19:38:46.988	info	system.adapter.admin.0: logging true
      admin.0	2018-03-27 19:38:46.982	info	Change log subscriber state: true
      admin.0	2018-03-27 19:38:42.556	info	Repository received successfully.
      host.ioBroker-Tinker	2018-03-27 19:38:39.195	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      admin.0	2018-03-27 19:38:39.011	info	Request actual repository...
      admin.0	2018-03-27 19:38:38.814	info	Use link "http://localhost:8081" to configure.
      admin.0	2018-03-27 19:38:38.813	info	http server listening on port 8081
      admin.0	2018-03-27 19:38:38.665	info	received all objects
      admin.0	2018-03-27 19:38:37.578	info	received all states
      admin.0	2018-03-27 19:38:35.864	info	requesting all objects
      admin.0	2018-03-27 19:38:35.862	info	requesting all states
      admin.0	2018-03-27 19:38:35.795	info	starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v6.12.2
      iobroker	2018-03-27 19:38:35.475	info	npm install iobroker.ping --production --prefix "/opt/iobroker" (System call)
      host.ioBroker-Tinker	2018-03-27 19:38:33.849	info	instance system.adapter.admin.0 started with pid 2728
      iobroker	2018-03-27 19:38:33.797	info	install ping
      host.ioBroker-Tinker	2018-03-27 19:38:33.797	warn	startInstance cannot find adapter "ping". Try to install it... 1 attempt
      host.ioBroker-Tinker	2018-03-27 19:38:33.792	info	starting 1 instance
      host.ioBroker-Tinker	2018-03-27 19:38:33.761	info	36 instances found
      Delete	2018-03-27 19:38:33.731	info	host system.host.ioBroker-Tinker
      host.ioBroker-Tinker	2018-03-27 19:38:33.694	info	InMemoryDB connected
      host.ioBroker-Tinker	2018-03-27 19:38:33.679	info	inMem-objects listening on port 9001
      host.ioBroker-Tinker	2018-03-27 19:38:33.303	info	inMem-states listening on port 9000
      host.ioBroker-Tinker	2018-03-27 19:38:33.224	info	ip addresses: 192.168.178.46 fe80::d842:eaff:fe3c:1ffa
      host.ioBroker-Tinker	2018-03-27 19:38:33.223	info	hostname: ioBroker-Tinker, node: v6.12.2
      host.ioBroker-Tinker	2018-03-27 19:38:33.221	info	Copyright (c) 2014-2017 bluefox, 2014 hobbyquaker
      host.ioBroker-Tinker	2018-03-27 19:38:33.210	info	iobroker.js-controller version 1.2.3 js-controller starting
      host.ioBroker-Tinker	2018-03-27 19:16:10.634	info	terminated
      host.ioBroker-Tinker	2018-03-27 19:16:10.461	info	All instances are stopped.
      host.ioBroker-Tinker	2018-03-27 19:16:10.461	info	instance system.adapter.history.0 terminated with code 0 (OK)
      host.ioBroker-Tinker	2018-03-27 19:16:10.459	info	All instances are stopped.
      host.ioBroker-Tinker	2018-03-27 19:16:10.459	info	instance system.adapter.admin.0 terminated with code 0 (OK)
      host.ioBroker-Tinker	2018-03-27 19:16:10.458	info	All instances are stopped.
      host.ioBroker-Tinker	2018-03-27 19:16:10.457	info	instance system.adapter.rpi2.0 terminated with code 0 (OK)
      host.ioBroker-Tinker	2018-03-27 19:16:10.456	info	All instances are stopped.
      host.ioBroker-Tinker	2018-03-27 19:16:10.456	info	instance system.adapter.javascript.0 terminated with code 0 (OK)
      host.ioBroker-Tinker	2018-03-27 19:16:10.454	info	All instances are stopped.
