    5. [gelöst] Hilfe bei zeitsteuerung
    • Aphofis
      Aphofis last edited by Aphofis
      Ist das so korrekt?
        <variables>
          <variable type="" id="u5iug_dP{RWS.8r9[r{%">Dauer</variable>
          <variable type="" id="Q7*Gw)fesXb}OUBj1{`;">Uhrzeit_1</variable>
          <variable type="undefined" id="Intervall">Intervall</variable>
          <variable type="undefined" id="schedule_1">schedule_1</variable>
        </variables>
        <block type="procedures_defnoreturn" id="jE$gVVpa7!Xtx{X@H^Fd" x="-737" y="-762">
          <field name="NAME">Futter</field>
          <statement name="STACK">
            <block type="variables_set" id="9kptcK|P^2:}bKZXyZ8f">
              <field name="VAR" id="u5iug_dP{RWS.8r9[r{%" variabletype="">Dauer</field>
                <block type="get_value" id=".,XzJi)h(f$9$~(`H$I!">
                  <field name="OID">Aqua_Control.0.Futterautomatik_multiplikator</field>
                <block type="control" id="%}iPzHc5tUi.(P1_MvRo">
                  <field name="OID">rpi2.0.gpio.25.state</field>
                    <block type="logic_boolean" id="SM.e~4#O=p?c/SXA|JX%">
                    <block type="comment" id="KV;?nPX*TAluqR-qF9f+">
                      <field name="COMMENT">Intervalldauer = Faktor</field>
                        <block type="timeouts_setinterval" id="1+dIQ5^rJM?nkaI[6WN}">
                          <field name="NAME">Intervall</field>
                          <field name="INTERVAL">800</field>
                          <field name="UNIT">ms</field>
                            <block type="math_change" id="!*zN$DgW0K=76_[.1*]X">
                              <value name="DELTA">
                                <shadow type="math_number" id="e_D7=bSd65:`]Q{qWSZD">
                                  <field name="NUM">-1</field>
                                <block type="controls_if" id="=/[;A-M~WF?KXEx~W0z?">
                                    <block type="logic_compare" id=";qY,PC)CB~{1#4iVHaj,">
                                      <field name="OP">LTE</field>
                                        <block type="variables_get" id="2k;4KgTu$A3wF)@V`ulP">
                                        <block type="math_number" id="?bnhw6qVm`$}~NCKlw2P">
                                          <field name="NUM">0</field>
                                    <block type="timeouts_clearinterval" id=";dz/hf`o4]4(2pDSH)I3">
                                    <block type="control" id="SeaFI}%xNdyzRbLV,6HN">
                                        <block type="logic_boolean" id="1_[)-;0}n;LMH}tCmhi:">
        <block type="comment" id="g{Y%*~I{x`_l;*~`c*Fr" x="-717" y="-405">
          <field name="COMMENT">1. Uhrzeit hh:mm</field>
            <block type="on_ext" id="}BTi=~h~RiZ;@8S.a_*{">
              <value name="OID0">
                <shadow type="field_oid" id="6R*wwsh+EjXJ1d`_3hxv">
                <block type="variables_set" id="{M}nz9j/hOc[/j9R0[zd">
                  <field name="VAR" id="Q7*Gw)fesXb}OUBj1{`;" variabletype="">Uhrzeit_1</field>
                    <block type="lists_split" id="g,gp5[yex~P:LF-[.*((">
                      <mutation mode="SPLIT"></mutation>
                      <field name="MODE">SPLIT</field>
                      <value name="INPUT">
                        <block type="on_source" id="Pyx^=nsIZs@M|nbNaAiW">
                      <value name="DELIM">
                        <shadow type="text" id="OEq|yeHMb*DILCJQAnkd">
                          <field name="TEXT">:</field>
                    <block type="schedule_clear" id="O0@)[PTM_!LiaM@04{V#">
                      <field name="NAME">schedule_1</field>
                        <block type="schedule_create" id="6x%+6G+PaD[w*{FuFm=K">
                          <value name="SCHEDULE">
                            <shadow type="field_cron" id="m4F75|F$}NA}2;e/avWa">
                              <field name="CRON">* * * * *</field>
                            <block type="cron_builder" id="q6(U2T{7uu}mYF)9QMKr">
                              <mutation seconds="false" as_line="false"></mutation>
                              <field name="LINE">FALSE</field>
                              <field name="WITH_SECONDS">FALSE</field>
                              <value name="DOW">
                                <shadow type="text" id=")8oVcqHY5re?jv#0QsO8">
                                  <field name="TEXT">*</field>
                              <value name="MONTHS">
                                <shadow type="text" id="GfQ!DoE|TZTliq*)8,@j">
                              <value name="DAYS">
                                <shadow type="text" id="S6hVuxIjcYJMlS^~:zE5">
