    3. Entwicklung
    4. [Neuer Adapter] hue-extended
    • BBTown
      BBTown @Zefau last edited by
      @Zefau
      ich kann mit den Datenpunkten nicht arbeiten.
      Andauernd scheint irgendetwas refresht zu werden, so das die Ansicht der Datenpunkte in einer Tour pumpt, zuckt und hin und her springt.
        sigi234 Forum Testing Most Active @BBTown last edited by
        @BBTown sagte in [Neuer Adapter] hue-lights:
        Bei mir auch........
        • BBTown
          @Zefau
          ich habe auch einige Fehlermeldungen
          hue-lights.0	2019-08-07 22:40:31.439	error	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
          hue-lights.0	2019-08-07 22:40:31.439	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
          hue-lights.0	2019-08-07 22:40:31.439	error	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
          hue-lights.0	2019-08-07 22:40:31.439	error	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
          hue-lights.0	2019-08-07 22:40:31.439	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
          hue-lights.0	2019-08-07 22:40:31.439	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
          hue-lights.0	2019-08-07 22:40:31.439	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5290:18)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Adapter.emit (events.js:198:13)
          hue-lights.0	2019-08-07 22:40:31.439	error	at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.hue-lights/hue-lights.js:79:19)
          hue-lights.0	2019-08-07 22:40:31.439	error	TypeError: library.terminate is not a function
          hue-lights.0	2019-08-07 22:40:31.439	error	uncaught exception: library.terminate is not a function
          • Zefau
            Merkwürdig, bei mir läuft es sauber. Dann geht erstmal auf die Vorversion. Ich schaue heute Abend nochmal.
            • Hiltex
              Hiltex last edited by
              Hi.
              Ich habe heute meine ersten HUE-Lampen in Betrieb genommen und direkt mal diesen Adapter ausprobiert. Auf der Suche nach einer Möglichkeit, eine Lampe mit einem einzelnen Befehl zu steuern ist mir aufgefallen, dass der Datenpunkt xy einer Lampe vom Typ value ist, jedoch einen Wert wie 0.2503,0.5168 trägt. Dieses Format passt jedoch nicht zum Typ value, weshalb man da nichts verwertbares eingeben kann.
              Gestattet mir jedoch bitte folgende allgemeine Frage:
              Wie kann man die Lichtfarbe, Helligkeit und Temperatur einer Lampe einstellen? Welche Datenpunkte müssen dazu verwendet werden?
              Zefau 2 Replies Last reply Reply Quote 0
              • Zefau
                @BBTown @sigi234 Hab nochmal ein Update auf Github geschoben (Versionsnummer bleibt gleich). Bitte nochmal probieren, ob es nun stabiler läuft.
                BBTown sigi234 2 Replies Last reply Reply Quote 0
                • Zefau
                  Zefau @Hiltex last edited by
                  @Hiltex sagte in [Neuer Adapter] hue-lights:
                  Habe ich in der aktuellen Version auf Github angepasst. Bitte die Version von Github drüber installieren. Danach bitte den Datenpunkt xy löschen und Adapter neustarten. Der (angepasste) Datenpunkt sollte dann richtig angelegt werden.
                  • Zefau
                    hue ist das Farbspektrum (Lichtfarbe?). Helligkeit ist bri.
                    Hiltex 1 Reply Last reply Reply Quote 0
                    • BBTown
                      @Zefau
                      Mein erster Eindruck ist, dass alles sehr viel ruhiger läuft 👍
                      • Hiltex
                        Hiltex @Zefau last edited by
                        @Zefau Danke. Aber hast du das auch mal ausprobiert? Normalerweise müsste die Lampe ja rot leuchten, wenn ich da eine 0 reinschreibe, gelb bei 90, usw. das funktioniert jedoch leider nicht.
                        Auch die Kombination mit HomeKit und Yahka funktioniert nicht, wobei ich behaupten würde, das HomeKit und Yahka korrekt arbeiten. Ich hab die Werte mal in ein paar Testdatenpunkte schreiben lassen und da kommen die Werte wie erwartet an.
                        Der andere Hue-Adapter arbeitet da meiner Ansicht nach auch nicht korrekt. Dort konnte ich mir aber mit XY behelfen.
                        Ich würde mich freuen, wenn du dir das nochmal anschauen könntest.
                        Zefau 3 Replies Last reply Reply Quote 0
                        • Zefau
                          Zefau @Hiltex last edited by Zefau
                          Laut hue API Dokumentation:
                          Hue of the light. This is a wrapping value between 0 and 65535.
                          Note, that hue/sat values are hardware dependent which means that programming two devices with the same value does not garantuee that they will be the same color. Programming 0 and 65535 would mean that the light will resemble the color red, 21845 for green and 43690 for blue.
