    4. [gelöst] Adapterinstallation - node gyp error
    SOLVED [gelöst] Adapterinstallation - node gyp error
      Sundance @Glasfaser last edited by
      @Glasfaser - das Serialport Problem konnte ich mit deinem ersten Vorschlag jetzt lösen. Allerdings ist das ursprüngliche problem, nämlich die iobroker.roomba Adapterinstallation leider immernoch ein Problem.. ich bekomme die gleiche Fehlermeldung:
      pi@HOME:~ $ iobroker install iobroker.roomba
      NPM version: 6.9.0
      npm install iobroker.roomba@1.0.0 --production --save --prefix "/opt/iobroker" (System call)
      node-pre-gyp WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz
      node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
      ../src/bmp/BMPParser.cc: In member function 'void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)':
      ../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         E(ptr - data > imgdOffset, "image data overlaps with another structure");
      ../src/bmp/BMPParser.cc:10:25: note: in definition of macro 'E'
       #define E(cond, msg) if(cond) return setErr(msg)
      ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         E(ptr - data + imgdSize > len, "not enough image data");
      ../src/CanvasRenderingContext2d.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)':
      ../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded 'abs(double&)' is ambiguous
         double current_scale_x = abs(transforms[1]);
      In file included from /usr/include/c++/6/cstdlib:75:0,
                       from /usr/include/c++/6/ext/string_conversions.h:41,
                       from /usr/include/c++/6/bits/basic_string.h:5417,
                       from /usr/include/c++/6/string:52,
                       from /usr/include/c++/6/stdexcept:39,
                       from /usr/include/c++/6/array:39,
                       from /usr/include/c++/6/tuple:39,
                       from /usr/include/c++/6/functional:55,
                       from /usr/include/c++/6/memory:79,
                       from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:21,
                       from /home/iobroker/.node-gyp/10.16.2/include/node/node.h:63,
                       from ../../nan/nan.h:54,
                       from ../src/backend/Backend.h:6,
                       from ../src/Canvas.h:5,
                       from ../src/CanvasRenderingContext2d.h:6,
                       from ../src/CanvasRenderingContext2d.cc:3:
      /usr/include/stdlib.h:735:12: note: candidate: int abs(int)
       extern int abs (int __x) __THROW __attribute__ ((__const__)) __wur;
      In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,
      /usr/include/c++/6/cstdlib:180:3: note: candidate: long long int std::abs(long long int)
         abs(long long __x) { return __builtin_llabs (__x); }
      /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)
         abs(long __i) { return __builtin_labs(__i); }
      ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded 'abs(double&)' is ambiguous
         double current_scale_y = abs(transforms[2]);
      make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Error 1
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.19.57-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v10.16.2
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.19.57-v7+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v10.16.2
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the canvas@2.5.0 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T10_20_42_621Z-debug.log
      host.HOME Adapter directory "null" does not exists
      Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
      Kann ich die canvas Installation irgendwie manuell machen, damit sich der Installer nicht daran aufhängt? Oder ist die Wurzel des Problems woanders?
      Danke nochmal für deine Hilfe..
      Beste Grüße
      sundance
      • Glasfaser
        Glasfaser @Sundance last edited by
        @Sundance
        Welche Versin von Js-controller hast du ?
          @Glasfaser ich habe aktuell die 1.5.14 installiert.
          • Glasfaser
            @Sundance
            Wie sieht es hiermit aus
            Installationsanweisungen folgen !!!
            Link Text
              @Glasfaser Ja, das hatte ich schon probiert vorhin.. ironischerweise kommen bei der Canvas installation gemäß dem Befehl aus der Installationsanleitung die gleichen Fehler (zumindest auf den ersten Blick):
              root@HOME:~# cd /opt/iobroker
              root@HOME:/opt/iobroker# sudo npm install canvas --unsafe-perm=true
              > canvas@2.5.0 install /opt/iobroker/node_modules/canvas
              make: Entering directory '/opt/iobroker/node_modules/canvas/build'
                SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                COPY Release/canvas-postbuild.node
                CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                CXX(target) Release/obj.target/canvas/src/Backends.o
                CXX(target) Release/obj.target/canvas/src/Canvas.o
                CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                               from /root/.node-gyp/10.16.2/include/node/v8.h:21,
                               from /root/.node-gyp/10.16.2/include/node/node.h:63,
              canvas.target.mk:138: recipe for target 'Release/obj.target/canvas/src/CanvasRenderingContext2d.o' failed
              make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /root/.npm/_logs/2019-08-08T11_38_50_244Z-debug.log
              Allerdings steht in der Anleitung auch, dass man Canvas in den iobroker.roomba Ordner erstellen soll. Der existiert aber bei mir (noch) nicht, zumindest nicht in /opt/iobroker/node_modules/ - oder muss der woanders hin? Muss ich den vorher händisch erstellen, oder bringt das nix?