                              <value name="HOURS">
                                <shadow type="text" id="NP{*G*@dWEP9M9mNlZFF">
                                <block type="lists_getIndex" id="-0gZ}|H=8/}~St}d%rl;">
                                    <block type="variables_get" id="8U#M]$`MHq(~A]~(v{2R">
                                  <value name="AT">
                                    <block type="math_number" id=")zFTxG~Gpp`eZw8r2,8w">
                                      <field name="NUM">1</field>
                              <value name="MINUTES">
                                <shadow type="text" id="I(LCmtz/NJ%:Tvp,*;JL">
                                <block type="lists_getIndex" id="0([.HRKLsVPA.X:jwVI@">
                                    <block type="variables_get" id="8#E0pY-UET(BcZH]~qB:">
                                  <value name="AT">
                                    <block type="math_number" id=";UF-jK:^cV#hui?GDL/V">
                                      <field name="NUM">2</field>
                            <block type="procedures_callnoreturn" id="/6qq{?/)+*vm:UnA$x,0">
                              <mutation name="Futter"></mutation>
                <block type="comment" id="7wspNJ:OA(%4Ab.`5IAO">
                  <field name="COMMENT">2. Uhrzeit hh:mm</field>
      Woher kommt jetzt die Uhrzeit in der Liste ???
      Und was kommt in den trigger für ein Objekt in die Objekt ID ?
      Oder kommt in den trigger dann der datenpunkt rein wo man die Uhrzeit einstellen kann für die erste Futter Dosierung?
        paul53 @Aphofis last edited by
        @Aphofis sagte:
        Ja, steht doch im Kommentar über dem Trigger.
        @Aphofis sagte in Hilfe bei zeitsteuerung:
        Ist das so korrekt?
        Ich habe keine Lust, das zu importieren. Poste bitte den vom Blockly erzeugten Javascript-Code ohne die letzte Zeile in Code tags.
        Aphofis 1 Reply Last reply Reply Quote 0
        • Aphofis
          Aphofis @paul53 last edited by Aphofis
          var Dauer, Uhrzeit_1, Intervall, schedule_1, Uhrzeit_2, schedule_2, Uhrzeit_3, schedule_3, Uhrzeit_4, schedule_4;
           * Beschreibe diese Funktion …
          function Futter() {
            Dauer = getState("Aqua_Control.0.Futterautomatik_multiplikator").val;
            setState("rpi2.0.gpio.25.state"/*Futterautomat_Buchse_4*/, true);
            // Intervalldauer = Faktor
            Intervall = setInterval(function () {
              Dauer = (typeof Dauer == 'number' ? Dauer : 0) + -1;
              if (Dauer <= 0) {
                (function () {if (Intervall) {clearInterval(Intervall); Intervall = null;}})();
              setState("rpi2.0.gpio.25.state"/*Futterautomat_Buchse_4*/, false);
            }, 800);
          // 1. Uhrzeit hh:mm
          on({id: 'Aqua_Control.0.Futterautomatik_Uhrzeit_1', change: "ne"}, function (obj) {
            var value = obj.state.val;
            Uhrzeit_1 = (obj.state ? obj.state.val : "").split(':');
            (function () {if (schedule_1) {clearSchedule(schedule_1); schedule_1 = null;}})();
            schedule_1 = schedule((Uhrzeit_1[1]).trim() + ' ' + (Uhrzeit_1[0]).trim() + ' ' + '*'.trim() + ' ' + '*'.trim() + ' ' + '*'.trim(), function () {
              Futter();
          // 2. Uhrzeit hh:mm
          on({id: 'Aqua_Control.0.Futterautomatik_Uhrzeit_2', change: "ne"}, function (obj) {
            Uhrzeit_2 = (obj.state ? obj.state.val : "").split(':');
            (function () {if (schedule_2) {clearSchedule(schedule_2); schedule_2 = null;}})();
            schedule_2 = schedule((Uhrzeit_2[1]).trim() + ' ' + (Uhrzeit_2[0]).trim() + ' ' + '*'.trim() + ' ' + '*'.trim() + ' ' + '*'.trim(), function () {
              Futter();
          // 3. Uhrzeit hh:mm
          on({id: 'Aqua_Control.0.Futterautomatik_Uhrzeit_3', change: "ne"}, function (obj) {
            Uhrzeit_3 = (obj.state ? obj.state.val : "").split(':');
            (function () {if (schedule_3) {clearSchedule(schedule_3); schedule_3 = null;}})();
            schedule_3 = schedule((Uhrzeit_3[1]).trim() + ' ' + (Uhrzeit_3[0]).trim() + ' ' + '*'.trim() + ' ' + '*'.trim() + ' ' + '*'.trim(), function () {
              Futter();
          // 4. Uhrzeit hh:mm
          on({id: 'Aqua_Control.0.Futterautomatik_Uhrzeit_4', change: "ne"}, function (obj) {
            Uhrzeit_4 = (obj.state ? obj.state.val : "").split(':');
            (function () {if (schedule_4) {clearSchedule(schedule_4); schedule_4 = null;}})();
            schedule_4 = schedule((Uhrzeit_4[1]).trim() + ' ' + (Uhrzeit_4[0]).trim() + ' ' + '*'.trim() + ' ' + '*'.trim() + ' ' + '*'.trim(), function () {
              Futter();
          Ok so korrekt?
