    4. [gelöst] Adapterinstallation - node gyp error
    SOLVED [gelöst] Adapterinstallation - node gyp error
      sigi234 Forum Testing Most Active @Sundance last edited by
      @Sundance sagte in Adapterinstallation schlägt fehl - node-gyp Fehler:
      gleiche Fehler wie vorher
      Was für welcher ? Was geht nicht, bzw. funktioniert nicht?
      In den Admin kommst du normal rein?
        Sundance @sigi234 last edited by Sundance
        @sigi234
        Hier der aktuelle Fehler-output aus dem Terminal:
        pi@HOME:~ $ iobroker install iobroker.roomba
        NPM version: 6.9.0
        npm install iobroker.roomba@1.0.0 --production --save --prefix "/opt/iobroker" (System call)
        node-pre-gyp WARN Using request for node-pre-gyp https download
        node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz
        node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
        ../src/bmp/BMPParser.cc: In member function 'void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)':
        ../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
           E(ptr - data > imgdOffset, "image data overlaps with another structure");
        ../src/bmp/BMPParser.cc:10:25: note: in definition of macro 'E'
         #define E(cond, msg) if(cond) return setErr(msg)
        ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
           E(ptr - data + imgdSize > len, "not enough image data");
        ../src/CanvasRenderingContext2d.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)':
        ../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded 'abs(double&)' is ambiguous
           double current_scale_x = abs(transforms[1]);
        In file included from /usr/include/c++/6/cstdlib:75:0,
                         from /usr/include/c++/6/ext/string_conversions.h:41,
                         from /usr/include/c++/6/bits/basic_string.h:5417,
                         from /usr/include/c++/6/string:52,
                         from /usr/include/c++/6/stdexcept:39,
                         from /usr/include/c++/6/array:39,
                         from /usr/include/c++/6/tuple:39,
                         from /usr/include/c++/6/functional:55,
                         from /usr/include/c++/6/memory:79,
                         from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:21,
                         from /home/iobroker/.node-gyp/10.16.2/include/node/node.h:63,
                         from ../../nan/nan.h:54,
                         from ../src/backend/Backend.h:6,
                         from ../src/Canvas.h:5,
                         from ../src/CanvasRenderingContext2d.h:6,
                         from ../src/CanvasRenderingContext2d.cc:3:
        /usr/include/stdlib.h:735:12: note: candidate: int abs(int)
         extern int abs (int __x) __THROW __attribute__ ((__const__)) __wur;
        In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,
        /usr/include/c++/6/cstdlib:180:3: note: candidate: long long int std::abs(long long int)
           abs(long long __x) { return __builtin_llabs (__x); }
        /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)
           abs(long __i) { return __builtin_labs(__i); }
        ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded 'abs(double&)' is ambiguous
           double current_scale_y = abs(transforms[2]);
        make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Error 1
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.19.57-v7+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
        gyp ERR! cwd /opt/iobroker/node_modules/canvas
        gyp ERR! node -v v10.16.2
        gyp ERR! node-gyp -v v3.8.0
        gyp ERR! not ok
        node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        node-pre-gyp ERR! System Linux 4.19.57-v7+
        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        node-pre-gyp ERR! node -v v10.16.2
        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
        node-pre-gyp ERR! not ok
        npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the canvas@2.5.0 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_17_48_762Z-debug.log
        host.HOME Adapter directory "null" does not exists
        Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
        In Admin komme ich normal rein, dort funktioniert auch alles wunderbar - allerdings hatte die Installation über Admin nie geklappt, daher habe ich es nun immer über die Konsole probiert. Leider bisher ohne Erfolg..
