    4. [Aufruf] G-Homa Adapter testen
    • AlCalzone
      AlCalzone Developer @RichieXX last edited by
      @RichieXX Das ist auch was anderes 😓
      Öffne bitte die Adapter-Datei mit einem Texteditor
      nano /opt/iobroker/node_modules/iobroker.g-homa/build/main.js
      und ändere die Zeilen 37/38 von
                  console.log = (msg) => adapter.log.debug("STDOUT > " + msg);
                  console.error = (msg) => adapter.log.error("STDERR > " + msg);
      zu
      //            console.log = (msg) => adapter.log.debug("STDOUT > " + msg);
      //            console.error = (msg) => adapter.log.error("STDERR > " + msg);
      (also einfach je 2 Slashes davor).
      Mit STRG+X schließen, Speichern mit Y bestätigen.
      Danach bitte nochmal probieren.
        RichieXX last edited by RichieXX
        @AlCalzone sagte in [Aufruf] G-Homa Adapter testen:
        DEBUG=g-homa node main.js --force --logs
        root@iobroker:~# cd /opt/iobroker/node_modules/iobroker.g-homa/build
        root@iobroker:/opt/iobroker/node_modules/iobroker.g-homa/build# DEBUG=g-homa node main.js --force --logs
        starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.g-homa, node: v8.16.0
        enumerating known plugs...
        found plug with id 85215c (offline)
        starting server...
        server started on port 55555
        searching plugs
          g-homa connection from ::ffff:192.168.253.39 +0ms
          g-homa connection from ::ffff:192.168.253.39 +2s
          g-homa invalid data in the receive buffer +27s
          g-homa ff000e8146000080005f00012a07055c63fe +0ms
        Error: invalid data in the receive buffer
            at parseMessage (/opt/iobroker/node_modules/g-homa/build/server.js:62:15)
            at Socket.<anonymous> (/opt/iobroker/node_modules/g-homa/build/server.js:210:26)
            at emitOne (events.js:116:13)
            at Socket.emit (events.js:211:7)
            at addChunk (_stream_readable.js:263:12)
            at readableAddChunk (_stream_readable.js:250:11)
            at Socket.Readable.push (_stream_readable.js:208:10)
            at TCP.onread (net.js:601:20)
        unhandled exception:invalid data in the receive buffer
        > stack: Error: invalid data in the receive buffer
        Das kommt, wenn der Plug im WLAN erreichbar ist:
        starting server...
        searching plugs
          g-homa connection from ::ffff:192.168.253.25 +573ms
          g-homa unknown plug type detected. triggercode is 0x346b +164ms
          g-homa the full payload was: 0x010ac0346b85215c01ff +1ms
          g-homa connection from ::ffff:192.168.253.39 +1s
        Added plug with ID 85215c
          g-homa got update: 010ae0346b85215cfffe01811100000100000000 +889ms
        Got updated info for Plug 85215c:
          state: off
          switched from: local
          type: undefined
        extendPlug: type = undefined, energyMeasurement != null: true
        current != null: false
        powerFactor != null: false
        power != null: false
        voltage != null: false
        voltage in plug.energyMeasurement => false
        current in plug.energyMeasurement => false
        power in plug.energyMeasurement => false
        powerFactor in plug.energyMeasurement => false
          g-homa invalid data in the receive buffer +49s
          g-homa ff00020103feff000e8146000080005f00012a07055c63fe +1ms
        • AlCalzone
          AlCalzone Developer @RichieXX last edited by AlCalzone
          @RichieXX Danke. Ich habe die Vermutung, dass es hier Konflikte mit einem anderen Gerät gibt. Du kannst mir helfen, heraus zu finden, wie das reagiert, damit ich die automatische Erkennung im Adapter verbessern kann.
          Dazu tue bitte folgendes:
          1. Konsole öffnen, cd /opt/iobroker/node_modules/g-homa/build
          2. node serial.js
          3. Gebe eine der IPs ein: 192.168.253.39 oder 192.168.253.25, [ENTER]
          4. Gebe ein: HF-A11ASSISTHREAD, dann [ENTER]
          5. Wenn eine Antwort kommt, gebe (relativ zügig) ein +ok, dann [ENTER]
          6. Gebe bitte nacheinander die folgenden Kommandos ein, jeweils gefolgt von [ENTER]. Wenn eine Antwort kommt, bitte hier posten:
            • AT+MID\r
            • AT+VER\r
            • AT+LVER\r
          7. Wiederhole das ganze für die andere IP-Adresse. Das Programm kannst du jeweils per STRG+C beenden.
            AT+LVER\r
            Aber gerne!
            Vorab als Info: Die IP ..39 ist ein MiLight LED Controller (YL5)
            root@iobroker:~# cd /opt/iobroker/node_modules/g-homa/build
            root@iobroker:/opt/iobroker/node_modules/g-homa/build# node serial.js
            G-Homa command line serial interface ready...