            paul53 @Aphofis last edited by paul53
            @Aphofis sagte:
            so korrekt?
            Nicht ganz: Das Auschalten von "rpi2.0.gpio.25.state"/Futterautomat_Buchse_4/ muss innerhalb der Prüfung Dauer <= 0 erfolgen. Die Datenpunkt-ID für den 1. Uhrzeit-Datenpunkt fehlt noch.
            • Aphofis
              Irgendwie will die Steuerung nicht das Gerät läuft nur für 800 ms mehr nicht.
              Ich verstehe noch nicht den gesamten Zusammenhang.
              function Futter() {
                setState("sonoff.0.Aqua_Dosierer.POWER1"/*Aqua_Dosierer_Pumpe_1*/, true);
                  if (Dauer <= 0) {
                  setState("sonoff.0.Aqua_Dosierer.POWER1"/*Aqua_Dosierer_Pumpe_1*/, false);
                }, 800);
              // 1. Uhrzeit hh:mm
              on({id: 'sonoff.0.Aqua_Dosierer.POWER1', change: "ne"}, function (obj) {
                  Futter();
              // 2. Uhrzeit hh:mm
              // 3. Uhrzeit hh:mm
              // 4. Uhrzeit hh:mm
                  Futter();
                @Aphofis sagte:
                @paul53 sagte in Hilfe bei zeitsteuerung:
                steuere Aqua_Dosierer_Pumpe_1 mit falsch muss in das Maul von falls Dauer <= 0, nicht darunter.
                Bist Du sicher, dass das der richtige Datenpunkt ist ?
                // 1. Uhrzeit hh:mm
                Aphofis 1 Reply Last reply Reply Quote 1
                • Aphofis
                  Ich habe nur eine nicht gebrauchte dosier Pumpe zum testen benutzt.
                  Sonst ist der furtterautomat leer bis die Steuerung funktioniert 😊🤪
                  • Aphofis
                    Jetzt da steuere in der Tasche unter dem stop zyklische Ausführung ist macht die Steuerung nix mehr
                      @Aphofis sagte:
                      Dann bau mal ein Log ein:
                      • Aphofis
                        Log eingebaut!
                        Kommt keine Meldung in der log nur das dass Script gestartet ist!
                        Wieso eigentlich
                        Erhöhe Dauer um -1 was bewirkt das ?
                        Das ich zwei datenpunkte habe!? Ist bewusst?
                        Einer wo die Uhrzeit drin steht wann dosiert werden soll und ein datenpunkt ist so zu sagen wie lange die Dosierung stattfinden soll
                        Also eine Dosierung sind 800ms
                        Wenn in dem datenpunkt multiplikator steht zb 3
                        Dann soll die Dosierung 3x800 Millisekunden lang sein demnach 2400 ms
                        Hoffe das ist so auch richtig rüber gekommen.
                        Diese beiden datenpunkte jetzt nur zur Dosierung Futter 1 die anderen können wenn’s läuft
                          @Aphofis sagte:
                          Nein, es müssten 3 Datenpunkte sein: Die Dauer enthält der DP "Aqua_Control.0.Futterautomatik_multiplikator", die Pumpensteuerung erfolgt an den DP "sonoff.0.Aqua_Dosierer.POWER1" und in welchem DP steht die Uhrzeit ? Deshalb meine Frage weiter oben:
                          Müsste der nicht eine ID haben wie "Aqua_Control.0.Futterautomatik_Uhrzeit_1" ?
                          • Aphofis
                            Das schon klar!
