    4. Test Adapter Meross v1.1.x
      apollon77 last edited by apollon77
      @Bibo-13 sagte in [Aufruf] Meross Cloud Adapter 1.1.0 Test:
      Caught 2019-08-12 11:18:30.321 error by controller[0]: TypeError: Cannot read property 'unit' of undefined
      gggrrrr ... mach in der Zeile:
                  if (roleValues[key]) common.unit = roleValues[key].unit;
      dann sollte aber gut sein 🙂
        Bibo*13 @apollon77 last edited by
        @apollon77 Ok läuft. herzlichen Dank. warte schon auf Deinen Update. Bis dann.
          Dann nochmal die Frage in die Runde:
          Hey an alle: hat noch jemand außer @Fenian einen smart hub mit den mts100 thermostaten? Dann bitte mal bei mir melden.
            @apollon77 zu Früh gefreut. Also doch warten auf Update.
            Caught 2019-08-12 13:45:06.566 error by controller[0]: at doWrite (/opt/iobroker/node_modules/iobroker.meross/node_modules/readable-stream/lib/_stream_writable.js:428:64)
            Caught 2019-08-12 13:45:06.566 error by controller[0]: at Writable.writable._write (/opt/iobroker/node_modules/iobroker.meross/node_modules/mqtt/lib/client.js:294:5)
            Caught 2019-08-12 13:45:06.566 error by controller[0]: at work (/opt/iobroker/node_modules/iobroker.meross/node_modules/mqtt/lib/client.js:283:12)
            Caught 2019-08-12 13:45:06.566 error by controller[0]: at MqttClient._handlePacket (/opt/iobroker/node_modules/iobroker.meross/node_modules/mqtt/lib/client.js:351:12)
            Caught 2019-08-12 13:45:06.566 error by controller[0]: at MqttClient._handlePublish (/opt/iobroker/node_modules/iobroker.meross/node_modules/mqtt/lib/client.js:1162:12)
            Caught 2019-08-12 13:45:06.565 error by controller[0]: at MqttClient.emit (events.js:194:7)
            Caught 2019-08-12 13:45:06.565 error by controller[0]: at emitThree (events.js:116:13)
            Caught 2019-08-12 13:45:06.565 error by controller[0]: at MqttClient.client.on (/opt/iobroker/node_modules/iobroker.meross/node_modules/meross-cloud/index.js:239:66)
            Caught 2019-08-12 13:45:06.565 error by controller[0]: at Object.knownDevices.(anonymous function).device.getControlElectricity [as callback] (/opt/iobroker/node_modules/iobroker.meross/main.js:441:17)
            Caught 2019-08-12 13:45:06.564 error by controller[0]: at setValuesElectricity (/opt/iobroker/node_modules/iobroker.meross/main.js:506:135)
            Caught 2019-08-12 13:45:06.563 error by controller[0]: TypeError: Cannot read property 'scale' of undefined
              Bibo*13 @Bibo*13 last edited by
              @Bibo-13 Ok habe den Code roleValues dort ebenfalls angepasst. jetzt sollte es laufen
              • tugsi
                tugsi last edited by
                Moin,
                hab die Version 1.1.2 heute aufgespielt, da ich den GarageOpener MSG100 installiert habe.
                Verbindung ist da, aber ich verstehe nicht, wozu der 0-garageDoorWorking da ist.
                0-garageDoor steht im geschlossenen Zustand auf false, fahre ich den per App auf, geht er auf true und bleibt da stehen, erst wenn das Tor wieder komplett geschlossen ist (der Reedkontakt zu signalisiert), springt er auf false zurück.
                Ansteuern per ioBroker geht nur, wenn ich eben 0-garageDoor auf true bzw false setze.
                Hätte jetzt eher erwartet das ich bei 0-garageDoorWorking den Schalter habe zum betätigen und bei 0-garageDoor den Zustand.
                Und missverstehe ich da etwas?
                  Working ist ala Homemmatic der stand wenn das Gerät reportet das es gerade arbeitet (also gerade von A nach B "fährt").
