    4. Nach Neuinstall keine Weboberfläche
      krissi last edited by
      Bei "sudo iobroker list instances" kommt nichts.
      root@bananapi:/opt/iobroker# sudo ps -A | grep io
          9 ?        00:00:00 migration/0
         10 ?        00:00:00 migration/1
         20 ?        00:00:00 bioset
         25 ?        00:00:00 rpciod
         29 ?        00:00:00 nfsiod
         30 ?        00:00:00 cifsiod
         69 ?        00:00:00 bioset
       7936 ?        00:00:06 io.js-controlle
      • V
        vader722 last edited by
        Moin,
        bei mir ist es auch so. Ich hab ioBroker auf einem neuen Raspi2 installiert. Nach dem Install läuft der ioBroker.js-controller, jedoch bekomme ich keine admin Instanz angezeigt. Ich kann sie weder anlegen:
        host.raspberrypi install adapter admin
        got /opt/iobroker/node_modules/iobroker.admin/admin
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        Cannot find view "system"
        TypeError: Cannot read property 'rows' of undefined
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:278:25
            at ObjectsInMemServer.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2159:48)
            at ObjectsInMemServer. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2144:33)
            at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:463:16)
            at ObjectsInMemServer.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2140:13)
            at checkDependencies (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:277:21)
            at install (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:353:13)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:401:25
            at callInstallOfAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:429:27)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:400:21</anonymous>
        noch kann ich ioBroker setup starten:
        /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:121
                    objects.getObject(obj._id, function (err, _obj) {
        TypeError: Cannot call method 'getObject' of undefined
            at dbSetup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:121:21)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:189:13
            at Object.States.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2095:82)
            at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:179:26)
            at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
        ich habs auf einem frisch installiertem Raspi2 probiert (npm install iobroker). Testweise hab ich ioBroker auch aus dem aktuellen Tarball installiert, hat aber den gleichen Effekt (npm install https://github.com/tarball/master).
        Log:
        2015-08-21 15:21:05.932  - info: host.raspberrypi ioBroker.js-controller version 0.7.9 js-controller starting
        2015-08-21 15:21:05.944  - info: host.raspberrypi Copyright (c) 2014-2015 bluefox, hobbyquaker
        2015-08-21 15:21:05.945  - info: host.raspberrypi hostname: raspberrypi
        2015-08-21 15:21:05.946  - info: host.raspberrypi ip addresses: 192.168.XXX.XXX
        2015-08-21 15:21:05.996  - info: inMem-states listening on port 9000
        2015-08-21 15:21:06.035  - info: inMem-objects listening on port 9001
        2015-08-21 15:21:06.055  - info: host.raspberrypi InMemoryDB connected
        2015-08-21 15:21:06.074  - error: host.raspberrypi _design/system missing - call node iobroker.js setup
        2015-08-21 21:49:09.010  - info: host.raspberrypi received SIGTERM
        2015-08-21 21:49:09.021  - info: host.raspberrypi terminated
        Gruss Marco
          Hi Marco. Danke für deine Antwort. Ich hab schon an mir gezweifelt. :? Bis jetzt hat das soweit alles immer ganz gut mit ccu.io usw. funktioniert (läuft auf nem cubi). Ich hab iobroker auch schon eine zeit lang auf nem raspi am laufen gehabt. nach dem letzten update hat sich das ding aber leider verabschiedet, ich hätte sonst nicht neu installiert!!! Jetzt habe ich mir extra nen Banana geholt und nix geht. Ich hoffe das bekommen wir irgendwie ans Laufen. 😉
          Gruß, Andre
            Sebbo last edited by
            Ja, also ich habe heute auch auf meinem Raspi2 neuinstalliert und habe das selbe Problem.
            Gruß Sebbo
              Bruzze last edited by
              Moin Zusammen,
              Habe exakt das gleiche Thema. Ich hatte eine Testinstallation auf einem Pi2, um von Dashui zu "Wechseln". Das war zeimlich "lahm".
              Daraufhin gestern einen Cubi erhalten und losgelegt.
              Ich habe 3 verschieden SD-Karten und 2 Rechner (Mac/Win) probiert. Gefühlt 20 x alles installiert/nachinstalliert/per FTP manuell ausgetauscht (Git-Hub etc). Jetzt 24 Std. später (inkl. Müdigkeit) habe ich dann durch Zufall diesen Thread gefunden.
              • Iobroker ist gestartet - aber kein Zugriff auf die Admin Seite
              • Es sieht so aus als würden keine Instanzen angelegt. List
              • "iobroker start admin" = Please enter instance of adapter, e.g. "web.0" = ABER ES GIBT DOCH KEINE INSTANZ
              • Wenn ich manuell "iobroker add iobroker.admin" eingebe kommt "TypeError: Cannot read property 'rows' of undefined…" und eine ellenlange Liste
              • Node -v gibt v0.10.22
              • Die eingabe ./iobroker update gibt folgenden Fehler "Error: Object "system.config" not found"
              • "npm cache clean" = hilft nix
              • diverse Neustarts = hilft nix
              • DHCP oder Fixe IP = hilft nix
              • Alles natürlich mit Root, aber selbst bei einem neuen User mit Root-Rechten geht es nicht
              testhalber habe ich dann mal CCU.io und Dashui installiert - DAS geht
              Ich hatte schon an meinem Verstand gezweifelt...
              Ich bin FROH das es Euch auch so geht - denn dann ist es ein generelles Thema 😞 😞 😞 😞
              B.
                Das einzige was ich dazu sagen kann ist die Fehlermeldung bei start admin!
