    4. [gelöst] Adapterinstallation - node gyp error
    SOLVED [gelöst] Adapterinstallation - node gyp error
      Sundance @Glasfaser last edited by
      @Glasfaser Ja, das hatte ich schon probiert vorhin.. ironischerweise kommen bei der Canvas installation gemäß dem Befehl aus der Installationsanleitung die gleichen Fehler (zumindest auf den ersten Blick):
      root@HOME:~# cd /opt/iobroker
      root@HOME:/opt/iobroker# sudo npm install canvas --unsafe-perm=true
      > canvas@2.5.0 install /opt/iobroker/node_modules/canvas
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz
      node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
      make: Entering directory '/opt/iobroker/node_modules/canvas/build'
        SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
        COPY Release/canvas-postbuild.node
        CXX(target) Release/obj.target/canvas/src/backend/Backend.o
        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
      ../src/bmp/BMPParser.cc: In member function 'void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)':
      ../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         E(ptr - data > imgdOffset, "image data overlaps with another structure");
      ../src/bmp/BMPParser.cc:10:25: note: in definition of macro 'E'
       #define E(cond, msg) if(cond) return setErr(msg)
      ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         E(ptr - data + imgdSize > len, "not enough image data");
        CXX(target) Release/obj.target/canvas/src/Backends.o
        CXX(target) Release/obj.target/canvas/src/Canvas.o
        CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
        CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
        CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
      ../src/CanvasRenderingContext2d.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)':
      ../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded 'abs(double&)' is ambiguous
         double current_scale_x = abs(transforms[1]);
      In file included from /usr/include/c++/6/cstdlib:75:0,
                       from /usr/include/c++/6/ext/string_conversions.h:41,
                       from /usr/include/c++/6/bits/basic_string.h:5417,
                       from /usr/include/c++/6/string:52,
                       from /usr/include/c++/6/stdexcept:39,
                       from /usr/include/c++/6/array:39,
                       from /usr/include/c++/6/tuple:39,
                       from /usr/include/c++/6/functional:55,
                       from /usr/include/c++/6/memory:79,
                       from /root/.node-gyp/10.16.2/include/node/v8.h:21,
                       from /root/.node-gyp/10.16.2/include/node/node.h:63,
                       from ../../nan/nan.h:54,
                       from ../src/backend/Backend.h:6,
                       from ../src/Canvas.h:5,
                       from ../src/CanvasRenderingContext2d.h:6,
                       from ../src/CanvasRenderingContext2d.cc:3:
      /usr/include/stdlib.h:735:12: note: candidate: int abs(int)
       extern int abs (int __x) __THROW __attribute__ ((__const__)) __wur;
      In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,
      /usr/include/c++/6/cstdlib:180:3: note: candidate: long long int std::abs(long long int)
         abs(long long __x) { return __builtin_llabs (__x); }
      /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)
         abs(long __i) { return __builtin_labs(__i); }
      ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded 'abs(double&)' is ambiguous
         double current_scale_y = abs(transforms[2]);
      canvas.target.mk:138: recipe for target 'Release/obj.target/canvas/src/CanvasRenderingContext2d.o' failed
      make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.19.57-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v10.16.2
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.19.57-v7+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v10.16.2
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the canvas@2.5.0 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2019-08-08T11_38_50_244Z-debug.log
      Allerdings steht in der Anleitung auch, dass man Canvas in den iobroker.roomba Ordner erstellen soll. Der existiert aber bei mir (noch) nicht, zumindest nicht in /opt/iobroker/node_modules/ - oder muss der woanders hin? Muss ich den vorher händisch erstellen, oder bringt das nix?
      Sorry, ich bin lost 😄 Danke für deine Geduld
      Beste Grüße
      Florian
      • Glasfaser
        Glasfaser @Sundance last edited by Glasfaser
        @Sundance
        Hast Du eingentlich schon mal wieder versucht roomba über die Konsole ganz normal zu installieren !?
          @Glasfaser Ja, habe es grade nochmal probiert.. aber die Fehler bleiben leider bestehen. Die Canvas Installation schlägt nachwievor fehl.. manuell installiert bekomme ich sie auch nicht.
          Ich habe grade nochmal die Verzeichnisberechtigungen "bereinigt", aber es hat leider nicht geholfen.