                  Mit 0-garageDoor true/false sagst Du ob es auf oder zu sein soll ... so lange wie es fährt sollte "working" auf true stehen und. danach auf false wieder gehen.
                  tugsi 1 Reply Last reply Reply Quote 0
                  • tugsi
                    tugsi @apollon77 last edited by
                    @apollon77 sagte in [Aufruf] Meross Cloud Adapter 1.1.0 Test:
                    Deswegen habe ich ja danach gefragt.
                    Das war definitiv nicht so, stand immer auf false.
                    Hab ich jetzt gerade extra nochmal getestet, es ändert sich nur das garageOpen je nach Zustand, working bleibt auf false.
                      Stell mal auf Debug und schick bitte mal das Log von so einem hoch ... fertig ... runter und so
                      • tugsi
                        tugsi last edited by tugsi
                        Hab hier mal ein Log, inklusive Neustart der Instanz
                        2019-08-15 22:16:06.740 - info: host.iobroker object change system.adapter.meross.0
                        2019-08-15 22:16:06.741 - info: host.iobroker "system.adapter.meross.0" enabled
                        2019-08-15 22:16:06.756 - info: host.iobroker instance system.adapter.meross.0 started with pid 14463
                        2019-08-15 22:16:07.664 - debug: meross.0 objectDB connected
                        2019-08-15 22:16:07.701 - debug: meross.0 statesDB connected
                        2019-08-15 22:16:07.723 - info: meross.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.meross, node: v8.16.0
                        2019-08-15 22:16:07.858 - debug: meross.0 connected set to false
                        2019-08-15 22:16:08.209 - info: meross.0 Device 19050587453810390834342xxxxxxxxx initialized
                        2019-08-15 22:16:08.209 - debug: meross.0 {"uuid":"19050587453810390834342xxxxxxxxx","onlineStatus":1,"devName":"Garagentor","devIconId":"device039_un","bindTime":1565861439,"deviceType":"msg100","subType":"us","channels":[{}],"region":"eu","fmwareVersion":"3.1.3","hdwareVersion":"3.0.0","userDevIcon":"","iconType":1,"skillNumber":null,"domain":"mqtt-eu.meross.com","reservedDomain":"mqtt-eu-alter.meross.com"}
                        2019-08-15 22:16:08.455 - info: meross.0 Device: 19050587453810390834342xxxxxxxxx connected
                        2019-08-15 22:16:08.458 - debug: meross.0 Device Send Raw: 19050587453810390834342xxxxxxxxx - data: {"header":{"from":"/app/300974-e75c8ef169ee8a18f5ccfda9157f1357/subscribe","messageId":"4c9677154d89057775ecf751d609aad4","method":"GET","namespace":"Appliance.System.Ability","payloadVersion":1,"sign":"aa43063072792aafb9cbf9262cab9f5d","timestamp":1565900168},"payload":{}}
                        2019-08-15 22:16:08.461 - debug: meross.0 connected set to true
                        2019-08-15 22:16:08.763 - debug: meross.0 19050587453810390834342xxxxxxxxx Abilities: {"payloadVersion":1,"ability":{"Appliance.Config.Key":{},"Appliance.Config.WifiList":{},"Appliance.Config.Wifi":{},"Appliance.Config.Trace":{},"Appliance.System.All":{},"Appliance.System.Hardware":{},"Appliance.System.Firmware":{},"Appliance.System.Debug":{},"Appliance.System.Online":{},"Appliance.System.Time":{},"Appliance.System.Clock":{},"Appliance.System.Ability":{},"Appliance.System.Runtime":{},"Appliance.System.Report":{},"Appliance.System.Position":{},"Appliance.System.DNDMode":{},"Appliance.Control.Multiple":{"maxCmdNum":5},"Appliance.Control.ToggleX":{},"Appliance.Control.TimerX":{"sunOffsetSupport":1,"notify":["Appliance.GarageDoor.State"]},"Appliance.Control.TriggerX":{"notify":["Appliance.GarageDoor.State"]},"Appliance.Control.Bind":{},"Appliance.Control.Unbind":{},"Appliance.Control.Upgrade":{},"Appliance.GarageDoor.State":{},"Appliance.Digest.TriggerX":{},"Appliance.Digest.TimerX":{}}}