                          • Zefau
                            Welche Kombination? Mit dem Datenpunkt für den hue Wert?
                            • Zefau
                              Sollte nun auch bei diesem Adapter funktionieren. Ggf. die alten States löschen und neu anlegen.
                              BBTown 2 Replies Last reply Reply Quote 0
                                sigi234 Forum Testing Most Active @Zefau last edited by sigi234
                                @Zefau sagte in [Neuer Adapter] hue-lights:
                                Nein nicht so Richtig, ich glaube es hat was damit zu tun, weil ich auch den Hue Adapter laufen habe und die App all4hue.
                                Wenn ich alles anhake habe ich ca. 3000 Datenpunkte..........
                                Edit2
                                Es wird besser, braucht anscheinend zum Anfang einige Zeit..........derzeit 1400 DP. Einige Haken habe ich aber mal rausgenommen.
                                • BBTown
                                  xy ist nun aber erneut als "text" angelegt?!
                                  • BBTown
                                    BBTown @Zefau last edited by BBTown
                                    @Zefau
                                    müßten "bri" und "level" nicht beide vom Typ "level.dimmer" sein?
                                    EDIT
                                    https://www.iobroker.net/#en/documentation/dev/stateroles.md
                                    • Zefau
                                      Zefau @BBTown last edited by
                                      Als was ist es denn im hue Adapter angelegt? Funktioniert es denn auch nicht als Text?
                                      • Hiltex
                                        Soweit richtig, 0...360° waren die alten Werte. Entsprechend der Beschreibung müsste bei voller Sättigung (255) und Farbwert 21845 die Lampe grün leuchten. Das tut sie aber nicht, die Farbe bleibt einfach unverändert und der Wert, der zuvor in hue geschrieben wurde, wird bei der nächsten Aktualisierung einfach auf 0 gesetzt.
                                        Ja genau, die Farbe über HomeKit -> Yahka -> hue-lights zu setzen. Das ist das eigentlich erklärte ziel. Dass das jedoch nicht funktioniert, wenn das manuelle setzen des hue-Wertes nicht klappt, scheint mir logisch 😉
                                        • Zefau
                                          @Hiltex Jo, ich versuche es komplett zu verstehen. Was sagt das Log?
                                          • Hiltex
                                            Hiltex @Zefau last edited by Hiltex
                                            @Zefau das Log:
                                            hue-lights.0	2019-08-09 07:59:18.602	debug	system.adapter.admin.0: logging true
                                            hue-lights.0	2019-08-09 07:59:13.941	debug	Refreshing scenes ({"scenes":{"HCms0PK98-UyxCI":{"name":"Entspannen","type":"GroupScene","group":"8","lights":["1","2"],"owner":"ebd73c0e-eba4-41b3-8c88-9a29acc06964","recycle":false,"locked":false,"
                                            hue-lights.0	2019-08-09 07:59:13.924	debug	Retrieving scenes from Hue Bridge...
                                            hue-lights.0	2019-08-09 07:59:13.915	debug	Refreshing lights ({"lights":{"1":{"state":{"on":false,"bri":254,"hue":0,"sat":189,"effect":"none","xy":[0.4426,0.4058],"ct":345,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":
                                            hue-lights.0	2019-08-09 07:59:13.904	debug	Received updated value for config.whitelist.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx-node.js_api.last use date: "2019-08-09T05:59:14"
                                            hue-lights.0	2019-08-09 07:59:13.902	debug	Received updated value for config.localtime: "2019-08-09T07:59:14"
                                            hue-lights.0	2019-08-09 07:59:13.901	debug	Received updated value for config.UTC: "2019-08-09T05:59:14"
                                            hue-lights.0	2019-08-09 07:59:13.900	debug	Refreshing config ({"config":{"name":"Philips hue","zigbeechannel":20,"bridgeid":"ECB5FAFFFE054110","mac":"ec:b5:fa:05:41:10","dhcp":true,"ipaddress":"192.168.243.61","netmask":"255.255.255.0","gatew
                                            hue-lights.0	2019-08-09 07:59:13.898	debug	Retrieving lights from Hue Bridge...
                                            hue-lights.0	2019-08-09 07:59:13.885	debug	Retrieving config from Hue Bridge...
                                            hue-lights.0	2019-08-09 07:59:13.065	debug	system.adapter.admin.0: logging false
                                            hue-lights.0	2019-08-09 07:59:07.813	info	Successfully set /lights/2/state/hue on device Nachttischlampe rechts (to 21000).
                                            hue-lights.0	2019-08-09 07:59:07.799	debug	Send command to Nachttischlampe rechts (lights/2/state): {"hue":21000}.
                                            79.9k
                                            adapter
                                            32
                                            441
                                            81225