      host.ioBroker-Tinker	2018-03-27 19:16:10.453	info	instance system.adapter.web.0 terminated with code 0 (OK)
      web.0	2018-03-27 19:16:10.411	info	terminating http server on port 8082
      host.ioBroker-Tinker	2018-03-27 19:16:10.419	info	stopInstance system.adapter.rpi2.0 killing pid 1688
      host.ioBroker-Tinker	2018-03-27 19:16:10.419	info	stopInstance system.adapter.vis-justgage.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.418	info	stopInstance system.adapter.vis-metro.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.418	info	stopInstance system.adapter.vis-fancyswitch.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.417	info	stopInstance system.adapter.vis-timeandweather.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.417	info	stopInstance system.adapter.vis-bars.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.417	info	stopInstance system.adapter.vis-hqwidgets.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.416	info	stopInstance system.adapter.vis.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.416	info	stopInstance system.adapter.mobile.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.413	info	stopInstance system.adapter.javascript.0 killing pid 1349
      host.ioBroker-Tinker	2018-03-27 19:16:10.413	warn	stopInstance system.adapter.hm-rega.0 not running
      host.ioBroker-Tinker	2018-03-27 19:16:10.412	info	stopInstance system.adapter.hm-rega.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.412	warn	stopInstance system.adapter.hm-rpc.0 not running
      host.ioBroker-Tinker	2018-03-27 19:16:10.411	info	stopInstance system.adapter.hm-rpc.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.410	info	stopInstance system.adapter.history.0 killing pid 1759
      host.ioBroker-Tinker	2018-03-27 19:16:10.409	info	stopInstance system.adapter.history.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.409	info	stopInstance system.adapter.web.0 killing pid 1163
      host.ioBroker-Tinker	2018-03-27 19:16:10.408	warn	stopInstance system.adapter.cloud.0 not running
      host.ioBroker-Tinker	2018-03-27 19:16:10.408	info	stopInstance system.adapter.cloud.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.408	warn	stopInstance system.adapter.discovery.0 not running
      host.ioBroker-Tinker	2018-03-27 19:16:10.407	info	stopInstance system.adapter.discovery.0
      host.ioBroker-Tinker	2018-03-27 19:16:10.406	info	stopInstance system.adapter.admin.0 killing pid 1749
      host.ioBroker-Tinker	2018-03-27 19:16:10.405	info	stopInstance system.adapter.admin.0
      rpi2.0	2018-03-27 19:16:10.425	info	terminating
      admin.0	2018-03-27 19:16:10.423	info	terminating
      history.0	2018-03-27 19:16:10.417	info	terminating
      javascript.0	2018-03-27 19:16:10.419	info	terminating
      admin.0	2018-03-27 19:16:10.410	info	terminating http server on port 8081
      host.ioBroker-Tinker	2018-03-27 19:16:10.398	info	received SIGTERM
      history.0	2018-03-27 19:13:57.751	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.history, node: v6.12.2
      history.0	2018-03-27 19:13:57.701	info	States connected to redis: 127.0.0.1:6379
      host.ioBroker-Tinker	2018-03-27 19:13:56.775	info	instance system.adapter.history.0 started with pid 1759
      admin.0	2018-03-27 19:13:54.425	info	Repository received successfully.
      host.ioBroker-Tinker	2018-03-27 19:13:53.224	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      admin.0	2018-03-27 19:13:53.137	info	Request actual repository...
      admin.0	2018-03-27 19:13:52.999	info	Use link "http://localhost:8081" to configure.
      admin.0	2018-03-27 19:13:52.999	info	http server listening on port 8081
      admin.0	2018-03-27 19:13:52.885	info	received all objects
      admin.0	2018-03-27 19:13:52.579	info	received all states
      admin.0	2018-03-27 19:13:52.231	info	requesting all objects
      admin.0	2018-03-27 19:13:52.229	info	requesting all states
      admin.0	2018-03-27 19:13:52.196	info	starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v6.12.2
      admin.0	2018-03-27 19:13:52.141	info	States connected to redis: 127.0.0.1:6379
      host.ioBroker-Tinker	2018-03-27 19:13:50.128	info	instance system.adapter.admin.0 started with pid 1749
      host.ioBroker-Tinker	2018-03-27 19:13:39.411	info	instance system.adapter.vis.0 terminated while should be started once
      rpi2.0	2018-03-27 19:13:38.974	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.12.2
      rpi2.0	2018-03-27 19:13:38.910	info	States connected to redis: 127.0.0.1:6379
      vis.0	2018-03-27 19:13:35.253	error	No license found for vis. Please get one on https://iobroker.net !
      host.ioBroker-Tinker	2018-03-27 19:13:37.606	info	instance system.adapter.rpi2.0 started with pid 1688
      vis.0	2018-03-27 19:13:35.242	info	starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.12.2
      vis.0	2018-03-27 19:13:35.195	info	States connected to redis: 127.0.0.1:6379
      javascript.0	2018-03-27 19:13:32.813	info	received all objects
      javascript.0	2018-03-27 19:13:32.534	info	received all states
      javascript.0	2018-03-27 19:13:32.291	info	requesting all objects
      javascript.0	2018-03-27 19:13:32.278	info	requesting all states
      javascript.0	2018-03-27 19:13:32.268	info	starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.12.2
        @AxelF1977:
        cannot find adapter "ping". Try to install it… 1 attempt `
        Das hatte ich gesucht.