        Habe es hier zwar als user "Pi" installiert - per root kommen aber die gleichen fehler.
          sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
          sudo npm install canvas --unsafe-perm=true
            @sigi234 said in Adapterinstallation schlägt fehl - node-gyp Fehler:
            Das hatte ich vorhin auch schonmal probiert, schlägt leider immernoch fehl.. hier die beiden outputs:
            pi@HOME:~ $ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
            Reading package lists... Done
            Building dependency tree
            build-essential is already the newest version (12.3).
            libgif-dev is already the newest version (5.1.4-0.4).
            libjpeg-dev is already the newest version (1:1.5.1-2).
            libpango1.0-dev is already the newest version (1.40.5-1).
            librsvg2-dev is already the newest version (2.40.16-1).
            libcairo2-dev is already the newest version (1.14.8-1+rpi1).
            0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
            Und bei canvas:
            pi@HOME:~ $ sudo npm install canvas --unsafe-perm=true
            > canvas@2.5.0 install /home/pi/node_modules/canvas
            make: Entering directory '/home/pi/node_modules/canvas/build'
              SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
              COPY Release/canvas-postbuild.node
              CXX(target) Release/obj.target/canvas/src/backend/Backend.o
              CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
              CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
              CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
              CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
              CXX(target) Release/obj.target/canvas/src/Backends.o
              CXX(target) Release/obj.target/canvas/src/Canvas.o
              CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
              CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
              CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                             from /root/.node-gyp/10.16.2/include/node/v8.h:21,
                             from /root/.node-gyp/10.16.2/include/node/node.h:63,
            canvas.target.mk:138: recipe for target 'Release/obj.target/canvas/src/CanvasRenderingContext2d.o' failed
            make: Leaving directory '/home/pi/node_modules/canvas/build'
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/home/pi/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
            gyp ERR! cwd /home/pi/node_modules/canvas
            gyp ERR! not ok
            node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
            node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
            node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
            node-pre-gyp ERR! cwd /home/pi/node_modules/canvas
            npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            npm WARN pi No description
            npm WARN pi No repository field.
            npm WARN pi No README data
            npm WARN pi No license field.
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /root/.npm/_logs/2019-08-08T12_31_14_478Z-debug.log
              Kommt das gleiche wenn du es über den Admin installierst?
              Gerade bei mir mal installiert:
                @sigi234 Jap, das gleiche Spiel.. host.HOME cannot install roomba:
                $ ./iobroker add roomba  --host HOME
                NPM version: 6.9.0
                node-pre-gyp
                node-pre-gyp
                 WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN
                ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]   E(ptr - data + imgdSize > len, "not enough image data");
                ../src/CanvasRenderingContext2d.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)’:../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                In file included from /usr/include/c++/6/cstdlib:75:0,                 from /usr/include/c++/6/ext/string_conversions.h:41,
                ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Fehler 1
                gyp
                 ERR! build error
                gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvas
                gyp ERR! not ok
                node-pre-gyp
                 ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                node-pre-gyp ERR! System Linux 4.19.57-v7+node-pre-gyp
                ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                node-pre-gyp
                 ERR! not ok
                npm
                npm
                WARN
                 optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                npm ERR! code ELIFECYCLEnpm ERR! errno 1
                npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
                npm ERR!
                npm
                 ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_39_29_830Z-debug.log
                host.HOME install adapter roomba
                NPM version: 6.9.0
                node-pre-gyp
                node-pre-gyp
                 WARN
                In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,                 from /usr/include/c++/6/bits/basic_string.h:5417,
                /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)   abs(long __i) { return __builtin_labs(__i); }
                ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous   double current_scale_y = abs(transforms[2]);
                gyp ERR!
                build error
                gyp
                gyp ERR!
                stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                gyp ERR! System Linux 4.19.57-v7+gyp
                gyp
                ERR! node-gyp -v v3.8.0gyp ERR! not ok
                node-pre-gyp
                 ERR! build error
                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp
                 ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                node-pre-gyp
                 ERR! System Linux 4.19.57-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.16.2
                npm
                npm
                 WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup
                npm
                npm
                ERR!
                errno
                 1npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
                npm ERR!
                npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_41_18_181Z-debug.log
                NPM version: 6.9.0
                node-pre-gyp
                node-pre-gyp
                 WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                gyp
                ERR!
                build error
                gyp
                gyp ERR!
                stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp
                 ERR! System Linux 4.19.57-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.16.2
                gyp ERR!
                node-pre-gyp
                 ERR! build error
                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
                node-pre-gyp
                node-pre-gyp ERR!
                node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                npm
                npm
                WARN
                npm
                WARN
                notsup
                npm
                npm
                ERR! errno
                npm
                npm ERR!
                npm ERR!
                npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_43_10_893Z-debug.log
                ERROR: host.HOME Cannot install roomba
                ERROR: process exited with code 13
                • Ralla66
                  Ralla66 Most Active last edited by
                  Error 404 wundert mich.
                  Finde nur die Version 2.6.0.
                  Falscher Link ?
                    Sundance @Ralla66 last edited by
                    @Ralla66 Stimmt.. der Link hier müsste es wohl sein laut repo:
                    https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
                    Da ist im link ein "ARM" zu viel.. aber passt die Version dann überhaupt noch? Was müsste ich anpassen, damit ich es installieren kann?
                    • Ralla66
                      Der Link geht ja, versuch über die URL zu installieren.
                        @Ralla66 das scheint nicht zu klappen:
                        $ ./iobroker url "https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz" --debug
                        install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
                        npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz --production --save --prefix "/opt/iobroker" (System call)
                        npm
                         ERR! code ENOPACKAGEJSON
                        npm
                        ERR!
                        package.json Non-registry package missing package.json: https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz.npm
                         ERR! package.json
                         npm can't find a package.json file in your current directory.
                        npm
                        npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T13_53_17_665Z-debug.log
                        process exited with code 0
                        • Ralla66
                          Da kann ich nicht mehr weiter helfen.
                          Dir scheint ein package.json file zu fehlen oder liegt im falschen directory.
                            @Ralla66 - okay, dann gebe ich mich erstmal geschlagen! Danke trotzdem für deine Hilfe!
                            • Zefau
                              Zefau last edited by
                              Installier mal canvas 2.6
                                Sundance @Zefau last edited by
                                @Zefau - danke für den hinweis. hast du einen Tipp wo und wie genau ich das installieren soll? Der Fehler mit "package.json" kommt leider auch bei dem entsprechendem Link von der 2.6 Version..
                                Ich habe als root einfach folgendes gemacht:
                                npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-x64.tar.gz
                                Aber der Fehler mit dem package.json bleibt:
                                root@HOME:/home/pi# npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-x64.tar.gz
                                npm ERR! code ENOPACKAGEJSON
                                npm ERR! package.json Non-registry package missing package.json: https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-x64.tar.gz.
                                npm ERR! package.json npm can't find a package.json file in your current directory.
                                npm ERR!     /root/.npm/_logs/2019-08-08T16_25_34_957Z-debug.log
                                Hast du einen Tipp?
                                • Zefau
                                  Zefau last edited by Zefau
                                  Sorry, war noch unterwegs, daher die knappe Antwort.
                                  Hast du die build-essentials installiert?
                                  Danach dann einfach canvas 2.6.0 von npm:
                                  sudo npm install canvas@2.6.0 --unsafe-perm=true
                                  EDIT: den zweiten Befehl im iobroker.roomba Ordner ausführen. Also unter /opt/iobroker/node_modules/iobroker.roomba.
                                  EDIT2: Hab jetzt den Verlauf nicht komplett gelesen, aber die fehlende package.json liegt daran, dass du in einem völlig falschen Ordner bist (/home/pi?). Die Befehle müssen im iobroker.roomba Ordner ausgeführt werden, wenn diese dafür greifen sollen.
                                    @Zefau kein Problem, danke für deine Unterstützung.