          Hast du noch eine Idee? In meinem letzten Installations-log Scheint es auch Probleme zu geben, einfache Ordner zu erstellen:
          gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.16.2"
          gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
          gyp ERR! configure error
          gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
          Es hilft nicht, diese Ordner händisch zu erstellen, oder?
            sigi234 Forum Testing Most Active @Sundance last edited by
            @Sundance sagte in Adapterinstallation schlägt fehl - node-gyp Fehler:
            einfach mal den Installations-Fixer anwenden: curl -sL https://iobroker.net/fix.sh | bash -
              Sundance @sigi234 last edited by
              @sigi234 Danke, Das hat das "permission denied" Problem behoben - aber den Rest leider nicht..
              root@HOME:/opt/iobroker# iobroker install iobroker.roomba
              NPM version: 6.9.0
              npm install iobroker.roomba@1.0.0 --production --save --prefix "/opt/iobroker" (System call)
                               from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:21,
                               from /home/iobroker/.node-gyp/10.16.2/include/node/node.h:63,
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_06_49_697Z-debug.log
              host.HOME Adapter directory "null" does not exists
              Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
              Gibt es außer einer kompletten Neuinstallation noch irgendwas, was ich testen könnte?
              Danke und beste grüße
              Sundance
                sigi234 Forum Testing Most Active @Sundance last edited by sigi234
                @Sundance
                Was sagt :
                node -v
                npm -v
                iobroker list instances
                  @sigi234
                  Hier die drei Ausgaben:
                  pi@HOME:~ $ node -v
                  v10.16.2
                  pi@HOME:~ $ npm -v
                  6.9.0
                  pi@HOME:~ $ iobroker list instances
                  + system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.cloud.0                 : cloud       - disabled
                  + system.adapter.discovery.0             : discovery   -  enabled
                    system.adapter.ham.0                   : ham         -  enabled
                  + system.adapter.history.0               : history     -  enabled
                  + system.adapter.hm-rega.0               : hm-rega     -  enabled
                  + system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
                  + system.adapter.hm-rpc.1                : hm-rpc      -  enabled, port: 0
                  + system.adapter.hue.0                   : hue         -  enabled, port: 80
                    system.adapter.info.0                  : info        -  enabled
                    system.adapter.iot.0                   : iot         - disabled
                  + system.adapter.javascript.0            : javascript  -  enabled
                    system.adapter.mobile.0                : mobile      - disabled
                    system.adapter.node-red.0              : node-red    -  enabled, port: 1880, bind: 0.0.0.0
                    system.adapter.sayit.0                 : sayit       -  enabled, port: 0
                    system.adapter.sonos.0                 : sonos       -  enabled
                    system.adapter.tr-064.0                : tr-064      -  enabled
                  + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.web.1                   : web         -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                    system.adapter.zigbee.0                : zigbee      -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019366630-if00
                  + instance is alive
                    @Sundance
                    Das passt Alles, ioBroker neu starten......
                      @sigi234 Habe ich gemacht - Installation nochmal versucht, gleiche Fehler wie vorher.. Gibt es noch etwas, was ich versuchen kann?
                      Danke vorab für deine Hilfe!
                        Was für welcher ? Was geht nicht, bzw. funktioniert nicht?
                        In den Admin kommst du normal rein?
                          Sundance @sigi234 last edited by Sundance
                          @sigi234
                          Hier der aktuelle Fehler-output aus dem Terminal:
                          pi@HOME:~ $ iobroker install iobroker.roomba
                          NPM version: 6.9.0
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_17_48_762Z-debug.log
                          In Admin komme ich normal rein, dort funktioniert auch alles wunderbar - allerdings hatte die Installation über Admin nie geklappt, daher habe ich es nun immer über die Konsole probiert. Leider bisher ohne Erfolg..
                          Habe es hier zwar als user "Pi" installiert - per root kommen aber die gleichen fehler.
                            sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                              @sigi234 said in Adapterinstallation schlägt fehl - node-gyp Fehler:
                              Das hatte ich vorhin auch schonmal probiert, schlägt leider immernoch fehl.. hier die beiden outputs:
                              pi@HOME:~ $ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                              Reading package lists... Done
                              Building dependency tree
                              build-essential is already the newest version (12.3).
                              libgif-dev is already the newest version (5.1.4-0.4).
                              libjpeg-dev is already the newest version (1:1.5.1-2).
                              libpango1.0-dev is already the newest version (1.40.5-1).
                              librsvg2-dev is already the newest version (2.40.16-1).
                              libcairo2-dev is already the newest version (1.14.8-1+rpi1).
                              0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
                              Und bei canvas:
                              pi@HOME:~ $ sudo npm install canvas --unsafe-perm=true
                              > canvas@2.5.0 install /home/pi/node_modules/canvas
                              make: Entering directory '/home/pi/node_modules/canvas/build'
                              make: Leaving directory '/home/pi/node_modules/canvas/build'
                              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/home/pi/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                              gyp ERR! cwd /home/pi/node_modules/canvas
                              gyp ERR! not ok
                              node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
                              node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                              node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                              node-pre-gyp ERR! cwd /home/pi/node_modules/canvas
                              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                              npm WARN pi No description
                              npm WARN pi No repository field.