              Sorry, ich bin lost 😄 Danke für deine Geduld
              Beste Grüße
              Florian
              • Glasfaser
                Glasfaser @Sundance last edited by Glasfaser
                @Sundance
                Hast Du eingentlich schon mal wieder versucht roomba über die Konsole ganz normal zu installieren !?
                  @Glasfaser Ja, habe es grade nochmal probiert.. aber die Fehler bleiben leider bestehen. Die Canvas Installation schlägt nachwievor fehl.. manuell installiert bekomme ich sie auch nicht.
                  Ich habe grade nochmal die Verzeichnisberechtigungen "bereinigt", aber es hat leider nicht geholfen.
                  Hast du noch eine Idee? In meinem letzten Installations-log Scheint es auch Probleme zu geben, einfache Ordner zu erstellen:
                  gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.16.2"
                  gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
                  gyp ERR! configure error
                  gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                  Es hilft nicht, diese Ordner händisch zu erstellen, oder?
                    sigi234 Forum Testing Most Active @Sundance last edited by
                    @Sundance sagte in Adapterinstallation schlägt fehl - node-gyp Fehler:
                    einfach mal den Installations-Fixer anwenden: curl -sL https://iobroker.net/fix.sh | bash -
                      Sundance @sigi234 last edited by
                      @sigi234 Danke, Das hat das "permission denied" Problem behoben - aber den Rest leider nicht..
                      root@HOME:/opt/iobroker# iobroker install iobroker.roomba
                      NPM version: 6.9.0
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_06_49_697Z-debug.log
                      Gibt es außer einer kompletten Neuinstallation noch irgendwas, was ich testen könnte?
                      Danke und beste grüße
                      Sundance
                        sigi234 Forum Testing Most Active @Sundance last edited by sigi234
                        @Sundance
                        Was sagt :
                        node -v
                        npm -v
                        iobroker list instances
                          @sigi234
                          Hier die drei Ausgaben:
                          pi@HOME:~ $ node -v
                          v10.16.2
                          pi@HOME:~ $ npm -v
                          6.9.0
                          pi@HOME:~ $ iobroker list instances
                          + system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            system.adapter.cloud.0                 : cloud       - disabled
                          + system.adapter.discovery.0             : discovery   -  enabled
                            system.adapter.ham.0                   : ham         -  enabled
                          + system.adapter.history.0               : history     -  enabled
                          + system.adapter.hm-rega.0               : hm-rega     -  enabled
                          + system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
                          + system.adapter.hm-rpc.1                : hm-rpc      -  enabled, port: 0
                          + system.adapter.hue.0                   : hue         -  enabled, port: 80
                            system.adapter.info.0                  : info        -  enabled
                            system.adapter.iot.0                   : iot         - disabled
                          + system.adapter.javascript.0            : javascript  -  enabled
                            system.adapter.mobile.0                : mobile      - disabled
                            system.adapter.node-red.0              : node-red    -  enabled, port: 1880, bind: 0.0.0.0
                            system.adapter.sayit.0                 : sayit       -  enabled, port: 0
                            system.adapter.sonos.0                 : sonos       -  enabled
                            system.adapter.tr-064.0                : tr-064      -  enabled
                          + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.web.1                   : web         -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                            system.adapter.zigbee.0                : zigbee      -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019366630-if00
                          + instance is alive
                            @Sundance
                            Das passt Alles, ioBroker neu starten......
                              @sigi234 Habe ich gemacht - Installation nochmal versucht, gleiche Fehler wie vorher.. Gibt es noch etwas, was ich versuchen kann?
                              Danke vorab für deine Hilfe!
                                Was für welcher ? Was geht nicht, bzw. funktioniert nicht?
                                In den Admin kommst du normal rein?
                                  Sundance @sigi234 last edited by Sundance
                                  @sigi234
                                  Hier der aktuelle Fehler-output aus dem Terminal:
                                  NPM version: 6.9.0
                                  gyp ERR! not ok
                                  npm ERR! errno 1
                                  npm ERR!
                                  npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_17_48_762Z-debug.log
                                  In Admin komme ich normal rein, dort funktioniert auch alles wunderbar - allerdings hatte die Installation über Admin nie geklappt, daher habe ich es nun immer über die Konsole probiert. Leider bisher ohne Erfolg..
                                  Habe es hier zwar als user "Pi" installiert - per root kommen aber die gleichen fehler.
                                    sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                      @sigi234 said in Adapterinstallation schlägt fehl - node-gyp Fehler:
                                      Das hatte ich vorhin auch schonmal probiert, schlägt leider immernoch fehl.. hier die beiden outputs:
                                      pi@HOME:~ $ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                      Reading package lists... Done
                                      Building dependency tree
                                      build-essential is already the newest version (12.3).