                                    Auch die Installtion von 2.6.0 schlägt fehl (404), allerdings scheint das Problem in einem falschen Link in dem package zu liegen. Habe diese Issue hier gefunden: https://github.com/node-gfx/node-canvas-prebuilt/issues/84
                                    Dann muss man aktuell wohl warten, bis das seitens der entwickler von node-canvas behoben ist, wenn ich das richtig verstehe?
                                    denniskawurek created this issue in node-gfx/node-canvas-prebuilt
                                    open Electron build fails (Pre-built binaries not found) #84
                                    • Zefau
                                      Zefau @Sundance last edited by Zefau
                                      @Sundance Kannst du das Log bitte posten? Welche URL wirft 404? Siehe https://github.com/node-gfx/node-canvas-prebuilt/releases welche prebuilts es gibt.
                                      Die prebuilds gibt es nur für LTS Versionen von node, also v8, v10 und v12. Du solltest von v11 zurück auf v10 gehen.
                                      Davon unabhängig: Wenn er keine prebuilts findet, dann kompiliert Linux eigl. selbst. Versucht das System dies bei dir gar nicht, oder kommt dann dein node-gyp Fehler?
                                        @Zefau Aktuell bin ich auf node Version 10.16.2 - müsste also passen, oder? Hier das log von der installation von canvas 2.6.0:
                                        root@HOME:/home/pi# sudo npm install canvas@2.6.0 --unsafe-perm=true
                                        > canvas@2.6.0 install /home/pi/node_modules/canvas
                                        node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-arm.tar.gz
                                        node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                                        ../src/bmp/BMPParser.cc:189:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                        ../src/bmp/BMPParser.cc:204:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                        ../src/Canvas.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)':
                                        ../src/Canvas.cc:415:26: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                             if (canvas->nBytes() > node::Buffer::kMaxLength) {
                                          CXX(target) Release/obj.target/canvas/src/closure.o
                                          CXX(target) Release/obj.target/canvas/src/color.o
                                          CXX(target) Release/obj.target/canvas/src/Image.o
                                          CXX(target) Release/obj.target/canvas/src/ImageData.o
                                          CXX(target) Release/obj.target/canvas/src/init.o
                                          CXX(target) Release/obj.target/canvas/src/register_font.o
                                          SOLINK_MODULE(target) Release/obj.target/canvas.node
                                          COPY Release/canvas.node
                                        npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
                                        + canvas@2.6.0
                                        added 62 packages from 35 contributors and audited 741 packages in 127.47s
                                        found 0 vulnerabilities
                                        Ich habe danach einfach nochmal die adapter installation versucht, aber sie schlägt weiterhin mit folgendem Log fehl:
                                        root@HOME:/home/pi# iobroker install iobroker.roomba
                                        ^[fNPM version: 6.9.0
                                        gyp ERR! not ok
                                        npm ERR! errno 1
                                        npm ERR!
                                        npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T18_50_01_882Z-debug.log
                                        • Zefau
                                          @Sundance Sieht an sich gut aus. Die Installation von Canvas 2.6.0 läuft durch, die von 2.5.0 (die aktuell noch bei ioBroker.roomba gezogen wird) nicht.
                                          Versuch mal die aktuelle Version vom Repository zu installieren: iobroker url https://github.com/Zefau/ioBroker.roomba.
                                          Github habe ich jetzt auf 2.6.0 aktualisiert, dann sollte es passen.
                                            @Zefau - Danke für das Update, jetzt hat es funktioniert! 🙂
                                            Adapter lies sich jetzt problemlos installieren - den 404 Fehler im Installationsdurchlauf zeigt er zwar immernoch an, aber es hat trotzdem geklappt.
                                            Vielen dank 🙂 bin gespannt auf den Adapter
                                            Zefau Glasfaser 2 Replies Last reply Reply Quote 0
                                            adapter installation installation node-pre-gyp err
                                            5350