                        2019-08-15 22:16:08.764 - debug: meross.0 Device Send Raw: 19050587453810390834342xxxxxxxxx - data: {"header":{"from":"/app/300974-e75c8ef169ee8a18f5ccfda9157f1357/subscribe","messageId":"9e24b521df242a81dd696bb0fe07fe67","method":"GET","namespace":"Appliance.System.All","payloadVersion":1,"sign":"ffafef4ba9a5dba97cbdaea6fd84e6a7","timestamp":1565900169},"payload":{}}
                        2019-08-15 22:16:08.764 - debug: meross.0 Device Raw: 19050587453810390834342xxxxxxxxx - data: {"header":{"messageId":"4c9677154d89057775ecf751d609aad4","namespace":"Appliance.System.Ability","method":"GETACK","payloadVersion":1,"from":"/appliance/19050587453810390834342xxxxxxxxx/publish","timestamp":1565900168,"timestampMs":359,"sign":"aa43063072792aafb9cbf9262cab9f5d"},"payload":{"payloadVersion":1,"ability":{"Appliance.Config.Key":{},"Appliance.Config.WifiList":{},"Appliance.Config.Wifi":{},"Appliance.Config.Trace":{},"Appliance.System.All":{},"Appliance.System.Hardware":{},"Appliance.System.Firmware":{},"Appliance.System.Debug":{},"Appliance.System.Online":{},"Appliance.System.Time":{},"Appliance.System.Clock":{},"Appliance.System.Ability":{},"Appliance.System.Runtime":{},"Appliance.System.Report":{},"Appliance.System.Position":{},"Appliance.System.DNDMode":{},"Appliance.Control.Multiple":{"maxCmdNum":5},"Appliance.Control.ToggleX":{},"Appliance.Control.TimerX":{"sunOffsetSupport":1,"notify":["Appliance.GarageDoor.State"]},"Appliance.Control.TriggerX":{"notify":["Appliance.GarageDoor.State"]},"Appliance.Control.Bind":{},"Appliance.Control.Unbind":{},"Appliance.Control.Upgrade":{},"Appliance.GarageDoor.State":{},"Appliance.Digest.TriggerX":{},"Appliance.Digest.TimerX":{}}}}
                        2019-08-15 22:16:09.085 - debug: meross.0 19050587453810390834342xxxxxxxxx All-Data: {"all":{"system":{"hardware":{"type":"msg100","subType":"us","version":"3.0.0","chipType":"mt7682","uuid":"19050587453810390834342xxxxxxxxx","macAddress":"34:29:8f:1e:xx:xx"},"firmware":{"version":"3.1.3","compileTime":"2019/05/22 09:19:59 GMT +08:00","wifiMac":"44:4e:6d:d2:xx:xx","innerIp":"192.168.0.34","server":"mqtt.meross.com","port":443,"userId":300974},"time":{"timestamp":1565900168,"timezone":"Europe/Berlin","timeRule":[[1553994000,7200,1],[1572138000,3600,0],[1585443600,7200,1],[1603587600,3600,0],[1616893200,7200,1],[1635642000,3600,0],[1648342800,7200,1],[1667091600,3600,0],[1679792400,7200,1],[1698541200,3600,0],[1711846800,7200,1],[1729990800,3600,0],[1743296400,7200,1],[1761440400,3600,0],[1774746000,7200,1],[1792890000,3600,0],[1806195600,7200,1],[1824944400,3600,0],[1837645200,7200,1],[1856394000,3600,0]]},"online":{"status":1}},"digest":{"togglex":[{"channel":0,"onoff":1,"lmTime":0}],"triggerx":[{"channel":0,"id":"f9185db004ceeaee","count":1}],"timerx":[{"channel":0,"id":"a4373e818c492b98","count":1}],"garageDoor":[{"channel":0,"open":0,"lmTime":1565898367}]}}}