                Da wird erwartet start admin.0
                Den Rest muss leider bluefox fixen : (
                Rainer
                Gesendet von meinem LIFETAB_S785X mit Tapatalk
                  pix last edited by
                  Schnell aus dem Gedächtnis: Probiert mal
                  iobroker add admin.0 --enabled --port:8081
                  Pix
                  Gesendet von meinem iPhone mit Tapatalk
                    Ich fürchte, das haben wir schon durch
                    http://forum.iobroker.org/viewtopic.php?p=10042#p10042
                    Aber da war noch was wie
                    Iobroker upload admin
                    Oder so ähnlich
                    Vielleicht liegt es aber am controller
                    Rainer
                      mctom last edited by
                      Hi zusammen,
                      ich hänge mich auch mal dran.
                      Habe das gleiche Probleme.
                      Habe ich auch ausprobiert und bekomme:
                         10 ?        00:00:00 migration/0
                         11 ?        00:00:00 migration/1
                         15 ?        00:00:00 migration/2
                         19 ?        00:00:00 migration/3
                         30 ?        00:00:00 bioset
                         34 ?        00:00:00 rpciod
                         37 ?        00:00:00 nfsiod
                         49 ?        00:00:00 DWC Notificatio
                       2584 ?        00:00:02 io.js-controlle
                      Können wir noch etwas testen für die Fehlersuche ?
                      Michael
                      • Bluefox
                        Bluefox last edited by
                        @mctom:
                        Hi zusammen,
                        Michael `
                        Also admin läuft nicht.
                        Was passiert bei:
                        cd /opt/iobroker
                        iobroker add admin –enabled --port 8091
                          Hallo Bluefox
                          root@bananapi:/opt/iobroker# iobroker add admin --enabled --port 8091
                          host.bananapi install adapter admin
                                          if (objs.rows.length) {
                              at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:278:25)
                              at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:29    5:6)
                              at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js    :220:12)
                              at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modu    les/component-bind/index.js:21:15)
                              at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_mod    ules/component-emitter/index.js:134:20)
                              at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager    .js:301:8)
                              at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modu    les/component-bind/index.js:21:15)
                              at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_mod    ules/component-emitter/index.js:134:20)
                              at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/sock    et.io-parser/index.js:247:12)
                              at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js    :291:16)
                          root@bananapi:/opt/iobroker# root@bananapi:/opt/iobroker# iobroker add admin --enabled --port 8091
                          -bash: root@bananapi:/opt/iobroker#:</anonymous></anonymous></anonymous>
                          ` > root@bananapi:/opt/iobroker# sudo ps -A | grep io
                          8267 ? 00:00:02 io.js-controlle
                          root@bananapi:/opt/iobroker# `
                            gleiches bild bei mir…
                            host.ioBrokerLIVE install adapter admin
                                at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                                at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
                                at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                                at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
                                at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                                at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                                at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)</anonymous></anonymous></anonymous>
                              Gibt es schon einen Workaround für unser Problem?
                              Gruß Sebbo
                              • Bluefox
                                Danke. Es war tatsächlich ein Fehler drin.
                                Es gibt jetzt zwei Möglichkeiten:
                                • alles löschen und neu installieren.
                                • oder updaten:
                                cd /opt/iobroker
                                iobroker stop
                                npm install iobroker.js-controller
                                iobroker setup
                                iobroker add admin
                                iobroker start
                                  was soll ich sagen, läuft… Vielen Dank!
                                  Gruß Sebbo
                                    VIS lässt sich allerdings auch nicht installieren.
                                    $ ./iobroker add vis
                                    host.raspberrypi install adapter visnpm install –production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
                                    npm
                                    WARN cannot run in wd
                                    iobroker.vis@0.6.12 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
                                    npm
                                    iobroker.vis@0.6.12 node node_modules/grunt/lib/grunt prepublish (wd=/opt/iobroker/node_modules/iobroker.vis)
                                    got /opt/iobroker/node_modules/iobroker.vis/admin
                                    upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                    upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                    • Bluefox
                                      @Sebbo:
                                      npm
                                      npm
                                      upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html `
                                      Rechte. (wd ist Working Directory)
                                      cd /opt/iobroker
                                      sudo chmod 777 * -R
                                      sudo iobroker add vis
                                        Ich glaub ich geb es erst mal auf bis es wieder läuft. ich hab jetzt komplett neu installiert (inkl. dem Update), gleiches Ergebniss. Vieleicht mach ich ja auch noch irgendwo einen Fehler. Ich wüsste aber nicht wo. Mehr als das aus der Anleitung kopieren kann ich auch nicht. 😞
                                          Hast du die rechte gesetzt, so wie bluefox es gepostet hat?
                                          Rainer
                                          2352_wemos_iobroker_wemos.txt
                                          2352_skript_iobroker.txt
                                            @Bluefox:
                                            @Sebbo:
                                            npm
                                            npm
                                            cd /opt/iobroker
                                            sudo chmod 777 * -R
                                            Ok, danke. Ich bekomme aber leider danach die selbe Fehlermeldung. :shock:
                                            Gruß Sebbo
                                            Edit: Hab jetzt nochmal komplett neu installiert. Aber Vis lässt sich noch immer nicht installieren. Es bleibt hängen, und mehr passiert nicht:
                                            npm install iobroker.vis --production --prefix "/opt/iobroker/node_modules" (System call)
                                            npm
                                             http GET https://registry.npmjs.org/iobroker.vis
                                            npm
                                             http 200 https://registry.npmjs.org/iobroker.vis
                                            npm
                                             http GET https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.6.13.tgz
                                            npm
                                             http
                                             200
                                            327_datenpunkte_anlegen.js
                                            327_wemos_iobroker_wemos.c
                                            44
                                            10634