                            Datenpunkt wie lange dosiert werden soll
                            Ist der futterautomatik_multiplikator
                            Mit wert 1-3 zb
                            Datenpunkt zum testen der auf die Steuerung reagieren soll mit true und false
                            Später dann der futterautomatik Motor
                            Und der datenpunkt mit der Uhrzeit
                            Ja ist
                            Gibt für die erste Futter Dosierung die Zeit an in
                            Formatierung 16:30 zb
                            • Aphofis
                              Wenn’s dann läuft wollte ich die selbe Steuerung dann auch für meine Triton Lösungen und Strontium Dosierung benutzen. Natürlich neu erstellt mit eigenen datenpunkten.
                              Mega wäre natürlich das wenn man zb 6 Dosierungen am Tag hat mit je 2ml (760ms = 1 ml) das dann in der Steuerung zb alle Dosierungen zusammen gezählt werden und dann in der Programmierung nicht mehr als 12 ml ( 9120ms) am Tag dosiert werden dürfen so noch mal als kleine Sperre das auch wirklich nicht mehr dosiert wird.
                                @Aphofis sagte:
                                Das ist ein Count down.
                                • Aphofis
                                  Ok Danke aber laufen will es immer noch nicht
                                  Komisch ist das es zu Anfang zumindest 800ms gelaufen ist nach dem ich steuere pumpe1 in die Tasche vom Intervall gepackt hatte kam nix mehr
                                    @Aphofis sagte:
                                    Dann poste mal den aktuellen Javascript-Code (ohne letzte Zeile).
                                    • Aphofis
                                      Der Code:
                                      function Futter() {
                                          console.log(Dauer);
                                          if (Dauer <= 0) {
                                        }, 800);
                                      // 1. Uhrzeit hh:mm
                                          Futter();
                                      // 3. Uhrzeit hh:mm
                                      // 4. Uhrzeit hh:mm
                                          Futter();
                                      Die datenpunkte:
                                        paul53 last edited by paul53
                                        @Aphofis
                                        Zeile 16: setState() ist immer noch außerhalb der Abfrage if(Dauer <= 0)
                                        Zeile 22: Die ID ist falsch (keine Uhrzeit)
                                        Mit welcher Uhrzeit hast Du es getestet ?
                                        Zum Testen der Funktion Futter rufe die Funktion mal beim Skripstart auf und prüfe den Typ des Multiplikator-Datenpunktes.
                                        Vielleicht hilft die Konvertierung nach Zahl ?
                                        Aphofis 2 Replies Last reply Reply Quote 1
                                        • Aphofis
                                          Hab ich mal eingefügt
                                          Zeiten trage ich in die datenpunkte
                                          Mit zb 16:30 ein
                                          • Aphofis
                                            Wenn ich das Script mit den Änderungen ausführe kommt die Meldung:
                                            Und die Play Pause Zeichen vom Script ist das Pause Zeichen jetzt gelb
                                            Im trigger ist wert
                                            aus trigger Objekt ID korrekt oder ?
                                            Und in der log hat JavaScript eine Menge Fehler mit welcher Steuerung das jetzt zu tun hat weiß ich nicht.
                                            javascript.0	2019-08-15 00:15:20.484	warn	at TCP.onread (net.js:601:20)
                                            javascript.0	2019-08-15 00:15:20.484	warn	at Socket.Readable.push (_stream_readable.js:208:10)
                                            javascript.0	2019-08-15 00:15:20.484	warn	at readableAddChunk (_stream_readable.js:250:11)
                                            javascript.0	2019-08-15 00:15:20.484	warn	at addChunk (_stream_readable.js:263:12)
                                            javascript.0	2019-08-15 00:15:20.483	warn	at Socket.emit (events.js:211:7)
                                            javascript.0	2019-08-15 00:15:20.483	warn	at emitOne (events.js:116:13)
                                            javascript.0	2019-08-15 00:15:20.483	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                                            javascript.0	2019-08-15 00:15:20.483	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                                            javascript.0	2019-08-15 00:15:20.483	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                                            javascript.0	2019-08-15 00:15:20.483	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                                            javascript.0	2019-08-15 00:15:20.483	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                                            javascript.0	2019-08-15 00:15:20.483	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                                            javascript.0	2019-08-15 00:15:20.483	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                                            javascript.0	2019-08-15 00:15:20.483	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                                            javascript.0	2019-08-15 00:15:20.483	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at WebSocket.emit (events.js:214:7)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at emitTwo (events.js:126:13)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                                            javascript.0	2019-08-15 00:15:20.482	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                                            javascript.0	2019-08-15 00:15:20.481	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                                            javascript.0	2019-08-15 00:15:20.480	warn	at Object.<anonymous> (script.js.Automatik_Steuerung.Aquarium_Niveau_Sensor:20:14)
                                            javascript.0	2019-08-15 00:15:20.480	warn	getState "Aqua_Control.0.Aquarium_ausschalten" not found (3)