                        2019-08-15 22:16:09.086 - debug: meross.0 19050587453810390834342xxxxxxxxx: initDeviceObjects with channels = [{}] and data = {"togglex":[{"channel":0,"onoff":1,"lmTime":0}],"triggerx":[{"channel":0,"id":"f9185db004ceeaee","count":1}],"timerx":[{"channel":0,"id":"a4373e818c492b98","count":1}],"garageDoor":[{"channel":0,"open":0,"lmTime":1565898367}]}
                        2019-08-15 22:16:09.088 - debug: meross.0 Device Raw: 19050587453810390834342xxxxxxxxx - data: {"header":{"messageId":"9e24b521df242a81dd696bb0fe07fe67","namespace":"Appliance.System.All","method":"GETACK","payloadVersion":1,"from":"/appliance/19050587453810390834342xxxxxxxxx/publish","timestamp":1565900168,"timestampMs":657,"sign":"463348b1ba794aff9da779def8ad95ea"},"payload":{"all":{"system":{"hardware":{"type":"msg100","subType":"us","version":"3.0.0","chipType":"mt7682","uuid":"19050587453810390834342xxxxxxxxx","macAddress":"34:29:8f:1e:xx:xx"},"firmware":{"version":"3.1.3","compileTime":"2019/05/22 09:19:59 GMT +08:00","wifiMac":"44:4e:6d:d2:xx:xx","innerIp":"192.168.0.34","server":"mqtt.meross.com","port":443,"userId":300974},"time":{"timestamp":1565900168,"timezone":"Europe/Berlin","timeRule":[[1553994000,7200,1],[1572138000,3600,0],[1585443600,7200,1],[1603587600,3600,0],[1616893200,7200,1],[1635642000,3600,0],[1648342800,7200,1],[1667091600,3600,0],[1679792400,7200,1],[1698541200,3600,0],[1711846800,7200,1],[1729990800,3600,0],[1743296400,7200,1],[1761440400,3600,0],[1774746000,7200,1],[1792890000,3600,0],[1806195600,7200,1],[1824944400,3600,0],[1837645200,7200,1],[1856394000,3600,0]]},"online":{"status":1}},"digest":{"togglex":[{"channel":0,"onoff":1,"lmTime":0}],"triggerx":[{"channel":0,"id":"f9185db004ceeaee","count":1}],"timerx":[{"channel":0,"id":"a4373e818c492b98","count":1}],"garageDoor":[{"channel":0,"open":0,"lmTime":1565898367}]}}}}
                        2019-08-15 22:16:09.129 - debug: meross.0 Device Send Raw: 19050587453810390834342xxxxxxxxx - data: {"header":{"from":"/app/300974-e75c8ef169ee8a18f5ccfda9157f1357/subscribe","messageId":"9b6f403e5fb762dfe5b7a530db54f136","method":"GET","namespace":"Appliance.System.Online","payloadVersion":1,"sign":"c1b3ea650d6104604f59264d9cfbf64a","timestamp":1565900169},"payload":{}}
                        2019-08-15 22:16:09.129 - info: meross.0 Devices initialized
                        2019-08-15 22:16:10.576 - debug: meross.0 Online: {"online":{"status":1}}
                        2019-08-15 22:16:10.576 - debug: meross.0 Device Raw: 19050587453810390834342xxxxxxxxx - data: {"header":{"messageId":"9b6f403e5fb762dfe5b7a530db54f136","namespace":"Appliance.System.Online","method":"GETACK","payloadVersion":1,"from":"/appliance/19050587453810390834342xxxxxxxxx/publish","timestamp":1565900169,"timestampMs":366,"sign":"c1b3ea650d6104604f59264d9cfbf64a"},"payload":{"online":{"status":1}}}
                        2019-08-15 22:16:10.581 - debug: meross.0 stateChange meross.0.19050587453810390834342xxxxxxxxx.online {"val":true,"ack":true,"ts":1565900170578,"q":0,"from":"system.adapter.meross.0","user":"system.user.admin","lc":1565900170578}
                        2019-08-15 22:16:20.264 - debug: meross.0 Device: 19050587453810390834342xxxxxxxxx Appliance.GarageDoor.State - data: {"state":[{"channel":0,"open":1,"lmTime":1565900179}]}