                              npm WARN pi No README data
                              npm WARN pi No license field.
                              npm ERR! errno 1
                              npm ERR!
                              npm ERR!     /root/.npm/_logs/2019-08-08T12_31_14_478Z-debug.log
                                Kommt das gleiche wenn du es über den Admin installierst?
                                Gerade bei mir mal installiert:
                                  @sigi234 Jap, das gleiche Spiel.. host.HOME cannot install roomba:
                                  $ ./iobroker add roomba  --host HOME
                                  NPM version: 6.9.0
                                  node-pre-gyp
                                  node-pre-gyp
                                   WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN
                                  ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                  ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                                  ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]   E(ptr - data + imgdSize > len, "not enough image data");
                                  ../src/CanvasRenderingContext2d.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)’:../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                                  In file included from /usr/include/c++/6/cstdlib:75:0,                 from /usr/include/c++/6/ext/string_conversions.h:41,
                                  ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                                  make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Fehler 1
                                  gyp
                                   ERR! build error
                                  gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                  gyp ERR! not ok
                                  node-pre-gyp
                                   ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                  node-pre-gyp ERR! System Linux 4.19.57-v7+node-pre-gyp
                                  ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                  node-pre-gyp
                                   ERR! not ok
                                  npm
                                  npm
                                  WARN
                                   optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                  npm ERR! code ELIFECYCLEnpm ERR! errno 1
                                  npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
                                  npm ERR!
                                  npm
                                   ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_39_29_830Z-debug.log
                                  host.HOME install adapter roomba
                                  NPM version: 6.9.0
                                  node-pre-gyp
                                  node-pre-gyp
                                   WARN
                                  In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,                 from /usr/include/c++/6/bits/basic_string.h:5417,
                                  /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)   abs(long __i) { return __builtin_labs(__i); }
                                  ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous   double current_scale_y = abs(transforms[2]);
                                  gyp ERR!
                                  build error
                                  gyp
                                  gyp ERR!
                                  stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                  gyp ERR! System Linux 4.19.57-v7+gyp
                                  gyp
                                  ERR! node-gyp -v v3.8.0gyp ERR! not ok
                                  node-pre-gyp
                                   ERR! build error
                                  node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp
                                   ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                                  node-pre-gyp
                                   ERR! System Linux 4.19.57-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                  node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.16.2
                                  npm
                                  npm
                                   WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup
                                  npm
                                  npm
                                  ERR!
                                  errno
                                   1npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
                                  npm ERR!
                                  npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_41_18_181Z-debug.log
                                  NPM version: 6.9.0
                                  node-pre-gyp
                                  node-pre-gyp
                                   WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                                  gyp
                                  ERR!
                                  build error
                                  gyp
                                  gyp ERR!
                                  stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp
                                   ERR! System Linux 4.19.57-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                                  gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.16.2
                                  gyp ERR!
                                  node-pre-gyp
                                   ERR! build error
                                  node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                  node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
                                  node-pre-gyp
                                  node-pre-gyp ERR!
                                  node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                                  npm
                                  npm
                                  WARN
                                  npm
                                  WARN
                                  notsup
                                  npm
                                  npm
                                  ERR! errno
                                  npm
                                  npm ERR!
                                  npm ERR!
                                  npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_43_10_893Z-debug.log
                                  ERROR: host.HOME Cannot install roomba
                                  ERROR: process exited with code 13
                                  • Ralla66
                                    Ralla66 Most Active last edited by
                                    Error 404 wundert mich.
                                    Finde nur die Version 2.6.0.
                                    Falscher Link ?
                                      Sundance @Ralla66 last edited by
                                      @Ralla66 Stimmt.. der Link hier müsste es wohl sein laut repo:
                                      https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
                                      Da ist im link ein "ARM" zu viel.. aber passt die Version dann überhaupt noch? Was müsste ich anpassen, damit ich es installieren kann?
                                      • Ralla66
                                        Der Link geht ja, versuch über die URL zu installieren.
                                          @Ralla66 das scheint nicht zu klappen:
                                          $ ./iobroker url "https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz" --debug
                                          install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
                                          npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz --production --save --prefix "/opt/iobroker" (System call)
                                          npm
                                           ERR! code ENOPACKAGEJSON
                                          npm
                                          ERR!
                                          package.json Non-registry package missing package.json: https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz.npm
                                           ERR! package.json
                                           npm can't find a package.json file in your current directory.
                                          npm
                                          npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T13_53_17_665Z-debug.log
                                          process exited with code 0
                                          • Ralla66
                                            Da kann ich nicht mehr weiter helfen.
                                            Dir scheint ein package.json file zu fehlen oder liegt im falschen directory.
                                            adapter installation installation node-pre-gyp err
                                            5350