                                      libgif-dev is already the newest version (5.1.4-0.4).
                                      libjpeg-dev is already the newest version (1:1.5.1-2).
                                      libpango1.0-dev is already the newest version (1.40.5-1).
                                      librsvg2-dev is already the newest version (2.40.16-1).
                                      libcairo2-dev is already the newest version (1.14.8-1+rpi1).
                                      0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
                                      Und bei canvas:
                                      pi@HOME:~ $ sudo npm install canvas --unsafe-perm=true
                                      > canvas@2.5.0 install /home/pi/node_modules/canvas
                                      make: Entering directory '/home/pi/node_modules/canvas/build'
                                      make: Leaving directory '/home/pi/node_modules/canvas/build'
                                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/home/pi/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                                      gyp ERR! cwd /home/pi/node_modules/canvas
                                      gyp ERR! not ok
                                      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
                                      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                      node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                      node-pre-gyp ERR! cwd /home/pi/node_modules/canvas
                                      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                      npm WARN pi No description
                                      npm WARN pi No repository field.
                                      npm WARN pi No README data
                                      npm WARN pi No license field.
                                      npm ERR! errno 1
                                      npm ERR!
                                      npm ERR!     /root/.npm/_logs/2019-08-08T12_31_14_478Z-debug.log
                                        Kommt das gleiche wenn du es über den Admin installierst?
                                        Gerade bei mir mal installiert:
                                          @sigi234 Jap, das gleiche Spiel.. host.HOME cannot install roomba:
                                          $ ./iobroker add roomba  --host HOME
                                          NPM version: 6.9.0
                                          node-pre-gyp
                                          node-pre-gyp
                                           WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN
                                          ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                          ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                                          ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]   E(ptr - data + imgdSize > len, "not enough image data");
                                          ../src/CanvasRenderingContext2d.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)’:../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                                          In file included from /usr/include/c++/6/cstdlib:75:0,                 from /usr/include/c++/6/ext/string_conversions.h:41,
                                          ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                                          make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Fehler 1
                                          gyp
                                           ERR! build error
                                          gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                          gyp ERR! not ok
                                          node-pre-gyp
                                           ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                          node-pre-gyp ERR! System Linux 4.19.57-v7+node-pre-gyp
                                          ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                          node-pre-gyp
                                           ERR! not ok
                                          npm
                                          npm
                                          WARN
                                           optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          npm ERR! code ELIFECYCLEnpm ERR! errno 1
                                          npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
                                          npm ERR!
                                          npm
                                           ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_39_29_830Z-debug.log
                                          host.HOME install adapter roomba
                                          NPM version: 6.9.0
                                          node-pre-gyp
                                          node-pre-gyp
                                           WARN
                                          In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,                 from /usr/include/c++/6/bits/basic_string.h:5417,
                                          /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)   abs(long __i) { return __builtin_labs(__i); }
                                          ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous   double current_scale_y = abs(transforms[2]);
                                          gyp ERR!
                                          build error
                                          gyp
                                          gyp ERR!
                                          stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                          gyp ERR! System Linux 4.19.57-v7+gyp
                                          gyp
                                          ERR! node-gyp -v v3.8.0gyp ERR! not ok
                                          node-pre-gyp
                                           ERR! build error
                                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp
                                           ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                                          node-pre-gyp
                                           ERR! System Linux 4.19.57-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.16.2
                                          npm
                                          npm
                                           WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup
                                          npm
                                          npm
                                          ERR!
                                          errno
                                           1npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
                                          npm ERR!
                                          npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_41_18_181Z-debug.log
                                          NPM version: 6.9.0
                                          node-pre-gyp
                                          node-pre-gyp
                                           WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                                          gyp
                                          ERR!
                                          build error
                                          gyp
                                          gyp ERR!
                                          stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp
                                           ERR! System Linux 4.19.57-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                                          gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.16.2
                                          gyp ERR!
                                          node-pre-gyp
                                           ERR! build error
                                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
                                          node-pre-gyp
                                          node-pre-gyp ERR!
                                          node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                                          npm
                                          npm
                                          WARN
                                          npm
                                          WARN
                                          notsup
                                          npm
                                          npm
                                          ERR! errno
                                          npm
                                          npm ERR!
                                          npm ERR!
                                          npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_43_10_893Z-debug.log
                                          ERROR: host.HOME Cannot install roomba
                                          ERROR: process exited with code 13
                                          • Ralla66
                                            Ralla66 Most Active last edited by
                                            Error 404 wundert mich.
                                            Finde nur die Version 2.6.0.
                                            Falscher Link ?
                                            adapter installation installation node-pre-gyp err
                                            5350