                        2019-08-15 22:16:20.266 - debug: meross.0 Device Raw: 19050587453810390834342xxxxxxxxx - data: {"header":{"messageId":"ba227cede49c7aeacedc102220430d16","namespace":"Appliance.GarageDoor.State","method":"PUSH","payloadVersion":1,"from":"/appliance/19050587453810390834342xxxxxxxxx/publish","timestamp":1565900180,"timestampMs":819,"sign":"1b87c9b0b101eb464613a39bdb22234b"},"payload":{"state":[{"channel":0,"open":1,"lmTime":1565900179}]}}
                        2019-08-15 22:16:20.270 - debug: meross.0 stateChange meross.0.19050587453810390834342xxxxxxxxx.0-garageDoor {"val":true,"ack":true,"ts":1565900180266,"q":0,"from":"system.adapter.meross.0","user":"system.user.admin","lc":1565900180266}
                        2019-08-15 22:16:20.274 - debug: meross.0 stateChange meross.0.19050587453810390834342xxxxxxxxx.0-garageDoorWorking {"val":false,"ack":true,"ts":1565900180271,"q":0,"from":"system.adapter.meross.0","user":"system.user.admin","lc":1565883585504}
                        2019-08-15 22:17:04.992 - debug: meross.0 Device: 19050587453810390834342xxxxxxxxx Appliance.GarageDoor.State - data: {"state":[{"channel":0,"open":0,"lmTime":1565900224}]}
                        2019-08-15 22:17:04.993 - debug: meross.0 Device Raw: 19050587453810390834342xxxxxxxxx - data: {"header":{"messageId":"1fe5e14cf7bac60ff87e785b6c0aa69e","namespace":"Appliance.GarageDoor.State","method":"PUSH","payloadVersion":1,"from":"/appliance/19050587453810390834342xxxxxxxxx/publish","timestamp":1565900225,"timestampMs":749,"sign":"dc6af88b4ef05bb2c06f023311b3bba3"},"payload":{"state":[{"channel":0,"open":0,"lmTime":1565900224}]}}
                        2019-08-15 22:17:04.998 - debug: meross.0 stateChange meross.0.19050587453810390834342xxxxxxxxx.0-garageDoor {"val":false,"ack":true,"ts":1565900224994,"q":0,"from":"system.adapter.meross.0","user":"system.user.admin","lc":1565900224994}
                        2019-08-15 22:17:04.999 - debug: meross.0 stateChange meross.0.19050587453810390834342xxxxxxxxx.0-garageDoorWorking {"val":false,"ack":true,"ts":1565900224996,"q":0,"from":"system.adapter.meross.0","user":"system.user.admin","lc":1565883585504}
                        2019-08-15 22:17:15.312 - info: host.iobroker object change system.adapter.meross.0
                        2019-08-15 22:17:15.313 - info: host.iobroker stopInstance system.adapter.meross.0
                        2019-08-15 22:17:15.313 - info: host.iobroker stopInstance system.adapter.meross.0 killing pid 14463
                        2019-08-15 22:17:15.318 - info: meross.0 Device: 19050587453810390834342xxxxxxxxx closed: null
                        2019-08-15 22:17:15.333 - debug: meross.0 stateChange meross.0.info.connection {"val":false,"ack":true,"ts":1565900235331,"q":0,"from":"system.adapter.meross.0","user":"system.user.admin","lc":1565900235331}
                        2019-08-15 22:17:15.335 - debug: meross.0 connected set to false
                        2019-08-15 22:17:15.336 - debug: meross.0 stateChange meross.0.19050587453810390834342xxxxxxxxx.online {"val":false,"ack":true,"ts":1565900235333,"q":0,"from":"system.adapter.meross.0","user":"system.user.admin","lc":1565900235333}
                        2019-08-15 22:17:17.674 - debug: meross.0 system.adapter.admin.0: logging true
                        2019-08-15 22:17:18.337 - info: host.iobroker instance system.adapter.meross.0 terminated with code 0 (OK)
                          danielmg last edited by
                          Die MSL120 wird zwar erkannt aber leider gibt es keinen color state um die Farbe über ioBroker zu steuern.