        Das muss für alle Instanzen noch durchlaufen werden, dann sind sie erst wirklich "da".
        Rainer
        • AxelF1977
          @Homoran:
          @AxelF1977:
          Rainer `
          Passiert das automatisch? Denn seit gut 1.5 Stunden passiert da nichts mehr, oder muss ich per Konsole was "anschubsen"?
            nein, das läuft.
            Dauert etwa 2 Stunden.
            Du kannst ja ab und zu deine Instanzen aufrufen und mit F5 aktualisieren, dann siehst du wie die Icons hinzukommen.
            Dann kann man auch die Adapterkonfigurationen aufrufen, überprüfen (spätestens beim HM-rpc muss die neue IP eingetragen werden) und die Adapter starten.
            Rainer
            • AxelF1977
              @Homoran:
              nein, das läuft.
              Rainer `
              Danke für Deine ausführliche Hilfe. Die Objekte sind nun schon nicht mehr hellgrau, sondern normal schwarz (also die Schrift) Starten die Instanzen später automatisch? Bzw. was sind die Schritte die ich noch machen muss, um es abzuschließen?
              Aktuell läuft es auch neben dem produktiven Raspi, daher kann der sich richtig auskäsen der Tinker.
                @AxelF1977:
                Starten die Instanzen später automatisch? `
                nein,
                @Homoran:
                Dann … die Adapter starten. `
                Rainer
                • AxelF1977
                  Sorry für die vielen Fragen :shock:
                  Alle Instanzen manuel starten ist ja kein Problem. Aber wie sieht es mit den Versionen der Adapter aus. ioBroker selber ist ja nach Stand jetzt bei 2.0.9. Die Updates der Adapter müssen auch manuel gestartet werden?
                  Kurz um, was muss ich alles noch manuel machen, und wann sehe ich das ich damit beginnen kann?
                  • AxelF1977
                    Das Tinker Board hat gerade kurz den Strom verloren, jetzt komme ich per Putty nicht mehr an die Konsole :oops:
                    > Network error, Connection refused
                      Jetzt ist es das volle Programm :evil:
                      @AxelF1977:
                      Aber wie sieht es mit den Versionen der Adapter aus. ioBroker selber ist ja nach Stand jetzt bei 2.0.9. Die Updates der Adapter müssen auch manuel gestartet werden? `
                      die eben mit 2 Stunden durchgelaufenen Installationen haben die neuesten Versionen installiert, die für das von dir gewählte repository (ich nehme an default = latest) freigegeben sind.
                      Infos dazu bitte http://www.iobroker.net/docu/?lang=de nachlesen.
                      @AxelF1977:
                      Das Tinker Board hat gerade kurz den Strom verloren, jetzt komme ich per Putty nicht mehr an die Konsole `
                      Das Problem ist relativ einfach erklärt:
                      Worst case: das Tinkerboard wqar gerade dabei Daten zu schreiben als der Strom ausfiel. dadurch sind die Daten auf der SD-Karte defekt.
                      Das ist kein spezifisches Problem bei irgendwelchen Einplatinenrechnern, das kann auch bei PCs passieren.
                      @AxelF1977:
                      klingt entweder nach einem Boot-Hänger oder eben defekten Bootsektor.
                      Ich (persönlich) würde in der Annahme 'es kann nur besser werden' noch einmal den Strom abziehen, etwas warten und erneut verbinden.
                      Schlimmstenfalls ist die Installation wie oben beschrieben defekt und muss eh neu gemacht werden.
                      Das ist mir übrigens vor 3 Tagen auch mit 2 von 8 Installationen passiert, als die Sicherung herausflog.