                                            host.GordonX-Pi	2019-08-15 00:15:02.578	info	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                                            daswetter.0	2019-08-15 00:15:02.045	debug	calling forecast 7 days: https://www.daswetter.com/wetter_Norderstedt-Europa-Deutschland-Schleswig+Holstein--1-27129.html
                                            daswetter.0	2019-08-15 00:15:02.045	debug	using new data structure
                                            daswetter.0	2019-08-15 00:15:02.045	debug	set timeout to 60 sec
                                            daswetter.0	2019-08-15 00:15:02.044	info	starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.16.0
                                            host.GordonX-Pi	2019-08-15 00:15:00.054	info	instance system.adapter.daswetter.0 started with pid 20997
                                            javascript.0	2019-08-15 00:14:30.455	warn	at TCP.onread (net.js:601:20)
                                            javascript.0	2019-08-15 00:14:30.454	warn	at Socket.Readable.push (_stream_readable.js:208:10)
                                            javascript.0	2019-08-15 00:14:30.453	warn	at readableAddChunk (_stream_readable.js:250:11)
                                            javascript.0	2019-08-15 00:14:30.452	warn	at addChunk (_stream_readable.js:263:12)
                                            javascript.0	2019-08-15 00:14:30.451	warn	at Socket.emit (events.js:211:7)
                                            javascript.0	2019-08-15 00:14:30.450	warn	at emitOne (events.js:116:13)
                                            javascript.0	2019-08-15 00:14:30.449	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                                            javascript.0	2019-08-15 00:14:30.445	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                                            javascript.0	2019-08-15 00:14:30.445	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                                            javascript.0	2019-08-15 00:14:30.444	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                                            javascript.0	2019-08-15 00:14:30.444	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                                            javascript.0	2019-08-15 00:14:30.444	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                                            javascript.0	2019-08-15 00:14:30.443	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                                            javascript.0	2019-08-15 00:14:30.442	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                                            javascript.0	2019-08-15 00:14:30.437	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                                            javascript.0	2019-08-15 00:14:30.437	warn	at WebSocket.emit (events.js:214:7)
                                            javascript.0	2019-08-15 00:14:30.436	warn	at emitTwo (events.js:126:13)
                                            javascript.0	2019-08-15 00:14:30.435	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                                            javascript.0	2019-08-15 00:14:30.434	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                                            javascript.0	2019-08-15 00:14:30.433	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                                            javascript.0	2019-08-15 00:14:30.433	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                                            javascript.0	2019-08-15 00:14:30.432	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                            javascript.0	2019-08-15 00:14:30.432	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                                            javascript.0	2019-08-15 00:14:30.432	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                                            javascript.0	2019-08-15 00:14:30.431	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                            javascript.0	2019-08-15 00:14:30.431	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                            javascript.0	2019-08-15 00:14:30.430	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                                            javascript.0	2019-08-15 00:14:30.430	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                                            javascript.0	2019-08-15 00:14:30.429	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                                            javascript.0	2019-08-15 00:14:30.429	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                            javascript.0	2019-08-15 00:14:30.429	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                                            javascript.0	2019-08-15 00:14:30.428	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                            javascript.0	2019-08-15 00:14:30.428	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                            javascript.0	2019-08-15 00:14:30.427	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
                                            javascript.0	2019-08-15 00:14:30.427	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
                                            javascript.0	2019-08-15 00:14:30.426	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                            javascript.0	2019-08-15 00:14:30.425	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                                            javascript.0	2019-08-15 00:14:30.424	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
                                            javascript.0	2019-08-15 00:14:30.424	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
                                            javascript.0	2019-08-15 00:14:30.423	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                                            javascript.0	2019-08-15 00:14:30.421	warn	at Object.<anonymous> (script.js.Automatik_Steuerung.Aquarium_Niveau_Sensor:20:14)
                                            javascript.0	2019-08-15 00:14:30.418	warn	getState "Aqua_Control.0.Aquarium_ausschalten" not found (3)
                                            Ist vielleicht die Datenbank Verbindung nicht hergestellt ?
                                            Nur müssten die Fehler was mit der Futter Automatik zu tun haben, jetzt hatte ich die Steuerung abgeschaltet die Fehler in der log kommen nicht mehr
                                            4187