                          Derzeit kann ich das nur über die Meross App oder Alexa App.
                          Wollte eine Automation inkl Farbe erstellen.
                            danielmg @danielmg last edited by
                            @danielmg said in [Aufruf] Meross Cloud Adapter 1.1.0 Test:
                            Jetzt habe ich 1.1.2 installiert und bekomme den folgenden Error Log 😕
                              apollon77 @danielmg last edited by
                              @danielmg Jippie ... jemand mit so einer farblampe im „real life“ 😉 ich hab das bisher blind programmiert weil ich so eine Lampe nicht hatte und auch auf Nachfrage bisher kein Feedback kam.
                              Bitte leg ein GitHub issue an. Ich bin ab Donnerstag wieder aus dem Urlaub da. Dann schau ich mir das an. Am besten bitte noch ein ausführliches log im debug log Modus. Und das zusammen mit dem Fehler Posten. Dann sehe ich genau welche Daten reinkommen und kann So den Fehler finden.
                              D sigi234 2 Replies Last reply Reply Quote 0
                                danielmg @apollon77 last edited by
                                @apollon77 Issue ist angelegt. Bis Freitag Abend werde ich noch antworten und testen können danach bin ich erstmal zwei Wochen im Urlaub 😉
                                  @danielmg versuche es bis dahin zu prüfen ... sonst danach.
                                    sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
                                    Hab auch so was, sende dir auch meinen Debug Log......
                                    iobroker.2019-08-29 - Kopie (4).zip
                                      Hallo Ingo,
                                      Debug Log wie gewünscht.
                                      Passwort wie im Chat.
                                      iobroker.2019-08-30 - Kopie.zip
                                        Ich habe gerade mal eine 1.2.0 auf GitHub gestellt. Die ist noch recht experimntell und installiert auch die Meros-Steuer-Library per Github (also mit git installiert sein auf dem Rechner). Damit testen wir mal ob wir die aktuellen Themen hinbekommen, dann mache ich eine 1.2.1 offiziell draus zum testen.
                                        Der Luftbefeuchter ist jetzt noch dazugekommen und die Farblampen gehen hoffentlich ohne Fehler. Bitte Feedback
                                          approx last edited by approx
                                          Ich hab aktuell zwei Steckdosen, den Hub und ein Thermostat im Einsatz.
                                          Die zwei Steckdosen lasen sich einwandfrei schalten und zeigen die Energiewerte an.
                                          Leider erscheint bei mir nix für das Thermostat.
                                          Bild Text
                                          meross.0	2019-11-02 17:38:59.036	info	(19644) Devices initialized
                                          meross.0	2019-11-02 17:38:57.186	info	(19644) {"payloadVersion":1,"ability":{"Appliance.Config.Key":{},"Appliance.Config.WifiList":{},"Appliance.Config.Wifi":{},"Appliance.Config.Trace":{},"Appliance.System.All":{},"Appliance.System.Hardw
                                          meross.0	2019-11-02 17:38:57.185	info	(19644) Ability Toggle/ToggleX not supported by Device 1811069847989629086034298f17d056: send next line from disk to developer
                                          meross.0	2019-11-02 17:38:56.812	info	(19644) Device: 1811069847989629086034298f17d056 connected
                                          meross.0	2019-11-02 17:38:56.810	info	(19644) Device: 19082963309123251h1248e1e900a721 connected
                                          meross.0	2019-11-02 17:38:56.806	info	(19644) Device: 19082912831870251h1248e1e900a04e connected
                                          meross.0	2019-11-02 17:38:56.638	info	(19644) Device 19082912831870251h1248e1e900a04e initialized
                                          meross.0	2019-11-02 17:38:56.635	info	(19644) Device 19082963309123251h1248e1e900a721 initialized
                                          meross.0	2019-11-02 17:38:56.544	info	(19644) Device 1811069847989629086034298f17d056 initialized
                                          meross.0	2019-11-02 17:38:55.973	info	(19644) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.meross, node: v10.17.0
                                          Kann ich irgenwie unterstützen, das der Meross-Adapter auch die Thermostate anzeigt und diese dann steuerbar sind?