                      Gestern habe ich mir 2 USV gekauft 😉
                      Rainer
                      • AxelF1977
                        Hallo Rainer,
                        ich befürchte fast, es hängt an anderer Stelle. Das Netzteil (Ich hoffe mein 5V 3A kommt heute)
                        Da ich davon ausgehe das die Installation zerschpossen ist, habe ich heute morgen eine 2. SD fertig gemacht. Alles aufgespielt. Diesmal aber zuerst apt-get update && apt-get upgrade durchlaufen lassen.
                        Als alles fertig war
                        Sudo reboot, und siehe da, der Tinker blieb stumm. Ich vermute daher dass das 5V 2,5V Raspi Netzteil nicht ausreicht (Liest man ja immer mal wieder).
                        Ich werde es heute Abend erneut versuchen.
                        Danke erstmal so weit für die Hilfe
                          Ja,
                          das Tinkerboard braucht ordentliche Stromversorgung.
                          @[url=https://forum.iobroker.net/viewtopic.php?f=34&t=5260&start=20#p59785:
                          ~~anderer Thread"]~~Am Anfang passierte nichts!
                          rote LED ging kurz an - wieder aus. Das wars.
                          Netzadapter gewechselt (auch 2,5A!) - Kabel gewechselt immer das gleiche.
                          Mit einem neuen 40W 5xUSB Netzteil für das Board alleine lief es dann `
                          Rainer
                          • AxelF1977
                            Tja, auch mit einen https://www.gravis.de/Zubehoer/Stromversorgung/Adapter-und-Kabel/Networx-Premium-USB-Netzteil-Aluminium-2x-USB-3-1A-Smart-IC-spacegrau-132215.htmll passiert nicht viel (schon 5 USB Kabel probiert). Mit der SD von gestern, unterbrochene Installation, bootet er, ist dann in der Fritzbox sichtbar, aber über Putty trotzdem nicht erreichbar. Mit der SD von heute Morgen, wo ich das Image aufgespielt habe und nur ein apt-get update && apt-get upgrade gemacht habe, verweigert er ganz den Dienst.
                            Zum Haare raufen. Ich mache jetzt die SD von heute morgen platt und setze das Image nochmal neu auf
                            Was mir nach dem Einlegen der SD bei Windowes aufgefallen ist, ist kann jetzt auf die kleine Partition zugreifen und es liegen alle Ordner drin (wie opt). Das ist doch sonst umgedreht, hier scheint was bei apt-get update && apt-get upgrade schief gelaufen zu sein
                            Eine frisch installierte SD Karte eingelegt, gebootet, gingt sofort. Als erstes ein sudo reboot gemacht, und er startete nicht mehr. Erst nach ziehen des Netzsteckers ging wieder was. Hilft das den Fehler einzugrenzen?
                              Habe keinen Tinker, aber was mir beim Orange Pi Plus 2e in fraglichen Sitationen geholfen hat: Direkt an die serielle Schnittstelle mit einem serial -> USB Wandler, z.B. CH340G umschaltbar 3.3 / 5V. Dann den Bootprozess mit einem anderen Rechner, z.B. mit Termite oder einem anderen Terminalprogramm mitloggen. Dann sieht man, wie weit er kommt und wo er hängt.
                              Und ich löte die Versorgung generell an. In kritischen Fällen kommt halt noch ein zwei 1000µF Low ESR dazu. Du kannst die Spannungslage aber auch mit so einem USB Voltmeter messen. Einfach in eine freie USB Buchse des Tinker (nicht zwischen Netzteil und Tinke) stecken, dann zeigt das die Spannung am Tinkerboard an. Bei meinem OPi mit gelöteten Anschlüssen ist die bei 5.05V, verwende ich den Barrel Stecker fehlen gleich ein paar hundert mV. Bei micro USB wirds kaum besser sein. Aber erst mal in die serielle reinhorchen, vielleicht bleibt er ja an einer nachvollziehbaren Stelle stecken.
                              Mittlerweile bin ich nach dem letzten Kernel-Update von armbian so weit, daß ich ein gebrauchtes Win 10 Notebook, i5, 8GB für ca. 200EUR mit 2 Jahren Garantie für wirtschaftlicher halte. Wenn man die eigene Zeit nicht unter Hobby, Forschung, Zulernen, Herausforderung, Gehirnjogging verbucht, sind diese embedded Systeme über die Zeit gerechnet unwirtschaftlich.