            Which IP to talk to? [default: Broadcast IP] 192.168.253.39
            talking to 192.168.253.39. enter "QUIT" to return to IP selection
            192.168.253.39 > HF-A11ASSISTHREAD
            192.168.253.39: 192.168.253.39,98D863080AB0,HF-LPT230
            192.168.253.39 > +ok
            192.168.253.39 > AT+MID\r
            192.168.253.39: +ok=HF-LPT230
            192.168.253.39 > AT+VER\r
            192.168.253.39: +ok=4.12.15 (2018-12-04 13:30 1M)
            192.168.253.39 > AT+LVER\r
            192.168.253.39 >
            Mit der ..25 (Das ist der einzige G-Home Plug den ich habe):
            Which IP to talk to? [default: Broadcast IP] 192.168.253.25
            talking to 192.168.253.25. enter "QUIT" to return to IP selection
            192.168.253.25 > HF-A11ASSISTHREAD
            192.168.253.25: 192.168.253.25,F0FE6B85215C,G-Homa
            192.168.253.25 > +ok
            192.168.253.25 > AT+MID\r
            192.168.253.25: +ok=G-Homa
            192.168.253.25 > AT+VER\r
            192.168.253.25: +ok=GAO,Outdoor,1.8.26
            192.168.253.25 > AT+LVER\r
            192.168.253.25: +ok=08 (2015-06-05 11:12 16B)
            Wenn ich das also richtig verstehen, wird irgendwie der MiLight hier versuch mit einzubinden und dabei kommt es verständlicherweise zu Kommunikationsproblemen. Korrekt?
            • AlCalzone
              @RichieXX Genau da liegt der Hase im Pfeffer. Bisher hatte nur noch keiner den Fall, dass gleich beides im selben Netzwerk hängt.
              Ich versuche bei Gelegenheit nochmal zu schauen, wie sich meine schon etwas ältere Dose ausgibt. Dann kann ich hoffentlich vermeiden, dass das MiLight mit dem G-Homa-Adapter spricht.
              Du wirst dich leider ein paar Tage gedulden müssen.
                Kein Problem. Mit dem Plug wird der Weihnachtsbaum geschaltet... 😁
                • AlCalzone
                  @RichieXX Probiere bitte mal die Version 0.5.0. Es kann sein, dass du dein MiLight vorher zurücksetzen musst.
                    Das ging dann doch schneller, wie ich erwartet habe 🙂
                    Hab die 0.5.0 installiert und der Fehler tritt weiterhin auf (ohne Reset des Milight).
                    Warum muss ich den Milight zurücksetzen? Reicht es wenn, ich dem eine neue IP verpasse?
                    Das ist die Ausgabe mit 0.5.0 (Ich hab nach dem "ERR" nicht weitergemacht):
                    192.168.253.39: +ERR=-1
                    192.168.253.39 >
                    starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.g-homa, node: v8.16.0
                    starting server...
                    searching plugs
                      g-homa connection from ::ffff:192.168.253.25 +0ms
                      g-homa unknown plug type detected. triggercode is 0x346b +220ms
                      g-homa the full payload was: 0x010ac0346b85215c01ff +0ms
                      g-homa connection from ::ffff:192.168.253.39 +206ms
                      g-homa got update: 010ae0346b85215cfffe01811100000100000000 +2s
                      state: off
                      type: undefined
                      g-homa connection from ::ffff:192.168.253.25 +972ms
                      g-homa unknown plug type detected. triggercode is 0x346b +43ms
                      state: off
                      type: undefined
                      g-homa ff00020103feff000e814600008000000000000705d299fe +0ms
                        at parseMessage (/opt/iobroker/node_modules/iobroker.g-homa/node_modules/g-homa/build/server.js:62:15)
                        at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.g-homa/node_modules/g-homa/build/server.js:210:26)
                    • AlCalzone
                      @RichieXX sagte in [Aufruf] G-Homa Adapter testen:
                      Weil der weiterhin denkt, er muss mit dem G-Homa-Adapter reden. Die Einstellung bekommst du nur mit einem Reset wieder weg.
                        Tut mie leid. Auch ein Reset hat keine Wirkung (ich habe angenommen, dass das drücken der Taste SET für 3s - Wiedereinbinden ins WLAN, ein Reset bedeutet, was anderes konnte ich nicht finden)
                        • AlCalzone
                          @RichieXX Schau mal hier:
                          1. Mi-Light WLAN Controller mit Spannung versorgen, die LED SYS blinkt. Der Mi-Light WLAN Controller arbeitet in den Werkseinstellungen als Access-Point Ein Werksreset kann durchgeführt werden, in dem der Reset Knopf 10 Sekunden lang gedrückt wird bis die beiden LEDs Link und SYS blinken.
                          2. Mit dem Smart Phone nach dem WLAN Netz milight suchen und verbinden. Wird das WLAN milight nicht gefunden, muss ein Werksreset durchgeführt werden.
                          3. App starten und die Systemkonfiguration durchführen (Einbindung in eigenes WLAN).
                            Es betrifft nicht die iBox2 sondern den neuen Milight Controller (https://milight.pro/manuals/YL5_EN.pdf) und ich denke ich habe den richtig zurückgesetzt. Ich habe leider auch nicht mehr so viel Zeit, denn das Teil geht wieder zurück (der iobroker-milight-adapter unterstützt den YL5 nicht). Ich verwende dann den gleichen Controller ohne WLAN. Dieser wird dann an die iBox2 angebunden. Davon habe ich zwei Stück im WLAN und die machen keine Probleme mit dem g-homa Adapter.
                            31.7k
                            79.8k
                            177
                            29798