                                          Ich habe gedacht, ich bin ja nicht dumm, nutze ich doch den Umweg über den Alexa2-Adapter. Hier wird das Thermostat
                                          zwar angezeigt, es lassen sich aber keine Werte setzten.
                                          Bild Text
                                          Beziehungsweise, sie lassen sich setzten, werden aber nicht ausgeführt.
                                          alexa2.0	2019-11-02 18:11:28.368	debug	(2391) State changed alexa2.0.requestResult: {"val":"FAILURE_TO_SEND","ack":true,"ts":1572714688365,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1572714625005}
                                          alexa2.0	2019-11-02 18:11:28.364	debug	(2391) Alexa-Remote: Response: {"controlResponses":[],"errors":[{"entity":{"entityId":"9d146428-df56-47d7-bbc0-099ff915ef97","entityType":"APPLIANCE"},"code":"FAILURE_TO_SEND","message":"Validation fa
                                          alexa2.0	2019-11-02 18:11:28.200	debug	(2391) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/phoenix/state","method":"PUT","timeout":10000,"headers":{}}and data={"controlRequests":[{"entityId":"9d146428-df56-47d7
                                          alexa2.0	2019-11-02 18:11:28.200	debug	(2391) Alexa-Remote: No authentication check needed (time elapsed 313305)
                                          alexa2.0	2019-11-02 18:11:28.199	debug	(2391) State changed alexa2.0.Smart-Home-Devices.9d146428-df56-47d7-bbc0-099ff915ef97.targetSetpoint: {"val":15,"ack":false,"ts":1572714688195,"q":0,"from":"system.adapter.admin.0","user":"system.user
                                          alexa2.0	2019-11-02 18:11:24.610	debug	(2391) State changed alexa2.0.requestResult: {"val":"FAILURE_TO_SEND","ack":true,"ts":1572714684608,"q":0,"from":"system.adapter.alexa2.0","user":"system.user.admin","lc":1572714625005}
                                          alexa2.0	2019-11-02 18:11:24.605	debug	(2391) Alexa-Remote: Response: {"controlResponses":[],"errors":[{"entity":{"entityId":"9d146428-df56-47d7-bbc0-099ff915ef97","entityType":"APPLIANCE"},"code":"FAILURE_TO_SEND","message":"JSON payload
                                          alexa2.0	2019-11-02 18:11:24.401	debug	(2391) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/phoenix/state","method":"PUT","timeout":10000,"headers":{}}and data={"controlRequests":[{"entityId":"9d146428-df56-47d7
                                          alexa2.0	2019-11-02 18:11:24.401	debug	(2391) Alexa-Remote: No authentication check needed (time elapsed 309506)
                                          alexa2.0	2019-11-02 18:11:24.400	debug	(2391) State changed alexa2.0.Smart-Home-Devices.9d146428-df56-47d7-bbc0-099ff915ef97.thermostatMode: {"val":"on","ack":false,"ts":1572714684396,"q":0,"from":"system.adapter.admin.0","user":"system.us
                                          Habe ich irgend etwas nicht richtig gemacht, oder funktioniert das einfach bei beiden Adaptern nicht?
                                          bis bald
                                          Thomas
                                            apollon77 @approx last edited by
                                            @approx Thermstatte sind in der Version auf GitHub drin. versuch mal. geht vllrnoch nicht alles 100%ig aber der Hub hatte die Grätsche gemacht bevor ich fertig war. Und danach kam ich noch nicht zum Fixen.
                                            Bitte versuchen und berichten.
                                            Alexa2 hängt davon ab wie Meross das genau inm Skill unterstützt ...
                                            Fenian 1 Reply Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            meross test
                                            4474