                                Hallo klassisch,
                                verzeihe mir, dass ich dir da widerspreche:
                                @klassisch:
                                Mittlerweile bin ich nach dem letzten Kernel-Update von armbian so weit, daß ich ein gebrauchtes Win 10 Notebook, i5, 8GB für ca. 200EUR mit 2 Jahren Garantie für wirtschaftlicher halte. `
                                Ich habe bisher überhaupt keine Probleme mit meinen Installationen.
                                Dass bei einem Stromausfall Das Dateisystem zerstört werden kann, weil sich das System gerade im Schreibzugriff befand und dieser nicht abgeschlossen werden konnte mal außen vorgelassen. Das kann nicht nur bei einer SD, sondern auch bei einem PC vorkommen.
                                Andere Probleme hatte ich noch nie!
                                Gut, das Notebook bringt seine eigene USV mit und ich habe auch im Medion Fabrikverkauf ein neues 14" Notebook mit Windows und Pentium N3xxx bereits für 222€ erstanden (inzwischen gepimpt mit mehr RAM und SSD, ist aber mein "normales" Notebook).
                                Rainer
                                • AxelF1977
                                  @klassisch:
                                  Habe keinen Tinker, aber was mir beim Orange Pi Plus 2e in fraglichen Sitationen geholfen hat: Direkt an die serielle Schnittstelle mit einem serial -> USB Wandler, z.B. CH340G umschaltbar 3.3 / 5V. Dann den Bootprozess mit einem anderen Rechner, z.B. mit Termite oder einem anderen `
                                  Uff, Dein Beitrag überfordert mich gerade. ABER, ich habe gerade eine Besserung. Ich habe die ganze Installation von der SD Karte auf einen USB Stick verschoben (per nand-sata-install). Danach war ein reboot kein Problem. Ich habe dann ein apt-get update && apt-get upgrad ausgeführt. Nach dem Abschluß ein reboot. Er startete nicht. Stecker gezogen, 10sek. gewartet, er ist wieder gestartet. Das ist mehr als die letzten 2 Tage.
                                  Ich merke auch die höhere Geschwindigkeit des USB Sticks, aller läuft schneller ab
                                  Dann mache ich mich mal ran ioBroker zu installieren, bzw. das Backup einzuspielen.
                                  Ich werde berichten. Bin gerade aber guter Dinge
                                    @AxelF1977:
                                    Ich merke auch die höhere Geschwindigkeit des USB Sticks, aller läuft schneller ab `
                                    Da das Tinkerboard aber nur USB 2.0 Anschlüsse hat deutet das entweder auf ganz billige und/oder defekte SD-Karten.
                                    Rainer
                                    • AxelF1977
                                      @Homoran:
                                      @AxelF1977:
                                      Rainer `
                                      Gelten http://www.mediamarkt.de/de/product/_samsung-evo-plus-2254436.html?uympq=vpqr&rbtc=%7C%7C%7C%7Cp%7C%7C&gclid=Cj0KCQjw-uzVBRDkARIsALkZAdn1EZgedtptOH7vMG0hE6wwkeoqEyDCdz75Z3UvFW4k0GsJVWqxUjMaAqCiEALw_wcB&gclsrc=aw.ds&dclid=CIPAyNzmj9oCFdU64AodM_EB_g als billig? Defekt, keine Ahnung
                                        Eigentlich nicht, es gibt aber auch Fakes.
                                        Das Tinkerboard hat einen der schnellsten Cardreader, etwa 2-3x so schnell wie andere SBC.
                                        Ich habe die Datenrate gerade nicht im Kopf, aber ein USB 2.0 kann nur 12MBit
                                        Rainer
                                        • AxelF1977
                                          @Homoran:
                                          Eigentlich nicht, es gibt aber auch Fakes. `
                                          hmm, die sind von Ebay, evtl. sind es fakes, aber das bekomme ich wohl nicht raus. Aber danke für den Hinweis. Zumindest habe ich jetzt keine Probleme mehr, er bootet anständig neu.
                                          ioBroker läuft jetzt im Browser und zieht hoffentlich alles richtig. Die Instanzen sind alle schon da, die Scripte auch, das hat keine 5 min gedauert.
                                          Du hattest geschrieben
                                          Bei beiden Installationen steht das selbe. Alsso doch alle updates manuel machen?
                                            Falscher Reiter!
                                            Das ist die liste aller repos, das was du nutzen willst musst du im Reiter Haupteinstellungen auswählten.
                                            Gruß Rainer
                                            205
                                            39454
